    5. Smarter - Handtuchtrockner
    • Humidor
      Humidor @paul53 last edited by
      @paul53 weiß nicht genau was du meinst, ja die Variable Überschuss geht dann auf 0
      <variables>
      <variable id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</variable>
      <variable id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</variable> </variables> <block type="comment" id="m|fsyw%~z-7@{pQ@klZ|" x="-238" y="90"> <field name="COMMENT">Hzg Bad</field> <next> <block type="on_ext" id="WmaDlVza-%|bE2PC4}$}"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="(K%m+UU(oymx/#ZG.8s3"> <field name="oid">0_userdata.0.AMIS.PVÜberschuss</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="!:6IVLh(.s7Zc7*X2PKe"> <value name="IF0"> <block type="logic_negate" id="K~rgK;sALe4{c~Ujl-i6"> <value name="BOOL"> <block type="variables_get" id="]y;likc+U,w(YnZm}|~">
      <field name="VAR" id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</field>
      <block type="controls_if" id="h2[afer[}5V$)v@slP7p">
      <block type="logic_operation" id="rf:ObtkmhtKVS)VP_4,," inline="false">
      <field name="OP">AND</field>
      <block type="logic_operation" id="DW7F}t8zu~$_G8Pa(3e" inline="false">
      <block type="logic_compare" id="n=Zb^9u~JGi|Z-2
      qlih">
      <field name="OP">LT</field>
      <block type="get_value" id="RO$ii/.eX+hbu0jJElK1">
      <field name="OID">fritzdect.0.DECT_116300118701.celsius</field>
      <block type="math_number" id="n|%GCJ*$Tgl4!/hO)HO"> <field name="NUM">22</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="UUL3U=9eId#Q,LtbX:V2"> <field name="OP">GT</field> <value name="A"> <block type="get_value" id="bEu_M3Bq!oRspkoETC#f"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.AMIS.PVÜberschuss</field> </block> </value> <value name="B"> <block type="math_number" id="Zc~cW;[({xEj*S-%?x4O"> <field name="NUM">1200</field> </block> </value> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="#wOy@POd~_)Cr41C.zxN"> <value name="BOOL"> <block type="get_value" id="KK{JE3@|BkciE$J.kqh">
      <field name="OID">fritzdect.0.DECT_116300118701.state</field>
      <block type="control" id="Z(yvxp=,f=]BzOy3RJnr">
      <block type="logic_boolean" id="2+({nx%:r6H=r[I,S$(">
      <block type="variables_set" id="=XNnI:dF{iPZY{5-gz{%">
      <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="4s?8X2O{mv4dkx!lU;tL"> <field name="BOOL">TRUE</field> </block> </value> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_operation" id="CZulk@VkYS.P.v*bY^1R" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="m![RY(f3FtDyAKVqo9Tx"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="*kPQc:gnP0$;XUky1kj)"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.AMIS.PVÜberschuss</field> </block> </value> <value name="B"> <block type="math_number" id="OzBUgjtn~Ed/)o1mWRp">
      <field name="NUM">0</field>
      <block type="get_value" id="/|7rf5ix1B=jk]U7zh">
      <statement name="DO1">
      <block type="control" id="eP7[z/)zQ@T,2a?:Lg6I">
      <block type="logic_boolean" id=");DfVmVomO7|R~G8m;!u">
      <block type="on" id=",{!!mR4nS4Q$NTlsUW,$">
      <block type="controls_if" id="plWmx0U+JD:-qOK9v0_p">
      <block type="on_source" id="~yBgynYAtE{~NXHsVeuA">
      <block type="controls_if" id="-BxVSGEfn}b7Ju@-,eep">
      <block type="logic_negate" id="8gfsgQ
      [.HE*?Dj}KtS+">
      <value name="BOOL">
      <block type="variables_get" id="9vFK#z{rQXnRH_pyLsz"> <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field>
      <block type="variables_set" id="tY.{vp+,c/t}#oMfS]%P">
      <block type="logic_boolean" id="+^XozkhgT@Hd+7)pS97H">
      <statement name="ELSE">
      <block type="variables_set" id="X=d18E?zu0fn:~a^N5g]">
      <block type="logic_boolean" id="x$~YvVoggOL:j%:-TCk"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="variables_set" id="gR)1K=HLZ:9nGMvrBmi!"> <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field>
      <block type="logic_boolean" id="4u_b=$jq?u6pPc{R~LHL">
      • Humidor
        @paul53 noch eine Info?
          paul53 @Humidor last edited by paul53
          @humidor sagte: noch eine Info?
