    4. Adapter "smartmeter"
      apollon77 last edited by
      Starte mal bitte den Adapter im Debug Modus (Instanzen expertenmodus dann ist da Spalte mit dem loglevel). Hast du im Adapter die Einstellungen und D0 als Protokoll gesetzt?
        church last edited by
        D0 ist als Protokoll gesetzt. Debug gibt folgendes:
        smartmeter.0	2017-08-11 22:22:42.168	debug	MESSAGE TIMEOUT TRIGGERED
        smartmeter.0	2017-08-11 22:20:42.108	debug	REMAINING DATA AFTER MESSAGE HANDLING:
        smartmeter.0	2017-08-11 22:20:42.108	debug	CURRENT PROCESS STEP 4 IN ISPROCESSCOMPLETE: false
        smartmeter.0	2017-08-11 22:20:42.107	debug	SET MESSAGE TIMEOUT TIMER: 120000
        smartmeter.0	2017-08-11 22:20:42.107	debug	CURRENT PROCESS STEP 4 IN ISPROCESSCOMPLETE: false
        smartmeter.0	2017-08-11 22:20:42.107	debug	OVERWRITE D0-MODE C WITH A
        smartmeter.0	2017-08-11 22:20:42.107	debug	CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
        smartmeter.0	2017-08-11 22:20:42.106	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
        smartmeter.0	2017-08-11 22:20:42.106	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r\n" -> ["/ESY5Q3DA2004 V3.03\r\n","/ESY5Q3DA2004 V3.03"]
        smartmeter.0	2017-08-11 22:20:42.106	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
        smartmeter.0	2017-08-11 22:20:42.106	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03" -> null
        smartmeter.0	2017-08-11 22:20:42.105	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
        smartmeter.0	2017-08-11 22:20:42.105	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.0" -> null
        smartmeter.0	2017-08-11 22:20:42.105	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3" -> null
        smartmeter.0	2017-08-11 22:20:42.104	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
        smartmeter.0	2017-08-11 22:20:42.104	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V" -> null
        smartmeter.0	2017-08-11 22:20:42.103	debug	MATCH-RESULT SIGNON: "/ESY5" -> null
        smartmeter.0	2017-08-11 22:20:42.102	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
        smartmeter.0	2017-08-11 22:20:41.092	debug	SET MESSAGE TIMEOUT TIMER: 120000
        smartmeter.0	2017-08-11 22:20:41.092	debug	SERIALPORT OPEN
        smartmeter.0	2017-08-11 22:20:41.092	debug	CREATE SERIALPORT: 9600 7 1 even
          Ok, warum hast du den "D0 Mode overwrite" denn gesetzt in den Einstellungen ?! Nimm das mal raus. Denke das das das Problem ist. Wenn nicht tut bitte nochmal log komplett inkl Start (der fehlt hier).
            Mit dem D0 overwrite hatte ich etwas "rumgespielt", daher im log im Modus "A", hatte aber auch schon andere Einstellungen!
            Hier der log inkl. Start ohne overwrite:
            host.raspberrypi	2017-08-12 09:22:56.878	info	Restart adapter system.adapter.smartmeter.0 because enabled
            host.raspberrypi	2017-08-12 09:22:56.877	error	instance system.adapter.smartmeter.0 terminated with code 0 (OK)
            smartmeter.0	2017-08-12 09:22:56.366	debug	SERIALPORT CLOSE
            smartmeter.0	2017-08-12 09:22:56.366	warn	Exception: Error: No or too long message from Serial Device.
            smartmeter.0	2017-08-12 09:22:56.366	error	Error: No or too long message from Serial Device. at SerialResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:200:11) a
            smartmeter.0	2017-08-12 09:22:56.365	error	uncaught exception: No or too long message from Serial Device.
