    4. Test Adapter HeatingControl v2.12.x
    • Rene_HM
      Rene_HM Developer @Dominik F. last edited by
      @dominik-f sagte in Test Adapter HeatingControl v2.9.x:
      Die neue Version 2.10.2 haut den Log mit Errors voll:
      behoben mit 2.10.3
        ManfredHi @Rene_HM last edited by
        @rene_hm
        Hab die 2.10.3 installiert.
        Beim Start sind allerdings im Logfile folgende Warn-Einträge vorhanden:
        2022-12-18 22:48:15.796 - info: host.iobroker instance system.adapter.heatingcontrol.0 terminated with code 0 (NO_ERROR)
        2022-12-18 22:48:18.958 - info: host.iobroker "system.adapter.heatingcontrol.0" enabled
        2022-12-18 22:48:19.702 - info: host.iobroker instance system.adapter.heatingcontrol.0 started with pid 312811
        2022-12-18 22:48:21.881 - info: heatingcontrol.0 (312811) starting. Version 2.10.3 (non-npm: rg-engineering/ioBroker.heatingcontrol) in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v16.18.1, js-controller: 4.0.23
        2022-12-18 22:48:21.928 - info: heatingcontrol.0 (312811) start CreateDatabase
        2022-12-18 22:48:21.931 - warn: heatingcontrol.0 (312811) WaitForTempIfWindowOpen:
        2022-12-18 22:48:21.932 - warn: heatingcontrol.0 (312811) WaitForTempIfWindowOpen: 11
        2022-12-18 22:48:21.933 - warn: heatingcontrol.0 (312811) WaitForTempIfWindowOpen: 13
        2022-12-18 22:48:21.934 - warn: heatingcontrol.0 (312811) WaitForTempIfWindowOpen: 14
        2022-12-18 22:48:21.935 - warn: heatingcontrol.0 (312811) WaitForTempIfWindowOpen:
        2022-12-18 22:48:21.936 - warn: heatingcontrol.0 (312811) WaitForTempIfWindowOpen:
        2022-12-18 22:48:21.937 - info: heatingcontrol.0 (312811) CreateDatabase done with 10 rooms
        2022-12-18 22:48:21.940 - info: heatingcontrol.0 (312811) start CreateDatapoints
        2022-12-18 22:48:23.778 - info: heatingcontrol.0 (312811) CreateDatapoints done
        2022-12-18 22:48:24.827 - info: heatingcontrol.0 (312811) start SetInfo
        2022-12-18 22:48:24.903 - info: heatingcontrol.0 (312811) SetInfo done
        2022-12-18 22:48:24.903 - info: heatingcontrol.0 (312811) start SetCurrent
        2022-12-18 22:48:24.983 - info: heatingcontrol.0 (312811) SetCurrent done
        2022-12-18 22:48:24.994 - info: heatingcontrol.0 (312811) subscribe devices start
        2022-12-18 22:48:24.994 - info: heatingcontrol.0 (312811) subscribe thermostats current 10
        Aufgefallen ist mir noch ein optischer Fehler:
        Die Sekunden werden zu weit oben dargestellt.
        Testen kann ich die Version erst morgen abend, weil die Kinder schon schlafen. Melde mich dann mit dem Ergebnis.
        DANKE jedenfalls für die rasche Umsetzung.
        • Rene_HM
          Rene_HM Developer last edited by
          @manfredh-1 sagte in Test Adapter HeatingControl v2.9.x:
          oh, ja. Die sind vom debuggen übrig gebliebn...
          Bei mir sieht das so aus:
          liegt wohl an der Bildschirmauflösung und dem langen Beschreibungstext...
            @rene_hm sagte in Test Adapter HeatingControl v2.9.x:
            möglicherweise. bei mir ist die Auflösung 1920x1080 und die Schriftskalierung auf 100% eingestellt.
            Ansonsten hat es jetzt bei allen Fenstern super funktioniert. Hab unterschiedliche Zeiten getestet und nun das optimale für die einzelnen Räume eingestellt. Super. Danke.