          Nein.
          Zur Verwendung von Variablen habe ich bereits geschrieben.
           <variables>
             <variable id="J[g|q0WcCQ$lG(S|TP`p">steckdose</variable>
           </variables>
                 <value name="OID0">
                         <value name="BOOL">
                               <block type="logic_compare" id="n=Zb^9u~JGi|Z-2qlih">
                                   <block type="on_source" id="^Zw6;J3NM.=o_QHIfeVw">
                           <block type="variables_set" id="Y:uXk([@33O|*EcEvZC-">
                             <field name="VAR" id="J[g|q0WcCQ$lG(S|TP`p">steckdose</field>
                               <block type="logic_boolean" id="k8#sut0s2709:o.nhIS?">
                         <value name="IF1">
                             <field name="OP">LTE</field>
                               <block type="on_source" id="PS1t9L#xZ;x(@eHHP10#">
                           <block type="variables_set" id="/+d#QA(l.c`6Nd.m51_z">
                               <block type="logic_boolean" id="c*Cyjv-G,I3+W|`.#P[a">
                           <block type="controls_if" id="})tCgv{wBfQw97dX@Xuv">
                               <block type="logic_compare" id="TLk|}7X@Qvtl_+?c0n?9">
                                 <field name="OP">NEQ</field>
                                   <block type="variables_get" id="mR*@R~HWo[L/u1(%D+F:">
                                   <block type="variables_get" id="3;,,Rl..U.T0K`wISUX=">
                           <block type="logic_negate" id="BaJxudKyZ{cTc`wx43.Y">
                             <value name="BOOL">
                         <value name="IF1">
                           <block type="logic_negate" id="8gfsgQ[.HE*?Dj}KtS+">
                             <value name="BOOL">
          Humidor 2 Replies Last reply Reply Quote 0
          • Humidor
            @paul53 ok, jetzt hab ich dich verstanden. danke.
            • Humidor
              Humidor @paul53 last edited by Humidor
              @paul53 es will nicht funktionieren, bei 0 wird mir der Trockner nicht abgeschaltet, nun habe ich eine weitere Triggervariabel drin, damit weiter die Bedingungen abgearbeitet werden, will auch nicht sauber funktionieren (so ein pfufferl Funktion fkt. wieder nicht, das nerft)
              Frage, warum fkt. der Vergleich nicht? ist das ein Systemfehler?
              warum ist die Variable undefiniert, sollte ein Bool sein
              <block xmlns="https://developers.google.com/blockly/xml" type="controls_if" id="iMG-g)W+/JBa1c0H4o:^" x="-85.99716186523438" y="1943">
              <block type="logic_compare" id="E7:1rr(1eLtr8iBYg8vs">
              <block type="get_value" id="6di?WSeWq5K.PkO_Z)R,">
              <block type="variables_get" id="Z?{k!DyEOM%Mt+vH3eLV">
              <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field>
              <block type="control" id="P@rQWr^[Hv%ygfQqqvB">
              <block type="variables_get" id="Pd8cVi{9va:z8,7sY^zL">
              <block type="debug" id="H36r9It9a}%=0]wtY2S/">
              <value name="TEXT">
              <shadow type="text" id="3%y$#U
              }5q=D=LwRvHY8">
              <field name="TEXT">SmartPlug Bad aktiviert</field>
              <block type="text_join" id="auz3gSf7.WYK1jWJ,d4r">
              <value name="ADD0">
              <block type="text" id="r[Jk^79uVZsQ7=_sJ$bb">
              <field name="TEXT">Smart Plug Bad geändert: </field>
              <value name="ADD1">
              <block type="convert_tostring" id="hthB0ZM5p?6HbOez-_Jr">
              <block type="variables_get" id="!v5M*M5k)2I`tb0FBRwJ">
              nach einer Zeit dann:
              why??
                @humidor sagte: warum ist die Variable undefiniert
                Das ist sie nach Skriptstart. Deshalb initialisiere sie außerhalb der Trigger:
                Da du einiges geändert hast, poste bitte den Export des kompletten Skripts in Code tags.