            smartmeter.0	2017-08-12 09:22:56.364	debug	MESSAGE TIMEOUT TRIGGERED
            smartmeter.0	2017-08-12 07:20:56.315	debug	REMAINING DATA AFTER MESSAGE HANDLING:
            smartmeter.0	2017-08-12 07:20:56.314	debug	CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
            smartmeter.0	2017-08-12 07:20:56.313	debug	SET MESSAGE TIMEOUT TIMER: 120000
            smartmeter.0	2017-08-12 07:20:56.310	debug	SerialResponseTransport do not support sending of Data! Ignore them
            smartmeter.0	2017-08-12 07:20:56.308	debug	CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
            smartmeter.0	2017-08-12 07:20:56.303	debug	CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
            smartmeter.0	2017-08-12 07:20:56.300	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
            smartmeter.0	2017-08-12 07:20:56.299	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r\n" -> ["/ESY5Q3DA2004 V3.03\r\n","/ESY5Q3DA2004 V3.03"]
            smartmeter.0	2017-08-12 07:20:56.298	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
            smartmeter.0	2017-08-12 07:20:56.297	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03" -> null
            smartmeter.0	2017-08-12 07:20:56.296	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
            smartmeter.0	2017-08-12 07:20:56.295	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3." -> null
            smartmeter.0	2017-08-12 07:20:56.294	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
            smartmeter.0	2017-08-12 07:20:56.293	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 " -> null
            smartmeter.0	2017-08-12 07:20:56.292	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
            smartmeter.0	2017-08-12 07:20:56.290	debug	MATCH-RESULT SIGNON: "/ESY" -> null
            smartmeter.0	2017-08-12 07:20:56.288	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
            smartmeter.0	2017-08-12 07:20:55.518	debug	SET MESSAGE TIMEOUT TIMER: 120000
            smartmeter.0	2017-08-12 07:20:55.511	debug	SERIALPORT OPEN
            smartmeter.0	2017-08-12 07:20:55.491	debug	CREATE SERIALPORT: 9600 7 1 even
            smartmeter.0	2017-08-12 07:20:55.484	debug	SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"10","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transportS
            smartmeter.0	2017-08-12 07:20:55.473	info	starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.11.2
              Ok, die Identifikation wird empfangen und danach nichts mehr. Es kann sein das er ein "ack" erwartet … würde aber gegen das sprechen was du oben als Beispiel hattest wo er es von sich aus gesendet hat ... die overrides kannst du mal durchprobieren falls du es nicht schon hast. Sonst schau ich gern nach dem 20.8. rein, da bin ich zurück aus dem Urlaub 😉
                Ps: mode override geht aber nur wenn Transport auf bidirektional senden und empfangen steht!
                  Ich habe dann mal auf bidirektional umgestellt und erhalte dann folgenden log (bei allen overwrite modes):
                  ! 2017-08-13 10:49:18.088 - [32minfo[39m: smartmeter.0 starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.11.2
                  ! 2017-08-13 10:49:18.099 - [34mdebug[39m: smartmeter.0 SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":"10","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transportSerialDataBits":7,"transportSerialStopBits":1,"transportSerialParity":"even","transportSerialMessageTimeout":null,"protocolD0WakeupCharacters":null,"protocolD0ModeOverwrite":"E","obisFallbackMedium":1}
                  ! 2017-08-13 10:49:18.108 - [34mdebug[39m: smartmeter.0 CREATE SERIALPORT: 9600 7 1 even
                  ! 2017-08-13 10:49:18.129 - [34mdebug[39m: smartmeter.0 SERIALPORT OPEN
                  ! 2017-08-13 10:49:18.136 - [34mdebug[39m: smartmeter.0 SERIALPORT RESET BAUDRATE TO 9600
                  ! 2017-08-13 10:49:18.141 - [34mdebug[39m: smartmeter.0 INITIAL MESSAGES TO SEND: 2
                  ! 2017-08-13 10:49:18.145 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
                  ! 2017-08-13 10:49:18.146 - [34mdebug[39m: smartmeter.0 TO SEND 2:
                  ! 2017-08-13 10:49:18.147 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
                  ! 2017-08-13 10:49:18.148 - [34mdebug[39m: smartmeter.0 TO SEND 1: /?!
