    4. Test Adapter zigbee2mqtt
      biker1602 last edited by
      @asgothian
      [Unit]
      Description=zigbee2mqtt
      After=network.target
      [Service]
      Environment=NODE_ENV=production
      ExecStart=/usr/bin/npm start
      WorkingDirectory=/opt/zigbee2mqtt
      StandardOutput=inherit
      # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
      StandardError=inherit
      Restart=always
      RestartSec=10s
      User=pi
      [Install]
      WantedBy=multi-user.target
      So habe den Pfad geändert
      pi@raspberrypi:/opt/zigbee2mqtt $ npm start
      > zigbee2mqtt@1.28.0 start
      > node index.js
      Zigbee2MQTT:info  2022-12-20 13:13:06: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-12-20.13-13-06' filename: log.txt
      Zigbee2MQTT:info  2022-12-20 13:13:06: Starting Zigbee2MQTT version 1.28.0 (commit #03ba647)
      Zigbee2MQTT:info  2022-12-20 13:13:06: Starting zigbee-herdsman (0.14.62)
      Zigbee2MQTT:info  2022-12-20 13:13:07: zigbee-herdsman started (resumed)
      Zigbee2MQTT:info  2022-12-20 13:13:07: Coordinator firmware version: '{"meta":{"maintrel":3,"majorrel":2,"minorrel":6,"product":0,"revision":20190608,"transportrev":2},"type":"zStack12"}'
      Zigbee2MQTT:info  2022-12-20 13:13:07: Currently 1 devices are joined:
      Zigbee2MQTT:info  2022-12-20 13:13:07: IKEA Smart Home Button (0x84fd27fffe1f7496): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      Zigbee2MQTT:info  2022-12-20 13:13:07: Zigbee: disabling joining new devices.
      Zigbee2MQTT:info  2022-12-20 13:13:07: Connecting to MQTT server at mqtt://localhost
      Zigbee2MQTT:info  2022-12-20 13:13:07: Connected to MQTT server
      Zigbee2MQTT:info  2022-12-20 13:13:07: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
      Zigbee2MQTT:info  2022-12-20 13:13:07: MQTT publish: topic 'zigbee2mqtt/IKEA Smart Home Button/availability', payload '{"state":"offline"}'
      Zigbee2MQTT:info  2022-12-20 13:13:07: Started frontend on port 0.0.0.0:8080
      Gestartet Adapter ist Grün und sobald ich die Konsole schließe ist er wieder Gelb
      Asgothian crunchip 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @biker1602 last edited by
        @biker1602
        Jein.
        Die Empfehlung geht zu 'alles neu', du kannst aber auch ein Distributions-Upgrade versuchen. Hab ich mal vor geraumer Zeit was zu geschrieben.
          Thomas Braun Most Active @Asgothian last edited by
          @asgothian sagte in Test Adapter zigbee2mqtt:
          auch wenn @thomas-braun Meinung ist das nur ein System auf dem aktuellen Stand lebensfähig ist.
          Zumindest macht es das Leben leichter mit noch unterstützen Systemen herumzuhantieren.
          • Asgothian
            Asgothian Developer @biker1602 last edited by
            @biker1602 solange du das Programm immer direkt per npm startet bleibt es so
            Du musst schon den Dienst starten. Nachdem du die Datei angepasst hast solltest du nochmal das versuchen was @ciddi89 weiter oben geschrieben hat:
            @ciddi89 sagte in Test Adapter zigbee2mqtt:
            @biker1602
            Mach mal
            systemctl daemon-reload
            Und dann noch mal
            sudo systemctl start zigbee2mqtt
            Und Ergebnis von
            systemctl status zigbee2mqtt.service
            • Asgothian
              Asgothian Developer @Thomas Braun last edited by
              @thomas-braun sagte in Test Adapter zigbee2mqtt:
              Grundsatzdiskussion - will ich hier nicht führen. Wir haben da unterschiedliche Ansichten.
                crunchip Forum Testing Most Active @biker1602 last edited by
                @biker1602 sagte in Test Adapter zigbee2mqtt:
                Verify that the configuration works:
                Start Zigbee2MQTT
                Show status
                Now that everything works, we want systemctl to start Zigbee2MQTT automatically on boot, this can be done by executing:
                sudo systemctl enable zigbee2mqtt.service
                ansonsten mach mal ein reboot
                  @asgothian
                  Da gibt es ja auch nix zu diskutieren, grundsätzlich ist es natürlich schwieriger ein System nach dem EOL am laufen zu halten als ein aktuell vom Hersteller noch unterstütztes.
