    4. [2.5.9 Fehler existiert] - Backup-Adapter erzeugt Fehler
    • simatec
      simatec Developer Most Active @Siggi0904 last edited by
      @siggi0904 Bitte poste hier nur den teil des Backups. Da sind keine Daten sichtbar
        Siggi0904 @simatec last edited by
        @simatec
        Super, der Fehler tritt nach dem Neustart des Adapters im Debug-Mode nicht auf.
        Dann muss ich wieder ein paar Tage warten, bis der Fehler auftritt.
        Dann hier die Logs:
        Startup der Instanz mit Debug-Mode
        2022-12-19 16:09:08.926 - info: backitup.0 (3064907) Got terminate signal TERMINATE_YOURSELF
        2022-12-19 16:09:08.927 - info: backitup.0 (3064907) cleaned everything up...
        2022-12-19 16:09:08.928 - info: backitup.0 (3064907) terminating
        2022-12-19 16:09:08.929 - info: backitup.0 (3064907) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-12-19 16:09:09.162 - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
        2022-12-19 16:09:09.671 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-12-19 16:09:12.300 - info: host.iobroker instance system.adapter.backitup.0 started with pid 989622
        2022-12-19 16:09:13.615 - debug: backitup.0 (989622) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2022-12-19 16:09:13.660 - debug: backitup.0 (989622) Objects client ready ... initialize now
        2022-12-19 16:09:13.756 - debug: backitup.0 (989622) Objects create System PubSub Client
        2022-12-19 16:09:13.757 - debug: backitup.0 (989622) Objects create User PubSub Client
        2022-12-19 16:09:13.890 - debug: backitup.0 (989622) Objects client initialize lua scripts
        2022-12-19 16:09:13.903 - debug: backitup.0 (989622) Objects connected to redis: 127.0.0.1:9001
        2022-12-19 16:09:13.951 - debug: backitup.0 (989622) Redis States: Use Redis connection: 127.0.0.1:9000
        2022-12-19 16:09:14.046 - debug: backitup.0 (989622) States create System PubSub Client
        2022-12-19 16:09:14.047 - debug: backitup.0 (989622) States create User PubSub Client
        2022-12-19 16:09:14.123 - debug: backitup.0 (989622) States connected to redis: 127.0.0.1:9000
        2022-12-19 16:09:14.282 - debug: backitup.0 (989622) Plugin sentry Initialize Plugin (enabled=true)
        2022-12-19 16:09:14.938 - info: backitup.0 (989622) starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
        2022-12-19 16:09:14.999 - debug: backitup.0 (989622) Backitup has recognized a linux system
        2022-12-19 16:09:15.085 - info: backitup.0 (989622) [iobroker] backup was activated at 01:00 every 2 day(s)
        2022-12-19 16:09:15.158 - debug: backitup.0 (989622) [iobroker] 10 00 01 */2 * *
        2022-12-19 16:09:15.159 - info: backitup.0 (989622) [ccu] backup was activated at 01:15 every 3 day(s)
        2022-12-19 16:09:15.176 - debug: backitup.0 (989622) [ccu] 10 15 01 */3 * *
        2022-12-19 16:09:15.218 - debug: backitup.0 (989622) noserverino option: false
        2022-12-19 16:09:15.218 - debug: backitup.0 (989622) cifs-mount command: "sudo mount -t cifs -o username=admin,password=****,rw,file_mode=0777,dir_mode=0777,vers=2.0 //Datenschlampe/Backup/Homematic-Pi/iobroker/standard /opt/iobroker/backups"
        2022-12-19 16:09:20.159 - debug: backitup.0 (989622) mount successfully completed
        2022-12-19 16:09:22.891 - debug: backitup.0 (989622) detect backup file 1 from NAS: iobroker_2022_12_03-01_00_27_backupiobroker.tar.gz
        2022-12-19 16:09:22.891 - debug: backitup.0 (989622) detect backup file 2 from NAS: iobroker_2022_12_05-01_00_24_backupiobroker.tar.gz
        2022-12-19 16:09:22.892 - debug: backitup.0 (989622) detect backup file 3 from NAS: iobroker_2022_12_07-01_00_27_backupiobroker.tar.gz
        2022-12-19 16:09:22.892 - debug: backitup.0 (989622) detect backup file 4 from NAS: iobroker_2022_12_15-01_00_25_backupiobroker.tar.gz
        2022-12-19 16:09:22.892 - debug: backitup.0 (989622) detect backup file 5 from NAS: iobroker_2022_12_17-01_00_25_backupiobroker.tar.gz
        2022-12-19 16:09:22.893 - debug: backitup.0 (989622) detect last backup file: iobroker_2022_12_17-01_00_25_backupiobroker.tar.gz
        2022-12-19 16:09:25.087 - debug: backitup.0 (989622) mount activ... umount in 2 Seconds!!
