    3. Einsteigerfragen
    4. Installation
    5. ioBroker Installation npm Err!
      Chris982 @Thomas Braun last edited by
       Welcome to the ioBroker installer!
          Installer version: 2022-12-09
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      OK:3 https://repos.influxdata.com/debian bullseye InRelease
      OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      OK:5 https://packages.grafana.com/enterprise/deb stable InRelease
      Changing npm registry to https://registry.npmjs.org
      npm ERR! builtins is not a function
      npm ERR!     /home/pi/.npm/_logs/2022-12-21T18_56_11_280Z-debug-0.log
      Installed gcc-c++
          Creating ioBroker user and directory (2/4)
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      npm ERR!     /home/pi/.npm/_logs/2022-12-21T18_56_16_582Z-debug-0.log
          Finalizing installation (4/4)
      Enabling autostart...
      Autostart enabled!
      Fixing directory permissions...
          ioBroker was installed successfully
          Open http://192.168.1.95 10.8.0.1:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      meinst du so?
        Thomas Braun Most Active @Chris982 last edited by Thomas Braun
        @chris982
        Check deine nodejs-Installation. Ich vermute die ist/war mal krumm.
          pi@raspberrypi:~ $ apt policy nodejs
          nodejs
          nodejs:
            Installiert:           16.19.0-deb-1nodesource1
            Installationskandidat: 16.19.0-deb-1nodesource1
            Versionstabelle:
           *** 16.19.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u1 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          Welcome to Node.js v16.19.0.
          Type ".help" for more information.
          ich denke auch weil da 2 nodejs installiert sind. aber wie kann ich die 12.22.12 löschen?
            @chris982
            Gar nicht. Die ist ja nicht (über den Paketmanager) installiert.
            Was sagt
            sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
            uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              pi@raspberrypi:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              armv7l
              Kein Docker
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.19.0
              v16.19.0
              8.19.3
              node:internal/modules/cjs/loader:998
                throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                  at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                  at node:internal/main/run_main_module:22:47 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
              pi@raspberrypi:~ $
                @chris982
                Ich weiß nicht wie oft das hier schon gefixt wurde. Such nach der Fehlermeldung.
                  ok, mache mich nochmal auf die suche, hbe vorhin aber nichts wirkliches gefunden.
                  Danke Dir schon mal
                    @chris982
                    Zuletzt genau in diesem Thread. Vor nicht mal 24 Stunden.
                      ja die sachen habe ich auch schon mehrfach gemacht aber es geht leider trotzdem nicht. oder habe ich noch was übersehen?
                      pi@raspberrypi:~ $ sudo systemctl stop iobroker
                      pi@raspberrypi:~ $ iobroker fix
                      library: loaded
                      Library version=2022-12-09
                      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                      pi@raspberrypi:~ $ sudo systemctl start iobroker
                      pi@raspberrypi:~ $ cd /opt/iobroker
                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                      npm ERR!     /home/iobroker/.npm/_logs/2022-12-21T19_50_27_303Z-debug-0.log
                      pi@raspberrypi:/opt/iobroker $ iobroker restart
                      pi@raspberrypi:/opt/iobroker $ iobroker status
                        throw err;
                        requireStack: []
                      pi@raspberrypi:/opt/iobroker $ cd
                      pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                      library: loaded
                      npm ERR!     /home/pi/.npm/_logs/2022-12-21T19_51_38_882Z-debug-0.log
                      Installed gcc-c++
                      npm ERR!     /home/pi/.npm/_logs/2022-12-21T19_51_44_342Z-debug-0.log
                      Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service -> /lib/systemd/system/iobroker.service.
                      Autostart enabled!
                      pi@raspberrypi:~ $
                        Thomas Braun Most Active last edited by Thomas Braun
                        @chris982 sagte in ioBroker Installation npm Err!:
                        iobroker stop
                        sudo apt update
                        sudo apt install --reinstall nodejs
                        type -P npm nodejs node
                        1.2k
                        8117
