    3. Off Topic
    4. Proxmox
    5. Brauche Hilfe bei proxmox v6 zu v7
      @feuersturm
      pveversion --verbose
      • Feuersturm
        Feuersturm @crunchip last edited by
        @crunchip sagte in Brauche Hilfe bei proxmox v6 zu v7:
        root@pve:/var/lib/lxcfs# pveversion --verbose
        proxmox-ve: not correctly installed (running kernel: 5.4.203-1-pve)
        pve-manager: not correctly installed (running version: 7.3-4/d69b70d4)
        pve-kernel-5.4: 6.4-20
        pve-kernel-5.3: 6.1-6
        pve-kernel-5.4.203-1-pve: 5.4.203-1
        pve-kernel-5.4.195-1-pve: 5.4.195-1
        pve-kernel-5.4.189-2-pve: 5.4.189-2
        pve-kernel-5.4.143-1-pve: 5.4.143-1
        pve-kernel-5.4.140-1-pve: 5.4.140-1
        pve-kernel-5.4.106-1-pve: 5.4.106-1
        pve-kernel-5.3.18-3-pve: 5.3.18-3
        pve-kernel-5.3.18-2-pve: 5.3.18-2
        pve-kernel-5.3.10-1-pve: 5.3.10-1
        ceph-fuse: not correctly installed
        corosync: not correctly installed
        criu: not correctly installed
        glusterfs-client: not correctly installed
        ifupdown: not correctly installed
        ksm-control-daemon: not correctly installed
        libjs-extjs: not correctly installed
        libknet1: not correctly installed
        libproxmox-acme-perl: not correctly installed
        libproxmox-backup-qemu0: not correctly installed
        libpve-access-control: not correctly installed
        libpve-apiclient-perl: not correctly installed
        libpve-common-perl: not correctly installed
        libpve-guest-common-perl: not correctly installed
        libpve-http-server-perl: not correctly installed
        libpve-storage-perl: not correctly installed
        libqb0: 1.0.5-1
        libspice-server1: not correctly installed
        lvm2: not correctly installed
        lxc-pve: not correctly installed
        lxcfs: not correctly installed
        novnc-pve: not correctly installed
        proxmox-backup-client: not correctly installed
        proxmox-backup-file-restore: not correctly installed
        proxmox-mini-journalreader: not correctly installed
        proxmox-offline-mirror-helper: not correctly installed
        proxmox-widget-toolkit: not correctly installed
        pve-cluster: not correctly installed
        pve-container: not correctly installed
        pve-docs: not correctly installed
        pve-edk2-firmware: not correctly installed
        pve-firewall: not correctly installed
        pve-firmware: not correctly installed
        pve-ha-manager: not correctly installed
        pve-i18n: not correctly installed
        pve-qemu-kvm: not correctly installed
        pve-xtermjs: not correctly installed
        qemu-server: not correctly installed
        smartmontools: not correctly installed
        spiceterm: not correctly installed
        swtpm: not correctly installed
        vncterm: not correctly installed
        zfsutils-linux: not correctly installed
          crunchip Forum Testing Most Active @Feuersturm last edited by
          @feuersturm da ist es wohl unvollständig
          bekommst du mit einem update nicht etwas neueres als 6.4-20
          @crunkfx sagte in Brauche Hilfe bei proxmox v6 zu v7:
          Ich habe die Erfahrung gemacht, dass ein Update von 6 auf 7 nur erfolgen soll wenn mindestens 6.7 installiert ist. Wenn du also ne ältere Version hast, erst Kernel updaten
          • Feuersturm
            @crunchip Ich hatte vor dem Update von 6 auf 7 proxmox über das Webinterface aktualisiert und was neueres als die 6.4 wurde mir nicht angeboten.
            Was wäre denn jetzt der nächste Schritt? Kernel update? Oder ein
            apt -f install
            (aus Failing upgrade to "bullseye" https://pve.proxmox.com/wiki/Upgrade_from_6.x_to_7.0)?
              @feuersturm sagte in Brauche Hilfe bei proxmox v6 zu v7:
              was haste denn in der sources.list stehen?
