    5. Überschussladung an nicht-smarter Wallbox Hilfe!?
      paul53 @Sub7 last edited by
      @sub7 sagte: ich habe die Änderungen aus deinen zwei vorherigen Posts gemacht.
      Nicht ganz. Deshalb hier der Export:
       <variables>
         <variable type="timeout" id="Timeout_1.8kW">Timeout_1.8kW</variable>
         <variable type="timeout" id="Timeout_3.7kW">Timeout_3.7kW</variable>
         <variable id=";t!!{he,NqY7LjF_(N[%">Ladepriorisierung</variable>
         <variable id="3hvpTzojo}y2$Ew~Gyhv">PV_laden-1.8kW</variable>
         <variable id="]@YsD2#L/zM,THq9GqS[">PV_laden_3_7kW</variable>
         <variable type="timeout" id="Timeout_Aus">Timeout_Aus</variable>
         <variable type="timeout" id="Timeout_ladung">Timeout_ladung</variable>
       </variables>
       <block type="on" id="$4wQL[ftP_6@,fTC3at$" x="-112" y="-98">
         <field name="OID">shelly.0.SHEM-3#3494547559AD#1.Emeter0.Power</field>
           <block type="comment" id="A%${1aeY]+DhiUchoxE4">
             <field name="COMMENT">Laden mit nur 1,8kW Leistung</field>
               <block type="controls_if" id="]ourj]{^20nkJwurfDR[">
                   <block type="logic_compare" id="1+gNc=EeK5e,fUJnc^}8">
                     <field name="OP">GT</field>
                       <block type="on_source" id="k_T:%FZ61/wK(R2^mIU3">
                       <block type="math_number" id="!]h!/j]Sjsh`~{_bVK-0">
                         <field name="NUM">-1500</field>
                   <block type="timeouts_cleartimeout" id="FgWgp`HD1-;4.K`v$}Us">
                     <field name="NAME">Timeout_1.8kW</field>
                 <value name="IF1">
                   <block type="logic_operation" id="zu**V*R;jsb+vDs)/J.U" inline="false">
                     <field name="OP">AND</field>
                       <block type="logic_negate" id="Qx^`}eX,?sgZ*uDGx_+k">
                         <value name="BOOL">
                           <block type="timeouts_gettimeout" id="@ndH!4yq0cG2I(uJ0y^N">
                       <block type="logic_operation" id="c[9-0L7e@xjMN5BlD9(," inline="false">
                           <block type="logic_negate" id="0yj+TV2u!*9F,.)fx!Zc">
                             <value name="BOOL">
                               <block type="variables_get" id="tj$S1IGl4$v1d|],20at">
                                 <field name="VAR" id=";t!!{he,NqY7LjF_(N[%">Ladepriorisierung</field>
                           <block type="logic_negate" id="1vQj}l,tkf2so_?uC5{G">
                             <value name="BOOL">
                               <block type="variables_get" id="53zCnmG4C|L%(*)wf_Q}">
                                 <field name="VAR" id="3hvpTzojo}y2$Ew~Gyhv">PV_laden-1.8kW</field>
                 <statement name="DO1">
                   <block type="timeouts_settimeout" id=":O-$Y1-hZ9)Lp3q_Dw,z">
                     <field name="DELAY">1</field>
                       <block type="comment" id="5=w_x$,??{yY}RJOtsj6">
                         <field name="COMMENT">Lastabwurf (1,8kW laden) Freigabe</field>
                           <block type="control" id="U9`dXV4#tZhe@IbMEz~=">
                             <field name="OID">hm-rpc.0.000218A995E697.3.STATE</field>
                               <block type="logic_boolean" id="QxAOUPlRj-Fc-cY{;TP1">
                               <block type="comment" id="XVRA]9A/@`Ya:~%i0cwJ">
                                 <field name="COMMENT">Ladefreigabe Wallbox</field>
                                   <block type="control" id="ANCablvP2!Z*FcTR$A$E">
                                     <field name="OID">shelly.0.SHEM-3#3494547559AD#1.Relay0.Switch</field>
                                       <block type="logic_boolean" id="I/RPAC+Rw)p%bOGUAOpl">
                                       <block type="variables_set" id="FF2Y;ps~$85/Q|T=rs*w">
                                           <block type="logic_boolean" id="}h`Uo;j}l+=wG$.6iu;G">
                   <block type="comment" id="rAG3V-k0Tx];%@JKviiJ">
                     <field name="COMMENT">Laden mit 3,7kW Leistung</field>
                       <block type="controls_if" id="}8)0BG-8cl8U#(jDmMb;">
                           <block type="logic_compare" id="@[^iqFZlZzxc(YkB:nbn">
