    4. [gelöst] Kein Webinterface nach fehlerhaftem update
    • haselchen
      haselchen Most Active @Dima S last edited by
      @dima-s
      Du hast den Passwort Schutz bzw SSL aktiv
      iobroker set admin.0 --ssl false
      und dann
      iobroker start admin.0
      • Dima S
        @dp20eic
        So, das update von buster auf bullseye hat etwas gedauert.
        Das System ist auf dem aktuellem Stand.
        Anbei ein aktuelles Auszug aus den Logfiles:
        pi@ioBroker:/opt/iobroker $ grep -i 'admin.0' log/iobroker.current.log
        2022-12-28 13:41:14.353  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 13:41:19.388  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 13:41:26.476  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 13:41:49.686  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 13:42:01.013  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 13:42:01.501  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 13:42:02.161  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 13:56:10.353  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 13:56:12.940  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 13:56:41.444  - error: host.ioBroker No adapter name is specified for readBaseSettings command from  system.adapter.admin.0
        2022-12-28 14:39:46.960  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 14:41:59.204  - info: admin.0 (1390) ==> Connected system.user.admin from ::ffff:192.168.50.38
        2022-12-28 15:09:38.204  - info: host.ioBroker iobroker host.ioBroker Adapter "system.adapter.admin.0" is stopped.
        2022-12-28 15:09:38.259  - info: admin.0 (1390) Adapter is disabled => stop
        2022-12-28 15:09:38.262  - info: admin.0 (1390) terminating https server on port 8081
        2022-12-28 15:09:38.364  - info: host.ioBroker "system.adapter.admin.0" disabled
        2022-12-28 15:09:38.366  - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=true)
        2022-12-28 15:09:38.389  - info: admin.0 (1390) Got terminate signal TERMINATE_YOURSELF
        2022-12-28 15:09:38.394  - info: admin.0 (1390) terminating
        2022-12-28 15:09:38.396  - info: admin.0 (1390) Terminated (NO_ERROR): Without reason
        2022-12-28 15:09:38.400  - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
        2022-12-28 15:09:39.132  - info: host.ioBroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2022-12-28 15:21:36.021  - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=false)
        2022-12-28 15:22:34.269  - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=false)
        2022-12-28 15:41:54.639  - info: host.ioBroker "system.adapter.admin.0" enabled
        2022-12-28 15:41:56.635  - info: host.ioBroker instance system.adapter.admin.0 started with pid 30138
        2022-12-28 15:41:58.221  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 15:41:58.221  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 15:42:28.520  - info: host.ioBroker instance system.adapter.admin.0 started with pid 31046
        2022-12-28 15:42:30.754  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 15:42:30.755  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 15:43:01.080  - info: host.ioBroker instance system.adapter.admin.0 started with pid 31971
        2022-12-28 15:43:02.641  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 15:43:02.642  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 15:43:32.882  - info: host.ioBroker instance system.adapter.admin.0 started with pid 415
        2022-12-28 15:43:34.564  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 15:43:34.564  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 15:44:04.797  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1703
        2022-12-28 15:44:06.365  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 15:44:06.366  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 15:44:36.577  - info: host.ioBroker instance system.adapter.admin.0 started with pid 2655
        2022-12-28 15:44:38.165  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 15:44:38.165  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 15:45:08.366  - info: host.ioBroker instance system.adapter.admin.0 started with pid 3570
        2022-12-28 15:45:10.203  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 15:45:10.204  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 15:45:40.538  - info: host.ioBroker instance system.adapter.admin.0 started with pid 4539
        2022-12-28 15:45:42.327  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 15:45:42.327  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 15:46:12.488  - info: host.ioBroker instance system.adapter.admin.0 started with pid 5422
        2022-12-28 15:46:14.163  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 15:46:14.163  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 15:46:44.379  - info: host.ioBroker instance system.adapter.admin.0 started with pid 6355
        2022-12-28 15:46:46.183  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:11:42.376  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:12:12.723  - info: host.ioBroker instance system.adapter.admin.0 started with pid 11543
        2022-12-28 18:12:16.209  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:12:16.209  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:12:44.033  - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=false)
        2022-12-28 18:13:56.113  - info: host.ioBroker instance system.adapter.admin.0 started with pid 731
        2022-12-28 18:13:57.989  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:13:57.989  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:14:28.665  - info: host.ioBroker instance system.adapter.admin.0 started with pid 861
        2022-12-28 18:14:30.844  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:14:30.845  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:15:01.324  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1058
        2022-12-28 18:15:04.519  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:15:04.519  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:15:37.531  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1266
        2022-12-28 18:15:39.795  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:15:39.795  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:16:10.186  - info: host.ioBroker instance system.adapter.admin.0 started with pid 2137
        2022-12-28 18:16:12.620  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:16:12.620  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:16:42.882  - info: host.ioBroker instance system.adapter.admin.0 started with pid 3096
        2022-12-28 18:16:44.403  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:16:44.403  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:17:14.686  - info: host.ioBroker instance system.adapter.admin.0 started with pid 4163
        2022-12-28 18:17:16.339  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:17:16.339  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:17:46.516  - info: host.ioBroker instance system.adapter.admin.0 started with pid 5181
        2022-12-28 18:17:48.271  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:17:48.271  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:18:18.466  - info: host.ioBroker instance system.adapter.admin.0 started with pid 6377
        2022-12-28 18:18:20.091  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:18:20.091  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:18:50.386  - info: host.ioBroker instance system.adapter.admin.0 started with pid 7438
        2022-12-28 18:18:55.329  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:18:55.330  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:19:25.550  - info: host.ioBroker instance system.adapter.admin.0 started with pid 8430
        2022-12-28 18:19:27.779  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:19:27.779  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:19:58.049  - info: host.ioBroker instance system.adapter.admin.0 started with pid 9398
