    4. JavaScript
    5. Objekt erstellt, aber kein State abrufbar
      A Former User last edited by
      Versuch es mal so:
      settingsIdAlive = this.getState('alive');
      this.log.debug(settingsIdAlive.val)
      Proper0912 1 Reply Last reply Reply Quote 0
      • Proper0912
        Proper0912 @Guest last edited by
        @ciddi89
        Hi habe es heute aus Probiert und geht nicht.
        Keine Ahnung was ich falsch mache!
          A Former User @Proper0912 last edited by
          @proper0912 hast mal ein Code wo du das Objekt erstellst, wo du es beschreibst und wo du es abrufst?
          • Proper0912
            @ciddi89
            Klar hier ist er:
            async function main() {
            	adapter.log.debug('adapter.main: << MAIN >>');
            	settingsID = adapter.config;
            	// +++++++++++++++++++ basic framework of Adapter ++++++++++++++++++++
            	await adapter.setObjectNotExistsAsync("alive", {
            		type: "state",
            		common: {
            			type: "boolean",
            			role: "state",
            			read: true,
            			write: true,
            			def: false,
            		native: {},
            	let settingsIdAlive = false;
            	await adapter.getStateAsync('alive', (err, state) => {
            		if (state) {
            			settingsIdAlive = state.val;
            		} else{
            			adapter.log.error(err)
            	adapter.log.debug(settingsIdAlive);
            	if (adapter.on) {
            		if (settingsIdAlive) {
            			// @ts-ignore
            			getDateOfInstanc(settingsID);
            			getValue(settingsID);
            		} else {
            			// +++++++++++++++++++ basic framework with medium of Adapter ++++++++++++++++++++
            			if ( settingsID.triggerID > "" && settingsID.medium > "" ){
            				await adapter.setObjectNotExistsAsync(settingsID.medium + ".connect", {
            					type: "state",
            					common: {
            						type: "boolean",
            						role: "state",
            						read: true,
            						write: true,
            						def: false,
            					native: {},
            				await adapter.setObjectNotExistsAsync(settingsID.medium + ".instanceValue", {
            					type: "state",
            					common: {
            						name: "instanceValue_" + settingsID.medium,
            						type: "number",
            						role: "value",
            						read: true,
            						write: true,
            						def: 0,
            						unit: "",
            					native: {},
            				await adapter.subscribeStates("*");
            				adapter.log.debug('adapter.main: << MAIN Objekt greated >>');
            			} else {
            				adapter.log.error("Keine referens Objekt-ID oder Medium angegeben")
            			await adapter.setStateAsync("alive", { val: true, ack: true });
            	} else {
            		adapter.log.error("Instance not startet");
            		if (state) {
            		} else{
            	adapter.stop();
            Das ist er!
              statt
              		if (state) {
              		} else{
              mach mal
              settingsIdAlive = await adapter.getStateAsync('alive')
              adapter.log.debug(settingsIdAlive.val);
              • Proper0912
                Proper0912 @Guest last edited by Proper0912
                @ciddi89
                Hi wenn ich das einfüge
                dann Sagt mein Programm: .val ist für boolean nicht verfügbar! ts(2339)
                  @proper0912 ja weil du vorher settingsIdAlive = false; deklariert hast. Nimmst du das raus und machst nur
                  let settingsIdAlive;
                  dann sollte es gehen.
                  Proper0912 2 Replies Last reply Reply Quote 0
                  • Proper0912
                    @ciddi89 Danke jetzt funktioniert es so wie sein soll danke!
                    • Proper0912
                      @ciddi89
                      Hi kannst du mir noch mal helfen?
                      Ich verstehe das einfach nicht.
                      Schau dir mal diesen Code an:
                      await adapter.setStateAsync(`${settingsID.medium}.connect`, { val: false, ack: true });
                      await adapter.getForeignState(settingsID.triggerID, (err, state) => {
                      	// state can be null!
                      	if (state) {
                      		adapter.setState(settingsID.path.instanceValue,{ val: state.val, ack: true });
                      		adapter.setStateAsync(`${settingsID.medium}.connect`, { val: true, ack: true });
                      	} else{
                      		adapter.log.info(err)
                      settingsID.value.instanceValue = await adapter.getStateAsync(`${settingsID.medium}.instanceValue`);
                      adapter.log.debug(settingsID.value.instanceValue.val)
                      Da lese ich Zahl aus einem andere Adapter und schreibe sie in mein Adapter.
                      Danach schreibe ich mir die Zahl aus meinem Adapter in eine Variable und gebe si aus im Debug als Kontrolle!
                      Aber erst beim zweiten mal wird sie auch in die Variable geschrieben! Habe ich das was falsch verstanden?
                      Oder ist es einfach nur zu spät!
                      Kannst du mir das noch mal Helfen ?
                      Oder ein anderer!
                      Danke!
                        A Former User @Proper0912 last edited by A Former User
                        @proper0912 also als erstes musst du bei jeder function wo der Name async drin ist auch ein await vorsetzen. Hier etwas zum lesen über asynchrone Funktionen. https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Statements/async_function
                        Verstehe nun aber nicht ganz was du vorhast? Wenn du mit variablen weiter arbeiten willst würde ich erstmal auf arrow functions verzichten. Macht es dir vielleicht ein bisschen einfacher. In dem fall ist es okay weil du ja nur setState nutzt aber achte bitte auf korrekte Deklaration wenn du async functions nutzt.
                        • Proper0912
                          @ciddi89 Danke noch mal für deine Hilfe!
                          Habe mir die Seite durchgelesen und habe es jetzt besser hinbekommen!
                          Klar ist es auch das es immer besser geht, aber für den Anfang bin ich schon ein wenig stolz das es jetzt geht.
                          Dank deiner Hilfe!
                            @proper0912 gerne, dafür ist das Forum ja da 😊
                            916