                  ! 2017-08-13 10:49:18.170 - [34mdebug[39m: smartmeter.0 DONE SEND 1
                  ! 2017-08-13 10:49:18.422 - [34mdebug[39m: smartmeter.0 DONE SEND 0
                  ! 2017-08-13 10:49:18.424 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
                  ! 2017-08-13 10:49:18.744 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:18.746 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ESY5" -> null
                  ! 2017-08-13 10:49:18.748 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:18.749 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ESY5Q3DA2004" -> null
                  ! 2017-08-13 10:49:18.750 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:18.751 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3" -> null
                  ! 2017-08-13 10:49:18.752 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:18.752 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3." -> null
                  ! 2017-08-13 10:49:18.755 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:18.756 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r" -> null
                  ! 2017-08-13 10:49:18.757 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:18.760 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r\n\r" -> ["/ESY5Q3DA2004 V3.03\r\n","/ESY5Q3DA2004 V3.03"]
                  ! 2017-08-13 10:49:18.763 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
                  ! 2017-08-13 10:49:18.767 - [34mdebug[39m: smartmeter.0 OVERWRITE D0-MODE C WITH E
                  ! 2017-08-13 10:49:18.772 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
                  ! 2017-08-13 10:49:18.773 - [34mdebug[39m: smartmeter.0 MESSAGES TO SEND: 2
                  ! 2017-08-13 10:49:19.030 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN GETNEXTMESSAGE
                  ! 2017-08-13 10:49:19.032 - [34mdebug[39m: smartmeter.0 TO SEND 2: 050
                  ! 2017-08-13 10:49:19.050 - [34mdebug[39m: smartmeter.0 DONE SEND 2
                  ! 2017-08-13 10:49:19.301 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN GETNEXTMESSAGE
                  ! 2017-08-13 10:49:19.302 - [34mdebug[39m: smartmeter.0 TO SEND 1:
                  ! 2017-08-13 10:49:19.302 - [34mdebug[39m: smartmeter.0 DONE SEND 0
                  ! 2017-08-13 10:49:19.304 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
                  ! 2017-08-13 10:49:19.304 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN ISPROCESSCOMPLETE: false
                  ! 2017-08-13 10:49:19.306 - [34mdebug[39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING:
                  ! 2017-08-13 10:49:20.736 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.738 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/E" -> null
                  ! 2017-08-13 10:49:20.741 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.742 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5" -> null
                  ! 2017-08-13 10:49:20.742 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.743 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q" -> null
                  ! 2017-08-13 10:49:20.744 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.744 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3D" -> null
                  ! 2017-08-13 10:49:20.745 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.745 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA" -> null
                  ! 2017-08-13 10:49:20.746 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.747 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2" -> null
                  ! 2017-08-13 10:49:20.748 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.748 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA20" -> null
                  ! 2017-08-13 10:49:20.749 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.750 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004" -> null
                  ! 2017-08-13 10:49:20.751 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.751 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 " -> null
                  ! 2017-08-13 10:49:20.752 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.753 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3" -> null
                  ! 2017-08-13 10:49:20.754 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.754 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3." -> null
                  ! 2017-08-13 10:49:20.755 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.756 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.0" -> null
                  ! 2017-08-13 10:49:20.758 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.759 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03" -> null
                  ! 2017-08-13 10:49:20.760 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.761 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n" -> null
                  ! 2017-08-13 10:49:20.762 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.763 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-" -> null
                  ! 2017-08-13 10:49:20.763 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.764 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0" -> null
                  ! 2017-08-13 10:49:20.765 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.765 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0" -> null
                  ! 2017-08-13 10:49:20.766 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.767 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0." -> null
                  ! 2017-08-13 10:49:20.768 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.769 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0" -> null
                  ! 2017-08-13 10:49:20.771 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.772 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0*" -> null
                  ! 2017-08-13 10:49:20.774 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.774 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.025" -> null
                  ! 2017-08-13 10:49:20.776 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.777 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(1" -> null
                  ! 2017-08-13 10:49:20.778 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.779 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXX" -> null