                               <block type="on_source" id="TNFuW~94!_y;TMwq?OQ6">
                               <block type="math_number" id="P?UKwKXa7-z.n93Nx``t">
                           <block type="timeouts_cleartimeout" id="w4U}HDwOB=:|?@(aG@MV">
                             <field name="NAME">Timeout_3.7kW</field>
                         <value name="IF1">
                           <block type="logic_operation" id="@0t4B]jt@]a7cDS2,bfJ" inline="false">
                               <block type="logic_negate" id="YNSR_.B%-q[ggjFq7/oE">
                                 <value name="BOOL">
                                   <block type="timeouts_gettimeout" id="=ubBtiSt6l/|wkG64}d;">
                               <block type="logic_operation" id="ZZhu%#gawc,]3/d:Aba/" inline="false">
                                   <block type="logic_negate" id="6;Hr@t|6~Hz!k5y|RhD0">
                                     <value name="BOOL">
                                       <block type="variables_get" id="O5N$32P(r=/d!5b=WZ#[">
                                   <block type="variables_get" id="b}?:7#q1c!ceD:]X#)WL">
                           <block type="timeouts_settimeout" id="qmT6f/(nmv@X@fuopHeT">
                               <block type="comment" id="UaB9Cr[jk,;ClTLU,nhl">
                                 <field name="COMMENT">Lastabwurf (1,8kW laden) beenden</field>
                                   <block type="control" id="[lIXy~ZA5FnFiF~VBQe/">
                                       <block type="logic_boolean" id="/oexX.IjL7{:cADc|55y">
                                       <block type="comment" id="JLFrf(1hcmU2w/dM`T($">
                                           <block type="control" id="VIqP?kgIFPzggbPL3nA:" disabled="true">
                                               <block type="logic_boolean" id="R[b7O7?[{cJr{h}n;C]/">
                                               <block type="variables_set" id="y|+5wTO|]!oWogp4CP6L">
                                                 <field name="VAR" id="]@YsD2#L/zM,THq9GqS[">PV_laden_3_7kW</field>
                                                   <block type="logic_boolean" id="QI`C4pdb=J4H-)kmsN1b">
                           <block type="comment" id="4^U_u2%h%:{p_2_nSk;L">
                             <field name="COMMENT">Laden Beenden</field>
                               <block type="controls_if" id="m@5jE)W9TrLWYyWfH5~/">
                                   <block type="logic_compare" id="0N?~zQzK+8QPhMVQI91T">
                                     <field name="OP">LT</field>
                                       <block type="on_source" id="pruOR[Iw=EW~:c6sEE{X">
                                       <block type="math_number" id="#Atkqp^N?6sPqLtus+dy">
                                         <field name="NUM">1000</field>
                                   <block type="timeouts_cleartimeout" id="pmJVFRiw^N1CaF^TNW$|">
                                     <field name="NAME">Timeout_ladung</field>
                                       <block type="timeouts_cleartimeout" id="klMU@ROv}+)Y_rZ`w~F@">
                                         <field name="NAME">Timeout_Aus</field>
                                 <value name="IF1">
                                   <block type="logic_negate" id="/`X#*6~3YLYQ.x~4x:RW">
                                     <value name="BOOL">
                                       <block type="variables_get" id="7=[8sze_(p8OQ#(#Vk3%">
                                   <block type="controls_if" id="0#UePKmT!/G=Cw2acVT8">
                                       <block type="variables_get" id="^9cz-ty!3e{q}sRWV1]$">
                                       <block type="controls_if" id="j3jDf]s{6se)2ZnJ9IC!">
                                           <block type="logic_negate" id="m9f$G~}_1r_%Y1pKH1II">
                                             <value name="BOOL">
                                               <block type="timeouts_gettimeout" id="C~D=?ovIeI/ztL[(PL:f">
                                           <block type="timeouts_settimeout" id="dQ!K)FB?m/YM^P#sC*DG">
                                             <field name="DELAY">4</field>
