    4. Test Adapter Devices 1.0.x
      gyle last edited by
      ich habe mal eine frage zur Konvertierungsfunktion...
      ich habe folg. Objekt, das eine Restlaufzeit in folg. format anzeigt:
      gibt es eine Möglichkeit das in folg Format zu bringen? hh:mm, also zb 01:20
      ? Danke
        sigi234 Forum Testing Most Active @gyle last edited by sigi234
        @gyle sagte in Test Adapter Devices 1.0.x:
        ? Danke
        Widget (Vis-materialdesign-value)
        [{"tpl":"tplVis-materialdesign-value","data":{"oid":"homeconnect.0.401010522278007458.programs.active.options.BSH_Common_Option_RemainingProgramTime","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","targetType":"auto","textAlign":"start","valuesFontColor":"#e00000","valuesFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.text","valuesFontSize":"18","prepandTextColor":"#ffffff","prepandTextFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.prepand","prepandTextFontSize":"15","appendTextColor":"#e00000","appendTextFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.append","appendTextFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.append","image":"timer-outline","imageColor":"#ffffff","iconPosition":"left","effectFontColor":"#mdwTheme:vis-materialdesign.0.colors.value.effect","effectFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.effect","effectDuration":"750","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"convertToDuration":"mm [Minuten]","valueLabelUnit":" min.","prepandText":"  Verbleibende Programmlaufzeit : ","changeEffectEnabled":true,"valueLabelWidth":"10","name":"Programmlaufzeit","iconHeight":"35"},"style":{"left":"917px","top":"308px","width":"357px","height":"39px","z-index":"5"},"widgetSet":"materialdesign"}]
          gyle @sigi234 last edited by
          @sigi234 ich nutze Lovelace als Visualisierung - bekomme ich das damit auch hin?
          • david83
            david83 last edited by
            Ich habe die Version 1.0.9 installiert.
            Es sind unter States vordefinierte States angelegt. So wie ich das verstanden habe, sollen diese genutzt werden um zukunftssicher auch von anderen Adaptern und Geräten erkannt und genutzt werden zu können.
            Nun fehlen dort ja viele Möglichkeiten/Statuse wie z.b. quality_link bei Zigbee Geräten. Wenn ich diese anlege oder importiere, ist das dann ja nicht das vorgegebene Schema. In wie fern kann das zum Problem werden? Sind weitere solcher vorgegebenen States geplant oder verstehe ich die Sache vielleicht ganz falsch?
              apollon77 @david83 last edited by
              @david83 das was sinnvoll zu Standardisieren ist und zb auch von Amazon Alexa oder Google genutzt wird ist da. Und die visu adapter die dies nutzen kennen das dann auch. Was du ggf noch sinnvoll ansiehst kannst du hinzufügen. Probleme gibt das in Zukunft keine
                gyle last edited by
                zur Berechnung eines Wertes würde ich gerne einen alias anlegen und die "Konvertierungsfunktion" nutzen.
                Geht soetwas wie:
                val - (wert eines anderen objektes) - (wert eines anderen objektes)
                wie müsste sowas dann aussehen?
                Danke & Grüße
                apollon77 paul53 2 Replies Last reply Reply Quote 0
                  apollon77 @gyle last edited by apollon77
                  @gyle Das ist aktuell nicht möglich. Für solche DInge empfielt sich ein JavaScript Skriptchen
                    paul53 @gyle last edited by
                    @gyle sagte: Geht soetwas wie:
                    Nein, der Alias kann nur den Wert des referenzierten Datenpunktes verarbeiten.
                    Für die Verknüpfung der Werte mehrerer Datenpunkt wird ein Skript benötigt.
                      Floh22964 last edited by
                      Hallo
                      Erst einmal vielen Dank für diesen tollen Adapter.
                      Ich habe lange im Forum gesucht um diesen Chat zu finden, denn all zu viele scheinen den ja nicht zu nutzen.
                      Leider wird der Adapter wohl nicht weiter auf GIT bearbeitet, dann dort antwortet keiner auf Probleme.
                      Ich habe angefangen all meine Geräte zu strukturieren und Licht, Steckdosen und ähnliches funktioniert auch sehr gut.
                      Was seit einiger Zeit nicht mehr funktioniert sind die Icon´s , so das man es nicht mehr personalisieren kann.
                      Auch funktioniert der Valve Adapter nicht, da bekommt man immer einen Fehler das dieser nicht da sei, ich würde den allerdings benötigen.
                      Ebenfalls als GIT Anfrage wie man denn eigene Adapter einstellen kann. In GIT gab es nur einen kurzen Kommentar das würde unter Admin funktionieren, ich zumindest kann es nicht finden. Außer das man an ein ander vorbei gesprochen hat und es gemeint ist einfach einen anderen Adapter durch zusätzliche Punkte zu erweitern um es dann auch seine Bedürfnisse anzupassen. Das würde ich persönlich als nicht gut finden, da der Adapter dann als zum Beispiel Licht angezeigt wird, aber ein Ventil ist.
                      Ich hoffe das hier noch wer mitließt da ich den Adapter super finde.
                        apollon77 @Floh22964 last edited by
                        @floh22964 Doch den Adater gibts noch und es gab auch Updates ...
                        79.9k
                        1226
