    • mickym
      mickym Most Active @Damrak2022 last edited by
      @damrak2022 Du hast den Flow nicht mehr?
      Wenn ich nicht alles für Dich aufheben würde. 😉
             "id": "06f078839c4a3e62",
             "type": "inject",
             "z": "289f539dcc33814e",
             "name": "Array in payload",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "[\"A\",\"n\",\"d\",\"y\"]",
             "payloadType": "json",
             "x": 2500,
             "y": 1220,
             "wires": [
                     "5fb2037cc82456a9",
                     "6cd003b9f6e813f8",
                     "08ef860ee820edba"
             "id": "5e9b8fb2f4a07204",
             "type": "debug",
             "name": "Ergebnis",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "statusType": "auto",
             "x": 3260,
             "y": 1220,
             "wires": []
             "id": "5fb2037cc82456a9",
             "type": "split",
             "name": "",
             "splt": "\\n",
             "spltType": "str",
             "arraySplt": 1,
             "arraySpltType": "len",
             "stream": false,
             "addname": "",
             "x": 2670,
             "y": 1220,
             "wires": [
                     "16eec1b48bf24e21",
                     "6299663e446a21c2"
             "id": "6cd003b9f6e813f8",
             "type": "debug",
             "name": "Ausgabe Array",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 2700,
             "y": 1120,
             "wires": []
             "id": "5d3dbb02f84f1ae9",
             "type": "join",
             "name": "",
             "mode": "reduce",
             "build": "object",
             "property": "payload",
             "propertyType": "msg",
             "key": "topic",
             "joiner": "\\n",
             "joinerType": "str",
             "accumulate": true,
             "timeout": "",
             "count": "",
             "reduceRight": false,
             "reduceExp": "$A & payload",
             "reduceInit": "",
             "reduceInitType": "str",
             "reduceFixup": "",
             "x": 3110,
             "y": 1220,
             "wires": [
                     "5e9b8fb2f4a07204"
             "id": "6299663e446a21c2",
             "type": "change",
             "name": "Ändern in Großbuchstaben",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "$uppercase(payload)\t",
                     "tot": "jsonata"
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "Name",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2900,
             "y": 1220,
             "wires": [
                     "5d3dbb02f84f1ae9"
      • Damrak2022
        @mickym Das hatte ich sogar noch:
        Also kommt eine Split node dahin und eine change node dahinter
        Aber wie muss ich dann die Change node konfigurieren?
        • mickym
          @damrak2022 Wer sagt Dir denn dass Du eine Change Node brauchst? Die war damals nur darin um die payload in Großbuchstaben zu verändern, wir wollen aber nur die Sequenz der einzelnen Nachrichten reduzieren.
          • Damrak2022
            @mickym Wenn ich im Dashboard was schalte, bekomme ich diesen Debug:
            Bildschirm­foto 2022-12-27 um 21.35.59.png Bildschirm­foto 2022-12-27 um 21.35.48.png
            • mickym
              @damrak2022 Nein - dieses Mal etwas anders.
              Vielleicht machst Du erst noch mal eine Debug Node hinter die split Node und erklärst was die macht.
              • mickym
                mickym Most Active @mickym last edited by
                @mickym Tja
                0truefalsetrue
                ist etwas komisches Ergebnis. 😉 - Also musst Du erst mal wieder verstehen, was die Sequenz reduzieren bedeutet. Deshalb schau mal die split Node an und am Besten kopierst du auch die Eigenschaften des Objektes wieder zurück in das topic.
                • Damrak2022
                  @mickym Sie gibt die Parts aus
                  Damrak2022 mickym 2 Replies Last reply Reply Quote 0
                  • Damrak2022
                    Damrak2022 @Damrak2022 last edited by
                    @damrak2022 Wohin soll ich die Eigenschaften kopieren? Ich erinner mich noch das bei Aufteilung alles mögliche eingeben kann
                    • mickym
                      @damrak2022 Ja wichtig ist aber das nun alle Teile des Objektes wieder in einzelne Nachrichten ausgegeben werden und dass Du richigerweise die Objekteigenschaft in das topic kopiert hast. Also das hast Du richtig gemacht, wie ich an der Debugausgabe gesehen habe.
                      So was steht nun in der Hilfe zur JOIN Node - zum Thema Squenz reduzieren.
                      Du hast ja wieder rausgelöscht, wie Deine JOIN Node aussieht.
                      Was ist denn $A ?