              • Feuersturm
                Feuersturm @crunchip last edited by Feuersturm
                @crunchip
                root@pve:/etc/apt# cat sources.list
                deb http://ftp.de.debian.org/debian bullseye main contrib
                deb http://ftp.de.debian.org/debian bullseye-updates main contrib
                # security updates
                #deb http://security.debian.org/debian-security/ bullseye-security main contrib
                deb http://deb.debian.org/debian-security/ bullseye-security main contrib
                und
                root@pve:/etc/apt/sources.list.d# ls
                pve-enterprise.list  pve-enterprise.list.dpkg-new  pve-no-subscription.list
                root@pve:/etc/apt/sources.list.d# cat pve-no-subscription.list
                # PVE pve-no-subscription repository provided by proxmox.com,
                # NOT recommended for production use
                deb http://download.proxmox.com/debian/pve bullseye pve-no-subscription
                # security updates
                #deb http://security.debian.org/debian-security bullseye/updates main contrib
                  @feuersturm klatch doch mal die non-free mit in die sources.list, ob dann was neues kommt
                  #non-free
                  deb http://deb.debian.org/debian bullseye main contrib non-free
                  deb-src http://deb.debian.org/debian bullseye main contrib non-free
                  deb http://deb.debian.org/debian-security/ bullseye-security main contrib non-free
                  deb-src http://deb.debian.org/debian-security/ bullseye-security main contrib non-free
                  deb http://deb.debian.org/debian bullseye-updates main contrib non-free
                  deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
                  • Feuersturm
                    @crunchip non-free hinzugefügt und Neustart vom Server gemacht
                    Leider keine Besserung
                    root@pve:~# cat /etc/apt/sources.list
                    deb http://ftp.de.debian.org/debian bullseye main contrib non-free
                    deb http://ftp.de.debian.org/debian bullseye-updates main contrib non-free
                    # security updates
                    root@pve:~# apt update
                    Hit:1 http://download.proxmox.com/debian/pve bullseye InRelease
                    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                    Hit:3 http://ftp.de.debian.org/debian bullseye InRelease
                    Hit:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
                    Reading package lists... Done
                    Building dependency tree... Done
                    All packages are up to date.
                      @feuersturm ähm warte mal, da steht ja schon bullseye drin.
                      eigentlich müsste es ja noch buster lauten, vor dem upgrade auf v7
                      • Feuersturm
                        @crunchip Vorher war alles auf Buster (proxmox war auf 6.4.x). Hab dann nach dieser Anleitung https://pve.proxmox.com/wiki/Upgrade_from_6.x_to_7.0 die sources auf bullseye umgestellt und das apt dist-upgrade dann gestartet. Dabei ist er dann bei den oben genannten 58% stehen geblieben. Als ich dann den Server an den Monitor angeschlossen habe ist er wie oben beschrieben hier stehen geblieben
                        Loading Linux 5.15.83-1-pve ...
                          @feuersturm ja das hab ich schon verstanden. ich war/bin nur gerade etwas irritiert, weil es ja nicht durchlief., dachte ich das eventuell buster noch drin steht.
                          oder du probierst es mit
                          apt -f install
                          aber wie gesagt, ich weiss nicht ob der kernel das Problem ist, bin da leider auch nicht so fit drin
                          ich hatte erst vor 3 Tage ein upgrade gemacht, daher bin ich aktuell bei 5.15.74-1, ein erneutes upgrade auf den 5.15.83-1 steh bei mir noch aus
                          • Feuersturm
                            @crunchip
                            Bevor ich apt -f install aufrufen konnte sagte das System, dass ich dpkg --configure -a aufrufen muss. Dies ist dann einmal durchgelaufen und das System ist danach auch wieder sauber mit dem Kernel 5.15.83-1 gestartet 🙂
                            Ich hab dann noch einmal ein apt -f install aufgerufen welches auch durchgelaufen ist.
                            Es scheint jetzt besser zu sein. Die Ausgabe von pveversion sieht jetzt auch anders aus als vorher.
                            Danke für deine Hilfe @crunchip
                            Linux pve 5.15.83-1-pve #1 SMP PVE 5.15.83-1 (2022-12-15T00:00Z) x86_64
                            The programs included with the Debian GNU/Linux system are free software;
                            the exact distribution terms for each program are described in the
                            individual files in /usr/share/doc/*/copyright.
                            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                            permitted by applicable law.