                  ! 2017-08-13 10:49:20.779 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.780 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXX" -> null
                  ! 2017-08-13 10:49:20.781 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.781 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX" -> null
                  ! 2017-08-13 10:49:20.782 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.783 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r" -> null
                  ! 2017-08-13 10:49:20.784 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.784 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n" -> null
                  ! 2017-08-13 10:49:20.786 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.791 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1" -> null
                  ! 2017-08-13 10:49:20.793 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.794 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8." -> null
                  ! 2017-08-13 10:49:20.796 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.796 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.02" -> null
                  ! 2017-08-13 10:49:20.797 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.798 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255" -> null
                  ! 2017-08-13 10:49:20.799 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.799 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(0" -> null
                  ! 2017-08-13 10:49:20.800 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.801 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00" -> null
                  ! 2017-08-13 10:49:20.802 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.805 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(0009" -> null
                  ! 2017-08-13 10:49:20.806 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.807 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(0009032" -> null
                  ! 2017-08-13 10:49:20.808 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.811 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324." -> null
                  ! 2017-08-13 10:49:20.813 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.813 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.38787" -> null
                  ! 2017-08-13 10:49:20.814 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.815 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743" -> null
                  ! 2017-08-13 10:49:20.815 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.816 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  ! 2017-08-13 10:49:20.817 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.817 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743k" -> null
                  ! 2017-08-13 10:49:20.818 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.819 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kW" -> null
                  ! 2017-08-13 10:49:20.820 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.820 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)" -> null
                  ! 2017-08-13 10:49:20.821 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.822 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r" -> null
                  ! 2017-08-13 10:49:20.827 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.828 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:2" -> null
                  ! 2017-08-13 10:49:20.832 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.833 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7" -> null
                  ! 2017-08-13 10:49:20.835 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.838 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.25" -> null
                  ! 2017-08-13 10:49:20.848 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.850 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261." -> null
                  ! 2017-08-13 10:49:20.853 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.853 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00" -> null
                  ! 2017-08-13 10:49:20.854 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.854 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r" -> null
                  ! 2017-08-13 10:49:20.855 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.856 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n" -> null
                  ! 2017-08-13 10:49:20.859 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.860 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0" -> null
                  ! 2017-08-13 10:49:20.861 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.862 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41" -> null
                  ! 2017-08-13 10:49:20.862 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.863 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41." -> null
                  ! 2017-08-13 10:49:20.863 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7" -> null
                  ! 2017-08-13 10:49:20.864 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.864 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7." -> null
                  ! 2017-08-13 10:49:20.956 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.957 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:" -> null
                  ! 2017-08-13 10:49:20.958 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.958 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96." -> null
                  ! 2017-08-13 10:49:20.959 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.960 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5" -> null
                  ! 2017-08-13 10:49:20.961 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.962 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5" -> null
                  ! 2017-08-13 10:49:20.963 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.964 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.52" -> null
                  ! 2017-08-13 10:49:20.965 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.966 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.525" -> null
                  ! 2017-08-13 10:49:20.967 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.968 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(8" -> null