        2022-12-28 18:19:59.754  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:19:59.755  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:20:29.980  - info: host.ioBroker instance system.adapter.admin.0 started with pid 10421
        2022-12-28 18:20:31.618  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:20:31.619  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:21:01.890  - info: host.ioBroker instance system.adapter.admin.0 started with pid 11372
        2022-12-28 18:21:03.688  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:21:03.688  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:21:34.122  - info: host.ioBroker instance system.adapter.admin.0 started with pid 12291
        2022-12-28 18:21:35.745  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:21:35.745  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:22:06.209  - info: host.ioBroker instance system.adapter.admin.0 started with pid 13255
        2022-12-28 18:22:07.713  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:22:07.713  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:22:37.934  - info: host.ioBroker instance system.adapter.admin.0 started with pid 14172
        2022-12-28 18:22:40.563  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:22:40.563  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:23:10.726  - info: host.ioBroker instance system.adapter.admin.0 started with pid 15134
        2022-12-28 18:23:12.355  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:23:12.355  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:23:42.610  - info: host.ioBroker instance system.adapter.admin.0 started with pid 16212
        2022-12-28 18:23:44.238  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:23:44.239  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:24:14.415  - info: host.ioBroker instance system.adapter.admin.0 started with pid 17430
        2022-12-28 18:24:18.824  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:24:18.824  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:24:55.759  - info: host.ioBroker instance system.adapter.admin.0 started with pid 18756
        2022-12-28 18:24:58.680  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:24:58.680  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:25:28.925  - info: host.ioBroker instance system.adapter.admin.0 started with pid 19762
        2022-12-28 18:25:30.634  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:25:30.634  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:26:00.815  - info: host.ioBroker instance system.adapter.admin.0 started with pid 20687
        2022-12-28 18:26:02.529  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:26:02.530  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:26:32.732  - info: host.ioBroker instance system.adapter.admin.0 started with pid 21570
        2022-12-28 18:26:34.347  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:26:34.347  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:27:04.580  - info: host.ioBroker instance system.adapter.admin.0 started with pid 22515
        2022-12-28 18:27:06.278  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:27:06.278  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:27:36.500  - info: host.ioBroker instance system.adapter.admin.0 started with pid 23437
        2022-12-28 18:27:38.075  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:27:38.075  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:28:08.287  - info: host.ioBroker instance system.adapter.admin.0 started with pid 24381
        2022-12-28 18:28:10.485  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:28:10.486  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:28:40.649  - info: host.ioBroker instance system.adapter.admin.0 started with pid 25308
        2022-12-28 18:28:42.342  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:28:42.342  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:29:12.515  - info: host.ioBroker instance system.adapter.admin.0 started with pid 26265
        2022-12-28 18:29:14.137  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:29:14.138  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:29:44.362  - info: host.ioBroker instance system.adapter.admin.0 started with pid 27169
        2022-12-28 18:29:47.149  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:29:47.150  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:30:17.386  - info: host.ioBroker instance system.adapter.admin.0 started with pid 28308
        2022-12-28 18:30:18.957  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:30:18.957  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:30:49.186  - info: host.ioBroker instance system.adapter.admin.0 started with pid 29175
        2022-12-28 18:30:50.775  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:30:50.775  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:31:21.008  - info: host.ioBroker instance system.adapter.admin.0 started with pid 30085
        2022-12-28 18:31:22.579  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:31:22.579  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:31:52.747  - info: host.ioBroker instance system.adapter.admin.0 started with pid 30911
        2022-12-28 18:31:54.740  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:31:54.740  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:32:24.924  - info: host.ioBroker instance system.adapter.admin.0 started with pid 31932
        2022-12-28 18:32:26.598  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:32:26.598  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:32:56.969  - info: host.ioBroker instance system.adapter.admin.0 started with pid 418
        2022-12-28 18:32:58.618  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:32:58.618  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:33:28.867  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1637
        2022-12-28 18:33:30.558  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:33:30.558  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:34:00.784  - info: host.ioBroker instance system.adapter.admin.0 started with pid 2595
        2022-12-28 18:34:02.345  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:34:02.345  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:34:32.529  - info: host.ioBroker instance system.adapter.admin.0 started with pid 3486
        2022-12-28 18:34:34.231  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:34:34.232  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:35:04.460  - info: host.ioBroker instance system.adapter.admin.0 started with pid 4440
        2022-12-28 18:35:06.089  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:35:06.089  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:35:36.281  - info: host.ioBroker instance system.adapter.admin.0 started with pid 5358
        2022-12-28 18:35:37.973  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:35:37.973  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:36:08.193  - info: host.ioBroker instance system.adapter.admin.0 started with pid 6293
        2022-12-28 18:36:10.450  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:36:10.450  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:36:40.617  - info: host.ioBroker instance system.adapter.admin.0 started with pid 7215
        2022-12-28 18:36:42.208  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:36:42.208  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:37:12.440  - info: host.ioBroker instance system.adapter.admin.0 started with pid 8171
        2022-12-28 18:37:14.104  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:37:14.104  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:37:44.397  - info: host.ioBroker instance system.adapter.admin.0 started with pid 9076
        2022-12-28 18:37:46.094  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:37:46.094  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:38:16.295  - info: host.ioBroker instance system.adapter.admin.0 started with pid 10030
        2022-12-28 18:38:18.020  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:38:18.020  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:38:48.284  - info: host.ioBroker instance system.adapter.admin.0 started with pid 10946
