    4. Server Cannot start inMem-objects on port 9001
      micw42 @apollon77 last edited by
      Also wenn ich den iobroker-log und den System-log zusammenfasse:
      2022-11-21 08:17:22.426 - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
      2022-11-21 08:17:22.433 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-11-21 08:17:22.434 - info: host.raspberrypi hostname: raspberrypi, node: v14.20.0
      2022-11-21 08:17:22.435 - info: host.raspberrypi ip addresses: 192.168.178.56 fd00::85ce:9c7a:3bcd:95ac fe80::3782:4c12:e099:c79e
      2022-11-21 08:17:24.559 - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      Nov 21 08:17:24 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=24/n/a
      Nov 21 08:17:24 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
      Nov 21 08:17:27 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
      Nov 21 08:17:27 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 1.
      Nov 21 08:17:27 raspberrypi systemd[1]: Stopped ioBroker Server.
      Nov 21 08:17:27 raspberrypi systemd[1]: Started ioBroker Server.
      2022-11-21 08:17:29.145 - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
      2022-11-21 08:17:29.153 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-11-21 08:17:29.153 - info: host.raspberrypi hostname: raspberrypi, node: v14.20.0
      2022-11-21 08:17:29.154 - info: host.raspberrypi ip addresses: 192.168.178.56 fd00::85ce:9c7a:3bcd:95ac fe80::3782:4c12:e099:c79e
      2022-11-21 08:17:31.270 - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      Nov 21 08:17:31 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=24/n/a
      Nov 21 08:17:31 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
      Nov 21 08:17:34 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
      Nov 21 08:17:34 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2.
      Nov 21 08:17:34 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
      Nov 21 08:17:34 raspberrypi systemd[1]: Stopped ioBroker Server.
      Nov 21 08:17:34 raspberrypi systemd[1]: Started ioBroker Server.
      Es sieht doch für mich so aus, als wenn der pi (aus welchem Grund auch immer) neu gestartet ist, der iobroker aber wegen des DB locks nicht starten konnte?
      Erst mit Ziehen des Steckers und nochmaligem Neustart lief wieder alles.
      Oder sehe ich das komplett falsch?
      Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @micw42 last edited by Thomas Braun
        @micw42 sagte in Server Cannot start inMem-objects on port 9001:
        ???? Nie einfach den Stecker ziehen!
        systemctl status iobroker
        sagt? Bitte in CodeTags eingebettet posten.
          apollon77 @micw42 last edited by
          @micw42 Also ja ok ... hatte nicht gesehen das der eine Start 1h später war.
          Das interessante ist das das letze im Log der "dritte "Started" ist und dann weder im syslog oder woanders nochwas kommt. Und wenn du auch sagst das SSH nicht mehr ging dann hat das system irgendwas. Weil dann ist das ja scheinbar komplett hängen geblieben - keine AHung ob es nicht auch passiert wäre wenn iobroker gestartet wäre.
          Aber ja es kann sein das bei so einem harten restart vom host das DLB Lock file noch da ist und es so beim Reboot zu diesem Fehler kommt weil halt das lock File der DB noch da ist ... das expired glaube ich 5 Minuten später oder so. Aber normalerweise gibt das dann einfach mehrere Startversuche bis dann einer tut.
          Das komisch bei dir ist das der rechner komplett nach 2 versuchen einfriert (weil SSH ja auch nicht geht) ... also da ist was anderes als ioBroker im Argen.
          Und dein Problem ist daher definitiv was anderes
            @apollon77 Danke für die Hilfe! Ich muss also "nur" rausfinden, warum sich der pi rebootet ...
