    3. Einsteigerfragen
    4. Installation
    5. iobroker Installation ok, aber kein Zugriff über localhost
      crunchip Forum Testing Most Active @mwolle last edited by
      @mwolle und jetzt mit deiner ip aufrufen
      • Glasfaser
        Glasfaser @mwolle last edited by
        @mwolle sagte in iobroker Installation ok, aber kein Zugriff über localhost:
        @glasfaser keine Besserung
        Dann zeigen :
        iobroker logs --watch
          mwolle @Glasfaser last edited by
          @glasfaser oh ha...
          2022-12-22 08:34:28.871  - error: admin.0 (5429) Cannot read properties of null (reading '_acl')
          2022-12-22 08:34:28.895  - info: admin.0 (5429) terminating http server on port 8081
          2022-12-22 08:34:28.897  - info: admin.0 (5429) terminating
          2022-12-22 08:34:28.898  - warn: admin.0 (5429) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
          2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
          2022-12-22 08:34:29.136  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
          2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
          2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
          2022-12-22 08:34:29.137  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
          2022-12-22 08:34:29.137  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2022-12-22 08:34:29.137  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
          2022-12-22 08:34:59.171  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5446
          2022-12-22 08:35:02.096  - info: admin.0 (5446) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
          2022-12-22 08:35:02.148  - info: admin.0 (5446) requesting all states
          2022-12-22 08:35:02.149  - info: admin.0 (5446) requesting all objects
          2022-12-22 08:35:02.250  - info: admin.0 (5446) received all objects
          2022-12-22 08:35:02.268  - warn: admin.0 (5446) Repository cannot be read: Active repo - stable
          2022-12-22 08:35:02.269  - warn: admin.0 (5446) Active repository "stable" cannot be read
          2022-12-22 08:35:02.372  - warn: admin.0 (5446) Cannot check node.js versions: Error: unexpected end of file
          2022-12-22 08:35:02.387  - info: admin.0 (5446) http server listening on port 8081
          2022-12-22 08:35:02.388  - info: admin.0 (5446) Use link "http://localhost:8081" to configure.
          2022-12-22 08:35:02.397  - info: admin.0 (5446) socket.io server listening on port 8081
          2022-12-22 08:35:02.406  - error: admin.0 (5446) uncaught exception: Cannot read properties of null (reading '_acl')
          2022-12-22 08:35:02.407  - error: admin.0 (5446) TypeError: Cannot read properties of null (reading '_acl')
          2022-12-22 08:35:02.407  - error: admin.0 (5446) Cannot read properties of null (reading '_acl')
          2022-12-22 08:35:02.433  - info: admin.0 (5446) terminating http server on port 8081
          2022-12-22 08:35:02.435  - info: admin.0 (5446) terminating
          2022-12-22 08:35:02.436  - warn: admin.0 (5446) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2022-12-22 08:35:02.627  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
          2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
          2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
          2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
          2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
          2022-12-22 08:35:02.628  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
          2022-12-22 08:35:02.629  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2022-12-22 08:35:02.629  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
          2022-12-22 08:35:32.671  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5475
          2022-12-22 08:35:35.040  - info: admin.0 (5475) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
          2022-12-22 08:35:35.095  - info: admin.0 (5475) requesting all states
          2022-12-22 08:35:35.096  - info: admin.0 (5475) requesting all objects
          2022-12-22 08:35:35.191  - info: admin.0 (5475) received all objects
          2022-12-22 08:35:35.208  - warn: admin.0 (5475) Repository cannot be read: Active repo - stable
          2022-12-22 08:35:35.210  - warn: admin.0 (5475) Active repository "stable" cannot be read
          2022-12-22 08:35:35.311  - warn: admin.0 (5475) Cannot check node.js versions: Error: unexpected end of file
          2022-12-22 08:35:35.324  - info: admin.0 (5475) http server listening on port 8081
          2022-12-22 08:35:35.325  - info: admin.0 (5475) Use link "http://localhost:8081" to configure.