        2022-12-28 18:38:49.912  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:38:49.913  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:39:20.122  - info: host.ioBroker instance system.adapter.admin.0 started with pid 11884
        2022-12-28 18:39:21.852  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:39:21.852  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:39:52.101  - info: host.ioBroker instance system.adapter.admin.0 started with pid 12798
        2022-12-28 18:39:53.847  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:39:53.847  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:40:24.013  - info: host.ioBroker instance system.adapter.admin.0 started with pid 13739
        2022-12-28 18:40:25.795  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:40:25.795  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:40:56.186  - info: host.ioBroker instance system.adapter.admin.0 started with pid 14694
        2022-12-28 18:40:57.890  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:40:57.890  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:41:28.287  - info: host.ioBroker instance system.adapter.admin.0 started with pid 15627
        2022-12-28 18:41:29.923  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:41:29.923  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:42:00.364  - info: host.ioBroker instance system.adapter.admin.0 started with pid 16584
        2022-12-28 18:42:02.013  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:42:02.014  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:42:32.221  - info: host.ioBroker instance system.adapter.admin.0 started with pid 17478
        2022-12-28 18:42:33.898  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:42:33.898  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:43:04.158  - info: host.ioBroker instance system.adapter.admin.0 started with pid 18434
        2022-12-28 18:43:05.840  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:43:05.840  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:43:36.061  - info: host.ioBroker instance system.adapter.admin.0 started with pid 19347
        2022-12-28 18:43:37.717  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:43:37.717  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:44:07.877  - info: host.ioBroker instance system.adapter.admin.0 started with pid 20302
        2022-12-28 18:44:09.630  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:44:09.631  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:44:40.436  - info: host.ioBroker instance system.adapter.admin.0 started with pid 21225
        2022-12-28 18:44:42.030  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:44:42.031  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:45:12.206  - info: host.ioBroker instance system.adapter.admin.0 started with pid 22181
        2022-12-28 18:45:13.930  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:45:13.930  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:45:44.195  - info: host.ioBroker instance system.adapter.admin.0 started with pid 23085
        2022-12-28 18:45:45.900  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:45:45.901  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:46:16.095  - info: host.ioBroker instance system.adapter.admin.0 started with pid 24037
        2022-12-28 18:46:17.838  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:46:17.838  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:46:48.298  - info: host.ioBroker instance system.adapter.admin.0 started with pid 24954
        2022-12-28 18:46:49.878  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:46:49.883  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:47:20.117  - info: host.ioBroker instance system.adapter.admin.0 started with pid 25891
        2022-12-28 18:47:21.788  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:47:21.789  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:47:52.009  - info: host.ioBroker instance system.adapter.admin.0 started with pid 26801
        2022-12-28 18:47:53.621  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:47:53.621  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:48:23.838  - info: host.ioBroker instance system.adapter.admin.0 started with pid 27726
        2022-12-28 18:48:25.544  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:48:25.544  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:48:55.753  - info: host.ioBroker instance system.adapter.admin.0 started with pid 28835
        2022-12-28 18:48:57.746  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:48:57.746  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:49:27.986  - info: host.ioBroker instance system.adapter.admin.0 started with pid 29893
        2022-12-28 18:49:29.765  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:49:29.765  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:50:00.430  - info: host.ioBroker instance system.adapter.admin.0 started with pid 30934
        2022-12-28 18:50:02.147  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:50:02.148  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:50:39.084  - info: host.ioBroker instance system.adapter.admin.0 started with pid 32099
        2022-12-28 18:50:45.061  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:50:45.061  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:51:15.301  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1150
        2022-12-28 18:51:20.959  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:51:20.959  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:51:51.398  - info: host.ioBroker instance system.adapter.admin.0 started with pid 2224
        2022-12-28 18:51:53.059  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:51:53.059  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:52:23.358  - info: host.ioBroker instance system.adapter.admin.0 started with pid 3197
        2022-12-28 18:52:24.985  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:52:24.985  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:52:59.167  - info: host.ioBroker instance system.adapter.admin.0 started with pid 4378
        2022-12-28 18:53:00.976  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:53:00.976  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:53:31.456  - info: host.ioBroker instance system.adapter.admin.0 started with pid 6076
        2022-12-28 18:53:32.981  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:53:32.981  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:54:18.974  - info: host.ioBroker instance system.adapter.admin.0 started with pid 7556
        2022-12-28 18:54:20.610  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:54:20.610  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:54:50.808  - info: host.ioBroker instance system.adapter.admin.0 started with pid 8483
        2022-12-28 18:55:03.891  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:55:03.891  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:55:34.133  - info: host.ioBroker instance system.adapter.admin.0 started with pid 9707
        2022-12-28 18:55:38.959  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:55:38.960  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:56:20.050  - info: host.ioBroker instance system.adapter.admin.0 started with pid 11112
        2022-12-28 18:56:23.037  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:56:23.037  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:56:53.234  - info: host.ioBroker instance system.adapter.admin.0 started with pid 12121
        2022-12-28 18:56:54.949  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:56:54.949  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:57:47.931  - info: host.ioBroker instance system.adapter.admin.0 started with pid 13774
        2022-12-28 18:57:51.076  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:57:51.076  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:58:21.276  - info: host.ioBroker instance system.adapter.admin.0 started with pid 14787
