    4. Test Adapter fb-checkpresence v1.1.x
    • Dominik F.
      Dominik F. @afuerhoff last edited by
      @afuerhoff
      Das sind bisher alle Meldungen:
      fb-checkpresence.0
      2022-12-17 13:34:59.172	info	loop successfully started
      fb-checkpresence.0
      2022-12-17 13:34:59.171	info	states successfully subscribed
      fb-checkpresence.0
      2022-12-17 13:34:59.171	info	createFbDeviceObjects finished successfully
      fb-checkpresence.0
      2022-12-17 13:34:55.900	info	createMemberObjects finished successfully
      fb-checkpresence.0
      2022-12-17 13:34:55.619	info	createGlobalObjects finished successfully
      fb-checkpresence.0
      2022-12-17 13:34:55.396	info	Layer3Forwarding1-GetDefaultConnectionService is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.396	info	LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.396	info	WANPPPConnection1-ForceTermination is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.396	info	DeviceConfig1-Reboot is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.396	info	X_AVM-DE_HostFilter-GetWANAccessByIP is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.395	info	X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.395	info	DeviceInfo1-GetInfo is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.395	info	WLANConfiguration3-GetSecurityKeys is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.395	info	WLANConfiguration3-GetInfo is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.395	info	WLANConfiguration3-SetEnable is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.394	info	WANIPConnection1-GetInfo is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.394	info	WANPPPConnection1-GetInfo is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.394	info	WANCommonInterfaceConfig1-GetCommonLinkProperties is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.394	info	DeviceInfo1-GetSecurityPort is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.394	info	Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.393	info	Hosts1-GetSpecificHostEntry is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.393	info	Hosts1-X_AVM-DE_GetMeshListPath is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.393	info	Hosts1-X_AVM-DE_GetHostListPath is supported
      fb-checkpresence.0
      2022-12-17 13:34:55.393	info	configuration default connection: 1.WANPPPConnection.1
      fb-checkpresence.0
      2022-12-17 13:34:55.391	info	start fb-checkpresence.0: FRITZ!Box 7590 version: 154.07.39-101676 ip-address: "fritz.box" - interval devices: 60 s - interval members: 30 s
      fb-checkpresence.0
      2022-12-17 13:34:53.590	info	starting. Version 1.1.22 (non-npm: afuerhoff/ioBroker.fb-checkpresence) in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v16.18.1, js-controller: 4.0.24
      host.IoBroker
      2022-12-17 13:34:52.444	info	instance system.adapter.fb-checkpresence.0 started with pid 127181
      host.IoBroker
      2022-12-17 13:34:49.860	info	iobroker exit 0
      host.IoBroker
      2022-12-17 13:34:49.423	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.IoBroker
      2022-12-17 13:34:48.892	info	stopInstance system.adapter.fb-checkpresence.0 send kill signal
      fb-checkpresence.0
      2022-12-17 13:34:48.849	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fb-checkpresence.0
      2022-12-17 13:34:48.849	info	terminating
      fb-checkpresence.0
      2022-12-17 13:34:48.849	info	cleaned everything up ...
      fb-checkpresence.0
      2022-12-17 13:34:48.847	info	Got terminate signal TERMINATE_YOURSELF
      host.IoBroker
      2022-12-17 13:34:48.845	info	stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
      host.IoBroker
      2022-12-17 13:34:48.819	info	iobroker Update "system.adapter.fb-checkpresence.0"
      host.IoBroker
      2022-12-17 13:34:48.789	info	iobroker upload [0] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/words.js words.js application/javascript
      host.IoBroker
      2022-12-17 13:34:48.781	info	iobroker upload [1] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/style.css style.css text/css
      host.IoBroker
      2022-12-17 13:34:48.776	info	iobroker upload [2] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.js index_m.js application/javascript
      host.IoBroker
      2022-12-17 13:34:48.772	info	iobroker upload [3] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.html index_m.html text/html
      host.IoBroker
      2022-12-17 13:34:48.768	info	iobroker upload [4] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/fb-checkpresence.png fb-checkpresence.png image/png
      host.IoBroker
      2022-12-17 13:34:48.757	info	iobroker upload [5] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/dateformat.png dateformat.png image/png
      host.IoBroker
      2022-12-17 13:34:48.708	info	iobroker upload [6] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/access_settings_network.png access_settings_network.png image/png
      host.IoBroker
      2022-12-17 13:34:48.665	info	iobroker removed 94 packages, and changed 2 packages in 5s58 packages are looking for funding run `npm fund` for details
      host.IoBroker
      2022-12-17 13:34:43.618	info	iobroker Installing afuerhoff/ioBroker.fb-checkpresence... (System call)
      host.IoBroker
      2022-12-17 13:34:43.618	info	iobroker NPM version: 8.19.2
      host.IoBroker
      2022-12-17 13:34:43.246	info	iobroker install afuerhoff/ioBroker.fb-checkpresence
      host.IoBroker
      2022-12-17 13:34:42.398	info	iobroker url afuerhoff/ioBroker.fb-checkpresence --host IoBroker --debug
      • Dominik F.