                            Last login: Sat Dec 24 01:20:39 2022
                            root@pve:~# pveversion --verbose
                            proxmox-ve: 7.3-1 (running kernel: 5.15.83-1-pve)
                            pve-manager: 7.3-4 (running version: 7.3-4/d69b70d4)
                            pve-kernel-5.15: 7.3-1
                            pve-kernel-helper: 7.3-1
                            pve-kernel-5.15.83-1-pve: 5.15.83-1
                            ceph-fuse: 14.2.21-1
                            corosync: 3.1.7-pve1
                            criu: 3.15-1+pve-1
                            glusterfs-client: 9.2-1
                            ifupdown: 0.8.36+pve2
                            ksm-control-daemon: 1.4-1
                            libjs-extjs: 7.0.0-1
                            libknet1: 1.24-pve2
                            libproxmox-acme-perl: 1.4.3
                            libproxmox-backup-qemu0: 1.3.1-1
                            libpve-access-control: 7.3-1
                            libpve-apiclient-perl: 3.2-1
                            libpve-common-perl: 7.3-1
                            libpve-guest-common-perl: 4.2-3
                            libpve-http-server-perl: 4.1-5
                            libpve-storage-perl: 7.3-1
                            libqb0: 1.0.5-1
                            libspice-server1: 0.14.3-2.1
                            lvm2: 2.03.11-2.1
                            lxc-pve: 5.0.0-3
                            lxcfs: 4.0.12-pve1
                            novnc-pve: 1.3.0-3
                            proxmox-backup-client: 2.3.1-1
                            proxmox-backup-file-restore: 2.3.1-1
                            proxmox-mini-journalreader: 1.3-1
                            proxmox-offline-mirror-helper: 0.5.0-1
                            proxmox-widget-toolkit: 3.5.3
                            pve-cluster: 7.3-1
                            pve-container: 4.4-2
                            pve-docs: 7.3-1
                            pve-edk2-firmware: 3.20220526-1
                            pve-firewall: 4.2-7
                            pve-firmware: 3.6-2
                            pve-ha-manager: 3.5.1
                            pve-i18n: 2.8-1
                            pve-qemu-kvm: 7.1.0-4
                            pve-xtermjs: 4.16.0-1
                            qemu-server: 7.3-2
                            smartmontools: 7.2-pve3
                            spiceterm: 3.2-2
                            swtpm: 0.8.0~bpo11+2
                            vncterm: 1.7-1
                            zfsutils-linux: 2.1.7-pve1
                            crunchip S D 3 Replies Last reply Reply Quote 0
                              @feuersturm sieht gut aus, nochmal Glück gehabt👍
                                saeft_2003 Most Active @Feuersturm last edited by
                                @feuersturm
                                Hast du einen lxc (vielleicht sogar wireguard) laufen?
                                  darkiop Most Active @Feuersturm last edited by
                                  @feuersturm Schieb zur Sicherheit nochmal ein
                                  apt dist-upgrade
                                  hinterher.
                                  • Feuersturm
                                    Feuersturm @saeft_2003 last edited by
                                    @saeft_2003 sagte in Brauche Hilfe bei proxmox v6 zu v7:
                                    @feuersturm
                                    Nein wireguard hab ich nicht im Einsatz
                                    • Feuersturm
                                      Feuersturm @darkiop last edited by
                                      @darkiop sagte in Brauche Hilfe bei proxmox v6 zu v7:
                                      apt dist-upgrade
                                      hinterher.
                                      Mach ich.
                                        @feuersturm
                                        Und einen anderen lxc oder nur VMs?
                                        • Feuersturm
                                          Feuersturm @saeft_2003 last edited by Feuersturm
                                          Container und VMs sind gemischt. Primär sind es LXCs und eine VM, wenn ich mich richtig erinnere.
                                          Siehst du einen Zusammenhang zu meinem Problem?
                                            @feuersturm
                                            Bei mir wurde auch das eingezeigt und dann nichts mehr…
                                            Während dem Update gab es folgenden Fehler, dass ist bei mir der einzigste lxc den ich habe. Kann natürlich auch Zufall sein. Bin echt kein linux profi…
                                            usr/sbin/grub-probe: error: disk `lvmid/d6vUe1-VmEL-SEgR-sIoS-IGLg-l441-4JTJ9F/UxkIqX-7fZT-iWgh-YcIu-0Qfh-Rnfd-GXLmxI' not found.
                                            Found Ubuntu 21.04 (21.04) on /dev/mapper/pve-vm--1500--disk--0
                                            Adding boot menu entry for UEFI Firmware Settings ...
                                            done
                                            9469
