    3. Off Topic
    4. Proxmox
    5. Brauche Hilfe bei proxmox v6 zu v7
      crunchip Forum Testing Most Active @Feuersturm last edited by
      @feuersturm sagte in Brauche Hilfe bei proxmox v6 zu v7:
      was neueres als die 6.4 wurde mir nicht angeboten.
      was haste denn in der sources.list stehen?
      • Feuersturm
        Feuersturm @crunchip last edited by Feuersturm
        @crunchip
        root@pve:/etc/apt# cat sources.list
        deb http://ftp.de.debian.org/debian bullseye main contrib
        deb http://ftp.de.debian.org/debian bullseye-updates main contrib
        # security updates
        #deb http://security.debian.org/debian-security/ bullseye-security main contrib
        deb http://deb.debian.org/debian-security/ bullseye-security main contrib
        und
        root@pve:/etc/apt/sources.list.d# ls
        pve-enterprise.list  pve-enterprise.list.dpkg-new  pve-no-subscription.list
        root@pve:/etc/apt/sources.list.d# cat pve-no-subscription.list
        # PVE pve-no-subscription repository provided by proxmox.com,
        # NOT recommended for production use
        deb http://download.proxmox.com/debian/pve bullseye pve-no-subscription
        # security updates
        #deb http://security.debian.org/debian-security bullseye/updates main contrib
          @feuersturm klatch doch mal die non-free mit in die sources.list, ob dann was neues kommt
          #non-free
          deb http://deb.debian.org/debian bullseye main contrib non-free
          deb-src http://deb.debian.org/debian bullseye main contrib non-free
          deb http://deb.debian.org/debian-security/ bullseye-security main contrib non-free
          deb-src http://deb.debian.org/debian-security/ bullseye-security main contrib non-free
          deb http://deb.debian.org/debian bullseye-updates main contrib non-free
          deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
          • Feuersturm
            @crunchip non-free hinzugefügt und Neustart vom Server gemacht
            Leider keine Besserung
            root@pve:~# cat /etc/apt/sources.list
            deb http://ftp.de.debian.org/debian bullseye main contrib non-free
            deb http://ftp.de.debian.org/debian bullseye-updates main contrib non-free
            # security updates
            root@pve:~# apt update
            Hit:1 http://download.proxmox.com/debian/pve bullseye InRelease
            Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
            Hit:3 http://ftp.de.debian.org/debian bullseye InRelease
            Hit:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
            Reading package lists... Done
            Building dependency tree... Done
            All packages are up to date.
              @feuersturm ähm warte mal, da steht ja schon bullseye drin.
              eigentlich müsste es ja noch buster lauten, vor dem upgrade auf v7
              • Feuersturm
                @crunchip Vorher war alles auf Buster (proxmox war auf 6.4.x). Hab dann nach dieser Anleitung https://pve.proxmox.com/wiki/Upgrade_from_6.x_to_7.0 die sources auf bullseye umgestellt und das apt dist-upgrade dann gestartet. Dabei ist er dann bei den oben genannten 58% stehen geblieben. Als ich dann den Server an den Monitor angeschlossen habe ist er wie oben beschrieben hier stehen geblieben
                Loading Linux 5.15.83-1-pve ...
                  @feuersturm ja das hab ich schon verstanden. ich war/bin nur gerade etwas irritiert, weil es ja nicht durchlief., dachte ich das eventuell buster noch drin steht.
                  oder du probierst es mit
                  apt -f install
                  aber wie gesagt, ich weiss nicht ob der kernel das Problem ist, bin da leider auch nicht so fit drin
                  ich hatte erst vor 3 Tage ein upgrade gemacht, daher bin ich aktuell bei 5.15.74-1, ein erneutes upgrade auf den 5.15.83-1 steh bei mir noch aus
                  • Feuersturm
                    @crunchip
                    Bevor ich apt -f install aufrufen konnte sagte das System, dass ich dpkg --configure -a aufrufen muss. Dies ist dann einmal durchgelaufen und das System ist danach auch wieder sauber mit dem Kernel 5.15.83-1 gestartet 🙂
                    Ich hab dann noch einmal ein apt -f install aufgerufen welches auch durchgelaufen ist.
                    Es scheint jetzt besser zu sein. Die Ausgabe von pveversion sieht jetzt auch anders aus als vorher.
                    Danke für deine Hilfe @crunchip
                    Linux pve 5.15.83-1-pve #1 SMP PVE 5.15.83-1 (2022-12-15T00:00Z) x86_64
                    The programs included with the Debian GNU/Linux system are free software;
                    the exact distribution terms for each program are described in the
                    individual files in /usr/share/doc/*/copyright.
                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                    permitted by applicable law.
