    5. Smarter - Handtuchtrockner
    • DJMarc75
      DJMarc75 @Humidor last edited by
      @humidor dann zeig Dein komplettes Blockly und lass den Debug unten weg... brauchen wir hier grad nicht um Dir zu helfen... nur das Blockly
      Humidor 1 Reply Last reply Reply Quote 0
      • Humidor
        Humidor @DJMarc75 last edited by Humidor
        @djmarc75 da sind oben noch 2 Plugs, die sind aktuell man vernachlässigbar
        <variables>
        <variable id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</variable> <variable id="jIGE4073UZ^0VwC#aJuo">HzgBenPVAktiviert</variable> <variable id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</variable>
        <variable id="I=r#[:pdyT+h|wsXE$|@">SmartPlugBen</variable>
        <variable id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</variable>
        <variable id="KD:P[N/4z@jQ6}[4|~Y">HzgBadButtonAktiviert</variable>
        </variables>
        <block type="comment" id="z=dwW7Z^I0)hUWc$k!f" x="-237" y="-213">
        <field name="COMMENT">INIT--------------</field>
        <block type="create" id="7Gf_Q8NN|bW1T3agv:sj">
        <field name="NAME">0_userdata.0.SmartPlugs.SmarPlug_HzgBad</field>
        <block type="logic_boolean" id="+ABL;uy{pNb(E|1)o5th">
        <value name="COMMON">
        <block type="text" id="Xcka@/|Q/tc|Xcv+Yr
        l">
        <field name="TEXT">{"name": "SmartPlug_HzgBad","role": "","type": "boolean","desc": "Blockly erzeugt","read": true,"write": true,"def": false}</field>
        <block type="create" id="==~ZA:E=R{8K~__,(hU4">
        <field name="NAME">0_userdata.0.SmartPlugs.SmarPlug_HzgBen</field>
        <block type="logic_boolean" id="0C{lx;ih)A3!zAk3r;S[">
        <block type="text" id="6)Fe,U(?]d1rrIof}-;"> <field name="TEXT">{"name": "SmartPlug_HzgBen","role": "","type": "boolean","desc": "Blockly erzeugt","read": true,"write": true,"def": false}</field> </block> </value> <next> <block type="comment" id="9FS}{3.hU$!)fvKxe5Z">
        <field name="COMMENT">Weihnachtsbeleuchtung</field>
        <block type="astro" id="|acq.X_z?/Lk3dB@w@f"> <field name="TYPE">sunsetStart</field> <field name="OFFSET">0</field> <statement name="STATEMENT"> <block type="control" id="pf#k{+=AWeayqQ(+!lU1"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHPLG-S#DCCD03#1.Relay0.Switch</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="pVxA|c4e44c1:K0q8;o">
        <block type="schedule" id="#ImvmsMd9}x#E[6,M(?
        <field name="SCHEDULE">0 21 * * </field>
        <block type="control" id="51G}JMMom|N~wZe?vuj"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHPLG-S#DCCD03#1.Relay0.Switch</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="eAT)89Q7NYX@3)OOY7Ae"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> <next> <block type="comment" id="}c]x52e-,Jd|e2*e^1$6"> <field name="COMMENT">Ben Heizung</field> <next> <block type="on_ext" id="yJDNB7t[~}.F8FBDdvsc"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="mY2gO+p3v.cztMJvtn:A"> <field name="oid">0_userdata.0.AMIS.PVÜberschuss</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="(;]E+4={9RA~rvpY_t3">
        <field name="oid">0_userdata.0.AMIS.Power</field>
        <block type="controls_if" id="NbvOvR?bhvqpF!].RQ)"> <mutation else="1"></mutation> <value name="IF0"> <block type="get_value" id="fco*1g?m:yToN*K~5|Ql"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.SmartPlugs.SmarPlug_HzgBen</field> </block> </value> <statement name="DO0"> <block type="controls_if" id="ApX@gbb0HHAZ?tTJ%DJL"> <value name="IF0"> <block type="logic_negate" id="nn1QFP)lE0/rD:963aMk"> <value name="BOOL"> <block type="variables_get" id="yoNWI)pdSK,NTqyhzXm~"> <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field>
        <block type="controls_if" id="TB%4pL)wZgd6[u6/qea">
        <block type="logic_compare" id=")h)thl1]/#%wS85^Q[Q">
        <field name="OP">EQ</field>
        <block type="get_value" id="k#BmbtWz2WX_]qlAzdxv">
        <field name="OID">0_userdata.0.AMIS.PVÜberschuss</field>
        <block type="math_number" id="rO7r2mky
