    3. Einsteigerfragen
    4. Installation
    5. iobroker Installation ok, aber kein Zugriff über localhost
      crunchip Forum Testing Most Active @mwolle last edited by crunchip
      @mwolle nein der admin läuft nicht, siehst du am fehlendem + davor
      wie schon geschrieben, admin starten
        mwolle @Glasfaser last edited by
        @glasfaser keine Besserung
          mwolle @crunchip last edited by
          @crunchip ok, aber mit iobroker start admin gibt es auch keine Besserung...
            @mwolle und jetzt mit deiner ip aufrufen
            • Glasfaser
              Glasfaser @mwolle last edited by
              @mwolle sagte in iobroker Installation ok, aber kein Zugriff über localhost:
              Dann zeigen :
              iobroker logs --watch
                @glasfaser oh ha...
                2022-12-22 08:34:28.871  - error: admin.0 (5429) Cannot read properties of null (reading '_acl')
                2022-12-22 08:34:28.895  - info: admin.0 (5429) terminating http server on port 8081
                2022-12-22 08:34:28.897  - info: admin.0 (5429) terminating
                2022-12-22 08:34:28.898  - warn: admin.0 (5429) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
                2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
                2022-12-22 08:34:29.137  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2022-12-22 08:34:29.137  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                2022-12-22 08:34:59.171  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5446
                2022-12-22 08:35:02.096  - info: admin.0 (5446) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
                2022-12-22 08:35:02.148  - info: admin.0 (5446) requesting all states
                2022-12-22 08:35:02.149  - info: admin.0 (5446) requesting all objects
                2022-12-22 08:35:02.250  - info: admin.0 (5446) received all objects
                2022-12-22 08:35:02.268  - warn: admin.0 (5446) Repository cannot be read: Active repo - stable
                2022-12-22 08:35:02.269  - warn: admin.0 (5446) Active repository "stable" cannot be read
                2022-12-22 08:35:02.372  - warn: admin.0 (5446) Cannot check node.js versions: Error: unexpected end of file
                2022-12-22 08:35:02.387  - info: admin.0 (5446) http server listening on port 8081
                2022-12-22 08:35:02.388  - info: admin.0 (5446) Use link "http://localhost:8081" to configure.
                2022-12-22 08:35:02.397  - info: admin.0 (5446) socket.io server listening on port 8081
                2022-12-22 08:35:02.406  - error: admin.0 (5446) uncaught exception: Cannot read properties of null (reading '_acl')
                2022-12-22 08:35:02.407  - error: admin.0 (5446) TypeError: Cannot read properties of null (reading '_acl')
                2022-12-22 08:35:02.407  - error: admin.0 (5446) Cannot read properties of null (reading '_acl')
                2022-12-22 08:35:02.433  - info: admin.0 (5446) terminating http server on port 8081
                2022-12-22 08:35:02.435  - info: admin.0 (5446) terminating
                2022-12-22 08:35:02.436  - warn: admin.0 (5446) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2022-12-22 08:35:02.627  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
                2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
                2022-12-22 08:35:02.629  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2022-12-22 08:35:02.629  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                2022-12-22 08:35:32.671  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5475
                2022-12-22 08:35:35.040  - info: admin.0 (5475) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
                2022-12-22 08:35:35.095  - info: admin.0 (5475) requesting all states
                2022-12-22 08:35:35.096  - info: admin.0 (5475) requesting all objects
                2022-12-22 08:35:35.191  - info: admin.0 (5475) received all objects
                2022-12-22 08:35:35.208  - warn: admin.0 (5475) Repository cannot be read: Active repo - stable
                2022-12-22 08:35:35.210  - warn: admin.0 (5475) Active repository "stable" cannot be read
                2022-12-22 08:35:35.311  - warn: admin.0 (5475) Cannot check node.js versions: Error: unexpected end of file
                2022-12-22 08:35:35.324  - info: admin.0 (5475) http server listening on port 8081
                2022-12-22 08:35:35.325  - info: admin.0 (5475) Use link "http://localhost:8081" to configure.
