    3. Einsteigerfragen
    4. IOBroker + Zigbee 3.0 USB Dongle Plus
      hpgo last edited by
      wie beschrieben habe ich mir einen neuen IOBroker Docker Container erstellt und den Zigbee Adapter installiert.
      Konfiguriert habe ich alles so wie in dem Video hier
      Bei mir werden allerdings unter Instanzen nicht die drei Hacken grün siehe Bildiobroker instanz.png
      Mit iobroker logs --watch ekomme ich den log
      root@RPi4:/opt/iobroker# iobroker logs --watch
      2022-12-23 20:59:35.766  - info: admin.0 (733) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2022-12-23 20:59:35.918  - error: zigbee.0 (31060) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2022-12-23 20:59:56.898  - info: host.RPi4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2022-12-23 20:59:56.909  - info: zigbee.0 (31060) Got terminate signal TERMINATE_YOURSELF
      2022-12-23 20:59:56.910  - info: host.RPi4 stopInstance system.adapter.zigbee.0 send kill signal
      2022-12-23 20:59:57.032  - info: admin.0 (733) <== Disconnect system.user.admin from ::ffff:192.168.178.32
      2022-12-23 20:59:56.913  - info: zigbee.0 (31060) cleaned everything up...
      2022-12-23 20:59:56.922  - info: zigbee.0 (31060) Zigbee: disabling joining new devices.
      2022-12-23 20:59:57.052  - warn: zigbee.0 (31060) Failed to stop zigbee during startup
      2022-12-23 20:59:57.053  - info: zigbee.0 (31060) terminating
      2022-12-23 20:59:57.054  - info: zigbee.0 (31060) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-12-23 20:59:57.609  - info: host.RPi4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-12-23 20:59:59.977  - info: host.RPi4 instance system.adapter.zigbee.0 started with pid 31113
      2022-12-23 21:00:04.251  - info: zigbee.0 (31113) starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.23
      2022-12-23 21:00:04.387  - info: zigbee.0 (31113) Starting Zigbee  npm ...
      2022-12-23 21:00:04.711  - error: zigbee.0 (31113) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
      2022-12-23 21:00:04.712  - error: zigbee.0 (31113) Failed to start Zigbee
      2022-12-23 21:00:04.713  - error: zigbee.0 (31113) Error herdsman start
      2022-12-23 21:00:04.902  - info: zigbee.0 (31113) Installed Version: iobroker.zigbee@1.7.6
      2022-12-23 21:00:14.718  - info: zigbee.0 (31113) Try to reconnect. 1 attempts left
      2022-12-23 21:00:14.720  - info: zigbee.0 (31113) Starting Zigbee  npm ...
      2022-12-23 21:00:14.739  - error: zigbee.0 (31113) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
      2022-12-23 21:00:14.742  - error: zigbee.0 (31113) Failed to start Zigbee
      2022-12-23 21:00:14.743  - error: zigbee.0 (31113) Error herdsman start
      2022-12-23 21:00:14.767  - info: zigbee.0 (31113) Installed Version: iobroker.zigbee@1.7.6
      2022-12-23 21:22:08.531  - info: admin.0 (733) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2022-12-23 21:22:08.725  - error: zigbee.0 (31113) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2022-12-23 21:22:22.343  - info: host.RPi4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2022-12-23 21:22:22.352  - info: host.RPi4 stopInstance system.adapter.zigbee.0 send kill signal
      2022-12-23 21:22:22.351  - info: zigbee.0 (31113) Got terminate signal TERMINATE_YOURSELF
      2022-12-23 21:22:22.476  - info: admin.0 (733) <== Disconnect system.user.admin from ::ffff:192.168.178.32
      2022-12-23 21:22:22.355  - info: zigbee.0 (31113) cleaned everything up...
      2022-12-23 21:22:22.362  - info: zigbee.0 (31113) Zigbee: disabling joining new devices.
      2022-12-23 21:22:22.515  - warn: zigbee.0 (31113) Failed to stop zigbee during startup
      2022-12-23 21:22:22.516  - info: zigbee.0 (31113) terminating
      2022-12-23 21:22:22.517  - info: zigbee.0 (31113) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-12-23 21:22:23.064  - info: host.RPi4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-12-23 21:22:25.398  - info: host.RPi4 instance system.adapter.zigbee.0 started with pid 32196
      2022-12-23 21:22:29.533  - info: zigbee.0 (32196) starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.23
      2022-12-23 21:22:29.711  - info: zigbee.0 (32196) Starting Zigbee  npm ...
      2022-12-23 21:22:30.060  - error: zigbee.0 (32196) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
      2022-12-23 21:22:30.061  - error: zigbee.0 (32196) Failed to start Zigbee
      2022-12-23 21:22:30.062  - error: zigbee.0 (32196) Error herdsman start
      2022-12-23 21:22:30.257  - info: zigbee.0 (32196) Installed Version: iobroker.zigbee@1.7.6
      2022-12-23 21:22:40.067  - info: zigbee.0 (32196) Try to reconnect. 1 attempts left
      2022-12-23 21:22:40.068  - info: zigbee.0 (32196) Starting Zigbee  npm ...
      2022-12-23 21:22:40.085  - error: zigbee.0 (32196) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
      2022-12-23 21:22:40.088  - error: zigbee.0 (32196) Failed to start Zigbee
      2022-12-23 21:22:40.090  - error: zigbee.0 (32196) Error herdsman start
      2022-12-23 21:22:40.140  - info: zigbee.0 (32196) Installed Version: iobroker.zigbee@1.7.6
      Würde mich freuen, wenn mir jemand weiterhelfen kann.
      Lg
      Thomas Braun T Glasfaser O 5 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @hpgo last edited by
        @hpgo sagte in IOBroker + Zigbee 3.0 USB Dongle Plus:
        root@RPi4
        User anlegen und damit durch das System hoppeln.
          TT-Tom @hpgo last edited by
          kann sein, dass dort das Hochkomma am Ende falsch ist.
          • Glasfaser
            Glasfaser @hpgo last edited by
            Docker Container
            Standard Frage :
            Stick zum Container durchgereicht !?
              @hpgo
              Wenn der Stick durchgereicht wurde:
              ls -lA /dev/serial/by-id/
              anschauen.
              • O
                ObiTobi @hpgo last edited by
                @hpgo said in IOBroker + Zigbee 3.0 USB Dongle Plus:
                Und wie hast Du ihn gebaut? (Parameter)
                  hpgo @Glasfaser last edited by hpgo
                  @glasfaser
                  tja gute Frage, wäre nie darauf gekommen das zu kontrollieren - muss mal schauen wie das geht.
                  Danke, hilft mir schon mal weiter
                  Edit: hab das hier gefunden und werde es morgen durchackern - heute bin, eich einfach viel zu müde.
                  Nochmals danke, melde mich morgen, wenn ich darf.