        c1;[0YTkXV-">
        <field name="NUM">0</field>
        <block type="variables_set" id="S%?J(3hgSP1jp%44@@to">
        <field name="VAR" id="I=r#[:pdyT+h|wsXE$|@">SmartPlugBen</field>
        <block type="logic_boolean" id="2x:G_I{C[[]D:]r~B@Xt">
        <value name="IF1">
        <block type="logic_operation" id="]4FETZUQq13/MP1l5J$k" inline="false">
        <field name="OP">AND</field>
        <block type="logic_compare" id="d:5_6(G=Jw2M6wZ)Jl2r">
        <field name="OP">GT</field>
        +,Tgs3I#G(/z[ZqcHN9">
        <block type="math_number" id="vwD4k;kXx,4uw=4f($g">
        <field name="NUM">1500</field>
        <block type="logic_negate" id="cn}Hla6KvyP+G!6M/y5T">
        <value name="BOOL">
        <block type="get_value" id="Gr@${G.^|v8%2C%MJ_5">
        <field name="OID">shelly.0.SHPLG-S#8044C6#1.Relay0.Switch</field>
        <statement name="DO1">
        <block type="variables_set" id="p?cvm%eiH?u);h|B}Rdw">
        <block type="logic_boolean" id="%s0S%px=rB$BMHf7_Kuz">
        <block type="variables_set" id="|PO~KGr/Z7S);%%8Jq{@">
        <field name="VAR" id="jIGE4073UZ^0VwC#aJuo">HzgBenPVAktiviert</field>
        <block type="logic_boolean" id="0umsXwGN(LY/n
        j:!!V">
        <block type="controls_if" id="tb3Zo0VF|DHz7d:vMi)6">
        <block type="logic_compare" id="?bFs^LJ$=[B!q33.415D">
        <field name="OP">NEQ</field>
        <block type="get_value" id="?$mmaTeHDO{Y4Z61PG73">
        <block type="variables_get" id="r;SW=;$T7Djnss?KYHAD">
        <block type="control" id="L/m_;ygSV-0ZooeZ1e/m">
        <block type="variables_get" id="?0v#8xfc_phYg2{nvOIN">
        <statement name="ELSE">
        <block type="variables_set" id="hBhgMTUxqcZNK4Q77L+c">
        <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="NR2[Ita|cx-C1Zz3rV.I"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="variables_set" id="gq5NDiz)n.aRg%Vz^I!">
        <block type="logic_boolean" id="LHRm3e4@=@DT$$?8:Y/8">
        <block type="control" id="+jCB/N79NQm=1iC^u*k"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHPLG-S#8044C6#1.Relay0.Switch</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="*Av;9x]5uPOk+5UHX|E*"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </statement> <next> <block type="on" id="1ofnM(8^@u410iRm.L#">
        <block type="controls_if" id="}z+.!1@owb3I_eB];]8B">
        <block type="on_source" id="DA9%A!]GFa%3|^I:_@|=">
        <block type="controls_if" id="Y|XpQQYR!:D9FqG6S[p6">
        <block type="logic_negate" id="~Pwco5sCao+qz=AE|s^E">
        <value name="BOOL">
        <block type="variables_get" id="p7z;5.~.xcJmD5{oi7#}">
        <block type="variables_set" id="3yl@z{)J|8ci36rY6#e@">
        <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="CICNz3lI-vQ]!Te2Un
        <block type="variables_set" id="C7lB^ijF@U[bI=ip27r"> <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field>
        <block type="logic_boolean" id="v{,|vk$f?a1ga$WLhK?"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="variables_set" id="@.(V|e@jCGmJv8.QwJ?H"> <field name="VAR" id="jIGE4073UZ^0VwC#aJuo">HzgBenPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="BCe|,zQnY~64zY[$V.L">
        <block type="comment" id="m|fsyw%~z-7@{pQ@klZ|">
        <field name="COMMENT">Hzg Bad</field>
        <block type="variables_set" id="VzBqFrD%u{!7;__LjF50">
        <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="c.R@v_JN,e8J*N0NK4sA"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="on_ext" id="WmaDlVza-%|bE2PC4}$}"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="(K%m+UU(oymx/#ZG.8s3"> <field name="oid">0_userdata.0.AMIS.PVÜberschuss</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="u)8iDg5W-T:O++#u94nN"> <field name="oid">0_userdata.0.AMIS.Power</field> </shadow> </value> <statement name="STATEMENT"> <block type="debug" id=")00za#hEg2!m1qLnmRCA" disabled="true"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="jNXGQwWFslme^E#Z]rlY"> <field name="TEXT">test</field> </shadow> <block type="text_join" id="l@r?8o.2RlJmmv/8.nq{"> <mutation items="2"></mutation> <value name="ADD0"> <block type="text" id="P-9URIODf0;XyV5rq{^^"> <field name="TEXT">- Status SmartPlugBag: </field> </block> </value> <value name="ADD1"> <block type="variables_get" id="W@W^m!TCqT[)6*1X/v/["> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> </block> </value> </block> </value> <next> <block type="controls_if" id="~z(C0Ym)^=1QfSjT7~)">