          2022-12-22 08:35:35.333  - info: admin.0 (5475) socket.io server listening on port 8081
          2022-12-22 08:35:35.342  - error: admin.0 (5475) uncaught exception: Cannot read properties of null (reading '_acl')
          2022-12-22 08:35:35.342  - error: admin.0 (5475) TypeError: Cannot read properties of null (reading '_acl')
          2022-12-22 08:35:35.343  - error: admin.0 (5475) Cannot read properties of null (reading '_acl')
          2022-12-22 08:35:35.371  - info: admin.0 (5475) terminating http server on port 8081
          2022-12-22 08:35:35.375  - info: admin.0 (5475) terminating
          2022-12-22 08:35:35.376  - warn: admin.0 (5475) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
          2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
          2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
          2022-12-22 08:35:35.597  - error: host.raspberrypi Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
          2022-12-22 08:35:35.598  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
          2022-12-22 08:35:35.598  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
          2022-12-22 08:35:35.598  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2022-12-22 08:35:35.598  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
          2022-12-22 08:36:05.642  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 5492
          2022-12-22 08:36:08.421  - info: admin.0 (5492) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
          Glasfaser apollon77 2 Replies Last reply Reply Quote 0
          • Glasfaser
            Keine Ahnung was da passiert ist , bei einer :
            Normale iobroker Installation auf Raspi PI 4:
            ich würde es nochmal neu aufsetzen
            • Glasfaser
              system.adapter.admin : admin - v6.3.3
              Ist jetzt eine 6.3.4 schon raus ... eventuell klemmte da was ..
              • Marc Berg
                Marc Berg Most Active @mwolle last edited by
                Unter welchem User hast du das ausgeführt?
                curl -sLf https://iobroker.net/install.sh | bash -
                  @glasfaser der Installer nimmt den 6.3.3...was mir aufgefallen ist, bei der ersten frischen Installation meckert bzgl. der Node.js rum, dass die 12 nicht mehr gültig ist. Danach habe ich die aktuellste Version installiert und den Installer noch mal rüberlaufen lassen, da kann auch kein Fehler mehr, das gilt auch für iobroker fix.
                  crunchip Glasfaser 2 Replies Last reply Reply Quote 0
                    mwolle @Marc Berg last edited by
                    @marc-berg der Standard pi User bzw. von mir angelegte.
                      hast du node vorher manuell installiert?
                      • Glasfaser
                        dann hast du alten Müll auf der Raspberry noch vorhanden und hast dann darauf ioBroker installiert !?
                        Zeige mal :
                        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                        uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          @glasfaser
                          armv7l
                          Kein Docker
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.19.0
                          v16.19.0
                          8.19.3
                          4.0.23
                          pi
                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                          x11
                          LXDE-pi
                          /home/pi
                          OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                          OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                          Paketlisten werden gelesen… Fertig
                          Abhängigkeitsbaum wird aufgebaut… Fertig
                          Statusinformationen werden eingelesen… Fertig
                          Alle Pakete sind aktuell.
                          nodejs:
                            Installiert:           16.19.0-deb-1nodesource1
                            Installationskandidat: 16.19.0-deb-1nodesource1
                            Versionstabelle:
                           *** 16.19.0-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                  100 /var/lib/dpkg/status
                               12.22.12~dfsg-1~deb11u1 500
                                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                            x11
                            desktop
                              mwolle @crunchip last edited by
                              @crunchip im Original Noobs 3.8.0 ist scheinbar Node.js 12.22 installiert, ich habe dann ein Update auf die neuste Version gemacht, aber erst nachdem iobroker bei Installation gemeckert hat.
                                @crunchip said in iobroker Installation ok, aber kein Zugriff über localhost:
                                x11
                                desktop
                                ? Heißt? Ja ist Desktopversion
                                  crunchip Forum Testing Most Active @mwolle last edited by crunchip
                                  @mwolle iobroker = Serverbetrieb, heisst ohne Desktop
                                  z.b https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                    @crunchip grundsätzlich, ja verstehe ich, aber: ich habe das jetzt bestimmt 40x genauso installiert, alles war ok. Hat sich das jetzt mit der neusten Installerversion dann geändert? Am Ende wollte ich den iobroker auch so standalone haben.
                                      Thomas Braun Most Active @mwolle last edited by
                                      @mwolle
                                      Noobs ist obsolet. Verwende den Imager.
                                        mwolle @Thomas Braun last edited by
                                        autsch, also play it again Sam und noch mal neu aufsetzen. Aber Desktop wird weiter unterstützt oder bleibt es beim Serverbetrieb?
                                          @mwolle braucht halt unnötige Ressourcen
                                            @crunchip das wäre nicht schlimm, weil das DIng nichts anderes tun soll, als Heizungsdaten zu protokollieren und mit Flot anzuzeigen. Mehr soll der nicht machen.
                                            4176