        2022-12-28 18:58:26.508  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:58:26.508  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:58:56.707  - info: host.ioBroker instance system.adapter.admin.0 started with pid 15796
        2022-12-28 18:59:05.456  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 18:59:05.456  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 18:59:48.951  - info: host.ioBroker instance system.adapter.admin.0 started with pid 17436
        2022-12-28 19:00:05.388  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:00:05.388  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:00:35.598  - info: host.ioBroker instance system.adapter.admin.0 started with pid 18875
        2022-12-28 19:00:37.779  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:00:37.779  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:01:07.942  - info: host.ioBroker instance system.adapter.admin.0 started with pid 19867
        2022-12-28 19:01:10.712  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:01:10.712  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:01:47.063  - info: host.ioBroker instance system.adapter.admin.0 started with pid 21040
        2022-12-28 19:01:55.716  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:01:55.716  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:02:25.894  - info: host.ioBroker instance system.adapter.admin.0 started with pid 22261
        2022-12-28 19:02:51.366  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:02:51.366  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:03:21.640  - info: host.ioBroker instance system.adapter.admin.0 started with pid 23956
        2022-12-28 19:03:23.188  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:03:23.188  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:03:53.432  - info: host.ioBroker instance system.adapter.admin.0 started with pid 24836
        2022-12-28 19:03:57.539  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:03:57.539  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:04:27.735  - info: host.ioBroker instance system.adapter.admin.0 started with pid 25894
        2022-12-28 19:04:33.597  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:04:33.597  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:05:07.730  - info: host.ioBroker instance system.adapter.admin.0 started with pid 27097
        2022-12-28 19:05:09.717  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:05:09.717  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:05:40.833  - info: host.ioBroker instance system.adapter.admin.0 started with pid 28038
        2022-12-28 19:06:03.205  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:06:03.205  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:06:33.576  - info: host.ioBroker instance system.adapter.admin.0 started with pid 29646
        2022-12-28 19:06:36.101  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:06:36.102  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:07:13.779  - info: host.ioBroker instance system.adapter.admin.0 started with pid 30893
        2022-12-28 19:07:21.937  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:07:21.937  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:08:09.064  - info: host.ioBroker instance system.adapter.admin.0 started with pid 32379
        2022-12-28 19:08:37.825  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:08:37.825  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:09:08.261  - info: host.ioBroker instance system.adapter.admin.0 started with pid 2135
        2022-12-28 19:09:11.322  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:09:11.322  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:09:48.878  - info: host.ioBroker instance system.adapter.admin.0 started with pid 3330
        2022-12-28 19:09:51.002  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:09:51.002  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:10:22.990  - info: host.ioBroker instance system.adapter.admin.0 started with pid 4312
        2022-12-28 19:10:27.668  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:10:27.668  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:10:58.553  - info: host.ioBroker instance system.adapter.admin.0 started with pid 5502
        2022-12-28 19:11:29.274  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:11:29.274  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:11:59.523  - info: host.ioBroker instance system.adapter.admin.0 started with pid 7196
        2022-12-28 19:12:09.796  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:12:09.797  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:12:40.550  - info: host.ioBroker instance system.adapter.admin.0 started with pid 8376
        2022-12-28 19:12:50.814  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:12:50.814  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:13:21.161  - info: host.ioBroker instance system.adapter.admin.0 started with pid 9607
        2022-12-28 19:13:23.986  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:13:23.986  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:13:54.269  - info: host.ioBroker instance system.adapter.admin.0 started with pid 10737
        2022-12-28 19:13:58.051  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:13:58.052  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:15:04.219  - info: host.ioBroker instance system.adapter.admin.0 started with pid 12695
        2022-12-28 19:15:14.093  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:15:14.093  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:15:55.187  - info: host.ioBroker instance system.adapter.admin.0 started with pid 14326
        2022-12-28 19:15:56.892  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:15:56.892  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:16:43.064  - info: host.ioBroker instance system.adapter.admin.0 started with pid 15733
        2022-12-28 19:16:46.737  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:16:46.737  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:17:19.888  - info: host.ioBroker instance system.adapter.admin.0 started with pid 16738
        2022-12-28 19:17:36.520  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:17:36.521  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:18:08.304  - info: host.ioBroker instance system.adapter.admin.0 started with pid 18169
        2022-12-28 19:18:29.211  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:18:29.212  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:19:01.880  - info: host.ioBroker instance system.adapter.admin.0 started with pid 19814
        2022-12-28 19:19:15.040  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:19:15.040  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:19:45.232  - info: host.ioBroker instance system.adapter.admin.0 started with pid 21058
        2022-12-28 19:19:46.819  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:19:46.819  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:19:57.091  - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=false)
        2022-12-28 19:21:07.801  - info: host.ioBroker instance system.adapter.admin.0 started with pid 726
        2022-12-28 19:21:11.128  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:21:11.129  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:21:41.509  - info: host.ioBroker instance system.adapter.admin.0 started with pid 889
        2022-12-28 19:21:44.583  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:21:44.584  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:22:14.905  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1113
        2022-12-28 19:22:17.453  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:22:17.453  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:22:47.866  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1310
        2022-12-28 19:22:49.996  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:22:49.996  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:23:20.567  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1897