        <block type="get_value" id="]3^kMmXHdM*X6hxcLT$"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.SmartPlugs.SmarPlug_HzgBad</field> </block> </value> <statement name="DO0"> <block type="controls_if" id="!:6IVLh(.s7Zc7*X2PKe"> <value name="IF0"> <block type="logic_negate" id="K~rgK;sALe4{c~Ujl-i6"> <value name="BOOL"> <block type="variables_get" id="]y;likc+U,w(YnZm}|~">
        <field name="VAR" id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</field>
        <block type="controls_if" id="h2[afer[}5V$)v@slP7p">
        <block type="logic_operation" id="|;joh}
        ;!mA?r5ZiSg#1" inline="false">
        <block type="logic_operation" id="Nmlt)igIsK,]cTElirIO" inline="false">
        <field name="OP">OR</field>
        <block type="logic_compare" id="m![RY(f3FtDyAKVqo9Tx">
        <block type="get_value" id="8g2XiUBKIj/;R,V+q?%]">
        <block type="math_number" id="OzBUgjtn~Ed/)o1mWRp"> <field name="NUM">0</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="mL7.f6Y8#0OmaVuk$71L"> <field name="OP">GT</field> <value name="A"> <block type="get_value" id="x!PfMXjU|/Qh^Cf|Sr]-"> <field name="ATTR">val</field> <field name="OID">fritzdect.0.DECT_116300118701.celsius</field> </block> </value> <value name="B"> <block type="math_number" id="wI[/OC#D;vOjTQ97fMcm"> <field name="NUM">25</field> </block> </value> </block> </value> </block> </value> <value name="B"> <block type="variables_get" id="]5o#-y)n;Y#t|.08E6k4"> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="*|c%1P3R}|bETp:H-Zru"> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> <value name="VALUE"> <block type="logic_boolean" id="TTB|-!JB/!/Llp_*?jXy"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id=":2bpKO5;oqCJ~(~?yU*H"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="twZ%b$:x7:Pk1$7*_oNr"> <field name="TEXT">SmartPlug Bad deaktiviert</field> </shadow> </value> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_operation" id="@YV5It9:.Rwjh0g_hu8P" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_operation" id="DW7F}t8zu~$_G*8Pa(3e" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="n=Zb^9u~JGi|Z-2*qlih"> <field name="OP">LT</field> <value name="A"> <block type="get_value" id="RO$ii/.eX+hbu0jJElK1"> <field name="ATTR">val</field> <field name="OID">fritzdect.0.DECT_116300118701.celsius</field> </block> </value> <value name="B"> <block type="math_number" id="n|%GCJ*$Tgl4!/hO)HO">
        <field name="NUM">23</field>
        <block type="logic_compare" id="UUL3U=9eId#Q,LtbX:V2">
        <block type="get_value" id="j7Og^vZs{Gb@!_FYa^rw">
        <block type="math_number" id="Zc~cW;[({xEj
        S-%?x4O">
        <field name="NUM">1200</field>
        <block type="logic_negate" id="BocLR@CABleTMd8S2aK$">
        <value name="BOOL">
        <block type="variables_get" id="QH;uW7]]0#@i8DmSXsBI">
        <block type="variables_set" id="_fw-lf1ke521sTDyD+sc">
        <block type="logic_boolean" id="x(T:dP4YUgCIhxf.6|"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="variables_set" id="=XNnI:dF{iPZY{5-gz{%"> <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field>
        <block type="logic_boolean" id="4s?8X2O{mv4dkx!lU;tL">
        <block type="debug" id="5,x6)%(2~s:amdJRme2N">
        <value name="TEXT">
        <shadow type="text" id=")8=(EFb/R{t4{8OSW[~|">
        <field name="TEXT">SmartPlug Bad aktiviert</field>
        <block type="controls_if" id="iMG-g)W+/JBa1c0H4o:^">
        <block type="logic_compare" id="E7:1rr(1eLtr8iBYg8vs">
        <block type="get_value" id="6di?WSeWq5K.PkO_Z)R,">
        <field name="OID">fritzdect.0.DECT_116300118701.state</field>