        @afuerhoff
        Durch deine neuen Warnmeldungen konnte ich tatsächlich die IP Adresse identifizieren.
        Es hat in der Fritzbox den Namen: PC-192-168-178-34
        Ich hab mich seit Tagen übrigens immer wieder gefragt, was das genau für ein Gerät ist^^
        afuerhoff 1 Reply Last reply Reply Quote 0
        • afuerhoff
          afuerhoff Developer @Dominik F. last edited by afuerhoff
          @dominik-f
          War denn für dieses Gerät in der Devicelist der Hostname leer? Hätte ja eigentlich dann nicht sein dürfen. Kannst du mir mal den einen Eintrag posten. Nicht die ganze Liste. Vielleicht hab ich ja auch noch einen Fehler drin.
          Dominik F. 2 Replies Last reply Reply Quote 1
          • Dominik F.
            @afuerhoff
            Nein, das Gerät wurde auch erstellt unter dem Namen.
            Ich hatte das Log leider gelöscht und warte gerade darauf, dass die Warnungen nochmals kommen, bisher aber nicht.
            • Dominik F.
              @afuerhoff
              So, nun kam endlich die Warnung:
              fb-checkpresence.0
              2022-12-20 14:00:41.482	warn	getAllFbObjects: Hostname is empty: AC:6F:BB:DB:1B:CE
              • afuerhoff
                @dominik-f
                Da müsste ja auch noch eine zweite Meldung gekommen sein. Wird dort ein Hostname in der Devicelist zum Gerät angezeigt?
                Dominik F. 1 Reply Last reply Reply Quote 0
                • Dominik F.
                  @afuerhoff
                  Nein, da wird nix angezeigt:
                  {"Index":"1","IPAddress":"192.168.178.34","MACAddress":"AC:6F:BB:DB:1B:CE","Active":"0","HostName":"","InterfaceType":"","X_AVM-DE_Port":"0","X_AVM-DE_Speed":"0","X_AVM-DE_UpdateAvailable":"0","X_AVM-DE_UpdateSuccessful":"unknown","X_AVM-DE_InfoURL":"","X_AVM-DE_MACAddressList":"","X_AVM-DE_Model":"","X_AVM-DE_URL":"","X_AVM-DE_Guest":"0","X_AVM-DE_RequestClient":"0","X_AVM-DE_VPN":"0","X_AVM-DE_WANAccess":"granted","X_AVM-DE_Disallow":"0","X_AVM-DE_IsMeshable":"0","X_AVM-DE_Priority":"0","X_AVM-DE_FriendlyName":"","X_AVM-DE_FriendlyNameIsWriteable":"1"}
                  • afuerhoff
                    @dominik-f
                    Ok. Danke. Dann ist es ein Fehler in der Fritzbox, der allerdings nicht ständig zuschlägt. Sonst hätte der Adapter das Objekt ja nicht anlegen können. In der nächsten Version fange ich das dann noch ab.
                    • Dominik F.
                      @afuerhoff
                      Ich danke dir.
                      Ich bin aber trotzdem sehr verwundert über das Gerät. Ich hab keine Ahnung was das sein soll^^
                      • afuerhoff
                        @dominik-f
                        Hier steht noch etwas bei AVM. Vielleicht hilft es.
                        -> Incorrect or unknown entries in the list of "Devices and Users"
                        https://en.avm.de/service/knowledge-base/dok/FRITZ-Box-7340-int/763_Incorrect-or-unknown-entries-in-the-list-of-Devices-and-Users/
                        • afuerhoff
                          afuerhoff Developer last edited by
                          Hallo, ich habe gerade eine neue Version ins Latest Repository hochgeladen. Die leeren Hostnames werden jetzt ignoriert und eine Warnmeldung ausgegeben.
                          • JB_Sullivan
                            JB_Sullivan last edited by JB_Sullivan
                            Juhu - ich glaube ich gehöre auch zu denen wo der Adapter nicht mehr mitspielen mag. Habe heute das Update hochgeladen, aber der Adapter läßt sich nun nicht mehr starten.
                            Er lief sonst Monatelang ohne Probleme.
                            PS: und dein Rollback auf eine frühere Version geht auch nicht, weil da wohl noch der Uralte ETRAGET Fehler für Windows User drin steckt - siehe unten.
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:16.190	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:16.189	info	terminating
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:16.188	info	cleaned everything up ...