        2022-12-28 19:23:23.873  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:23:23.873  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:23:54.062  - info: host.ioBroker instance system.adapter.admin.0 started with pid 3001
        2022-12-28 19:23:56.296  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:23:56.297  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:24:26.470  - info: host.ioBroker instance system.adapter.admin.0 started with pid 4093
        2022-12-28 19:24:28.341  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:24:28.342  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:24:58.535  - info: host.ioBroker instance system.adapter.admin.0 started with pid 5079
        2022-12-28 19:25:00.430  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:25:00.430  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:25:30.594  - info: host.ioBroker instance system.adapter.admin.0 started with pid 6089
        2022-12-28 19:25:32.142  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:25:32.142  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:26:02.306  - info: host.ioBroker instance system.adapter.admin.0 started with pid 7026
        2022-12-28 19:26:03.995  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:26:03.995  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:26:34.237  - info: host.ioBroker instance system.adapter.admin.0 started with pid 7992
        2022-12-28 19:26:36.303  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:26:36.303  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:27:06.517  - info: host.ioBroker instance system.adapter.admin.0 started with pid 8977
        2022-12-28 19:27:08.109  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:27:08.110  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:27:38.277  - info: host.ioBroker instance system.adapter.admin.0 started with pid 9930
        2022-12-28 19:27:39.859  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:27:39.859  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:28:10.085  - info: host.ioBroker instance system.adapter.admin.0 started with pid 10901
        2022-12-28 19:28:11.715  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:28:11.715  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:28:41.986  - info: host.ioBroker instance system.adapter.admin.0 started with pid 11853
        2022-12-28 19:28:43.577  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:28:43.577  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:29:13.845  - info: host.ioBroker instance system.adapter.admin.0 started with pid 12829
        2022-12-28 19:29:15.486  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:29:15.486  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:29:45.650  - info: host.ioBroker instance system.adapter.admin.0 started with pid 13768
        2022-12-28 19:29:47.243  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:29:47.243  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:30:17.453  - info: host.ioBroker instance system.adapter.admin.0 started with pid 14743
        2022-12-28 19:30:19.049  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:30:19.049  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:30:49.317  - info: host.ioBroker instance system.adapter.admin.0 started with pid 15668
        2022-12-28 19:30:51.243  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:30:51.243  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:31:21.419  - info: host.ioBroker instance system.adapter.admin.0 started with pid 16636
        2022-12-28 19:31:23.176  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:31:23.176  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:31:53.343  - info: host.ioBroker instance system.adapter.admin.0 started with pid 17575
        2022-12-28 19:31:55.102  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:31:55.102  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:32:25.472  - info: host.ioBroker instance system.adapter.admin.0 started with pid 18550
        2022-12-28 19:32:27.141  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:32:27.142  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:32:57.380  - info: host.ioBroker instance system.adapter.admin.0 started with pid 19479
        2022-12-28 19:32:58.934  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:32:58.934  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:33:29.156  - info: host.ioBroker instance system.adapter.admin.0 started with pid 20450
        2022-12-28 19:33:30.760  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:33:30.760  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:34:00.972  - info: host.ioBroker instance system.adapter.admin.0 started with pid 21379
        2022-12-28 19:34:02.517  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:34:02.517  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:34:32.828  - info: host.ioBroker instance system.adapter.admin.0 started with pid 22365
        2022-12-28 19:34:34.379  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:34:34.379  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:35:04.618  - info: host.ioBroker instance system.adapter.admin.0 started with pid 23338
        2022-12-28 19:35:06.198  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:35:06.199  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:35:36.438  - info: host.ioBroker instance system.adapter.admin.0 started with pid 24291
        2022-12-28 19:35:37.991  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:35:37.991  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:36:08.226  - info: host.ioBroker instance system.adapter.admin.0 started with pid 25272
        2022-12-28 19:36:09.794  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:36:09.794  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:36:39.963  - info: host.ioBroker instance system.adapter.admin.0 started with pid 26363
        2022-12-28 19:36:41.806  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:36:41.806  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:37:12.031  - info: host.ioBroker instance system.adapter.admin.0 started with pid 27356
        2022-12-28 19:37:14.860  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:37:14.860  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:37:45.093  - info: host.ioBroker instance system.adapter.admin.0 started with pid 28312
        2022-12-28 19:37:46.619  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:37:46.619  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:38:16.982  - info: host.ioBroker instance system.adapter.admin.0 started with pid 29290
        2022-12-28 19:38:18.635  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:38:18.635  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:38:48.891  - info: host.ioBroker instance system.adapter.admin.0 started with pid 30289
        2022-12-28 19:39:42.180  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:39:42.180  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:40:47.685  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1954
        2022-12-28 19:40:55.364  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:40:55.364  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:41:38.734  - info: host.ioBroker instance system.adapter.admin.0 started with pid 3508
        2022-12-28 19:41:46.170  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:41:46.170  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:42:21.831  - info: host.ioBroker instance system.adapter.admin.0 started with pid 6028
        2022-12-28 19:42:23.708  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:42:23.708  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:42:54.300  - info: host.ioBroker instance system.adapter.admin.0 started with pid 9514
        2022-12-28 19:42:55.977  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:42:55.977  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:43:26.162  - info: host.ioBroker instance system.adapter.admin.0 started with pid 12286
        2022-12-28 19:43:27.808  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:43:27.808  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:43:58.061  - info: host.ioBroker instance system.adapter.admin.0 started with pid 13290