        <block type="variables_get" id="Z?{k!DyEOM%Mt+vH3eLV">
        <block type="control" id="P@rQWr^[Hv%ygfQq
        qvB">
        <block type="variables_get" id="Pd8cVi{9va:z8,7sY^zL">
        <block type="debug" id="H36r9It9a}%=0]wtY2S/">
        <value name="TEXT">
        <shadow type="text" id="3%y$#U*}5q=D=LwRvHY8">
        <block type="text_join" id="auz3gSf7.WYK1jWJ,d4r">
        <value name="ADD0">
        <block type="text" id="r[Jk^79uVZsQ7=_sJ$bb">
        <field name="TEXT">Smart Plug Bad geändert: </field>
        <value name="ADD1">
        <block type="convert_tostring" id="hthB0ZM5p?6HbOez-_Jr">
        <block type="variables_get" id="!v5MM5k)2Itb0FBRwJ"> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> </block> </value> </block> </value> </block> </value> </block> </next> </block> </statement> </block> </next> </block> </statement> </block> </statement> <statement name="ELSE"> <block type="controls_if" id="LMAxl+;SZ8E(TlZKxWl">
        <block type="get_value" id="j:Fq]C
        4d+}EE,zt!CB1">
        <block type="control" id="kp_2D29pPxyBD?BILdYy">
        <block type="logic_boolean" id="^Lvuh$RDtEkNp]pH:1Kx">
        <block type="variables_set" id="fi,8jMb]:;nRjEANg30]">
        <block type="logic_boolean" id="S,N!K.oxOUE@TF/rg6(K">
        <block type="variables_set" id="eGU=ps7+5m=7SwxtH|">
        <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="Opy{.zEg](?ok;}cd1"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id="SVXtBpd[q?mvCcep~3m5"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="2GJS]MKCljICYnyib-$Z"> <field name="TEXT">SmartPlug Bad ausgeschaltet</field> </shadow> </value> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> </block> </next> </block> </statement> <next> <block type="on" id=",{!!mR4nS4Q$NTlsUW,$"> <field name="OID">fritzdect.0.DECT_116300118701.state</field> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="controls_if" id="n,.3vp!##~_]qz%P/^Ib"> <mutation else="1"></mutation> <value name="IF0"> <block type="on_source" id="jKN0mfg1|:PbOG^Gb|/J"> <field name="ATTR">state.val</field> </block> </value> <statement name="DO0"> <block type="controls_if" id="-BxVSGEfn}b7Ju@-,eep"> <value name="IF0"> <block type="logic_negate" id="8gfsgQ_[.HE*?Dj}KtS+"> <value name="BOOL"> <block type="variables_get" id="9vFK#z{rQXnRH_pyLsz">
        <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="tY.{vp+,c/t}#oMfS]%P"> <field name="VAR" id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="+^XozkhgT@Hd+7)pS97H"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="debug" id="?Hw8wf.Tjw?6RDCyh[3b"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="f0)M{RAR(rVV_;+OAixu"> <field name="TEXT">- Hzg Bad Button aktiviert</field> </shadow> </value> </block> </next> </block> </statement> </block> </statement> <statement name="ELSE"> <block type="variables_set" id="X=d18E?zu0fn:~a^N5g]"> <field name="VAR" id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="x$~YvVoggOL:j%:-TCk">
        <block type="variables_set" id="gR)1K=HLZ:9nGMvrBmi!">
        <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="4u_b=$jq?u6pPc{R~LHL"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id="/IL]Z5=@*;.99-BJeE{g"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="+G{;4~G4E2V+}e;^).-">
        <field name="TEXT">- Hzg Bad Button / PV deaktiviert</field>
        aktuell sehe ich kein Fehlverhalten, es hat nur lange gedauert bis es gelaufen ist, dabei Fehlersuche ohne Erfolg (daher die Debugs)
        gibt es eine Möglickeit die Variablen (Wert) im Objektbaum zu sehen?
        DJMarc75 paul53 2 Replies Last reply Reply Quote 0
        • DJMarc75
          DJMarc75 @Humidor last edited by DJMarc75
          @humidor sagte in Smarter - Handtuchtrockner:
          ja klar, indem Du die Variablen an das Debug hängst...
          Humidor 1 Reply Last reply Reply Quote 1
          • Humidor
            @djmarc75 auch mit direktem Bezug auf die Variable - undefined
            hatte heute einen Restart vom Raspi, seither fkt. es wieder nicht.
