    3. Einsteigerfragen
    4. Installation
    5. ioBroker Installation npm Err!
    • X
      Xerxes55 @Thomas Braun last edited by
      pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
      ## Installing the NodeSource Node.js 16.x repo...
      ## Populating apt-get cache...
      + apt-get update
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Reading package lists... Done
      ## Confirming "bullseye" is supported...
      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/bullseye/Release'
      ## Adding the NodeSource signing key to your keyring...
      + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
      ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
      + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
      + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
      ## Running `apt-get update` for you...
      + apt-get update
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Get:3 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
      Get:4 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages [784 B]
      Fetched 5,370 B in 1s (4,860 B/s)
      ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
      ## You may also need development tools to build native addons:
           sudo apt-get install gcc g++ make
      ## To install the Yarn package manager, run:
           curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
           echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
           sudo apt-get update && sudo apt-get install yarn
      pi@raspberrypi:~ $ sudo apt install nodejs
      Building dependency tree... Done
      The following packages were automatically installed and are no longer required:
        gyp libc-ares2 libfuse2 libjs-inherits libjs-is-typedarray libjs-psl
        libjs-typedarray-to-buffer libssl-dev libuv1-dev node-abbrev node-agent-base
        node-ajv node-ansi node-ansi-regex node-ansi-styles node-ansistyles
        node-aproba node-archy node-are-we-there-yet node-asap node-asn1
        node-assert-plus node-asynckit node-aws-sign2 node-aws4 node-balanced-match
        node-bcrypt-pbkdf node-brace-expansion node-builtins node-cacache
        node-caseless node-chalk node-chownr node-clone node-color-convert
        node-color-name node-colors node-columnify node-combined-stream
        node-concat-map node-console-control-strings node-copy-concurrently
        node-core-util-is node-dashdash node-debug node-defaults node-delayed-stream
        node-delegates node-depd node-ecc-jsbn node-encoding node-err-code
        node-escape-string-regexp node-extend node-extsprintf node-fast-deep-equal
        node-forever-agent node-form-data node-fs-write-stream-atomic
        node-fs.realpath node-function-bind node-gauge node-getpass node-glob
        node-graceful-fs node-har-schema node-har-validator node-has-flag
        node-has-unicode node-hosted-git-info node-http-signature
        node-https-proxy-agent node-iconv-lite node-iferr node-imurmurhash
        node-indent-string node-inflight node-inherits node-ini node-ip
        node-ip-regex node-is-typedarray node-isarray node-isexe node-isstream
        node-jsbn node-json-parse-better-errors node-json-schema
        node-json-schema-traverse node-json-stable-stringify
        node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream
        node-jsprim node-leven node-lockfile node-lru-cache node-mime
        node-mime-types node-minimatch node-mkdirp node-move-concurrently node-ms
        node-mute-stream node-nopt node-normalize-package-data node-npm-bundled
        node-npm-package-arg node-npmlog node-number-is-nan node-oauth-sign
        node-object-assign node-once node-opener node-osenv node-p-map
        node-path-is-absolute node-performance-now node-process-nextick-args
        node-promise-inflight node-promise-retry node-promzard node-psl node-puka
        node-punycode node-qs node-read node-read-package-json node-readable-stream
        node-resolve node-resolve-from node-retry node-rimraf node-run-queue
        node-safe-buffer node-semver node-set-blocking node-signal-exit node-slash
        node-spdx-correct node-spdx-exceptions node-spdx-expression-parse
        node-spdx-license-ids node-sshpk node-ssri node-string-decoder
        node-string-width node-strip-ansi node-supports-color node-tar
        node-text-table node-through node-tunnel-agent node-tweetnacl
        node-typedarray-to-buffer node-unique-filename node-uri-js
        node-util-deprecate node-uuid node-validate-npm-package-license
        node-validate-npm-package-name node-verror node-wcwidth.js node-which
        node-wide-align node-wrappy node-write-file-atomic node-yallist
      Use 'sudo apt autoremove' to remove them.
      The following packages will be REMOVED:
        libnode-dev libnode72 node-gyp npm
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 4 to remove and 0 not upgraded.
      Need to get 24.2 MB of archives.
      After this operation, 82.2 MB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Get:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.19.0-deb-1nodesource1 [24.2 MB]
      Fetched 24.2 MB in 4s (5,772 kB/s)
      Reading changelogs... Done
      (Reading database ... 181133 files and directories currently installed.)
      Removing npm (7.5.2+ds-2) ...
      Removing node-gyp (7.1.2-4) ...
      Removing libnode-dev (12.22.12~dfsg-1~deb11u1) ...
      dpkg: libnode72:armhf: dependency problems, but removing anyway as you requested:
       nodejs depends on libnode72 (= 12.22.12~dfsg-1~deb11u1).
      Removing libnode72:armhf (12.22.12~dfsg-1~deb11u1) ...
      (Reading database ... 180169 files and directories currently installed.)
      Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_armhf.deb ...
      Unpacking nodejs (16.19.0-deb-1nodesource1) over (12.22.12~dfsg-1~deb11u1) ...
      Setting up nodejs (16.19.0-deb-1nodesource1) ...
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
      Processing triggers for man-db (2.9.4-2) ...