            Ein anderes Problem besteht aber nach wie vor:
            Beim Homematic HmIP-eTRV-2 Thermostat wird beim Öffnen vorher der Status von "auto" auf "manual" gestellt, danach folgt die Meldung "manual WindowOpen" und beim schließen des Fensters geht der Status wieder auf "manual" mit den Graden die für das Fenster Offen gelten.
            Wenn man da vergisst, das händisch einzustellen, bleibt der Raum kalt.
            Hast du dafür eine Lösung. Mit den Werten wie für die anderen Heizkörper hat es nichts auf sich, das hab ich schon ausprobiert. Egal ob ich 1 Sek. oder 15 Sek. einstelle, es ist immer das gleiche.
            Im Logfile ist übrigens noch das komische Sonderzeichen anstatt des Grad-Zeichens vorhanden (UTF8-Problem ?), ist aber nur ein optischer Fehler.
            DANKE !
            • Rene_HM
              Rene_HM Developer @ManfredHi last edited by
              Das liegt m.E. am timing des Thermostats im Zusammenhang mit dem Fenstersensor. Kannst du mir dafür nochmal ein debug log erstellen?
                Hallo, anbei das gewünschte Logfile. Ich habe alle Räume bis auf einen (Büro) deaktiviert.
                debug-log_20221221.txt
                • Rene_HM
                  @manfredh-1 wie befürchtet, die Änderung der Zieltemperatur auf 12°C kommt früher, als die Änderung des Fenstersensors. Die aktuelle Implementierung geht davon aus, dass zunächst der Fenstersensor "Window Open" meldet und danach vom Thermostat die reduzierte Zieltemperatur kommt. Hier ist es jetzt anders herum.
                  Wieso kommt aber der Fenstersensor vom gleichen Gerät wie die Zieltemperatur? Kannst du den Fenstersensor nicht direkt im Adapter eintragen?
                  M B 2 Replies Last reply Reply Quote 0
                    Es ist eigentlich so konfiguriert wie bei den normalen Homematic Thermostaten:
                    Ich habe den Thermostat mit dem Fenstersensor in Homematic verknüpft (damit dieser auch funktioniert, sollte mal iobroker ausfallen). Und im HC habe ich ebenfalls den Fenstersensor eingetragen.
                      ManfredHi last edited by ManfredHi
                      @Rene_HM
                      Ich habe jetzt im HC beim Fenstersensor, nicht den Datenpunkt der Homematic-Gruppe (INT....) eingetragen, sondern direkt den Datenpunkt des Fenstersensors, damit funktioniert es jetzt.
                      Dürfte an der Verzögerung der Gruppe liegen.
                      In der Gruppe gibt es den Datenpunkt "WINDOW STATE" und beim Fenstersensor den Datenpunkt "STATE".
                      • Rene_HM
                        @manfredh-1 ah, das war die Gruppe... Trotzdem würde ich im Adapter den Sensor immer direkt eintragen, damit der state immer zuerst ankommt...
                        M Stephan Schleich 2 Replies Last reply Reply Quote 0
                          Ja, hab das jetzt bei allen gemacht. Bei den normalen Homematic-Thermostaten hat es aber auf die von dir umgesetzte WaitForTempIfWindowOpen Funktion keine Auswirkung. Die muss ich bei zwei Thermostaten höher als 10 sek. einstellen.
                          Vielen Dank für Deine Bemühungen.
                          • Stephan Schleich
                            Stephan Schleich @Rene_HM last edited by Stephan Schleich
                            @rene_hm Müsste ich nicht bei Ziel-Temp 22 und Ist-Temp 20.72 einen Offset von 1 bzw. 0.5 haben? Bei mir wird 0 angezeigt
                              babl @Rene_HM last edited by
                              @rene_hm wal was allgemeines.
                              Ich habe eine Pelletsheizung von Fröling für die es ja auch den Fröling connect adapter gibt. Wo ich mir schon sehr viele Fragen gestellt habe ist in der zusammenarbeit des heatingcontrol adapters und der heizung selbst.