        2022-12-19 16:09:27.493 - debug: backitup.0 (989622) umount successfully completed
        Log vom Backup (Leider ohne Fehler):
        2022-12-19 16:12:26.816 - debug: backitup.0 (989622) Backup has started ...
        2022-12-19 16:12:36.816 - debug: backitup.0 (989622) [iobroker/mount] noserverino option: false
        2022-12-19 16:12:36.817 - debug: backitup.0 (989622) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=admin,password=****,rw,file_mode=0777,dir_mode=0777,vers=2.0 //Datenschlampe/Backup/Homematic-Pi/iobroker/standard /opt/iobroker/backups"
        2022-12-19 16:12:41.581 - debug: backitup.0 (989622) [iobroker/mount] mount successfully completed
        2022-12-19 16:12:41.583 - debug: backitup.0 (989622) [iobroker/mount] done
        2022-12-19 16:12:44.936 - debug: backitup.0 (989622) [iobroker/iobroker] host.iobroker 7667 states saved
        2022-12-19 16:12:45.076 - debug: backitup.0 (989622) [iobroker/iobroker] host.iobroker 9295 objects saved
        2022-12-19 16:12:48.650 - debug: backitup.0 (989622) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2022_12_19-16_12_41_backupiobroker.tar.gz
        2022-12-19 16:12:49.718 - debug: backitup.0 (989622) [iobroker/iobroker] done
        2022-12-19 16:12:50.022 - debug: backitup.0 (989622) [iobroker/mysql] MySql-Backup started ...
        2022-12-19 16:14:36.723 - debug: backitup.0 (989622) [iobroker/mysql] MySql File deleted!
        2022-12-19 16:14:36.726 - debug: backitup.0 (989622) [iobroker/mysql] MySql-Backup for is finish
        2022-12-19 16:14:36.726 - debug: backitup.0 (989622) [iobroker/mysql] done
        2022-12-19 16:14:37.977 - debug: backitup.0 (989622) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
        2022-12-19 16:14:38.312 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-Wohnzimmer
        2022-12-19 16:14:38.313 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Wechselschaltung
        2022-12-19 16:14:38.313 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Fenster_geschlossen
        2022-12-19 16:14:38.313 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-Bad
        2022-12-19 16:14:38.314 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-Schlafzimmer
        2022-12-19 16:14:38.314 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Tests
        2022-12-19 16:14:38.314 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Fenster_geschlossen
        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: BattUeberwachung
        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: FensterOffenLichtAnSteckdosenEin
        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Licht_überall_aus
        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Steckdosen_überall_aus
        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Eingangstür_offen
        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: BattUeberwachungAlexa
        2022-12-19 16:14:38.318 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Alarmanlage
        2022-12-19 16:14:38.319 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: ErreichbarkeitAlexa
        2022-12-19 16:14:38.319 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Aqara_Zauberwürfel
        2022-12-19 16:14:38.319 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: MorgensLichtEinArbeit
        2022-12-19 16:14:38.320 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: EingangstürAlexa
        2022-12-19 16:14:38.321 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TemperaturAnsage
        2022-12-19 16:14:38.321 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftfeuchtigkeitAnsage
        2022-12-19 16:14:38.322 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftdruckAnsage
        2022-12-19 16:14:38.322 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftfeuchtigkeitAnsage
        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftfeuchtigkeitAnsage
        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AnwesenheitTaster
        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AnwesenheitHandy
        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TestHandyErreichbarkeit
        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: PersonKommt
        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: WillkommenZuhause
        2022-12-19 16:14:38.324 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: HandyLaden100%
        2022-12-19 16:14:38.324 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: HandystatusAnsage
        2022-12-19 16:14:38.326 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: HandyAkkustandMinimal
        2022-12-19 16:14:38.326 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TabletStatusAnsage
        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TabletAkkustandMinimal
        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TabletLaden100%
        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AdapterNeustarten
        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: CarportLichtAus
        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: CarportLichtMorgensEin
        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: CarportLichtAbendsEin
        2022-12-19 16:14:38.328 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AstroDaten