            • DJMarc75
              @humidor Na wenn die Variable, laut Deinem Screenshot, keinen Wert bekommt, dann ist diese halt auch "undefined"
              • Humidor
                @djmarc75 true/false wäre ja definiert
                Humidor paul53 2 Replies Last reply Reply Quote 0
                • Humidor
                  Humidor @Humidor last edited by Humidor
                  @humidor ach ich Idiot, die Variable die ich debugge, war nicht definiert.... so ein Depp
                  dennoch schalet mir das Spiel gerade nicht...
                  • DJMarc75
                    @humidor warum setzt Du die Variablen 2 mal ??
                    macht keinen Sinn !
                      paul53 @Humidor last edited by paul53
                      @humidor sagte: true/false wäre ja definiert
                      Die Variablen SmartPlugBad und SmartPlugBen müssen initialisiert werden! Bei den anderen Variablen ist es nicht nötig.
                      EDIT: Wie hoch ist die Leistungsaufnahme der beiden Heizungen?
                        @humidor
                        Ich habe mal die Ausschaltbedingung für beide Heizungen auf Überschuss < 100 geändert und den doppelten Trigger entfernt.
                         <variables>
                           <variable id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</variable>
                           <variable id="HLabyAd:2nQ}/NML;EAq">Temperatur</variable>
                         </variables>
                         <block type="comment" id="z=dwW7Z^I0)hUWc$k!f" x="-136" y="-260">
                                 <block type="text" id="Xcka@/|Q/tc|Xcv+Yrl">
                                             <block type="schedule" id="#ImvmsMd9}x#E[6,M(?">
                                                 <block type="variables_set" id="T:OJh$QAE@dYyx%-Zseu">
                                                     <block type="get_value" id="wi0;LmRK]|?-9g[9yO51">
                                                         <block type="get_value" id="|A_Y-a*[tt%7[kH+v#Ps">
                                                           <value name="OID0">
        <value name="BOOL">
        <block type="on_source" id="Hy=tG%V,OewFti1.fXz`">
        <block type="math_number" id="rO7r2mkyc1;[0YTkXV-">
        <field name="NUM">100</field>
        <value name="IF1">
        <block type="on_source" id="=pLg:aB#k0O/WJH7Wv`5">
        <field name="NUM">1600</field>
        <block type="logic_boolean" id="0umsXwGN(LY/nj:!!V">
        <value name="IF1">
        <block type="get_value" id="(aYkcX/I(pzVo|`X$sEE">
        <value name="BOOL">
        <block type="variables_set" id="N,/~h9;9.JbWzU8$~1a*">
        <field name="VAR" id="HLabyAd:2nQ}/NML;EAq">Temperatur</field>
        <block type="on_source" id="!ar_r$01pMg+XNiz*t@!">
        <field name="OP">GTE</field>
        <block type="variables_get" id="i=)iIh}a]G1RSa2XRI=|">
        <value name="IF1">
        <field name="OP">LTE</field>
        <block type="variables_get" id="?+f0rAV,pn$;)/tcql[K">
        <block type="on_source" id="B5i4y6y,UwZDHs]C[*rR">
        <block type="math_number" id="Zc~cW;[({xEjS-%?x4O">
        <field name="NUM">1300</field>
        <block type="control" id="P@rQWr^[Hv%ygfQqqvB">
        <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <value name="IF1">
        <block type="get_value" id="j:Fq]C4d+}EE,zt!CB1">
        <value name="TEXT">
        <value name="BOOL">
        <block type="logic_boolean" id="CICNz3lI-vQ]!Te2Un">
        <value name="BOOL">
        <value name="TEXT">
        <value name="TEXT">
                        Was hat die Weihnachtsbeleuchtung in diesem Skript zu suchen?
                        • Humidor
                          Humidor @paul53 last edited by
                          @paul53 Morgen!
                          Ja ich weiß, dass das wahr/falsch da nicht hingehört, es war ein Test.
                          Nachdem ich mich aber auf die falschen Variablen konzentriert haben, waren die SmartPluxx nicht deklariert und daher auch undefined, also alles richtig
                          ich sagte auch, dass die 2 anderen zu vernachlässigen sind
                          da ich die Heizkörper manuell per Soft-Schalter de-/aktiviere, passen die Werte schon.
                          • Humidor
                            @humidor ich habe das lange beobachtet
                            der Trigger fkt. nicht .
                            1. Triggervariable ist 0
                            2. Triggervariable ist im Minus
                              damit kommt kein Trigger mehr, der Handtuchtrockner bleibt mir aktiv
                            umgestellt auf Trigger/Sekunde, funktioniert.
                            • wendy2702
                              wendy2702 @Humidor last edited by
                              ich will etwas ähnliches realisieren. Funktioniert dein Blockly jetzt?
                              Falls ja, kannst du vielleicht einen Export bereitsstellen.
                              668