                Was ist der Trigger-DP "Power"?
                Humidor 1 Reply Last reply Reply Quote 0
                • Humidor
                  @paul53 wie im Bild oben zu sehen, mache ich die Initialisierung per wahr/falsch (Bool)
                  nach einer Zeit hat es dann auch funktioniert, das ist ein zeitliches Fehlverhalten
                  für mich ist es damit erledigt, mehr kann ich da dann eh nicht beitragen.
                  es gibt gerade ein neues Update von Admin und Skript, ich bin aber nicht der, der sofort auf die letzte Version updated, gebranntes Kind halt.
                    @humidor sagte: wie im Bild oben zu sehen, mache ich die Initialisierung per wahr/falsch (Bool)
                    Das ist einen andere Variable.
                    • Humidor
                      @paul53 hmm, eine Deklaration mit bool ist doch eindeutig, da gibts doch keine Diskussion und ist bei allen Programmiersprachen die ich kenne. ?
                      • DJMarc75
                        DJMarc75 @Humidor last edited by
                        @humidor dann zeig Dein komplettes Blockly und lass den Debug unten weg... brauchen wir hier grad nicht um Dir zu helfen... nur das Blockly
                        • Humidor
                          Humidor @DJMarc75 last edited by Humidor
                          @djmarc75 da sind oben noch 2 Plugs, die sind aktuell man vernachlässigbar
                          <variables>
                          <variable id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</variable> <variable id="jIGE4073UZ^0VwC#aJuo">HzgBenPVAktiviert</variable> <variable id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</variable>
                          <variable id="I=r#[:pdyT+h|wsXE$|@">SmartPlugBen</variable>
                          <variable id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</variable>
                          <variable id="KD:P[N/4z@jQ6}[4|~Y">HzgBadButtonAktiviert</variable>
                          </variables>
                          <block type="comment" id="z=dwW7Z^I0)hUWc$k!f" x="-237" y="-213">
                          <field name="COMMENT">INIT--------------</field>
                          <block type="create" id="7Gf_Q8NN|bW1T3agv:sj">
                          <field name="NAME">0_userdata.0.SmartPlugs.SmarPlug_HzgBad</field>
                          <block type="logic_boolean" id="+ABL;uy{pNb(E|1)o5th">
                          <value name="COMMON">
                          <block type="text" id="Xcka@/|Q/tc|Xcv+Yr
                          l">
                          <field name="TEXT">{"name": "SmartPlug_HzgBad","role": "","type": "boolean","desc": "Blockly erzeugt","read": true,"write": true,"def": false}</field>
                          <block type="create" id="==~ZA:E=R{8K~__,(hU4">
                          <field name="NAME">0_userdata.0.SmartPlugs.SmarPlug_HzgBen</field>
                          <block type="logic_boolean" id="0C{lx;ih)A3!zAk3r;S[">
                          <block type="text" id="6)Fe,U(?]d1rrIof}-;"> <field name="TEXT">{"name": "SmartPlug_HzgBen","role": "","type": "boolean","desc": "Blockly erzeugt","read": true,"write": true,"def": false}</field> </block> </value> <next> <block type="comment" id="9FS}{3.hU$!)fvKxe5Z">
                          <field name="COMMENT">Weihnachtsbeleuchtung</field>
                          <block type="astro" id="|acq.X_z?/Lk3dB@w@f"> <field name="TYPE">sunsetStart</field> <field name="OFFSET">0</field> <statement name="STATEMENT"> <block type="control" id="pf#k{+=AWeayqQ(+!lU1"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHPLG-S#DCCD03#1.Relay0.Switch</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="pVxA|c4e44c1:K0q8;o">
                          <block type="schedule" id="#ImvmsMd9}x#E[6,M(?