                                               <block type="comment" id="`UBRn~o47hO%[*urSD;x">
                                                   <block type="control" id="6P[j9~,ThS5.6)4|Uv~I">
                                                       <block type="logic_boolean" id="d7I}K~Ge$J{?]seuXW6R">
                                                       <block type="variables_set" id="x=pNl?3le_!m/HuFBgOk">
                                                           <block type="logic_boolean" id="[}zSMva!{7gwFV.*b$w{">
                                     <value name="IF1">
                                       <block type="logic_negate" id="kkz5jcTfmn?dZ[NO*x*:">
                                         <value name="BOOL">
                                           <block type="timeouts_gettimeout" id="2WjOw;3@JwLvHY%c%B^k">
                                       <block type="timeouts_settimeout" id="mU~cyc5)|eM2[RfU[Us%">
                                           <block type="comment" id="Dj]!T4pK3AXd6LD-WTzw">
                                               <block type="control" id="$6hC:h9r7POj2%.!z~D%">
                                                   <block type="logic_boolean" id="O[fz8v!rbK^6ffjYQ5mh">
                                                   <block type="variables_set" id="#pvQ0Y/bV/==;q6`WGKY">
                                                       <block type="logic_boolean" id="L_*.0Z_2ug,nv=t/}dUD">
           <block type="comment" id="},68DrkN]Qs0sxrqunPE">
             <field name="COMMENT">Ladepriorisierung Taster</field>
               <block type="on" id="sR_dvCQ)1/3!=1!C:b`j">
                 <field name="CONDITION">gt</field>
                   <block type="comment" id="EWUYteUc2lgAjYIushWK">
                       <block type="control" id="Wt~4R%K^mNn#HzO}G}bd">
                           <block type="logic_boolean" id=",ev#lF494;UaT:h6z`g#">
                           <block type="comment" id="?]0Pb1?CYP3lhu+)dIJM">
                             <field name="COMMENT">Ladfreigabe Wallbox</field>
                               <block type="control" id="m5!sdC45DHMO~mwjz(Rw">
                                   <block type="logic_boolean" id="#DW|QhnR4g8iMY://uE@">
                                   <block type="variables_set" id="#Ou%SJ`ssQrmMQZ:lR4@">
                                       <block type="logic_boolean" id="NQubyOf86$`BtadX1+h1">
                                       <block type="timeouts_cleartimeout" id="{RRzWHB_[ab2F2|O|i%w">
                                           <block type="timeouts_cleartimeout" id="n]PnPMvpWO-bd[]63z/U">
                                               <block type="timeouts_cleartimeout" id="n;CgQ,7[Msta)GRGGWVU">
                                                   <block type="timeouts_cleartimeout" id="2llI`Vw)5;MsmpwG^UX+">
                                                       <block type="timeouts_settimeout" id="I=o*dw`qwZZvu,Xp,YN4">
                                                         <field name="DELAY">240</field>
                                                           <block type="comment" id="[JPzfN,QJ{!8L6uHXo[|">
                                                               <block type="control" id="c}xSZrphnZgxgV+^,IW,">
        <block type="logic_boolean" id="UhwRBjXX3S9VQ6R-;GLz">
        <block type="variables_set" id="p=G#u7u6r5TX)zGt]5jm">
        <block type="logic_boolean" id="IR_-UZrv0PcDxg-D9b}]">
        Sub7 @paul53 last edited by Sub7
        @paul53 said in Überschussladung an nicht-smarter Wallbox Hilfe!?:
        Ich danke Dir, ich werde es morgen Mittag testen und berichten.
        Wünsche Dir noch einen schönen Abend
        Edit: Hat alles Funktioniert, danke @paul53
          Sub7 @Sub7 last edited by
          ich habe jetzt noch ein paar Dinge an dem Skript mehr oder weniger sinnvoll eingefügt.
          Soweit funktioniert alles und ich freue mich das Ganze bald in der Praxis zu testen.
          @paul53 Jetzt fehlt mir nur noch eine Funktion mit der ich über einen Taster den gestarteten Ladevorgang (Ladepriorisierung) abbrechen kann. Wenn Du mir hierbei noch helfen könntest wäre echt super.