                  ! 2017-08-13 10:49:20.969 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.970 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82" -> null
                  ! 2017-08-13 10:49:20.971 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.972 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n" -> null
                  ! 2017-08-13 10:49:20.973 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.974 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0" -> null
                  ! 2017-08-13 10:49:20.975 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.976 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0" -> null
                  ! 2017-08-13 10:49:20.977 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.978 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:9" -> null
                  ! 2017-08-13 10:49:20.979 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.979 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96." -> null
                  ! 2017-08-13 10:49:20.980 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.981 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1" -> null
                  ! 2017-08-13 10:49:20.982 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.983 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.25" -> null
                  ! 2017-08-13 10:49:20.984 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.985 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255" -> null
                  ! 2017-08-13 10:49:20.986 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.987 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255*" -> null
                  ! 2017-08-13 10:49:20.988 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.988 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.25525" -> null
                  ! 2017-08-13 10:49:20.989 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.990 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(" -> null
                  ! 2017-08-13 10:49:20.991 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.992 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1E" -> null
                  ! 2017-08-13 10:49:20.993 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.994 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ES" -> null
                  ! 2017-08-13 10:49:20.995 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.995 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1" -> null
                  ! 2017-08-13 10:49:20.996 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.997 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY113" -> null
                  ! 2017-08-13 10:49:20.998 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:20.999 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY113X" -> null
                  ! 2017-08-13 10:49:21.000 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:21.001 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY113XXX" -> null
                  ! 2017-08-13 10:49:21.002 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:21.003 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY113XXXXXX" -> null
                  ! 2017-08-13 10:49:21.004 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:21.008 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY113XXXXXXX" -> null
                  ! 2017-08-13 10:49:21.009 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:21.010 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY113XXXXXXX)\r\n!\r" -> null
                  ! 2017-08-13 10:49:21.011 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
                  ! 2017-08-13 10:49:21.012 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r/ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0
                  255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY113XXXXXXX)\r\n!\r\n" -> ["ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY113XXXXXXX)\r\n!\r\n","ESY5Q3DA2004 V3.03\r\n\r\n1-0:0.0.0255(XXXXXX)\r\n1-0:1.8.0255(00090324.3878743kWh)\r\n1-0:21.7.255255(000261.00W)\r\n1-0:41.7.255255(000151.31W)\r\n1-0:61.7.255255(000043.67W)\r\n1-0:1.7.255255(000455.98W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY113XXXXXXX)\r\n"]
                  ! 2017-08-13 10:49:21.018 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN HANDLEMESSAGE
                  ! 2017-08-13 10:49:21.052 - [31merror[39m: smartmeter.0 uncaught exception: Invalid Obis String ESY5Q3DA2004 V3.03
                  ! 1-0:0.0.0255
                  ! 2017-08-13 10:49:21.052 - [31merror[39m: smartmeter.0 Error: Invalid Obis String ESY5Q3DA2004 V3.03
                  ! 1-0:0.0.0
                  255
                  ! at new ObisMeasurement (/opt/iobroker/node_modules/smartmeter-obis/lib/ObisMeasurement.js:46:23)
                  ! at D0Protocol.prepareResult (/opt/iobroker/node_modules/smartmeter-obis/lib/protocols/D0Protocol.js:199:31)
                  ! at D0Protocol.handleMessage (/opt/iobroker/node_modules/smartmeter-obis/lib/protocols/D0Protocol.js:158:27)
                  ! at SerialPort. <anonymous>(/opt/iobroker/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:60:41)
                  ! at emitOne (events.js:96:13)
                  ! at SerialPort.emit (events.js:188:7)
                  ! at SerialPort.raw (/opt/iobroker/node_modules/serialport/lib/parsers.js:7:13)
                  ! at SerialPort._emitData (/opt/iobroker/node_modules/serialport/lib/serialport.js:313:18)
                  ! at SerialPort. <anonymous>(/opt/iobroker/node_modules/serialport/lib/serialport.js:293:14)
                  ! at SerialPort. <anonymous>(/opt/iobroker/node_modules/serialport/lib/serialport.js:306:7)
                  ! 2017-08-13 10:49:21.056 - [33mwarn[39m: smartmeter.0 Exception: Error: Invalid Obis String ESY5Q3DA2004 V3.03
                  ! 1-0:0.0.0*255
                  ! 2017-08-13 10:49:21.061 - [34mdebug[39m: smartmeter.0 SERIALPORT CLOSE
                  ! 2017-08-13 10:49:21.563 - [32minfo[39m: smartmeter.0 terminating
                  ! 2017-08-13 08:49:21.588 - [31merror[39m: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code 0 (OK)
                  ! 2017-08-13 08:49:21.589 - [32minfo[39m: host.raspberrypi Restart adapter system.adapter.smartmeter.0 because enabled[/spoiler]</anonymous></anonymous></anonymous>
                  Wünsche noch schönen Urlaub !!