        2022-12-19 16:14:38.328 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Jalousiesteuerung
        2022-12-19 16:14:38.328 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Helligkeit-AußenAnsage
        2022-12-19 16:14:38.330 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-AußenAnsage
        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Jalousiesteuerung
        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Xiaomi_Geräte
        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftreinigerEinAus
        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftqualitätAnsage
        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Nachtmodus
        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: BenzinpreiseAnsage
        2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: NachttischAus
        2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: StatusHomeMatic
        2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: WeckerAusUrlaubKrank
        2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: IchBinWeg
        2022-12-19 16:14:38.335 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AnwesenheitBewegung
        2022-12-19 16:14:38.335 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Eiswarnung
        2022-12-19 16:14:38.931 - debug: backitup.0 (989622) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
        2022-12-19 16:14:39.085 - debug: backitup.0 (989622) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
        2022-12-19 16:14:39.086 - debug: backitup.0 (989622) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2022_12_19-16_14_37_backupiobroker.tar.gz
        2022-12-19 16:14:39.086 - debug: backitup.0 (989622) [iobroker/javascripts] done
        2022-12-19 16:14:39.538 - debug: backitup.0 (989622) [iobroker/cifs] used copy path: /Backup/Homematic-Pi/iobroker/standard
        2022-12-19 16:14:39.538 - debug: backitup.0 (989622) [iobroker/cifs] done
        2022-12-19 16:14:40.141 - debug: backitup.0 (989622) [iobroker/clean] done
        2022-12-19 16:14:41.057 - debug: backitup.0 (989622) [iobroker/historyHTML] new history html values created
        2022-12-19 16:14:41.058 - debug: backitup.0 (989622) [iobroker/historyHTML] done
        2022-12-19 16:14:41.322 - debug: backitup.0 (989622) [iobroker/historyJSON] new history json values created
        2022-12-19 16:14:41.323 - debug: backitup.0 (989622) [iobroker/historyJSON] done
        2022-12-19 16:14:41.492 - debug: backitup.0 (989622) [iobroker/umount] mount activ, umount is started ...
        2022-12-19 16:14:46.709 - debug: backitup.0 (989622) [iobroker/umount] umount successfully completed
        2022-12-19 16:14:46.711 - debug: backitup.0 (989622) [iobroker/umount] done
        2022-12-19 16:14:46.863 - debug: backitup.0 (989622) [iobroker] exec: done
        Aus der Historie (log von heute vor dem Restart des Adapters), der Fehler:
        2022-12-19 15:44:32.227 - error: backitup.0 (3064907) [iobroker/iobroker] node:internal/bootstrap/switches/does_own_process_state:126
        2022-12-19 15:44:32.229 - error: backitup.0 (3064907) [iobroker/iobroker] cachedCwd = rawMethods.cwd();
        2022-12-19 15:44:32.229 - error: backitup.0 (3064907) [iobroker/iobroker] ^
        2022-12-19 15:44:32.229 - error: backitup.0 (3064907) [iobroker/iobroker] Error: ENOENT: no such file or directory, uv_cwd
        2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at process.wrappedCwd (node:internal/bootstrap/switches/does_own_process_state:126:28)
        2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at Object.process.cwd (/opt/iobroker/node_modules/graceful-fs/polyfills.js:10:19)
        2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at fe.Yargs (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/index.cjs:1:61304)
        2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at Argv (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:12:16)
        2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at Object. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:7:1)
        2022-12-19 15:44:32.235 - error: backitup.0 (3064907) [iobroker/iobroker] at Module._compile (node:internal/modules/cjs/loader:1155:14)
        2022-12-19 15:44:32.235 - error: backitup.0 (3064907) [iobroker/iobroker] at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
        2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] at Module.load (node:internal/modules/cjs/loader:1033:32)
        2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] at Function.Module._load (node:internal/modules/cjs/loader:868:12)
        2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] at Module.require (node:internal/modules/cjs/loader:1057:19) {
        2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] errno: -2,
        2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] code: 'ENOENT',
        2022-12-19 15:44:32.237 - error: backitup.0 (3064907) [iobroker/iobroker] syscall: 'uv_cwd'
        2022-12-19 15:44:32.237 - error: backitup.0 (3064907) [iobroker/iobroker] }
        Thomas Braun simatec 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Siggi0904 last edited by
          @siggi0904
          Smb vers=2.0 dürfte falsch sein. Mittlerweile sollte eigentlich alles auf Version 3 sein.