            <variables>
            </variables>
              <field name="OID">shelly.0.SHEM-3#3494547559AD#1.Emeter2.Power</field>
                              <field name="NUM">-1400</field>
                      <value name="IF1">
                              <value name="BOOL">
                                  <value name="BOOL">
                                  <value name="BOOL">
                          <field name="DELAY">3</field>
                                          <field name="OID">hm-rpc.0.00021A49A85AF2.3.STATE</field>
                                          <field name="DELAY_MS">2</field>
                                      <field name="NUM">-1300</field>
                              <value name="IF1">
                                      <value name="BOOL">
                                          <value name="BOOL">
                                              <field name="NUM">1100</field>
                                      <value name="IF1">
                                          <value name="BOOL">
                                                  <value name="BOOL">
                                          <value name="IF1">
                                              <value name="BOOL">
                                              <field name="DELAY">6</field>
                    <block type="on_ext" id="L#YE!lPD[B=Dr)bg)Er3">
                      <value name="OID0">
                        <shadow type="field_oid" id=".C8^%a2*C4?O%e#@,jl]">
                          <field name="oid">mqtt.0.shellyplusi4-485519993044.status.input:0</field>
                      <value name="OID1">
                        <shadow type="field_oid" id="S#F48={NAgosgE90Q6g}">
                          <field name="oid">javascript.0.Eigene_Datenpunkte.Test.Taster_laden_ein</field>
                        <block type="controls_if" id="=1P,#;x|%y#gJz0a3hPL">
                            <block type="logic_operation" id="ZfN/_NbRz}{9@_G[|bu." inline="false">
                              <field name="OP">OR</field>
                                <block type="logic_compare" id="YSbAM)AyF2$xBY({I,:T">
                                  <field name="OP">EQ</field>
                                    <block type="get_value" id="40OaS:?n)J)W5Q-a~FNg">
                                      <field name="OID">mqtt.0.shellyplusi4-485519993044.status.input:0</field>
                                    <block type="text" id="phl.R!y6=%7dyaxvgo8:">
                                      <field name="TEXT">{"id":0,"state":true}</field>
                                <block type="logic_compare" id="Yw4,8g)][G=sSAhn,8f_">
                                    <block type="get_value" id="yAM5P%{A4){nr$RC7~XB">
                                      <field name="OID">javascript.0.Eigene_Datenpunkte.Test.Taster_laden_ein</field>
                                    <block type="logic_boolean" id=")6LC?yI8E!:8M;@m2-B|">
        <field name="DELAY">320</field>
                        <block type="comment" id="=4sOoG*8Su?UfHIYD6e=">
                          <field name="COMMENT">Ladezustandsanzeige</field>
                            <block type="on_ext" id="qE)3NloHa(xD@0r2prcC">
                              <mutation xmlns="http://www.w3.org/1999/xhtml" items="4"></mutation>
                              <value name="OID0">
                                <shadow type="field_oid" id="k}+HV}TbmJesp`dM2.mg">
                                  <field name="oid">hm-rpc.0.000218A995E697.3.STATE</field>
                              <value name="OID1">
                                <shadow type="field_oid" id="#Z8b.RI7f1vTm,W*wrfZ">
                              <value name="OID2">
                                <shadow type="field_oid" id="AO.(BxeWYppO6ScYJiWd">
                                  <field name="oid">javascript.0.Eigene_Datenpunkte.Test.Taster_laden_beenden</field>
                              <value name="OID3">
                                <shadow type="field_oid" id="D}d3Gfo7D.~`,_=j3E3W">
                                  <field name="oid">hm-rpc.0.00021A49A85AF2.3.STATE</field>
                                <block type="controls_if" id="QYffXS!FX!z[VEB8-xE6">
                                  <mutation elseif="3"></mutation>
                                    <block type="logic_operation" id="Ym|/4=H5Sx,q-V:%L/D1" inline="false">
                                        <block type="logic_compare" id="q@+3bG3j7A%vm8vMNG/8">
                                            <block type="get_value" id="%#0DW`0PUoh5B7xl=G_q">
                                            <block type="logic_boolean" id="R_!X3P6dd2O83Eb4J?MI">
                                        <block type="logic_operation" id="oK]we2|2w3IM,S@^S:.T" inline="false">
                                            <block type="logic_compare" id="gx^`enTQ0_/z_z8ELFu4">