              @micw42 ja damit würde ich starten ;-)) sorry das ich da nicht mehr helfen kann. Ich persönlich würde mit dem Netzteil anfangen.
                woehrer last edited by
                ich habe jetzt hier schon einiges gelesen aber leider war die richtige Lösung für mich noch nicht greifbar. Habe natürlich auch schon das ein oder andere versucht.
                woehrer@iobrokerifa:/opt/iobroker/iobroker-data$ cd ..
                woehrer@iobrokerifa:/opt/iobroker$ iob version
                4.0.23
                woehrer@iobrokerifa:/opt/iobroker$ iob status
                Objects type: jsonl
                States  type: jsonl
                woehrer@iobrokerifa:/opt/iobroker$ node node_modules/iobroker.js-controller/controller.js --logs
                2022-12-22 08:42:12.631  - info: host.iobrokerifa iobroker.js-controller version 4.0.23 js-controller starting
                2022-12-22 08:42:12.635  - info: host.iobrokerifa Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2022-12-22 08:42:12.636  - info: host.iobrokerifa hostname: iobrokerifa, node: v14.21.1
                2022-12-22 08:42:12.636  - info: host.iobrokerifa ip addresses: 192.168.20.70 fe80::11:32ff:fe27:dee
                2022-12-22 08:42:14.720  - error: host.iobrokerifa-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                woehrer@iobrokerifa:/opt/iobroker$ node -v
                v14.21.1
                woehrer@iobrokerifa:/opt/iobroker$ npm -v
                6.14.17
                woehrer@iobrokerifa:/opt/iobroker$ sudo ss -tulpn | grep LISTEN
                tcp   LISTEN 0      511             127.0.0.1:9000       0.0.0.0:*    users:(("iobroker.js-con",pid=672,fd=26))
                tcp   LISTEN 0      511             127.0.0.1:9001       0.0.0.0:*    users:(("iobroker.js-con",pid=672,fd=20))
                tcp   LISTEN 0      511               0.0.0.0:50001      0.0.0.0:*    users:(("io.sia.0",pid=1748,fd=26))
                tcp   LISTEN 0      4096        127.0.0.53%lo:53         0.0.0.0:*    users:(("systemd-resolve",pid=654,fd=14))
                tcp   LISTEN 0      128               0.0.0.0:22         0.0.0.0:*    users:(("sshd",pid=720,fd=3))
                tcp   LISTEN 0      511                     *:8082             *:*    users:(("io.web.0",pid=1152,fd=27))
                tcp   LISTEN 0      128                  [::]:22            [::]:*    users:(("sshd",pid=720,fd=4))
                tcp   LISTEN 0      511                     *:8087             *:*    users:(("io.simple-api.0",pid=1863,fd=26))
                Wäre echt super wenn mir da noch jemand ein Tipp hätte.
                  Thomas Braun Most Active @woehrer last edited by
                  @woehrer sagte in Server Cannot start inMem-objects on port 9001:
                  ein Tipp hätte.
                  NodeJS v16 fahren.
                    apollon77 @woehrer last edited by
                    @woehrer Also als allererstes:
                    • iob stop
                    • 1 Minute warten
                    • iob fix - dort dann vor allem bitte schauen bei "Step 3" und Ausgabe posten bzw sagen wie lang das bedauert hat
                    • iob start
                    tuts dann?
                      @apollon77 :
                      Der komplette fix ist in ca 15 Sekunden durchgelaufen. Das hatte ich schon versucht. Läuft leider trotzdem nicht.
                      woehrer@iobrokerifa:/opt/iobroker$ iobroker fix
                      library: loaded
                      Library version=2022-12-09
                          Welcome to the ioBroker installation fixer!
                          Script version: 2022-12-09
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/4)
                      [sudo] password for woehrer:
                      OK:1 https://deb.nodesource.com/node_14.x focal InRelease
                      OK:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                      Holen:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
                      Holen:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease [99,8 kB]
                      Holen:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                      Es wurden 324 kB in 1 s geholt (501 kB/s).
                      Paketlisten werden gelesen… Fertig
                      Installed gcc-c++
                          Checking ioBroker user and directory permissions (2/4)
                      Created /etc/sudoers.d/iobroker
                      Fixing directory permissions...
                          Database maintenance (3/4)
                      Checking for uncompressed JSONL databases... This might take a while!
                      npx: Installierte 12 in 4.456s
                      No path given, using /opt/iobroker/iobroker-data
                      Compressing /opt/iobroker/iobroker-data/states.jsonl
                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                      Compressed 2 JSONL files. Done
                          Checking autostart (4/4)
                      Enabling autostart...
