    3. Einsteigerfragen
    4. Installation
    5. iobroker Installation ok, aber kein Zugriff über localhost
    • Glasfaser
      Glasfaser @mwolle last edited by
      @mwolle
      mache mal
      iobroker start admin
        crunchip Forum Testing Most Active @mwolle last edited by crunchip
        @mwolle nein der admin läuft nicht, siehst du am fehlendem + davor
        wie schon geschrieben, admin starten
          mwolle @Glasfaser last edited by
          @glasfaser keine Besserung
            mwolle @crunchip last edited by
            @crunchip ok, aber mit iobroker start admin gibt es auch keine Besserung...
              @mwolle und jetzt mit deiner ip aufrufen
              • Glasfaser
                @mwolle sagte in iobroker Installation ok, aber kein Zugriff über localhost:
                Dann zeigen :
                iobroker logs --watch
                  @glasfaser oh ha...
                  2022-12-22 08:34:28.871  - error: admin.0 (5429) Cannot read properties of null (reading '_acl')
                  2022-12-22 08:34:28.895  - info: admin.0 (5429) terminating http server on port 8081
                  2022-12-22 08:34:28.897  - info: admin.0 (5429) terminating
                  2022-12-22 08:34:28.898  - warn: admin.0 (5429) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
                  2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                  2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                  2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                  2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                  2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
                  2022-12-22 08:34:29.137  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2022-12-22 08:34:29.137  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                  2022-12-22 08:34:59.171  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5446
                  2022-12-22 08:35:02.096  - info: admin.0 (5446) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
                  2022-12-22 08:35:02.148  - info: admin.0 (5446) requesting all states
                  2022-12-22 08:35:02.149  - info: admin.0 (5446) requesting all objects
                  2022-12-22 08:35:02.250  - info: admin.0 (5446) received all objects
                  2022-12-22 08:35:02.268  - warn: admin.0 (5446) Repository cannot be read: Active repo - stable
                  2022-12-22 08:35:02.269  - warn: admin.0 (5446) Active repository "stable" cannot be read
                  2022-12-22 08:35:02.372  - warn: admin.0 (5446) Cannot check node.js versions: Error: unexpected end of file
                  2022-12-22 08:35:02.387  - info: admin.0 (5446) http server listening on port 8081
                  2022-12-22 08:35:02.388  - info: admin.0 (5446) Use link "http://localhost:8081" to configure.
                  2022-12-22 08:35:02.397  - info: admin.0 (5446) socket.io server listening on port 8081
                  2022-12-22 08:35:02.406  - error: admin.0 (5446) uncaught exception: Cannot read properties of null (reading '_acl')
                  2022-12-22 08:35:02.407  - error: admin.0 (5446) TypeError: Cannot read properties of null (reading '_acl')
                  2022-12-22 08:35:02.407  - error: admin.0 (5446) Cannot read properties of null (reading '_acl')
                  2022-12-22 08:35:02.433  - info: admin.0 (5446) terminating http server on port 8081
                  2022-12-22 08:35:02.435  - info: admin.0 (5446) terminating
                  2022-12-22 08:35:02.436  - warn: admin.0 (5446) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2022-12-22 08:35:02.627  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
                  2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                  2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                  2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                  2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                  2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
                  2022-12-22 08:35:02.629  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2022-12-22 08:35:02.629  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                  2022-12-22 08:35:32.671  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5475
                  2022-12-22 08:35:35.040  - info: admin.0 (5475) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
                  2022-12-22 08:35:35.095  - info: admin.0 (5475) requesting all states
                  2022-12-22 08:35:35.096  - info: admin.0 (5475) requesting all objects
                  2022-12-22 08:35:35.191  - info: admin.0 (5475) received all objects
                  2022-12-22 08:35:35.208  - warn: admin.0 (5475) Repository cannot be read: Active repo - stable
                  2022-12-22 08:35:35.210  - warn: admin.0 (5475) Active repository "stable" cannot be read
                  2022-12-22 08:35:35.311  - warn: admin.0 (5475) Cannot check node.js versions: Error: unexpected end of file
                  2022-12-22 08:35:35.324  - info: admin.0 (5475) http server listening on port 8081
                  2022-12-22 08:35:35.325  - info: admin.0 (5475) Use link "http://localhost:8081" to configure.
