    4. Gelöst - netatmo Adapter Version 1.1.5 läuft seit dem 10.08.17 nicht mehr
    • coyote
      coyote Most Active last edited by
      Gerade probiert, geht leider noch nicht.
      • integer63
        integer63 last edited by
        Bei mir genau das gleiche - gerade neu gestartet - geht nicht.
        • eric2905
          eric2905 last edited by
          Möglicherweise hat Netatmo was geändert, was zum Huster ab dem 08.08. geführt hat.
          Da muss dann ggf. der Adapter-Entwickler mal schauen.
          Gruß,
          Eric
          Von unterwegs getippert
            andyb last edited by
            Bei mir auch das gleiche.
            ! host.orangepiplus2e 2017-08-11 07:31:24.821 error instance system.adapter.netatmo.0 terminated with code 0 (OK)
            ! netatmo.0 2017-08-11 07:31:24.638 info terminating
            ! netatmo.0 2017-08-11 07:31:23.771 info cleaned everything up…
            ! netatmo.0 2017-08-11 07:31:23.767 error at IncomingMessage.g (events.js:292:16)
            ! netatmo.0 2017-08-11 07:31:23.767 error at IncomingMessage. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/request/request.js:1091:12)
            ! netatmo.0 2017-08-11 07:31:23.767 error at Request.emit (events.js:188:7)
            ! netatmo.0 2017-08-11 07:31:23.767 error at emitOne (events.js:96:13)
            ! netatmo.0 2017-08-11 07:31:23.767 error at Request. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/request/request.js:1171:10)
            ! netatmo.0 2017-08-11 07:31:23.767 error at Request.emit (events.js:191:7)
            ! netatmo.0 2017-08-11 07:31:23.767 error at emitTwo (events.js:106:13)
            ! netatmo.0 2017-08-11 07:31:23.767 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/request/request.js:188:22)
            ! netatmo.0 2017-08-11 07:31:23.767 error at netatmo. (/opt/iobroker/node_modules/iobroker.netatmo/netatmoLib.js:156:25)
            ! netatmo.0 2017-08-11 07:31:23.767 error at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/netatmoLib.js:46:17)
            ! netatmo.0 2017-08-11 07:31:23.767 error Error: Authenticate error: Status code503
            ! netatmo.0 2017-08-11 07:31:23.761 error uncaught exception: Authenticate error: Status code503
            ! netatmo.0 2017-08-11 07:31:23.288 info starting. Version 1.1.7 in /opt/iobroker/node_modules/iobroker.netatmo, node: v6.11.2
            Allerdings ist @PArt im Forum seit 01.07.2017 nicht mehr gesehen, ich weiss nicht wieviel Hoffnung man da haben kann…..
            Ich wollte im Trello eine Karte eröffnen, aber entweder bin ich nicht fähig dazu oder darf ich das nicht....
            Edit:
            https://api.netatmo.com/api/getstationsdata bringt:
            "We’ll be back soon!
            Sorry for the inconvenience but we’re performing some maintenance at the moment.
            — Netatmo"
            Edit2: FHEM, Openhab, IPS,.... in allen Foren ist Panik. Netatmo is halt doch recht verbreitet.
            • I
              Iobroker515 last edited by
              bei mir klappt es leider auch noch nicht. selbst mit der Version 1.20 auch nicht
              host.ioBroker-RasPi 2017-08-11 08:56:43.998 error instance system.adapter.netatmo.0 terminated with code 0 (OK)
              netatmo.0 2017-08-11 08:56:43.941 info cleaned everything up…
              netatmo.0 2017-08-11 08:56:43.940 error Error: Authenticate error: Status code503 at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/netatmoLib.js:46:17) at netatmo. (/opt/iobroker/node_modules/iob
              netatmo.0 2017-08-11 08:56:43.937 error uncaught exception: Authenticate error: Status code503
              netatmo.0 2017-08-11 08:56:43.727 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v6.11.2
              host.ioBroker-RasPi 2017-08-11 08:56:39.366 info instance system.adapter.netatmo.0 started with pid 13818
              host.ioBroker-RasPi 2017-08-11 08:56:09.351 info Restart adapter system.adapter.netatmo.0 because enabled
              host.ioBroker-RasPi 2017-08-11 08:56:09.350 error instance system.adapter.netatmo.0 terminated with code 0 (OK)
              netatmo.0 2017-08-11 08:56:09.297 info terminating
              netatmo.0 2017-08-11 08:56:09.276 info cleaned everything up...
