    3. Einsteigerfragen
    4. Installation
    5. ioBroker Installation npm Err!
      Thomas Braun Most Active @Xerxes55 last edited by
      @xerxes55
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
      sagt?
      • X
        Xerxes55 @Thomas Braun last edited by
        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.19.0
        v16.19.0
        8.19.3
        node:internal/modules/cjs/loader:998
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
            at Function.Module._load (node:internal/modules/cjs/loader:841:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
            at node:internal/main/run_main_module:22:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        pi@raspberrypi:~ $
          @xerxes55
          systemctl status iobroker.service
          • X
            pi@raspberrypi:~ $ systemctl status iobroker.service
            ● iobroker.service - ioBroker Server
                 Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
                 Active: active (running) since Tue 2022-12-20 22:03:13 CET; 8min ago
                   Docs: http://iobroker.net
               Main PID: 7918 (iobroker.js-con)
                  Tasks: 11 (limit: 3720)
                    CPU: 10.455s
                 CGroup: /system.slice/iobroker.service
                         └─7918 iobroker.js-controller
            Dec 20 22:03:13 raspberrypi systemd[1]: Started ioBroker Server.
            Dec 20 22:03:15 raspberrypi sudo[7967]: iobroker : PWD=/ ; USER=root ; COMMAND=>
            Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session opened >
            Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session closed >
            Dec 20 22:03:16 raspberrypi bash[7918]: object system.meta.uuid created: 9c0c44>
            Dec 20 22:03:16 raspberrypi bash[7918]: object system.user.admin created
            lines 1-16/16 (END)...skipping...
                    CPU: 10.455s
            lines 1-16/16 (END)
              @xerxes55 sagte in ioBroker Installation npm Err!:
              sudo systemctl stop iobroker
              iobroker fix
              sudo systemctl start iobroker
              • X
                pi@raspberrypi:~ $ sudo systemctl stop iobroker
                pi@raspberrypi:~ $ iobroker fix
                library: loaded
                Library version=2022-12-09
                ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                pi@raspberrypi:~ $ sudo systemctl start iobroker
                pi@raspberrypi:~ $
                  @xerxes55
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                  iobroker restart
                  iobroker status
                  • X
                    Habe die Installation noch mal gestartet und?
                    pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                    library: loaded
                        Welcome to the ioBroker installer!
                        Installer version: 2022-12-09
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/4)
                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                    Reading package lists... Done
                    Changing npm registry to https://registry.npmjs.org
                    Installed gcc-c++
                        Creating ioBroker user and directory (2/4)
                    Created /etc/sudoers.d/iobroker
                    Directory /opt/iobroker created
                        Installing ioBroker (3/4)
                        Finalizing installation (4/4)
                    Enabling autostart...
                    Autostart enabled!
                    Fixing directory permissions...
                        ioBroker was installed successfully
                        Open http://192.168.178.58:8081 in a browser and start configuring!
                    You need to re-login before doing anything else on the console!
                    pi@raspberrypi:~ $
                    Hurra, jetzt geht es, aber warum?
                      aber warum?
                      Weil jetzt die richtige nodeJS-Version installiert ist.
                        @xerxes55
                        Und was sagt nun
                        • X
                          Aber warum diese Problem? Ich die Installation strikt nach den Anleitung gemacht. Wer installiert NodeJS. Linux oder ioBroker?
                          • X
                            armv7l
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.19.0
                            v16.19.0
                            8.19.3
                            4.0.23
                            pi
                            pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                            tty
                            /home/pi
                            nodejs:
                              Installed: 16.19.0-deb-1nodesource1
                              Candidate: 16.19.0-deb-1nodesource1
                              Version table:
                             *** 16.19.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                    100 /var/lib/dpkg/status
                                 12.22.12~dfsg-1~deb11u1 500
                                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                            pi@raspberrypi:~ $
                              Der Paketmanager. Der wird auch eigentlich vom Installationsskript richtig gefüttert. Keine Ahnung was du da gemacht hast.
                              • X
                                Xerxes55 @Xerxes55 last edited by
                                @xerxes55
                                Jetzt ist ales ok? Kann ich damit produktiv arbeiten?
                                  @xerxes55
                                  Sollte passen.
                                  • X
                                    @thomas-braun said in ioBroker Installation npm Err!:
                                    Ich habe schon mehrmals geschrieben: alles gemäß der Anleitung in dem Link am Anfang. Den Beitrag hast du auch selbst geschrieben! Bin kein Linux Fachmann!
                                      Homoran Global Moderator Administrators @Xerxes55 last edited by
                                      da muss aber beteits eine alte nodejs vor dem Aufruf des Installers drauf gewesen sein,
                                      Deswegen wurde iobroker unvollständig installiert.
                                      Entweder du, oder wenn noch nichts drauf is installiert iobroker die momentan aktuelle Version.
                                        Das weiß ich. Und daher weiß ich auch, dass es genau so auch funktioniert.
                                        • X
                                          Ich habe die SD Karte komplett neu geschrieben, daher weiß ich nicht woher das kommt. Trotzdem vielen, vielen Dank!
                                            Chris982 last edited by
                                            Hey, habe ein ähnliches Problem, wollte das updateaus dem iobroker machen aber irgendwas ist schief gelaufen.
                                            Habe danach schon einiges versucht zu deinstallieren wie die node und iobroker aber jetzt geht gar nix mehr.
                                            wenn ich über den installtions link den iobroker neu installieren will kommt:
                                            OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                            OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                            OK:3 https://repos.influxdata.com/debian bullseye InRelease
                                            OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                            OK:5 https://packages.grafana.com/enterprise/deb stable InRelease
                                            npm ERR! builtins is not a function
                                            npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_11_280Z-debug-0.log
                                            Installed gcc-c++
                                            npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_16_582Z-debug-0.log
                                            Autostart enabled!
                                            Open http://192.168.1.95 10.8.0.1:8081 in a browser and start configuring!
                                            eine idee was ich machen kann? er ist definitv nicht mehr erreichbar
                                            1.0k
                                            8117