                  2022-12-22 08:35:35.333  - info: admin.0 (5475) socket.io server listening on port 8081
                  2022-12-22 08:35:35.342  - error: admin.0 (5475) uncaught exception: Cannot read properties of null (reading '_acl')
                  2022-12-22 08:35:35.342  - error: admin.0 (5475) TypeError: Cannot read properties of null (reading '_acl')
                  2022-12-22 08:35:35.343  - error: admin.0 (5475) Cannot read properties of null (reading '_acl')
                  2022-12-22 08:35:35.371  - info: admin.0 (5475) terminating http server on port 8081
                  2022-12-22 08:35:35.375  - info: admin.0 (5475) terminating
                  2022-12-22 08:35:35.376  - warn: admin.0 (5475) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
                  2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                  2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                  2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                  2022-12-22 08:35:35.598  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                  2022-12-22 08:35:35.598  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
                  2022-12-22 08:35:35.598  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2022-12-22 08:35:35.598  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                  2022-12-22 08:36:05.642  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5492
                  2022-12-22 08:36:08.421  - info: admin.0 (5492) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
                  Glasfaser apollon77 2 Replies Last reply Reply Quote 0
                  • Glasfaser
                    Keine Ahnung was da passiert ist , bei einer :
                    Normale iobroker Installation auf Raspi PI 4:
                    ich würde es nochmal neu aufsetzen
                    • Glasfaser
                      system.adapter.admin : admin - v6.3.3
                      Ist jetzt eine 6.3.4 schon raus ... eventuell klemmte da was ..
                      • Marc Berg
                        Marc Berg Most Active @mwolle last edited by
                        Unter welchem User hast du das ausgeführt?
                        curl -sLf https://iobroker.net/install.sh | bash -
                          @glasfaser der Installer nimmt den 6.3.3...was mir aufgefallen ist, bei der ersten frischen Installation meckert bzgl. der Node.js rum, dass die 12 nicht mehr gültig ist. Danach habe ich die aktuellste Version installiert und den Installer noch mal rüberlaufen lassen, da kann auch kein Fehler mehr, das gilt auch für iobroker fix.
                          crunchip Glasfaser 2 Replies Last reply Reply Quote 0
                            mwolle @Marc Berg last edited by
                            @marc-berg der Standard pi User bzw. von mir angelegte.
                              hast du node vorher manuell installiert?
                              • Glasfaser
                                dann hast du alten Müll auf der Raspberry noch vorhanden und hast dann darauf ioBroker installiert !?
                                Zeige mal :
                                sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  @glasfaser
                                  armv7l
                                  Kein Docker
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v16.19.0
                                  v16.19.0
                                  8.19.3
                                  4.0.23
                                  pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                  x11
                                  LXDE-pi
                                  /home/pi
                                  OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                  OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  Paketlisten werden gelesen… Fertig
                                  Abhängigkeitsbaum wird aufgebaut… Fertig
                                  Statusinformationen werden eingelesen… Fertig
                                  Alle Pakete sind aktuell.
                                  nodejs:
                                    Installiert:           16.19.0-deb-1nodesource1
                                    Installationskandidat: 16.19.0-deb-1nodesource1
                                    Versionstabelle:
                                   *** 16.19.0-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                          100 /var/lib/dpkg/status
                                       12.22.12~dfsg-1~deb11u1 500
                                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                    x11
                                    desktop
                                      @crunchip im Original Noobs 3.8.0 ist scheinbar Node.js 12.22 installiert, ich habe dann ein Update auf die neuste Version gemacht, aber erst nachdem iobroker bei Installation gemeckert hat.
                                        @crunchip said in iobroker Installation ok, aber kein Zugriff über localhost:
                                        x11
                                        desktop
                                        ? Heißt? Ja ist Desktopversion
                                          @mwolle iobroker = Serverbetrieb, heisst ohne Desktop
                                          z.b https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                            @crunchip grundsätzlich, ja verstehe ich, aber: ich habe das jetzt bestimmt 40x genauso installiert, alles war ok. Hat sich das jetzt mit der neusten Installerversion dann geändert? Am Ende wollte ich den iobroker auch so standalone haben.
                                            4176