                    Last login: Sat Dec 24 01:20:39 2022
                    root@pve:~# pveversion --verbose
                    proxmox-ve: 7.3-1 (running kernel: 5.15.83-1-pve)
                    pve-manager: 7.3-4 (running version: 7.3-4/d69b70d4)
                    pve-kernel-5.15: 7.3-1
                    pve-kernel-helper: 7.3-1
                    pve-kernel-5.4: 6.4-20
                    pve-kernel-5.3: 6.1-6
                    pve-kernel-5.15.83-1-pve: 5.15.83-1
                    pve-kernel-5.4.203-1-pve: 5.4.203-1
                    pve-kernel-5.4.195-1-pve: 5.4.195-1
                    pve-kernel-5.4.189-2-pve: 5.4.189-2
                    pve-kernel-5.4.143-1-pve: 5.4.143-1
                    pve-kernel-5.4.140-1-pve: 5.4.140-1
                    pve-kernel-5.4.106-1-pve: 5.4.106-1
                    pve-kernel-5.3.18-3-pve: 5.3.18-3
                    pve-kernel-5.3.18-2-pve: 5.3.18-2
                    pve-kernel-5.3.10-1-pve: 5.3.10-1
                    ceph-fuse: 14.2.21-1
                    corosync: 3.1.7-pve1
                    criu: 3.15-1+pve-1
                    glusterfs-client: 9.2-1
                    ifupdown: 0.8.36+pve2
                    ksm-control-daemon: 1.4-1
                    libjs-extjs: 7.0.0-1
                    libknet1: 1.24-pve2
                    libproxmox-acme-perl: 1.4.3
                    libproxmox-backup-qemu0: 1.3.1-1
                    libpve-access-control: 7.3-1
                    libpve-apiclient-perl: 3.2-1
                    libpve-common-perl: 7.3-1
                    libpve-guest-common-perl: 4.2-3
                    libpve-http-server-perl: 4.1-5
                    libpve-storage-perl: 7.3-1
                    libqb0: 1.0.5-1
                    libspice-server1: 0.14.3-2.1
                    lvm2: 2.03.11-2.1
                    lxc-pve: 5.0.0-3
                    lxcfs: 4.0.12-pve1
                    novnc-pve: 1.3.0-3
                    proxmox-backup-client: 2.3.1-1
                    proxmox-backup-file-restore: 2.3.1-1
                    proxmox-mini-journalreader: 1.3-1
                    proxmox-offline-mirror-helper: 0.5.0-1
                    proxmox-widget-toolkit: 3.5.3
                    pve-cluster: 7.3-1
                    pve-container: 4.4-2
                    pve-docs: 7.3-1
                    pve-edk2-firmware: 3.20220526-1
                    pve-firewall: 4.2-7
                    pve-firmware: 3.6-2
                    pve-ha-manager: 3.5.1
                    pve-i18n: 2.8-1
                    pve-qemu-kvm: 7.1.0-4
                    pve-xtermjs: 4.16.0-1
                    qemu-server: 7.3-2
                    smartmontools: 7.2-pve3
                    spiceterm: 3.2-2
                    swtpm: 0.8.0~bpo11+2
                    vncterm: 1.7-1
                    zfsutils-linux: 2.1.7-pve1
                    crunchip S D 3 Replies Last reply Reply Quote 0
                      @feuersturm sieht gut aus, nochmal Glück gehabt👍
                        saeft_2003 Most Active @Feuersturm last edited by
                        @feuersturm
                        Hast du einen lxc (vielleicht sogar wireguard) laufen?
                          darkiop Most Active @Feuersturm last edited by
                          @feuersturm Schieb zur Sicherheit nochmal ein
                          apt dist-upgrade
                          hinterher.
                          • Feuersturm
                            Feuersturm @saeft_2003 last edited by
                            @saeft_2003 sagte in Brauche Hilfe bei proxmox v6 zu v7:
                            @feuersturm
                            Nein wireguard hab ich nicht im Einsatz
                            • Feuersturm
                              Feuersturm @darkiop last edited by
                              @darkiop sagte in Brauche Hilfe bei proxmox v6 zu v7:
                              apt dist-upgrade
                              hinterher.
                              Mach ich.
                                @feuersturm
                                Und einen anderen lxc oder nur VMs?
                                • Feuersturm
                                  Feuersturm @saeft_2003 last edited by Feuersturm
                                  Container und VMs sind gemischt. Primär sind es LXCs und eine VM, wenn ich mich richtig erinnere.
                                  Siehst du einen Zusammenhang zu meinem Problem?
                                    @feuersturm
                                    Bei mir wurde auch das eingezeigt und dann nichts mehr…
                                    Während dem Update gab es folgenden Fehler, dass ist bei mir der einzigste lxc den ich habe. Kann natürlich auch Zufall sein. Bin echt kein linux profi…
                                    usr/sbin/grub-probe: error: disk `lvmid/d6vUe1-VmEL-SEgR-sIoS-IGLg-l441-4JTJ9F/UxkIqX-7fZT-iWgh-YcIu-0Qfh-Rnfd-GXLmxI' not found.
                                    Found Ubuntu 21.04 (21.04) on /dev/mapper/pve-vm--1500--disk--0
                                    Adding boot menu entry for UEFI Firmware Settings ...
                                    done
                                    • Feuersturm
                                      @saeft_2003 ich poste dir später mal ein paar Screenshots, wie ich es bei mir wieder mit dem alten Kernel zum laufen bekomme habe.
                                        @feuersturm
                                        Das wäre echt super. Weil das Problem hatte ich bei meinem Testsystem das habe ich einfach neu aufgesetzt. Bei meinem Produktivsystem steht das Update noch an. Davor hab ich etwas bammel auch wenn ich weiß das ich einfach neu aufsetzten kann…
                                          crunchip Forum Testing Most Active @saeft_2003 last edited by
                                          das Problem
                                          ein Problem, aber nicht das selbe
                                            saeft_2003 Most Active @crunchip last edited by
                                            @crunchip
                                            Ok hatte gedacht das es evtl das gleiche Problem war…
                                            81.1k
                                            9577