                      Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                        woehrer @Thomas Braun last edited by
                        Bin jetzt mal hoch auf v16
                        v16.19.0
                        8.19.3
                        library: loaded
                        OK:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                        Holen:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
                        OK:3 https://deb.nodesource.com/node_16.x jammy InRelease
                        Es wurden 324 kB in 1 s geholt (576 kB/s).
                        Installed gcc-c++
                        Autostart enabled!
                        Bekomme immernoch die Fehlermeldung und der admin Adapter startet weiterhin nicht. Alles andere scheint aber zu laufen
                        Thomas Braun crunchip W 3 Replies Last reply Reply Quote 0
                          @woehrer
                          iobroker diag
                          ausführen und Ergebnisse bekannt geben.
                            crunchip Forum Testing Most Active @woehrer last edited by
                            iob logs --watch
                            iob list instances
                              woehrer @woehrer last edited by woehrer
                              @woehrer
                                                      v.2022-12-13
                              Operatingsystem:        Ubuntu 22.04.1 LTS
                              Installation:           microsoft
                              Timezone:               Europe/Berlin
                              User-ID:                1000
                              X-Server:               false
                              Pending OS-Updates:     0
                              Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                                      /usr/bin/node           v16.19.0
                                                      /usr/bin/npm            8.19.3
                              ioBroker Core:          js-controller           4.0.23
                                                      admin                   6.3.3
                              Objects type: jsonl
                              States  type: jsonl
                              Pending iob updates:    2
                              Active repo(s): stable
                              Objects:                6726
                              States:                 6193
                              Size of iob-Database:
                              7.5M    /opt/iobroker/iobroker-data/objects.jsonl
                              4.7M    /opt/iobroker/iobroker-data/objects.json.migrated
                              4.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              5.0M    /opt/iobroker/iobroker-data/states.jsonl
                              1.2M    /opt/iobroker/iobroker-data/states.json.migrated
                              1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                              ====================== END OF SUMMARY ==================
                              2022-12-22 09:47:26.773  - info: host.iobrokerifa instance system.adapter.admin.0 started with pid 3788
                              2022-12-22 09:47:27.787  - info: admin.0 (3788) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
                              2022-12-22 09:47:27.814  - info: admin.0 (3788) requesting all states
                              2022-12-22 09:47:27.816  - info: admin.0 (3788) requesting all objects
                              2022-12-22 09:47:27.956  - warn: admin.0 (3788) Cannot check node.js versions: Error: unexpected end of file
                              2022-12-22 09:47:28.326  - info: admin.0 (3788) received all objects
                              2022-12-22 09:47:28.438  - info: admin.0 (3788) Request actual repository...
                              2022-12-22 09:47:28.523  - info: admin.0 (3788) http server listening on port 8081
                              2022-12-22 09:47:28.523  - info: admin.0 (3788) Use link "http://localhost:8081" to configure.
                              2022-12-22 09:47:28.527  - info: admin.0 (3788) socket.io server listening on port 8081
                              2022-12-22 09:47:28.539  - error: admin.0 (3788) uncaught exception: Cannot read properties of null (reading '_acl')
                              2022-12-22 09:47:28.539  - error: admin.0 (3788) TypeError: Cannot read properties of null (reading '_acl')
                                  at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                                  at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                                  at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                                  at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                                  at processImmediate (node:internal/timers:468:21)
                              2022-12-22 09:47:28.540  - error: admin.0 (3788) Cannot read properties of null (reading '_acl')
                              2022-12-22 09:47:28.556  - info: admin.0 (3788) terminating http server on port 8081
                              2022-12-22 09:47:28.560  - info: admin.0 (3788) terminating
                              2022-12-22 09:47:28.561  - warn: admin.0 (3788) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2022-12-22 09:47:28.779  - info: host.iobrokerifa Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                              2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
                              2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                              2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                              2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                              2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                              2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
                              2022-12-22 09:47:28.814  - error: host.iobrokerifa instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2022-12-22 09:47:28.814  - info: host.iobrokerifa Restart adapter system.adapter.admin.0 because enabled
                                @woehrer
                                Das ist WSL2 oder sowas?