                          <field name="SCHEDULE">0 21 * * </field>
                          <block type="control" id="51G}JMMom|N~wZe?vuj"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHPLG-S#DCCD03#1.Relay0.Switch</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="eAT)89Q7NYX@3)OOY7Ae"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> <next> <block type="comment" id="}c]x52e-,Jd|e2*e^1$6"> <field name="COMMENT">Ben Heizung</field> <next> <block type="on_ext" id="yJDNB7t[~}.F8FBDdvsc"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="mY2gO+p3v.cztMJvtn:A"> <field name="oid">0_userdata.0.AMIS.PVÜberschuss</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="(;]E+4={9RA~rvpY_t3">
                          <field name="oid">0_userdata.0.AMIS.Power</field>
                          <block type="controls_if" id="NbvOvR?bhvqpF!].RQ)"> <mutation else="1"></mutation> <value name="IF0"> <block type="get_value" id="fco*1g?m:yToN*K~5|Ql"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.SmartPlugs.SmarPlug_HzgBen</field> </block> </value> <statement name="DO0"> <block type="controls_if" id="ApX@gbb0HHAZ?tTJ%DJL"> <value name="IF0"> <block type="logic_negate" id="nn1QFP)lE0/rD:963aMk"> <value name="BOOL"> <block type="variables_get" id="yoNWI)pdSK,NTqyhzXm~"> <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field>
                          <block type="controls_if" id="TB%4pL)wZgd6[u6/qea">
                          <block type="logic_compare" id=")h)thl1]/#%wS85^Q[Q">
                          <block type="get_value" id="k#BmbtWz2WX_]qlAzdxv">
                          <block type="math_number" id="rO7r2mky
                          c1;[0YTkXV-">
                          <block type="variables_set" id="S%?J(3hgSP1jp%44@@to">
                          <field name="VAR" id="I=r#[:pdyT+h|wsXE$|@">SmartPlugBen</field>
                          <block type="logic_boolean" id="2x:G_I{C[[]D:]r~B@Xt">
                          <value name="IF1">
                          <block type="logic_operation" id="]4FETZUQq13/MP1l5J$k" inline="false">
                          <block type="logic_compare" id="d:5_6(G=Jw2M6wZ)Jl2r">
                          +,Tgs3I#G(/z[ZqcHN9">
                          <block type="math_number" id="vwD4k;kXx,4uw=4f($g">
                          <field name="NUM">1500</field>
                          <block type="logic_negate" id="cn}Hla6KvyP+G!6M/y5T">
                          <value name="BOOL">
                          <block type="get_value" id="Gr@${G.^|v8%2C%MJ_5">
                          <field name="OID">shelly.0.SHPLG-S#8044C6#1.Relay0.Switch</field>
                          <block type="variables_set" id="p?cvm%eiH?u);h|B}Rdw">
                          <block type="logic_boolean" id="%s0S%px=rB$BMHf7_Kuz">
                          <block type="variables_set" id="|PO~KGr/Z7S);%%8Jq{@">
                          <field name="VAR" id="jIGE4073UZ^0VwC#aJuo">HzgBenPVAktiviert</field>
                          <block type="logic_boolean" id="0umsXwGN(LY/n
                          j:!!V">
                          <block type="controls_if" id="tb3Zo0VF|DHz7d:vMi)6">
                          <block type="logic_compare" id="?bFs^LJ$=[B!q33.415D">
                          <block type="get_value" id="?$mmaTeHDO{Y4Z61PG73">
                          <block type="variables_get" id="r;SW=;$T7Djnss?KYHAD">
                          <block type="control" id="L/m_;ygSV-0ZooeZ1e/m">
                          <block type="variables_get" id="?0v#8xfc_phYg2{nvOIN">
                          <block type="variables_set" id="hBhgMTUxqcZNK4Q77L+c">
                          <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="NR2[Ita|cx-C1Zz3rV.I"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="variables_set" id="gq5NDiz)n.aRg%Vz^I!">
                          <block type="logic_boolean" id="LHRm3e4@=@DT$$?8:Y/8">
                          <block type="control" id="+jCB/N79NQm=1iC^u*k"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHPLG-S#8044C6#1.Relay0.Switch</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="*Av;9x]5uPOk+5UHX|E*"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </statement> <next> <block type="on" id="1ofnM(8^@u410iRm.L#">
                          <block type="controls_if" id="}z+.!1@owb3I_eB];]8B">
                          <block type="on_source" id="DA9%A!]GFa%3|^I:_@|=">
                          <block type="controls_if" id="Y|XpQQYR!:D9FqG6S[p6">