                    @asgothian said in Test Adapter zigbee2mqtt:
                    @biker1602
                    Mach mal
                    Und dann noch mal
                    Und Ergebnis von
                    Das war es jetzt bleibt er grün. 👌 Jetzt ist zwar der IKEA Button Offline aber vielleicht erholt er sich ja noch. Oder muss der neiu angelernt werden?
                    • Asgothian
                      @asgothian
                      Da gibt es viel zu diskutieren. Der OP hat kein problem damit sein System am laufen zu halten - es läuft. Er hat ein problem damit aus einer nicht auf sein System zugeschnittenen Anleitung zusätzliche Software zum laufen zu kriegen. Das wäre bei dem neu aufgesetzten System genau so geblieben, da sich an dem eigentlichen Fehler absolut NICHTS durch das neue System ändert.
                      Die Frage ist also nicht ob ein neues System einfacher zu warten ist, sondern ob das neu installieren das Problem des OP's löst. Tut es nicht.
                      A.
                        Thomas Braun Most Active @Asgothian last edited by Thomas Braun
                        @asgothian
                        Richtig, die Service-Datei ist hüben wie drüben falsch.
                        Trotzdem wird ein abgekündigtes System künstlich am Leben gehalten, die Aufgabe das Release zu wechseln stellt sich früher oder später ohnehin.
                        Je länger das herausgezögert wird desto komplexer wird das aber erfahrungsgemäß. Deswegen beizeiten wechseln und nicht das EOL eintreten lassen. Dafür gibt es ja den Übergangszeitraum von über einem Jahr bei Debian von Release zu Release. Kommt ja nicht aus heiterem Himmel.
                        Die 'große' Operation ist jetzt mit einem Pflästerchen etwas herausgezögert worden. Aber wie viele Pflaster willste da noch draufpappen?
                          arteck Developer Most Active @Thomas Braun last edited by
                          aber im andern thread... und nicht HIER
                            toralt @IdleBit last edited by
                            @idlebit mal eine generelle Frage:
                            Ich habe zigbee2mqtt auf die neueste Version upgedatet (28.5) und bekomme anschließen jede Minute einen disconnect des Adapters wegen websocket error. Adapter ist aktuell bei 2.5.0.
                            Ich habe nun meine Backup VM gestartet und bin somit wieder auf Version 28.4 bei zigbee2mqtt. Nun funktioniert wieder alles wie vorher. Muss ich nach dem Update von zigbee2mqtt wieder irgendwas in der config anpassen bevor der Adapter wieder funktioniert? In der Dokumentation von @nox309 konnte ich hierzu nichts finden.
                            ? arteck 2 Replies Last reply Reply Quote 0
                              A Former User @toralt last edited by
                              @toralt ne eigentlich nicht. Habe auch das Update gemacht und danach lief alles wieder wie vorher.
                                arteck Developer Most Active @toralt last edited by arteck
                                @toralt 29.0 ist das neuste.. und JA du solltest dir das update howto bei zigbee2mqtt durchlesen..
                                  Jan.S100 @IdleBit last edited by
                                  @idlebit sagte in Test Adapter zigbee2mqtt:
                                  Aktuelle Test Version NPM version
                                  Veröffentlichungsdatum wartet noch auf die Freigabe für das Beta-Repo
                                  Github Link https://github.com/o0shojo0o/ioBroker.zigbee2mqtt
                                  Hallo, mal eine kleine Frage. Wann kommt der Adapter ins Beta-Repo?
                                  Bei anderen Adaptern ging das meiner Meinung nach schneller.
                                  Ihr macht hier eine tolle Arbeit. 👍
                                  Ich vergesse immer nachzuschauen ob ein neues Update bei Github gibt. 😱
                                  Allen ein gesundes neues Jahr.
                                  Jan
                                    arteck Developer Most Active @Jan.S100 last edited by arteck
                                    @jan-s100 wenn @apollon77 zeit gefunden hat für ein Code Review.
                                    bis dahin musst du es von GIT installieren
                                      toralt @arteck last edited by
                                      @arteck Stimmt, Sorry, 1.29.0
                                      Genau nach der offiziellen Anleitung habe ich das update gemacht. zigbee2mqtt läuft danach ja auch bestens. Nur der Adapter halt nicht mehr.
                                        @toralt das dauert so 5 sec bis der sich wieder neu verbindet.
                                          @arteck ja, das klappt auch, dann ist er ne minute grün, dann kommt ein websocket error und er wird gelb, dann wird er gleich wieder grün, nach ca 1 minute wieder websocket error. Das geht dann immer so weiter.
                                            apollon77 @toralt last edited by
                                            @toralt zeig doch mal ein Log
                                            T 2 Replies Last reply Reply Quote 1
                                            zigbee zigbee 3.0 zigbee2mqtt
                                            52
                                            526
                                            103703