                2022-12-22 08:35:35.333  - info: admin.0 (5475) socket.io server listening on port 8081
                2022-12-22 08:35:35.342  - error: admin.0 (5475) uncaught exception: Cannot read properties of null (reading '_acl')
                2022-12-22 08:35:35.342  - error: admin.0 (5475) TypeError: Cannot read properties of null (reading '_acl')
                2022-12-22 08:35:35.343  - error: admin.0 (5475) Cannot read properties of null (reading '_acl')
                2022-12-22 08:35:35.371  - info: admin.0 (5475) terminating http server on port 8081
                2022-12-22 08:35:35.375  - info: admin.0 (5475) terminating
                2022-12-22 08:35:35.376  - warn: admin.0 (5475) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
                2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                2022-12-22 08:35:35.598  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                2022-12-22 08:35:35.598  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
                2022-12-22 08:35:35.598  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2022-12-22 08:35:35.598  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                2022-12-22 08:36:05.642  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5492
                2022-12-22 08:36:08.421  - info: admin.0 (5492) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
                Glasfaser apollon77 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  Keine Ahnung was da passiert ist , bei einer :
                  Normale iobroker Installation auf Raspi PI 4:
                  ich würde es nochmal neu aufsetzen
                  • Glasfaser
                    system.adapter.admin : admin - v6.3.3
                    Ist jetzt eine 6.3.4 schon raus ... eventuell klemmte da was ..
                    • Marc Berg
                      Marc Berg Most Active @mwolle last edited by
                      Unter welchem User hast du das ausgeführt?
                      curl -sLf https://iobroker.net/install.sh | bash -
                        @glasfaser der Installer nimmt den 6.3.3...was mir aufgefallen ist, bei der ersten frischen Installation meckert bzgl. der Node.js rum, dass die 12 nicht mehr gültig ist. Danach habe ich die aktuellste Version installiert und den Installer noch mal rüberlaufen lassen, da kann auch kein Fehler mehr, das gilt auch für iobroker fix.
                        crunchip Glasfaser 2 Replies Last reply Reply Quote 0
                          mwolle @Marc Berg last edited by
                          @marc-berg der Standard pi User bzw. von mir angelegte.
                            hast du node vorher manuell installiert?
                            • Glasfaser
                              dann hast du alten Müll auf der Raspberry noch vorhanden und hast dann darauf ioBroker installiert !?
                              Zeige mal :
                              sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                              uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                @glasfaser
                                armv7l
                                Kein Docker
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.19.0
                                v16.19.0
                                8.19.3
                                4.0.23
                                pi
                                pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                x11
                                LXDE-pi
                                /home/pi
                                OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Paketlisten werden gelesen… Fertig
                                Abhängigkeitsbaum wird aufgebaut… Fertig
                                Statusinformationen werden eingelesen… Fertig
                                Alle Pakete sind aktuell.
                                nodejs:
                                  Installiert:           16.19.0-deb-1nodesource1
                                  Installationskandidat: 16.19.0-deb-1nodesource1
                                  Versionstabelle:
                                 *** 16.19.0-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                        100 /var/lib/dpkg/status
                                     12.22.12~dfsg-1~deb11u1 500
                                        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                  x11
                                  desktop
                                    @crunchip im Original Noobs 3.8.0 ist scheinbar Node.js 12.22 installiert, ich habe dann ein Update auf die neuste Version gemacht, aber erst nachdem iobroker bei Installation gemeckert hat.
                                      @crunchip said in iobroker Installation ok, aber kein Zugriff über localhost:
                                      x11
                                      desktop
                                      ? Heißt? Ja ist Desktopversion
                                        @mwolle iobroker = Serverbetrieb, heisst ohne Desktop
                                        z.b https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                          @crunchip grundsätzlich, ja verstehe ich, aber: ich habe das jetzt bestimmt 40x genauso installiert, alles war ok. Hat sich das jetzt mit der neusten Installerversion dann geändert? Am Ende wollte ich den iobroker auch so standalone haben.
                                            Thomas Braun Most Active @mwolle last edited by
                                            @mwolle
                                            Noobs ist obsolet. Verwende den Imager.
                                            4176