        2022-12-28 19:43:59.638  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:43:59.638  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:44:29.844  - info: host.ioBroker instance system.adapter.admin.0 started with pid 14308
        2022-12-28 19:44:31.362  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:44:31.362  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:45:01.562  - info: host.ioBroker instance system.adapter.admin.0 started with pid 15261
        2022-12-28 19:45:03.195  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:45:03.195  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:45:33.369  - info: host.ioBroker instance system.adapter.admin.0 started with pid 16261
        2022-12-28 19:45:34.960  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:45:34.960  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:46:05.190  - info: host.ioBroker instance system.adapter.admin.0 started with pid 18454
        2022-12-28 19:46:06.694  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:46:06.694  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:46:40.280  - info: host.ioBroker instance system.adapter.admin.0 started with pid 19453
        2022-12-28 19:46:41.953  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:46:41.954  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:47:12.197  - info: host.ioBroker instance system.adapter.admin.0 started with pid 20460
        2022-12-28 19:47:13.728  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:47:13.728  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:47:43.961  - info: host.ioBroker instance system.adapter.admin.0 started with pid 21526
        2022-12-28 19:47:45.566  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:47:45.566  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:48:15.782  - info: host.ioBroker instance system.adapter.admin.0 started with pid 22547
        2022-12-28 19:48:17.333  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:48:17.333  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:48:47.508  - info: host.ioBroker instance system.adapter.admin.0 started with pid 23567
        2022-12-28 19:48:51.940  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:48:51.940  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:49:22.159  - info: host.ioBroker instance system.adapter.admin.0 started with pid 24591
        2022-12-28 19:49:23.713  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:49:23.713  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:49:53.946  - info: host.ioBroker instance system.adapter.admin.0 started with pid 25573
        2022-12-28 19:49:55.503  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:49:55.503  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:50:25.695  - info: host.ioBroker instance system.adapter.admin.0 started with pid 26645
        2022-12-28 19:50:34.849  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:50:34.849  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:51:05.172  - info: host.ioBroker instance system.adapter.admin.0 started with pid 28048
        2022-12-28 19:51:06.811  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:51:06.811  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:51:37.058  - info: host.ioBroker instance system.adapter.admin.0 started with pid 29138
        2022-12-28 19:51:38.665  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:51:38.665  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:52:08.897  - info: host.ioBroker instance system.adapter.admin.0 started with pid 30150
        2022-12-28 19:52:10.380  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:52:10.381  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:52:40.601  - info: host.ioBroker instance system.adapter.admin.0 started with pid 31115
        2022-12-28 19:52:42.482  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:52:42.482  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:53:12.743  - info: host.ioBroker instance system.adapter.admin.0 started with pid 32121
        2022-12-28 19:53:14.460  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:53:14.460  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:53:44.661  - info: host.ioBroker instance system.adapter.admin.0 started with pid 662
        2022-12-28 19:53:46.331  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:53:46.331  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:54:16.711  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1977
        2022-12-28 19:54:18.477  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:54:18.477  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:54:49.560  - info: host.ioBroker instance system.adapter.admin.0 started with pid 2946
        2022-12-28 19:54:51.552  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:54:51.552  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:55:21.817  - info: host.ioBroker instance system.adapter.admin.0 started with pid 3950
        2022-12-28 19:55:23.380  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:55:23.381  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:55:53.574  - info: host.ioBroker instance system.adapter.admin.0 started with pid 4908
        2022-12-28 19:55:55.127  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:55:55.127  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:56:25.409  - info: host.ioBroker instance system.adapter.admin.0 started with pid 5879
        2022-12-28 19:56:27.021  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:56:27.021  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:56:57.280  - info: host.ioBroker instance system.adapter.admin.0 started with pid 6836
        2022-12-28 19:56:58.812  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:56:58.812  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:57:29.095  - info: host.ioBroker instance system.adapter.admin.0 started with pid 7818
        2022-12-28 19:57:30.718  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:57:30.718  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:58:00.897  - info: host.ioBroker instance system.adapter.admin.0 started with pid 8774
        2022-12-28 19:58:02.529  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:58:02.529  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:58:32.857  - info: host.ioBroker instance system.adapter.admin.0 started with pid 9767
        2022-12-28 19:58:34.405  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:58:34.405  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:59:04.613  - info: host.ioBroker instance system.adapter.admin.0 started with pid 10740
        2022-12-28 19:59:06.344  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:59:06.344  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 19:59:36.530  - info: host.ioBroker instance system.adapter.admin.0 started with pid 11688
        2022-12-28 19:59:38.082  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 19:59:38.082  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:00:08.276  - info: host.ioBroker instance system.adapter.admin.0 started with pid 12673
        2022-12-28 20:00:09.806  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:00:09.806  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:00:40.028  - info: host.ioBroker instance system.adapter.admin.0 started with pid 13626
        2022-12-28 20:00:41.629  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:00:41.629  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:01:11.834  - info: host.ioBroker instance system.adapter.admin.0 started with pid 14613
        2022-12-28 20:01:13.385  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:01:13.385  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:01:43.630  - info: host.ioBroker instance system.adapter.admin.0 started with pid 15550
        2022-12-28 20:01:45.193  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:01:45.193  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:02:15.420  - info: host.ioBroker instance system.adapter.admin.0 started with pid 16545