            Siggi0904 @Thomas Braun last edited by
            @thomas-braun Ne, NAS ist auf Minimum 2.0 und Maximum 3.0 eingestellt (Synology DSM 6).
            Das sollte also passen und das Backup läuft ja auch grundsätzlich.
              Thomas Braun Most Active @Siggi0904 last edited by Thomas Braun
              @siggi0904
              Dann stell es im Backitup-Adapter auf 3.0.
              • simatec
                @siggi0904 Poste mal die Ausgaben von:
                npm -v
                node -v
                nodjs -v
                  @simatec sagte in [Mit Version 2.5.9 behoben] - Backup-Adapter erzeugt Fehler:
                  npm -v
                  8.19.2
                  v16.18.1
                  v16.18.1
                  @thomas-braun sagte in [Mit Version 2.5.9 behoben] - Backup-Adapter erzeugt Fehler:
                  @siggi0904
                  Behebt das, das Problem?
                    @siggi0904 sagte in [Mit Version 2.5.9 behoben] - Backup-Adapter erzeugt Fehler:
                    Möglicherweise...
                    • simatec
                      simatec Developer Most Active @Thomas Braun last edited by simatec
                      Das Problem liegt hier eher tiefer im nodejs oder npm.
                      Es wird bei einer handvoll User der auszuführende Pfad des iobroker Backups nicht gefunden bzw. kann nicht drauf zugegriffen werden.
                      Das sagt dieses uv_cwd oder so aus
                        Thomas Braun Most Active @simatec last edited by
                        @simatec
                        Weiß ich.
                        • simatec
                          Wir suchen aktuell nach Lösungen dieses Bugs.
                          In meiner Welt eher schwierig, da es sich nicht auf Backitup zurückführen lässt.
                          Der Bug kam mit irgendeiner Node Version oder auch npm.
                          Ein npm clear cache oder reboot behebt das Problem temporär
                            skinni last edited by
                            Ich bin ja der Meinung er kam bei mir mit dem node Update von 14 auf 16. Seit ich aber mein System neu aufgesetzt habe, hatte ich bisher Ruhe.. Dafür hab ich seit dem "Cannot check node.js versions", aber das ist jetzt hier nicht das Thema 🙂
                              @simatec
                              Da passt was mit den Pfaden / den Berechtigungen nicht. Kann auch mit mount optionen oder dem verwendeten Protokoll zusammenhängen.
                                Das merkwürdige ist, dass der Fehler auftritt wenn man ein Addon aktualisiert hat.
                                Wenn ich am System nichts ändere, läuft das super durch.
                                  @siggi0904
                                  Was für ein 'Addon'?
                                    @thomas-braun egal welches. Sobald eine Aktualisierung läuft, kommt beim nächsten Backup-Lauf der Fehler.
                                    Aber das ist nur ein Gefühl. Ich stellte aber das Verhalten so fest.
                                    • simatec
                                      @simatec
                                      Da gehe ich nicht von aus. Denn der Fehler besagt, dass er den Backup Prozess nicht ausführen kann, da der Pfad in Benutzung und somit blockiert ist.
                                      Damit wird aber nicht der Backuppfad sondern der Pfad zum js-controller gemeint
                                        Und noch ergänzend:
                                        Wenn der Fehler im Backitup auftritt kann ich manuell sauber ein iob backup machen.
                                        Da kommt kein Fehler.
                                          Da wird ja auch nix gemountet.
                                          • simatec
                                            Und der Befehl wird nicht über node Module gefahren sondern direkt über die CLI
                                            Wenn du denkst, dass es was mit dem mount zu tun hat, bin ich gerne für weitere Ideen bereit
                                            5652