                              Als gedankengang habe ich für mich mal überlegt es wäre doch eigentlich für jede heizung sinnvoll nach auslastung gesteuert zu werden (1. Sinnvoll für den Geldbeutel und sinnvoll fürs Klima)
                              Wenn ich jetzt smarte Thermostate besitze dann regeln die ja den Heizungsverlauf doch leider bekommt ja hier die Heizung selbst nichts mit.
                              Wäre es da nicht sinnvoller einen Adapter zu entwickeln der auch die Anforderungen der Heizung widerspiegelt.
                              Also nicht unbedingt nach aussentemperatur sondern nach anforderung.
                              Was ich mir so denke wäre folgendes. bis 4 uhr früh läuft die Absenkung, ab 4 Uhr 30 wird geheizt (aber leider kann das nur wöchentlich vorgegeben werden an die Heizung) was ist genau in so fällen wie weihnachten, trotzdem macht die Heizung genau das selbe außer man stellt es um. Warum könnte das nicht der heatingcontrol übernehmen? Hier sind ja widerrum alles hinterlegt, feiertag, urlaub abwesenheit, anwesenheit usw.
                              Es müßte uns nur gelingen dies mit der Heizung zu verknüpfen in dem man z.B im Heatingcontrol die Heizkurvenparameter mitabfragt.
                              Denn erstens gibt es bei Fröling nur eine Heizlinie und keine Kurve, was ein bisschen blöd ist (Script geschrieben daß es in abhängigkeit der Aussentemperatur steuert) doch trotzdem würde sowas mit der Kopplung der Heizung doch sinn ergeben, was denkt ihr?
                              mkshb Rene_HM 2 Replies Last reply Reply Quote 0
                              • mkshb
                                mkshb @babl last edited by
                                Moin @babl,
                                in meinen Augen hast Du einen Denkfehler in Deiner Ausführung. Deine Heizung hält den Vorlauf auf Temperatur und reagiert damit bereits auf Anforderung. Sind keine Heizkörper aufgedreht, kühlt der Vorlauf weniger schnell ab und die Heizung muss weniger nachheizen.
                                Bin kein Heizungsfachmann, aber es klingt für mich als würdest Du eine smarte Schaltung bauen wollen um eine smarte Schaltung zu bauen. 😉
                                  babl @mkshb last edited by
                                  @mkshb und was machst du z.B. wenn man sagt ab 22 Uhr Partybetrieb im heatingcontrol und die Heizung macht die Nachtabsenkung? oder wie aktuell zu den Feiertagen hier ist ja eine ganz andere Lebensgewohnheit, später aufstehen auch später ins bett, hier müssen dann immer 2 Seiten geändert werden, die Heizung selbst und heatingcontrol
                                  mkshb 1 Reply Last reply Reply Quote 0
                                  • mkshb
                                    @babl
                                    Ja, da ist was dran. Aus der Richtung hatte ich Deine Idee nicht betrachtet.
                                    Tatsächlich lasse ich meine Viessmann Heizung die Nachtabsenkung verschieben, wenn der Party-Modus aktiviert ist. Gelöst per Skript.
                                    Die abzubildende Logik für Heatingcontrol wäre durchaus komplex und je nach Heizungstyp unterschiedlich. Bin gespannt ob noch mehr Wortmeldungen dazu kommen.
                                      @mkshb genau, und das meinte ich damit, es gibt soviele lebensbereiche wo daß mit der Heizung oder auch Kühlung verwendet werden könnte, ich habe mir auch mit scripte für die Heizkurve ausgeholfen, aber so eine komplexe steuerung wäre doch ein traum für uns alle. Auch wenn die Umstellung an der Heizung mittlerweile sehr komfortabel ist, doch das müßte nicht sein, denn die anforderung würde über heatingcontrol (als Beispiel) gemanagd.
                                      McWoolf 1 Reply Last reply Reply Quote 0
                                      • McWoolf
                                        McWoolf @babl last edited by
                                        Hallo Leute!
                                        Wenn ich den Adapter auf v2.9.x update, stürzt mein Adapter immer wieder ab und das schon seit einer fast gefühlten Ewigkeit.