                          <block type="logic_negate" id="~Pwco5sCao+qz=AE|s^E">
                          <value name="BOOL">
                          <block type="variables_get" id="p7z;5.~.xcJmD5{oi7#}">
                          <block type="variables_set" id="3yl@z{)J|8ci36rY6#e@">
                          <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="CICNz3lI-vQ]!Te2Un
                          <block type="variables_set" id="C7lB^ijF@U[bI=ip27r"> <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field>
                          <block type="logic_boolean" id="v{,|vk$f?a1ga$WLhK?"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="variables_set" id="@.(V|e@jCGmJv8.QwJ?H"> <field name="VAR" id="jIGE4073UZ^0VwC#aJuo">HzgBenPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="BCe|,zQnY~64zY[$V.L">
                          <block type="comment" id="m|fsyw%~z-7@{pQ@klZ|">
                          <block type="variables_set" id="VzBqFrD%u{!7;__LjF50">
                          <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="c.R@v_JN,e8J*N0NK4sA"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="on_ext" id="WmaDlVza-%|bE2PC4}$}"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="(K%m+UU(oymx/#ZG.8s3"> <field name="oid">0_userdata.0.AMIS.PVÜberschuss</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="u)8iDg5W-T:O++#u94nN"> <field name="oid">0_userdata.0.AMIS.Power</field> </shadow> </value> <statement name="STATEMENT"> <block type="debug" id=")00za#hEg2!m1qLnmRCA" disabled="true"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="jNXGQwWFslme^E#Z]rlY"> <field name="TEXT">test</field> </shadow> <block type="text_join" id="l@r?8o.2RlJmmv/8.nq{"> <mutation items="2"></mutation> <value name="ADD0"> <block type="text" id="P-9URIODf0;XyV5rq{^^"> <field name="TEXT">- Status SmartPlugBag: </field> </block> </value> <value name="ADD1"> <block type="variables_get" id="W@W^m!TCqT[)6*1X/v/["> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> </block> </value> </block> </value> <next> <block type="controls_if" id="~z(C0Ym)^=1QfSjT7~)">
                          <block type="get_value" id="]3^kMmXHdM*X6hxcLT$"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.SmartPlugs.SmarPlug_HzgBad</field> </block> </value> <statement name="DO0"> <block type="controls_if" id="!:6IVLh(.s7Zc7*X2PKe"> <value name="IF0"> <block type="logic_negate" id="K~rgK;sALe4{c~Ujl-i6"> <value name="BOOL"> <block type="variables_get" id="]y;likc+U,w(YnZm}|~">
                          <block type="logic_operation" id="|;joh}
                          ;!mA?r5ZiSg#1" inline="false">
                          <block type="logic_operation" id="Nmlt)igIsK,]cTElirIO" inline="false">
                          <field name="OP">OR</field>
                          <block type="get_value" id="8g2XiUBKIj/;R,V+q?%]">
                          <block type="math_number" id="OzBUgjtn~Ed/)o1mWRp"> <field name="NUM">0</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="mL7.f6Y8#0OmaVuk$71L"> <field name="OP">GT</field> <value name="A"> <block type="get_value" id="x!PfMXjU|/Qh^Cf|Sr]-"> <field name="ATTR">val</field> <field name="OID">fritzdect.0.DECT_116300118701.celsius</field> </block> </value> <value name="B"> <block type="math_number" id="wI[/OC#D;vOjTQ97fMcm"> <field name="NUM">25</field> </block> </value> </block> </value> </block> </value> <value name="B"> <block type="variables_get" id="]5o#-y)n;Y#t|.08E6k4"> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="*|c%1P3R}|bETp:H-Zru"> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> <value name="VALUE"> <block type="logic_boolean" id="TTB|-!JB/!/Llp_*?jXy"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id=":2bpKO5;oqCJ~(~?yU*H"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="twZ%b$:x7:Pk1$7*_oNr"> <field name="TEXT">SmartPlug Bad deaktiviert</field> </shadow> </value> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_operation" id="@YV5It9:.Rwjh0g_hu8P" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_operation" id="DW7F}t8zu~$_G*8Pa(3e" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="n=Zb^9u~JGi|Z-2*qlih"> <field name="OP">LT</field> <value name="A"> <block type="get_value" id="RO$ii/.eX+hbu0jJElK1"> <field name="ATTR">val</field> <field name="OID">fritzdect.0.DECT_116300118701.celsius</field> </block> </value> <value name="B"> <block type="math_number" id="n|%GCJ*$Tgl4!/hO)HO">
                          <field name="NUM">23</field>
                          <block type="get_value" id="j7Og^vZs{Gb@!_FYa^rw">
