    3. Einsteigerfragen
    4. Was bedeutet = Cannot check node.js versions...
      muuulle @Thomas Braun last edited by
      Moin,
      ich habe die gleiche Fehlermeldung:
      Kein Docker
      /usr/bin/nodejs
      /home/pi/.nvm/versions/node/v14.19.3/bin/node
      /home/pi/.nvm/versions/node/v14.19.3/bin/npm
      v16.19.0
      v14.19.3
      9.2.0
      4.0.23
      pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev i2c gpio spi iobroker
      tty
      /home/pi
      OK:1 http://phoscon.de/apt/deconz buster-beta InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:3 http://archive.raspberrypi.org/debian buster InRelease
      OK:4 https://deb.nodesource.com/node_16.x buster InRelease
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           16.19.0-deb-1nodesource1
        Installationskandidat: 16.19.0-deb-1nodesource1
        Versionstabelle:
       *** 16.19.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
        Thomas Braun Most Active @muuulle last edited by Thomas Braun
        @muuulle
        Joh, nodejs falsch installiert.
        Lasst die Finger von nvm.
        Und Buster ist tot, installiert da ein Bullseye-Release.
        • RoddiEF
          RoddiEF last edited by
          Bei mir dasselbe: "Cannot check node.js versions: Error: unexpected end of file"
          x86_64
          Docker-Installation
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.19.0
          v16.19.0
          8.19.3
          4.0.23
          root
          root
          /opt/iobroker
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
          Hit:3 http://deb.debian.org/debian-security bullseye-security InRelease
          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
          Reading package lists... Done
          Building dependency tree... Done
          1 package can be upgraded. Run 'apt list --upgradable' to see it.
          nodejs:
            Installed: 16.19.0-deb-1nodesource1
            Candidate: 16.19.0-deb-1nodesource1
            Version table:
                  500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u1 500
                  500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
               12.22.5~dfsg-2~11u1 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
          Wie man sehen kann, ist es eine Dockerinstallation. Ist die aktuelle von buanet die einen Angeboten wird wenn man ioBroker installiert. Das Problem scheint ja bekannt zu sein aber eine Lösung wohl nicht in Sicht oder täusche ich mich?
          Fabio 1 Reply Last reply Reply Quote 0
          • Fabio
            Fabio @RoddiEF last edited by
            @roddief es gab ein Admin Update auf 6.3.5 https://github.com/ioBroker/ioBroker.admin/releases/tag/v6.3.5
            RoddiEF 1 Reply Last reply Reply Quote 0
            • RoddiEF
              RoddiEF @Fabio last edited by RoddiEF
              @fa-bio sagte in Was bedeutet = Cannot check node.js versions...:
              Das mag sein, aber es soll Menschen geben die sich nicht bis in die Tiefen der Bits und Byte im ioBroker auskennen.
              Einer davon bin ich. Ich habe schon 2 Tage gebraucht um die Shelly-Adapter zum laufen zu bekommen und das nur weil ich mal Testweise von Bridge auf Host umgestellt habe. Und schon wurden die Adapter grün. Da muss man auch erstmal drauf kommen 😞
              Ich versuche immer erst ein Problem selber zu lösen, Frage erst wenn meine Möglichkeiten (sei es durch Tante Google oder hier im Forum durch Lesen der Beiträge) erschöpft sind und ich nicht weiterkomme.
              Aber zurück zu dem hier Aufgeführten Problem:
              Wenn mir Updates im ioB angeboten werden dann Update ich schon wenn möglich. Wird mir kein Update angeboten dann sieht es für mich so aus das es nichts zu Updaten gibt.
              Edit:
              Hat sich Dank eines anderen Beitrags hier im Forum erledigt. Adapter ist auf aktueller Version. Mal schauen ob der Fehler noch Auftritt.
                Danke für deine Hinweise. Bullseye ist installiert, bei der Abkehr von NVM bräuchte ich Unterstützung. Wenn du sagst, halb so dramatisch, das System läuft ja - dann würde ich es so belassen 😉
                …ansonsten wäre ich sehr froh (und angewiesen) über ein paar Zeilen Terminal Code 🙂
                T Thomas Braun 2 Replies Last reply Reply Quote 0
                  TT-Tom @muuulle last edited by
                  @muuulle thomas hat in seiner Signatur den link für nodeJS dort ist alles beschrieben
                    @muuulle sagte in Was bedeutet = Cannot check node.js versions...:
                    Nein, musst du anpacken.
                      Ist so besser?
                      Kein Docker
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.19.0
                      v16.19.0
                      8.19.3
                      4.0.23
                      pi
                      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                      tty
                      /home/pi
                      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                      All packages are up to date.
                      nodejs:
                        Version table:
                              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                        @muuulle
                        Ja, jetzt ist es richtig aufgesetzt.
                        Updates/Upgrades jetzt nur noch per Paketmanager.
                        32
                        2777