        2022-12-28 20:02:16.965  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:02:16.965  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:02:47.230  - info: host.ioBroker instance system.adapter.admin.0 started with pid 17492
        2022-12-28 20:02:48.789  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:02:48.789  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:03:19.355  - info: host.ioBroker instance system.adapter.admin.0 started with pid 18475
        2022-12-28 20:03:23.080  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:03:23.080  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:03:53.269  - info: host.ioBroker instance system.adapter.admin.0 started with pid 19440
        2022-12-28 20:03:54.890  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:03:54.890  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:04:25.084  - info: host.ioBroker instance system.adapter.admin.0 started with pid 20419
        2022-12-28 20:04:26.648  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:04:26.648  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:04:56.841  - info: host.ioBroker instance system.adapter.admin.0 started with pid 21382
        2022-12-28 20:04:58.438  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:04:58.438  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:05:28.674  - info: host.ioBroker instance system.adapter.admin.0 started with pid 22358
        2022-12-28 20:05:30.346  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:05:30.346  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:06:00.533  - info: host.ioBroker instance system.adapter.admin.0 started with pid 23310
        2022-12-28 20:06:02.010  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:06:02.011  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:06:32.277  - info: host.ioBroker instance system.adapter.admin.0 started with pid 24292
        2022-12-28 20:06:33.803  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:06:33.804  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:07:03.997  - info: host.ioBroker instance system.adapter.admin.0 started with pid 25277
        2022-12-28 20:07:05.566  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:07:05.567  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:07:35.737  - info: host.ioBroker instance system.adapter.admin.0 started with pid 26232
        2022-12-28 20:07:37.290  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:07:37.291  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:08:07.460  - info: host.ioBroker instance system.adapter.admin.0 started with pid 27234
        2022-12-28 20:08:09.087  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:08:09.087  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:08:39.280  - info: host.ioBroker instance system.adapter.admin.0 started with pid 28196
        2022-12-28 20:08:40.775  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:08:40.775  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:09:10.959  - info: host.ioBroker instance system.adapter.admin.0 started with pid 29181
        2022-12-28 20:09:12.573  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:09:12.573  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:09:42.751  - info: host.ioBroker instance system.adapter.admin.0 started with pid 30136
        2022-12-28 20:09:44.333  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:09:44.334  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:10:14.524  - info: host.ioBroker instance system.adapter.admin.0 started with pid 31118
        2022-12-28 20:10:16.016  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:10:16.016  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:10:46.221  - info: host.ioBroker instance system.adapter.admin.0 started with pid 32295
        2022-12-28 20:10:47.853  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:10:47.854  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:11:18.093  - info: host.ioBroker instance system.adapter.admin.0 started with pid 1120
        2022-12-28 20:11:19.734  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:11:19.734  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:11:49.912  - info: host.ioBroker instance system.adapter.admin.0 started with pid 2440
        2022-12-28 20:11:51.665  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:11:51.665  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:12:21.865  - info: host.ioBroker instance system.adapter.admin.0 started with pid 3443
        2022-12-28 20:12:23.552  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:12:23.552  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:12:53.731  - info: host.ioBroker instance system.adapter.admin.0 started with pid 4440
        2022-12-28 20:12:55.379  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:12:55.379  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:13:25.852  - info: host.ioBroker instance system.adapter.admin.0 started with pid 5497
        2022-12-28 20:13:27.454  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:13:27.454  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:13:57.657  - info: host.ioBroker instance system.adapter.admin.0 started with pid 6491
        2022-12-28 20:13:59.198  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:13:59.198  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:14:29.536  - info: host.ioBroker instance system.adapter.admin.0 started with pid 7507
        2022-12-28 20:14:31.127  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:14:31.127  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:15:01.333  - info: host.ioBroker instance system.adapter.admin.0 started with pid 8454
        2022-12-28 20:15:03.047  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:15:03.047  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:15:33.442  - info: host.ioBroker instance system.adapter.admin.0 started with pid 9414
        2022-12-28 20:15:36.911  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:15:36.911  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:16:07.071  - info: host.ioBroker instance system.adapter.admin.0 started with pid 10501
        2022-12-28 20:16:08.664  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:16:08.664  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:16:38.824  - info: host.ioBroker instance system.adapter.admin.0 started with pid 11465
        2022-12-28 20:16:40.367  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:16:40.367  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:17:10.599  - info: host.ioBroker instance system.adapter.admin.0 started with pid 12458
        2022-12-28 20:17:12.212  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:17:12.212  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:17:42.662  - info: host.ioBroker instance system.adapter.admin.0 started with pid 13422
        2022-12-28 20:17:45.018  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:17:45.018  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-28 20:18:15.190  - info: host.ioBroker instance system.adapter.admin.0 started with pid 14422
        2022-12-28 20:18:16.742  - error: host.ioBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-12-28 20:18:16.742  - info: host.ioBroker Restart adapter system.adapter.admin.0 because enabled
        • Dima S
          Dima S last edited by
          @haselchen
          sobald ich den Befehl ausführe, erhalte ich folgende Rückmeldung:
          pi@ioBroker:~ $ iobroker set admin.0 --ssl false
          Adapter "admin.0" has no setting "ssl".
          No parameters set.
          pi@ioBroker:~ $
          Leider hilft es auch nicht weiter. Aber war einen Versuch Wert. 🙂
          Homoran ? 2 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @Dima S last edited by
            @dima-s sagte in Kein Webinterface nach fehlerhaftem update:
            nimm iobroker set admin.0 --secure false
              A Former User @Dima S last edited by
              @dima-s
              Aus Deinenm letzten Log-File sehe ich, das der js_controller gestoppt ist.
              kannst Du mal nach der iobroker Dokumentation ioBroker läuft nicht versuchen.