                                  Das ist eine virtuelle Maschine in der Ubuntu 22 läuft
                                    virtuelle Maschine
                                    Welche?
                                      @woehrer selbiges ist auch hier
                                      https://forum.iobroker.net/post/914523
                                        @woehrer Admin 6.3.5 installieren!
                                          Karl 1 last edited by
                                          Bei mir ist ein ähnliches Problem aufgetreten wie bei bischemer am 14. März 2022 und bei offensichtlich mehreren anderen.
                                          Ich habe den RPI mit sudo shutdown -h 0 runtergefahren, die Stromversorgung abgeklemmt und mit Win32DiskImager die SD auf eine Backup Platte kopiert.
                                          Nach dem erneuten Einlegen der SD und Anlegen der Versorgungsspannung startet der RPI und auch der ioBroker, der Zugriff über das Web Interface und Vis ist nicht mehr möglich.
                                          Den gleichen Effekt hatte ich schon vor einigen Wochen, ich habe mich damit beholfen, dass ich mit einem früheren Backup alle zwischenzeitlichen Änderungen nachgezogen habe (was man einmal machen kann, was aber keine Dauerlösung ist).
                                          Da der Effekt m.E. entweder mit dem Shutdown oder dem Abklemmen der Versorgung zu tun hat, kann dieses Problem immer wieder auftauchen, sei es bei einem regulären Backup oder bei einem Spannungsausfall im Versorgungsnetz.
                                          Ich habe alles hier Geschriebene gelesen und nachvollzogen aber keine Lösung für mich gefunden!
                                          Angefügt einige Infos zu meinem Problem:
                                          pi@raspberrypi:~ $ iob info
                                          2023-01-02 19:09:42.694  - error: host.raspberrypi No connection to databases possible, restart
                                          2023-01-02 19:09:42.748  - info: host.raspberrypi iobroker _restart
                                          2023-01-02 19:09:48.841  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                                          2023-01-02 19:09:48.862  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                          2023-01-02 19:09:48.865  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
                                          2023-01-02 19:09:48.867  - info: host.raspberrypi ip addresses: 192.168.178.43 2003:ea:f10:b800:e3c1:cab5:4a9b:7a32 fe80::78fb:de3d:17ae:be62
                                          2023-01-02 19:10:18.939  - error: host.raspberrypi No connection to databases possible, restart
                                          ```pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -l
                                          insgesamt 529504
                                          drwxrwxrwx+   2 iobroker iobroker      4096 Mai  2  2022 backitup
                                          drwxrwxrwx+   2 iobroker iobroker      4096 Jan  2 09:26 backup-objects
                                          drwxrwxrwx+  21 iobroker iobroker      4096 Nov 26 11:59 files
                                          drwxrwxrwx+ 185 iobroker iobroker     12288 Jan  2 00:02 history
                                          -rw-rwxrw-+   1 iobroker iobroker      4715 Mai  2  2022 iobroker.json
                                          -rw-rw-rw-+   1 iobroker iobroker         3 Jan  2 11:11 notifications.json
                                          -rw-rw-rw-+   1 iobroker iobroker   3715730 Mai  2  2022 objects.json.bak.migrated
                                          -rw-rw-rw-+   1 iobroker iobroker 524134421 Jan  2 10:52 objects.jsonl
                                          drwxrwxrwx+   2 iobroker iobroker      4096 Jan  2 19:44 objects.jsonl.lock
                                          -rw-rw-rw-+   1 iobroker iobroker   3718224 Mai  2  2022 objects.json.migrated
                                          -rw-rw-rw-+   1 iobroker iobroker    442833 Mai  2  2022 states.json.bak.migrated
                                          -rw-rw-rw-+   1 iobroker iobroker   9691615 Jan  2 11:11 states.jsonl
                                          -rw-rw-rw-+   1 iobroker iobroker    442977 Mai  2  2022 states.json.migrated
                                            apollon77 @Karl 1 last edited by
                                            @karl-1 Dann fang doch mal mit "iob fix" an ... danach sollte deine objects.jsonl kleiner sein ... gehts dann besser?
                                            429
                                            82904