                                                <block type="get_value" id="`J2/V32[e?Rt,r-iOU-L">
                                                <block type="logic_boolean" id="xvOZI^@ha0q}fLEcBZrt">
                                            <block type="logic_negate" id="43XKO0pvD{Pxf|Gnn6N+">
                                              <value name="BOOL">
                                                <block type="variables_get" id="*IUq=op+S5~t6LxOAmD{">
                                    <block type="control" id="41;AiE$Rat^_Uo_KC9@s">
                                      <field name="OID">javascript.0.Eigene_Datenpunkte.Test.Ladezustand_Wallbox</field>
                                        <block type="text" id="b7yCL5_(gs|s}yE:teKS">
                                          <field name="TEXT">Manueller Start</field>
                                  <value name="IF1">
                                    <block type="logic_compare" id="aOE?L3Aax?rFY;E?;h+)">
                                        <block type="logic_operation" id="[GAu+u8`}|GEc[$P~Px]" inline="false">
                                            <block type="get_value" id="q.zFhW?77`){`a,3O;2c">
                                            <block type="get_value" id="I*dEL8fJ0(QSrL^$L;K9">
                                        <block type="logic_boolean" id="vGwwiDT7x@i?$40CfdvN">
                                    <block type="control" id="[u0}@=s`#k9qm-E#S#6t">
                                        <block type="text" id="4@:iTLGOi5@}z0l]-|BX">
                                          <field name="TEXT">Laden 1.8kW</field>
                                  <value name="IF2">
                                    <block type="logic_operation" id="zRY=}*R6VJZ$PA!Q|-N)" inline="false">
                                        <block type="logic_negate" id="*O=~+O0?x|mP@OFvlOa)">
                                          <value name="BOOL">
                                            <block type="variables_get" id=":srI7$6*Tq3)9FLRtULn">
                                        <block type="logic_operation" id="UgC$V2T}fgTack?Ff$a(" inline="false">
                                            <block type="logic_compare" id="VoZZE|-VX7]GT[blR}*!">
                                                <block type="get_value" id="}Qxo:(itxtp=e8[lc9Q2">
                                                <block type="logic_boolean" id="8PFO~GjzYp}N/Y8(PrDU">
                                            <block type="logic_compare" id="cBfqtN;]XzKpJQy|74=P">
                                                <block type="get_value" id="Q-Sd?4^d#edu+vqx2Won">
                                                <block type="logic_boolean" id="n*y//0^hLAL4;y;CB!o]">
                                  <statement name="DO2">
                                    <block type="control" id="Afbw%P.BGNTl+~{vb?um">
                                        <block type="text" id="XA@LIztXvllxsqboU-m+">
                                          <field name="TEXT">Laden 3.7kW</field>
                                  <value name="IF3">
                                    <block type="logic_compare" id="=Z{B^YO/]BZrAUTe2!LB">
                                        <block type="get_value" id="okn(7BG.#4.!fm}iAz!7">
                                        <block type="logic_boolean" id="L=;jv*5)T%SVrn-:yzWb">
                                  <statement name="DO3">
                                    <block type="control" id=".ySJ`BN!`XSP=Z?bR{}F">
                                        <block type="text" id="q,$o3Wye1fTM#dT5+P3A">
                                          <field name="TEXT">Keine Freigabe</field>
                                    <block type="comment" id="P!)CRi@KlveMm|6KS)XL">
                                      <field name="COMMENT">Countdown Ladepriorisierung</field>
                                        <block type="controls_if" id="f-0=|p{LwILBP!{pr$x$">
                                            <block type="variables_get" id="9pS0tR~hiLkWRUq3[num">
                                            <block type="control" id="pi0QSlq*+SeHcWE;SeN_">
                                              <field name="OID">mytime.0.Countdown.Test.cmd</field>
                                                <block type="text" id="=NW:~$L}7_Q-M.xqnaL5">
                                                  <field name="TEXT">start</field>
                                          <statement name="ELSE">
                                            <block type="control" id="u_riLpm/J#!GAk$d)?5q">
                                                <block type="text" id="8qqA_m(MJgu.GJDnfIC`">
                                                  <field name="TEXT">end</field>
            paul53 @Sub7 last edited by paul53
            @sub7 sagte: über einen Taster den gestarteten Ladevorgang (Ladepriorisierung) abbrechen kann.