                                        Die Versionen von 2.9.x funktionieren tadellos. Jemand vlt eine Idee oder besser gesagt, was wird benötigt um dem Fehler auf die Schliche zu kommen?
                                        Frohe Feiertage noch
                                        • McWoolf
                                          McWoolf @McWoolf last edited by
                                          @mcwoolf sagte in Test Adapter HeatingControl v2.9.x:
                                          Hallo Leute!
                                          2022-12-27 11:49:50.789 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                          2022-12-27 11:49:50.790 - error: host.iobroker Caught by controller[0]: Error: No instanceName provided or not a string
                                          2022-12-27 11:49:50.790 - error: host.iobroker Caught by controller[0]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[0]: at Adapter.sendTo (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5962:30)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[0]: at sendNotificationTelegram (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:225:23)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[0]: at sendNotification (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:123:21)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[0]: at ThermostatLog (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:60:9)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[0]: at Timeout.SetThermostatTarget (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/database.js:1991:9)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[0]: at listOnTimeout (node:internal/timers:561:11)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[0]: at processTimers (node:internal/timers:502:7)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[2]: Error: No instanceName provided or not a string
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[2]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[2]: at Adapter.sendTo (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5962:30)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[2]: at sendNotificationTelegram (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:225:23)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[2]: at sendNotification (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:123:21)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[2]: at ThermostatLog (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:60:9)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[2]: at Timeout.SetThermostatTarget (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/database.js:1991:9)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[2]: at listOnTimeout (node:internal/timers:561:11)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[4]: Error: No instanceName provided or not a string
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[4]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[4]: at Adapter.sendTo (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5962:30)
                                          2022-12-27 11:49:50.791 - error: host.iobroker Caught by controller[4]: at sendNotificationTelegram (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:225:23)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[4]: at sendNotification (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:123:21)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[4]: at ThermostatLog (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:60:9)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[4]: at Timeout.SetThermostatTarget (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/database.js:1991:9)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[4]: at listOnTimeout (node:internal/timers:561:11)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[4]: at processTimers (node:internal/timers:502:7)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[6]: Error: No instanceName provided or not a string
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[6]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[6]: at Adapter.sendTo (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5962:30)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[6]: at sendNotificationTelegram (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:225:23)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[6]: at sendNotification (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:123:21)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[6]: at ThermostatLog (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:60:9)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[6]: at Timeout.SetThermostatTarget (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/database.js:1991:9)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[6]: at listOnTimeout (node:internal/timers:561:11)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[6]: at processTimers (node:internal/timers:502:7)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[7]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[8]: Error: No instanceName provided or not a string
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[8]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[8]: at Adapter.sendTo (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5962:30)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[8]: at sendNotificationTelegram (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:225:23)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[8]: at sendNotification (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:123:21)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[8]: at ThermostatLog (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:60:9)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[8]: at Timeout.SetThermostatTarget (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/database.js:1991:9)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[8]: at listOnTimeout (node:internal/timers:561:11)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[8]: at processTimers (node:internal/timers:502:7)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[9]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[9]: Error: No instanceName provided or not a string
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[9]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[9]: at Adapter.sendTo (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5962:30)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[9]: at sendNotificationTelegram (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:225:23)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[9]: at sendNotification (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:123:21)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[9]: at ThermostatLog (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/logging.js:60:9)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[9]: at Timeout.SetThermostatTarget (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/database.js:1991:9)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[9]: at listOnTimeout (node:internal/timers:561:11)
                                          2022-12-27 11:49:50.792 - error: host.iobroker Caught by controller[9]: at processTimers (node:internal/timers:502:7)
                                          2022-12-27 11:49:50.792 - error: host.iobroker instance system.adapter.heatingcontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          • Rene_HM
                                            Rene_HM Developer @McWoolf last edited by
                                            @mcwoolf Du versuchst, Meldungen per telegram zu verschicken, hast aber keine Telegram-Instanz konfiguriert....
                                            Abhilfe: entweder in den Benachrichtigungseinstellungen Telegram deaktvieren oder eine Telegram-Instanz konfigurieren..
                                            heating
                                            236
                                            3158
                                            1867459