                      • Damrak2022
                        @mickym So sehen jetzt meine Split und join node aus:
                        Bildschirm­foto 2022-12-27 um 21.46.41.png Bildschirm­foto 2022-12-27 um 21.46.26.png
                        Was $A ist weiß ich nicht mehr
                        Das steht in der Hilfe zur Join Node:
                        Sequenz reduzieren
                        Einen Ausdruck auf alle Nachrichten einer Sequenz anwenden, um sie auf eine einzige Nachricht zu reduzieren.
                        • mickym
                          @damrak2022 Dis split Node ist OK. Bei der JOIN Node müssen wir jetzt was anderes machen. Weil wir ja jetzt die payload nicht wieder zusammenhängen wollen.
                          Zur Erinnerung: Wir wollen in einem Fall alle Nachrichten mit UND verknüpfen, um zu analysieren dass alle Geräte eingeschaltet sind, im anderen Fall alle Nachrichten mit ODER verknüpfen um zu analysieren ob alle Geräte ausgeschaltet sind.
                          • Damrak2022
                            @mickym Ja
                            • mickym
                              @damrak2022 sagte in Visualisierung mit Node Red erstellen:
                              Sequenz reduzieren
                              Genau:
                              In der $A wird also das Gesamtergebnis festgehalten.
                              Also die erste Nachricht kommt an und das Ergebnis des Reduktionsausdrucks wird wieder in $A gespeichtert.
                              Die zweite Nachricht kommt an und das Ergebnis des Reduktionsausdrucks wird wieder in $A gespeichert.
                              usw.
                              Als wir die Buchstaben zum Wort zusammengesetzt haben haben wir $A & payload im Reduktionsausdruck angegeben.
                              Deshalb wurde Dein Name gebildet.
                              Am Anfang stand in $A nichts. Dann kam ein A in der payload an. Dann hast Du nichts mit A verknüpft und in $A stand A.
                              Dann kam in der nächsten Nachricht ein N an. Du hast also den Inhalt von $A - nämlich A - nun mit einem N verknüpft und deshalb stand in $A nun AN usw.
                              So nun wollen wir alles entweder mit UND oder ODER verknüpfen und das Ergebnis in $A abspeichern.
                              Damit das Ergebnis richtig wird geben wir noch den richtigen Anfangswert für $A mit. Bei der UND Verknüpfung ein boolesches true, bei der ODER Verknüpfung ein boolesches ODER.
                              Wie Du mit JSONATA UND und ODER verknüpfst steht hier in der JSONATA Doku: https://docs.jsonata.org/boolean-operators
                              • Damrak2022
                                @mickym sagte in Visualisierung mit Node Red erstellen:
                                Habe da reingeschaut, aber wirklich kapieren tue ich diese Erklärungen nie: Heißt das hinter das $A muss noch ein $boolean, also so:
                                $A,$boolean
                                • mickym
                                  @damrak2022 Nein Du verknüpfst im Reduktionsausdruck das Ergebnis der vorigen Nachricht mit der payload der aktuellen Nachricht.
                                  Also in der einen Node mit der Du alle Nachrichten mit UND verknüpfen willst, um zu überprüfen ob alles AN ist, gibst Du als Reduktionsausdruck an
                                  $A and payload
                                  in der Node - in der Du die Nachrichten alle mit ODER verknüpfen willst, verknüpfst Du
                                  $A or payload
                                  in der Node - in der Du mit ODER verknüpfst, initialisierst Du $A mit false, in der Node, in der Du mit UND verknüpfst initialisierst Du den Anfangswert $A mit true.
                                  • Damrak2022
                                    @mickym Bildschirm­foto 2022-12-27 um 22.16.04.png Bildschirm­foto 2022-12-27 um 22.15.55.png
                                    • mickym
                                      @damrak2022 Richtig. Gut 👍 Ich hoffe nur, dass Du die richtige Verknüpfung an der richtigen Node gemacht hast.
                                      • Damrak2022
                                        @mickym Ja, habe ich
                                        • mickym
                                          @damrak2022 Gut dann kannst Du dieses Ergebnis ja nun in die beiden Datenpunkte schreiben. Wobei eigentlich brauchst das eigentlich nicht in die datenpunkte schreiben. Die kannst eigentlich löschen und kannst das Ergebnis auch direkt im Dashboard ausgeben.
                                          Also lösche die iobroker OUT nodes und die beiden Datenpunkte.
                                          • Damrak2022
                                            @mickym Habe ich versucht. In allen Datenpunkten bei den Shellys bei Switch den Haken bei "bestätigt" gesetzt und Wert schreiben geklickt. In den Datenpunkten ist allerdings noch nichts zu sehen.
                                            2369313