            Ist "javascript.0.Eigene_Datenpunkte.Test.Taster_laden_ein" ein Taster oder ein Schalter? Im Skript wird er auf "wahr" geprüft zum Einschalten der Ladepriorisierung. Wenn es ein Schalter ist, könnte bei "falsch" die Ladepriorisierung beendet werden.
            Wie verhält es sich mit dem DP "mqtt.0.shellyplusi4-485519993044.status.input:0"?
            EDIT: Weshalb wird bei "Ladezustandsanzeige" auf Datenpunkte getriggert, die innerhalb der Callback-Funktion nicht ausgewertet werden?
            Übrigens: Zum Schreiben eigener Datenpunkte verwendet man besser "aktualisiere" anstelle von "steuere".
              Der Shelly ist ein Hardwaretaster (Serientaster zwei Tastwippen) bisher aber nur ein Kanal in Verwendung für Ladepriorisierung und die anderen beiden sollen Softwaretaster in der VIS vom Tablet sein (Taster-Ein Ladeprio Taster-Aus Ladepriorisierung ohne Ablauf der Zeit beenden).
              Den Rest mit den Variablen steig ich noch nicht ganz durch, aber im Trockenversuch mit den Schaltsteckdosen funktioniert es, ist halt wieder völlig umständlich und teilweise doppelt umgesetzt.
              Sorry für meine kurzen Antworten, muss aber gerade vom Smartphone schreiben.
                @sub7 sagte: Taster-Aus Ladepriorisierung
                Dann dafür einen eigenen Trigger auf "ist wahr" verwenden.
                Wenn man bei den beiden Tastern für "Ladepriorisierung Ein" auf "ist größer als letztes" triggert, kann man sich die Oder-Abfragen sparen.
                  So, bin jetzt zuhause und habe die Änderungen eingepflegt, sieht jetzt wie folgt aus.
                    <variables>
                    </variables>
                              <value name="IF1">
                                      <value name="BOOL">
                                          <value name="BOOL">
                                          <value name="BOOL">
                                      <value name="IF1">
                                              <value name="BOOL">
                                                  <value name="BOOL">
                                              <value name="IF1">
                                                  <value name="BOOL">
                                                          <value name="BOOL">
                                                  <value name="IF1">
                                                      <value name="BOOL">
                              <value name="OID0">
                              <value name="OID1">
        <block type="comment" id="wteP^$GXA`N^22R?KhCi">
        <block type="control" id="Y%?cWoX:k~;@A]d6bGi#">
        <block type="logic_boolean" id="MOwKytL#:_lk*|%g??oL">
        <block type="variables_set" id="TU1dc|o]Re+hJ*NCZM,h">
        <block type="logic_boolean" id="_BSPxo(n6{HQ.Gq$tfxR">
                                <block type="comment" id="r#tz-vTLkT*8,2j`1,;f">
                                  <field name="COMMENT">Ladepriorisierung beenden Taster</field>
                                    <block type="on_ext" id="z/?.cqXX1Fy}8j0Myu`-">
                                      <value name="OID0">
                                        <shadow type="field_oid" id="((.8;ox^p5*/sfPk*PhR">
                                              <value name="OID0">
                                              <value name="OID1">
                                              <value name="OID2">
                                              <value name="OID3">
                                                              <value name="BOOL">
                                                  <value name="IF1">
                                                  <value name="IF2">
                                                          <value name="BOOL">
                                                  <value name="IF3">
                    @sub7 sagte: sieht jetzt wie folgt aus.
                    Was sollen die beiden Taster-DP in diesem Trigger?
                      Ich war mir nicht sicher ob ich die brauche, ich nehme wenn ich mir unsicher bin im Zweifelsfall ein Paar Datenpunkte zuviel rein, bevor mir nachher der Trigger in einer nötigen Situation nicht auslöst. Mache ich aber auch raus wenn es für Dich keinen Sinn ergibt.
                        @sub7 sagte: Mache ich aber auch raus wenn es für Dich keinen Sinn ergibt.
                        Das ergibt keinen Sinn, da die Datenpunkte in der Callback-Funktion des Triggers nicht ausgewertet werden. Sie erzeugen nur unnötigen Ressourcen-Verbrauch.
                        1737