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:16.184	info	Got terminate signal TERMINATE_YOURSELF
                            host.GLTGLT)
                            2022-12-21 17:56:16.149	info	host.GLT(GLT) stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
                            host.GLTGLT)
                            2022-12-21 17:56:16.149	info	host.GLT(GLT) "system.adapter.fb-checkpresence.0" disabled
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:16.069	warn	onReady: Fb init: ReferenceError: AbortController is not defined
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:16.048	info	starting. Version 1.1.23 in C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence, node: v14.16.0, js-controller: 4.0.24
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:15.607	debug	States connected to redis: 127.0.0.1:9000
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:15.552	debug	States create User PubSub Client
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:15.551	debug	States create System PubSub Client
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:15.519	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:15.473	debug	Objects connected to redis: 127.0.0.1:9001
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:15.465	debug	Objects client initialize lua scripts
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:15.318	debug	Objects create User PubSub Client
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:15.317	debug	Objects create System PubSub Client
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:15.316	debug	Objects client ready ... initialize now
                            fb-checkpresence.0
                            10364	2022-12-21 17:56:15.270	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                            $ iobroker upgrade fb-checkpresence@1.1.21 --debug
                            Update fb-checkpresence from @1.1.23 to @1.1.21
                            NPM version: 6.14.11
                            Installing iobroker.fb-checkpresence@1.1.21... (System call)
                            npm ERR! code ETARGET
                            npm ERR! A complete log of this run can be found in: npm ERR! C:\iobroker\GLT\env\npm-cache\_logs\2022-12-21T17_06_59_598Z-debug.log
                            upload [6] fb-checkpresence.admin C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence/admin/access_settings_network.png access_settings_network.png image/png
                            upload [5] fb-checkpresence.admin C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence/admin/dateformat.png dateformat.png image/png
                            upload [3] fb-checkpresence.admin C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence/admin/index_m.html index_m.html text/html
                            upload [2] fb-checkpresence.admin C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence/admin/index_m.js index_m.js application/javascript
                            upload [0] fb-checkpresence.admin C:/iobroker/GLT/node_modules/iobroker.fb-checkpresence/admin/words.js words.js application/javascript
                            Process exited with code 0
                            afuerhoff 3 Replies Last reply Reply Quote 0
                            • afuerhoff
                              afuerhoff Developer @JB_Sullivan last edited by afuerhoff
                              @jb_sullivan
                              Mach mal auf Version 1.1.20 oder 1.1.22. Die 21 gab es gar nicht offiziell.
                              • JB_Sullivan
                                JB_Sullivan @afuerhoff last edited by
                                @afuerhoff OK - Danke, die 1.1.20 funktioniert wieder - bzgl. der "nicht offiziellen" Version - dann sollte so etwas idealer Weise nicht über den Admin in der Adapter History auftauchen.
                                • afuerhoff
                                  @jb_sullivan
                                  Hallo, die Funktion AbortController, die ich nutze, ist leider erst ab Node 15 implementiert.
                                  Du nutzt noch die Node 14 Version. Sorry. Die alte Funktionalität, die ich bisher genutzt habe ist in axios abgekündigt. Node 14 ist übrigens im Maintenance Status. Du solltest auf Node 16 updaten.
                                  • afuerhoff
                                    @jb_sullivan
                                    Hallo, ich hab mal eine Testversion auf Github hochgeladen. Die kannst Du testen. Die alte Funktionalität habe ich optional noch mit eingebaut. Ich hoffe es funktioniert so.
                                    • JB_Sullivan
                                      @afuerhoff Guten Morgen - ich habe die GIT Version installiert und diese funktioniert einwandfrei - Vielen Dank für deinen Einsatz.
                                      • afuerhoff
                                        @jb_sullivan
                                        Ok. Danke für die Rückmeldung. Die kommt dann ins Latest.
                                        • afuerhoff
                                          Hallo, neue Version ist jetzt im Latest.
                                          Sie benutzt CancelToken, wenn AbortController nicht zur Verfügung steht, was bei Node 14 der Fall ist. Mit diesen Funktionen kann ein laufender Axios Request abgebrochen werden.
                                            Thias last edited by
                                            getAllFbObjects: Hostname of fritzbox device XX: XX: XX: XX: XX: XX is empty!
                                            die Fehlermeldung kommt seit einigen Tagen. Ich habe schon die Version 1.1.24 installiert und die Fritz!Box mehrfach neu gestartet.
                                            Nach dem Neustart ist erst einmal Ruhe, dann kommt der Fehler nach einigen Zeit wieder.
                                            Betroffen sind mehrere MAC-Adressen, die teilweise in der Fritz!Box als ungenutzte Verbindung stehen.
                                            In der Fritz!Box habe ich dann einen generischen Rechnernamen (PC+IP-Adresse)
                                            Weitere Fehlermeldungen kommen nicht.
                                            Hat noch jemand Ideen?
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            263702