                          S-%?x4O">
                          <block type="logic_negate" id="BocLR@CABleTMd8S2aK$">
                          <value name="BOOL">
                          <block type="variables_get" id="QH;uW7]]0#@i8DmSXsBI">
                          <block type="variables_set" id="_fw-lf1ke521sTDyD+sc">
                          <block type="logic_boolean" id="x(T:dP4YUgCIhxf.6|"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="variables_set" id="=XNnI:dF{iPZY{5-gz{%"> <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field>
                          <block type="debug" id="5,x6)%(2~s:amdJRme2N">
                          <value name="TEXT">
                          <shadow type="text" id=")8=(EFb/R{t4{8OSW[~|">
                          <block type="controls_if" id="iMG-g)W+/JBa1c0H4o:^">
                          qvB">
                          <value name="TEXT">
                          <shadow type="text" id="3%y$#U*}5q=D=LwRvHY8">
                          <value name="ADD0">
                          <value name="ADD1">
                          <block type="variables_get" id="!v5MM5k)2Itb0FBRwJ"> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> </block> </value> </block> </value> </block> </value> </block> </next> </block> </statement> </block> </next> </block> </statement> </block> </statement> <statement name="ELSE"> <block type="controls_if" id="LMAxl+;SZ8E(TlZKxWl">
                          <block type="get_value" id="j:Fq]C
                          4d+}EE,zt!CB1">
                          <block type="control" id="kp_2D29pPxyBD?BILdYy">
                          <block type="logic_boolean" id="^Lvuh$RDtEkNp]pH:1Kx">
                          <block type="variables_set" id="fi,8jMb]:;nRjEANg30]">
                          <block type="logic_boolean" id="S,N!K.oxOUE@TF/rg6(K">
                          <block type="variables_set" id="eGU=ps7+5m=7SwxtH|">
                          <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="Opy{.zEg](?ok;}cd1"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id="SVXtBpd[q?mvCcep~3m5"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="2GJS]MKCljICYnyib-$Z"> <field name="TEXT">SmartPlug Bad ausgeschaltet</field> </shadow> </value> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> </block> </next> </block> </statement> <next> <block type="on" id=",{!!mR4nS4Q$NTlsUW,$"> <field name="OID">fritzdect.0.DECT_116300118701.state</field> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="controls_if" id="n,.3vp!##~_]qz%P/^Ib"> <mutation else="1"></mutation> <value name="IF0"> <block type="on_source" id="jKN0mfg1|:PbOG^Gb|/J"> <field name="ATTR">state.val</field> </block> </value> <statement name="DO0"> <block type="controls_if" id="-BxVSGEfn}b7Ju@-,eep"> <value name="IF0"> <block type="logic_negate" id="8gfsgQ_[.HE*?Dj}KtS+"> <value name="BOOL"> <block type="variables_get" id="9vFK#z{rQXnRH_pyLsz">
                          <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="tY.{vp+,c/t}#oMfS]%P"> <field name="VAR" id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="+^XozkhgT@Hd+7)pS97H"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="debug" id="?Hw8wf.Tjw?6RDCyh[3b"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="f0)M{RAR(rVV_;+OAixu"> <field name="TEXT">- Hzg Bad Button aktiviert</field> </shadow> </value> </block> </next> </block> </statement> </block> </statement> <statement name="ELSE"> <block type="variables_set" id="X=d18E?zu0fn:~a^N5g]"> <field name="VAR" id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="x$~YvVoggOL:j%:-TCk">
                          <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="4u_b=$jq?u6pPc{R~LHL"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id="/IL]Z5=@*;.99-BJeE{g"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="+G{;4~G4E2V+}e;^).-">
                          <field name="TEXT">- Hzg Bad Button / PV deaktiviert</field>
                          aktuell sehe ich kein Fehlverhalten, es hat nur lange gedauert bis es gelaufen ist, dabei Fehlersuche ohne Erfolg (daher die Debugs)
                          gibt es eine Möglickeit die Variablen (Wert) im Objektbaum zu sehen?
                          DJMarc75 paul53 2 Replies Last reply Reply Quote 0
                          • DJMarc75
                            DJMarc75 @Humidor last edited by DJMarc75
                            @humidor sagte in Smarter - Handtuchtrockner:
                            ja klar, indem Du die Variablen an das Debug hängst...