              VG
              Bernd
              • Dima S
                @dp20eic
                Danke für die Anleitung. Wieder etwas dazugelernt. 🙂
                Habe mich nun ein wenig weiter hangeln können und habe bei den Logfiles
                cd /opt/iobroker
                node node_modules/iobroker.js-controller/controller.js --logs
                folgendes gefunden
                2022-12-29 11:35:30.974  - error: host.ioBroker-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                pi@ioBroker:/opt/iobroker $
                Anschließend die aktuelle js-controller version aufgespielt
                nach der Anleitung
                https://forum.iobroker.net/topic/54757/no-connection-to-databases-possible/27t
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                und den Fixer ausgeführt
                https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verf%C3%BCgbar
                @Homoran
                Der Befehl hat funktioniert. Brachte leider auch keinen Erfolg.
                Leider ohne Erfolg.
                Ich hoffe ihr habt noch weitere Ideen. 🙂
                  A Former User last edited by
                  kann es sein, das da schon etwas auf diesem Port lauscht, oder noch ein Zombie im System den Port blockiert?
                  Was sagt denn,
                  # sudo netstat -tulpn | grep -i 'liste'
                  VG
                  Bernd
                  Dima S 1 Reply Last reply Reply Quote 0
                  • Dima S
                    Dima S @Guest last edited by Dima S
                    @dp20eic
                    Sieht glaube ich nicht danach aus.
                    pi@ioBroker:/opt/iobroker $ sudo netstat -tulpn | grep -i 'liste'
                    tcp        0      0 192.168.50.49:12010     0.0.0.0:*               LISTEN      1407/io.hm-rpc.2
                    tcp        0      0 192.168.50.49:12001     0.0.0.0:*               LISTEN      1384/io.hm-rpc.1
                    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1430/io.mqtt.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1430/io.mqtt.0
                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1332/node-red
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1219/iobroker.js-co
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1219/iobroker.js-co
                    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      2521/io.jarvis.0
                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      476/influxd
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      513/sshd: /usr/sbin
                    tcp        0      0 192.168.50.49:18701     0.0.0.0:*               LISTEN      1358/io.hm-rpc.0
                    tcp6       0      0 :::8086                 :::*                    LISTEN      476/influxd
                    tcp6       0      0 :::22                   :::*                    LISTEN      513/sshd: /usr/sbin
                    tcp6       0      0 :::80                   :::*                    LISTEN      1332/node-red
                    Hab nun etwas weiter recherchiert und hoffe es hilft bei der Diagnose:
                    Folgende Files im Pfad: "/opt/iobroker/iobroker-data" werden erstellt:
                    Nach dem Löschen werden diese erneut nach einiger Zeit erstellt.
                    Die Ausgabe der Logs sieht dann etwas anderes aus:
                    pi@ioBroker:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
                    2022-12-29 12:11:08.737  - info: host.ioBroker iobroker.js-controller version 4.0.24 js-controller starting
                    2022-12-29 12:11:08.751  - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2022-12-29 12:11:08.754  - info: host.ioBroker hostname: ioBroker, node: v16.19.0
                    2022-12-29 12:11:08.756  - info: host.ioBroker ip addresses: 192.168.50.49 2001:9e8:a427:5800:4758:fda0:bca9:2fd7 fe80::bdb6:304:422a:5967
                    2022-12-29 12:11:09.884  - info: host.ioBroker-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
                    2022-12-29 12:11:38.785  - error: host.ioBroker No connection to databases possible, restart
                    2022-12-29 12:11:38.791  - info: host.ioBroker iobroker _restart
                    Nach ein paar Minuten wird erneut dieser Fehler angezeigt:
                    2022-12-29 12:12:34.798  - info: host.ioBroker iobroker.js-controller version 4.0.24 js-controller starting
                    2022-12-29 12:12:34.812  - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2022-12-29 12:12:34.814  - info: host.ioBroker hostname: ioBroker, node: v16.19.0
                    2022-12-29 12:12:34.816  - info: host.ioBroker ip addresses: 192.168.50.49 2001:9e8:a427:5800:4758:fda0:bca9:2fd7 fe80::bdb6:304:422a:5967
                    2022-12-29 12:12:36.938  - error: host.ioBroker-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                    Läuft der JS-Controller mehrfach und beeinflusst sich gegenseitig???
                    PS:
                    Sobald der iobroker beendet wird laufen keine weiteren Services mehr:
                      @dima-s
                      Ich habe nicht alles aus diesem Thread gelesen Server cannot ...
                      Kannst ja mal da rückwärts schauen ob da noch Lösungsansätze dabei sind.
                      Den fix hattest Du schon laufen lassen?
                      # cd /opt/iobroker
                      # iob fix
                      Wenn nach dem stoppen des iobrokers noch laufen sollte, dann siehst Du das mit,
                      # ps aux
                      VG
                      Bernd
                      • Dima S
                        @dp20eic
                        Falls jemand über ähnlich Problem stolpert.
                        Habe nun die Variante e) aus dem nachfolgendem Link ausgeführt .
                        https://forum.iobroker.net/topic/22867/how-to-node-js-f%C3%BCr-iobroker-richtig-updaten/2
                        Das hat zum Ziel geführt 🙂
                        Vielen Dank für die sehr gute und schnelle Unterstützung.
                        Werde wohl beim nächsten update etwas mehr Zeit einplanen 🙂
                          A Former User @Dima S last edited by A Former User
                          Bitte auch nicht warten, bis das System zu alt wird, lieber regelmäßig updates vom OS und den anderen Komponenten machen. Denke, das das im endefekt Zeit spart 🙂
                          Glückwunsch, das es wieder lüppt 🙂
                          VG
                          Bernd
                          Achso: Wenn es gelöst ist, dann wäre es gut, wenn Du im ersten Post noch ein [gelöst] vor die Überschrift setzt.
                          admin adapter update adapter fehler
                          521