      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -           library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installer!
          Installer version: 2022-12-09
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [311 kB]
      Fetched 334 kB in 1s (288 kB/s)
      Changing npm registry to https://registry.npmjs.org
      Installed gcc-c++
          Creating ioBroker user and directory (2/4)
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      npm ERR! code 24
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c -- node iobroker.js setup first
      npm ERR! creating conf/iobroker.json
      npm ERR!  Cannot read system.config: null (OK when migrating or restoring)
      npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
      npm ERR!     /home/pi/.npm/_logs/2022-12-20T21_02_15_028Z-debug-0.log
          Finalizing installation (4/4)
      Enabling autostart...
      Autostart enabled!
      Fixing directory permissions...
          ioBroker was installed successfully
          Open http://192.168.178.58:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      pi@raspberrypi:~ $
      Das sagt die Konsole!
        Thomas Braun Most Active @Xerxes55 last edited by
        @xerxes55
        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
        sagt?
        • X
          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.19.0
          v16.19.0
          8.19.3
          node:internal/modules/cjs/loader:998
            throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
              at Function.Module._load (node:internal/modules/cjs/loader:841:27)
              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
              at node:internal/main/run_main_module:22:47 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
          pi@raspberrypi:~ $
            @xerxes55
            systemctl status iobroker.service
            • X
              pi@raspberrypi:~ $ systemctl status iobroker.service
              ● iobroker.service - ioBroker Server
                   Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
                   Active: active (running) since Tue 2022-12-20 22:03:13 CET; 8min ago
                     Docs: http://iobroker.net
                 Main PID: 7918 (iobroker.js-con)
                    Tasks: 11 (limit: 3720)
                      CPU: 10.455s
                   CGroup: /system.slice/iobroker.service
                           └─7918 iobroker.js-controller
              Dec 20 22:03:13 raspberrypi systemd[1]: Started ioBroker Server.
              Dec 20 22:03:15 raspberrypi sudo[7967]: iobroker : PWD=/ ; USER=root ; COMMAND=>
              Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session opened >
              Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session closed >
              Dec 20 22:03:16 raspberrypi bash[7918]: object system.meta.uuid created: 9c0c44>
              Dec 20 22:03:16 raspberrypi bash[7918]: object system.user.admin created
              lines 1-16/16 (END)...skipping...
                      CPU: 10.455s
              lines 1-16/16 (END)
                @xerxes55 sagte in ioBroker Installation npm Err!:
                sudo systemctl stop iobroker
                iobroker fix
                sudo systemctl start iobroker
                • X
                  pi@raspberrypi:~ $ sudo systemctl stop iobroker
                  pi@raspberrypi:~ $ iobroker fix
                  library: loaded
                  ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                  pi@raspberrypi:~ $ sudo systemctl start iobroker
                  pi@raspberrypi:~ $
                    @xerxes55
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                    iobroker restart
                    iobroker status
                    • X
                      Habe die Installation noch mal gestartet und?
                      library: loaded
                      Installed gcc-c++
                      Autostart enabled!
                      pi@raspberrypi:~ $
                      Hurra, jetzt geht es, aber warum?
                        aber warum?
                        Weil jetzt die richtige nodeJS-Version installiert ist.
                          @xerxes55
                          Und was sagt nun
                          • X
                            Aber warum diese Problem? Ich die Installation strikt nach den Anleitung gemacht. Wer installiert NodeJS. Linux oder ioBroker?
                            • X
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.19.0
                              v16.19.0
                              8.19.3
                              4.0.23
                              pi
                              pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                              tty
                              /home/pi
                              nodejs:
                                Installed: 16.19.0-deb-1nodesource1
                                Candidate: 16.19.0-deb-1nodesource1
                                Version table:
                               *** 16.19.0-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                      100 /var/lib/dpkg/status
                                   12.22.12~dfsg-1~deb11u1 500
                                      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                              pi@raspberrypi:~ $
                                Der Paketmanager. Der wird auch eigentlich vom Installationsskript richtig gefüttert. Keine Ahnung was du da gemacht hast.
                                • X
                                  Xerxes55 @Xerxes55 last edited by
                                  @xerxes55
                                  Jetzt ist ales ok? Kann ich damit produktiv arbeiten?
                                    @xerxes55
                                    Sollte passen.
                                    • X
                                      @thomas-braun said in ioBroker Installation npm Err!:
                                      Ich habe schon mehrmals geschrieben: alles gemäß der Anleitung in dem Link am Anfang. Den Beitrag hast du auch selbst geschrieben! Bin kein Linux Fachmann!
                                        Homoran Global Moderator Administrators @Xerxes55 last edited by
                                        da muss aber beteits eine alte nodejs vor dem Aufruf des Installers drauf gewesen sein,
                                        Deswegen wurde iobroker unvollständig installiert.
                                        Entweder du, oder wenn noch nichts drauf is installiert iobroker die momentan aktuelle Version.
                                          Das weiß ich. Und daher weiß ich auch, dass es genau so auch funktioniert.
                                          • X
                                            Ich habe die SD Karte komplett neu geschrieben, daher weiß ich nicht woher das kommt. Trotzdem vielen, vielen Dank!
                                            8117