                            Humidor 1 Reply Last reply Reply Quote 1
                            • Humidor
                              @djmarc75 auch mit direktem Bezug auf die Variable - undefined
                              hatte heute einen Restart vom Raspi, seither fkt. es wieder nicht.
                              • DJMarc75
                                @humidor Na wenn die Variable, laut Deinem Screenshot, keinen Wert bekommt, dann ist diese halt auch "undefined"
                                • Humidor
                                  @djmarc75 true/false wäre ja definiert
                                  Humidor paul53 2 Replies Last reply Reply Quote 0
                                  • Humidor
                                    Humidor @Humidor last edited by Humidor
                                    @humidor ach ich Idiot, die Variable die ich debugge, war nicht definiert.... so ein Depp
                                    dennoch schalet mir das Spiel gerade nicht...
                                    • DJMarc75
                                      @humidor warum setzt Du die Variablen 2 mal ??
                                      macht keinen Sinn !
                                        @humidor sagte: true/false wäre ja definiert
                                        Die Variablen SmartPlugBad und SmartPlugBen müssen initialisiert werden! Bei den anderen Variablen ist es nicht nötig.
                                        EDIT: Wie hoch ist die Leistungsaufnahme der beiden Heizungen?
                                          @humidor
                                          Ich habe mal die Ausschaltbedingung für beide Heizungen auf Überschuss < 100 geändert und den doppelten Trigger entfernt.
                                           <variables>
                                             <variable id="HLabyAd:2nQ}/NML;EAq">Temperatur</variable>
                                           </variables>
                                           <block type="comment" id="z=dwW7Z^I0)hUWc$k!f" x="-136" y="-260">
                                                   <block type="text" id="Xcka@/|Q/tc|Xcv+Yrl">
                                                               <block type="schedule" id="#ImvmsMd9}x#E[6,M(?">
        <block type="variables_set" id="T:OJh$QAE@dYyx%-Zseu">
        <block type="get_value" id="wi0;LmRK]|?-9g[9yO51">
        <block type="get_value" id="|A_Y-a*[tt%7[kH+v#Ps">
        <value name="OID0">
        <value name="BOOL">
        <block type="on_source" id="Hy=tG%V,OewFti1.fXz`">
        <block type="math_number" id="rO7r2mkyc1;[0YTkXV-">
        <field name="NUM">100</field>
        <value name="IF1">
        <block type="on_source" id="=pLg:aB#k0O/WJH7Wv`5">
        <field name="NUM">1600</field>
        <block type="logic_boolean" id="0umsXwGN(LY/nj:!!V">
        <value name="IF1">
        <block type="get_value" id="(aYkcX/I(pzVo|`X$sEE">
        <value name="BOOL">
        <block type="variables_set" id="N,/~h9;9.JbWzU8$~1a*">
        <field name="VAR" id="HLabyAd:2nQ}/NML;EAq">Temperatur</field>
        <block type="on_source" id="!ar_r$01pMg+XNiz*t@!">
        <field name="OP">GTE</field>
        <block type="variables_get" id="i=)iIh}a]G1RSa2XRI=|">
        <value name="IF1">
        <block type="variables_get" id="?+f0rAV,pn$;)/tcql[K">
        <block type="on_source" id="B5i4y6y,UwZDHs]C[*rR">
        <block type="math_number" id="Zc~cW;[({xEjS-%?x4O">
        <field name="NUM">1300</field>
        <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <value name="IF1">
        <block type="get_value" id="j:Fq]C4d+}EE,zt!CB1">
        <value name="TEXT">
        <value name="BOOL">
        <block type="logic_boolean" id="CICNz3lI-vQ]!Te2Un">
        <value name="BOOL">
        <value name="TEXT">
        <value name="TEXT">
                                          Was hat die Weihnachtsbeleuchtung in diesem Skript zu suchen?
                                          • Humidor
                                            @paul53 Morgen!
                                            Ja ich weiß, dass das wahr/falsch da nicht hingehört, es war ein Test.
                                            Nachdem ich mich aber auf die falschen Variablen konzentriert haben, waren die SmartPluxx nicht deklariert und daher auch undefined, also alles richtig
                                            ich sagte auch, dass die 2 anderen zu vernachlässigen sind
                                            da ich die Heizkörper manuell per Soft-Schalter de-/aktiviere, passen die Werte schon.
                                            668