              netatmo.0 2017-08-11 08:56:09.273 error at IncomingMessage.g (events.js:292:16)
              netatmo.0 2017-08-11 08:56:09.273 error at IncomingMessage. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/request/request.js:1091:12)
              netatmo.0 2017-08-11 08:56:09.273 error at Request.emit (events.js:188:7)
              netatmo.0 2017-08-11 08:56:09.273 error at emitOne (events.js:96:13)
              netatmo.0 2017-08-11 08:56:09.273 error at Request. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/request/request.js:1171:10)
              netatmo.0 2017-08-11 08:56:09.273 error at Request.emit (events.js:191:7)
              netatmo.0 2017-08-11 08:56:09.273 error at emitTwo (events.js:106:13)
              netatmo.0 2017-08-11 08:56:09.273 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/request/request.js:188:22)
              netatmo.0 2017-08-11 08:56:09.273 error at netatmo. (/opt/iobroker/node_modules/iobroker.netatmo/netatmoLib.js:156:25)
              netatmo.0 2017-08-11 08:56:09.273 error at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/netatmoLib.js:46:17)
              netatmo.0 2017-08-11 08:56:09.273 error Error: Authenticate error: Status code503
              netatmo.0 2017-08-11 08:56:09.268 error uncaught exception: Authenticate error: Status code503
              netatmo.0 2017-08-11 08:56:08.747 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v6.11.2
              host.ioBroker-RasPi 2017-08-11 08:56:04.786 info instance system.adapter.netatmo.0 started with pid 13808
              Und das wo ich mein Netatmo Sortiment noch um den Regensensor ergänzt habe 😞
              Auf der Seite des Entwicklers Patrick Arns gibt es leider auch keine weiteren Infos darüber.
              • eric2905
                Schau mal bitte im „Edit“ ein Posting über Deinem.
                Da steht die entsprechende Info, das es bei Netatmo selber klemmt.
                Gruß,
                Eric
                • I
                  Hi Eric,
                  oh, das hatte ich gerade übersehen.
                  Hoffentlich läuft es bald wieder.
                  Dann können wir ja leider nur abwarten und für meinen Urlaub muss ich mein Bewässerungs Programm dann noch mal ändern ;-(
                  VG
                  • I
                    Es läuft wieder 🙂
                    ich war bis gerade unterwegs und wollte jetzt noch einmal nach schauen und jetzt klappt es wieder:
                    Und das sogar mit der Version 1.1.5 (ich hatte heute morgen nämlich ein altes Backup eingespielt)
                    Hoffentlich bleibt es jetzt so…
                      Jo, bei mir geht auch alles wieder….
                      Machst du netterweise ein [gelöst] in den Betreff
                      • I
                        seit dem 11.08.2017 - 15:20 Uhr läuft der Adapter wieder 🙂
                          eXTreMe last edited by
                          netatmo hatte letzte woche schon mal API probleme. da hatte ich bei netatmo per facebook message nachgefragt und die haben es bestätigt.
                          wo der fehler liegt (also ob iobroker oder ob netatmo) kann man am einfachsten testen indem man sich bei einem anderen dienst welcher mit netatmo verknüpfbar ist mal versucht (neu) einzuloggen bzw die verknüpfung herzustellen.
                          ich mach das ganz gerne bei IFTTT da ich keine applets für netatmo mit IFTT am laufen hab. bisher war es jedes mal so dass der api login für die netatmo kontoverknüpfung nicht geladen hat oder eine fehlermeldung vom webserver kam. demnach war klar dass der fehler nicht am iobroker adapter sondern an der netatmo api liegen muss.
                          schade dass sich die geräte nur über die api und nicht lokal im heimnetz abfragen lassen…
                            Brauchst keinen anderen Dienst, im Browser ein
                            reicht.
                            1652