                    Komisch komisch … mach mal wieder auf serial nur lesen und den override raus. Ich kapiere es gerade nicht. Versuch bitte mal Version 5.10 oder 5.11 (im Admin Expertenmodus unter Adapter dann ganz rechts ist ein Dropdown-Menü für ältere versionen. Will nur sicher gehen das es nicht an der 0.5.12 liegt ...
                      Bei den "downgrades" bekomme ich folgende Fehlermeldungen:
                      iobroker	2017-08-14 17:00:27.100	info	exit 0
                      iobroker	2017-08-14 17:00:27.085	info	Adapter "smartmeter" updated
                      iobroker	2017-08-14 17:00:27.022	info	upload [0] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
                      iobroker	2017-08-14 17:00:26.960	info	upload [1] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
                      iobroker	2017-08-14 17:00:26.804	info	upload [2] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
                      iobroker	2017-08-14 17:00:26.727	info	upload [3] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
                      iobroker	2017-08-14 17:00:26.636	info	upload [4] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
                      iobroker	2017-08-14 17:00:26.603	info	got /opt/iobroker/node_modules/iobroker.smartmeter/admin
                      iobroker	2017-08-14 17:00:19.439	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.smartmeter"
                      iobroker	2017-08-14 17:00:19.404	info	npm ERR! /opt/npm-debug.log
                      iobroker	2017-08-14 17:00:19.404	info	npm ERR! Please include the following file with any support request:
                      iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget a package version that doesn't exist.
                      iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget In most cases you or one of your dependencies are requesting
                      iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget This is most likely not a problem with npm itself.
                      iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget 0.5.12, 0.5.8, 0.5.7, 0.5.6, 0.5.5, 0.5.4, 0.5.0, 0.4.1, 0.4.0, 0.3.3, 0.3.2, 0.3.1, 0.3.0, 0.2.6, 0.2.4, 0.2.0, 0.1.1, 0.1.0
                      iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget Valid install targets:
                      iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget No compatible version found: iobroker.smartmeter@0.5.11
                      iobroker	2017-08-14 17:00:19.404	info	npm ERR! code ETARGET
                      iobroker	2017-08-14 17:00:19.398	info	npm ERR! npm v3.10.10
                      iobroker	2017-08-14 17:00:19.398	info	npm ERR! node v6.11.2
                      iobroker	2017-08-14 17:00:19.398	info	npm ERR! Linux 4.9.35-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.smartmeter@0.5.11" "--production" "--prefix" "/opt/iobroker"
                      iobroker	2017-08-14 17:00:07.577	info	npm install iobroker.smartmeter@0.5.11 --production --prefix "/opt/iobroker" (System call)
                      iobroker	2017-08-14 17:00:05.362	info	upgrade smartmeter@0.5.11
                        Ok dann nimm die 0.5.8 😉 das André waren github Zwischenversionen …
                          Bis 0.5.9 runter hatte ich probiert 8-)
                          Downgrade auf 0.5.8 hat dann funktioniert und es werden jetzt erstmalig die Datenpunkte angelegt:
                          Leider bleibt es bei dem einmaligen Einlesen, im log kommt dann wieder der Fehler:
                          smartmeter.0	2017-08-15 14:33:54.508	debug	SERIALPORT CLOSE
                          smartmeter.0	2017-08-15 14:33:54.508	warn	Exception: Error: No or too long message from Serial Device.
                          smartmeter.0	2017-08-15 14:33:54.508	error	Error: No or too long message from Serial Device. at SerialResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialR
                          smartmeter.0	2017-08-15 14:33:54.507	error	uncaught exception: No or too long message from Serial Device.
                          smartmeter.0	2017-08-15 14:33:54.506	debug	MESSAGE TIMEOUT TRIGGERED
                          smartmeter.0	2017-08-15 14:33:44.454	debug	REMAINING DATA AFTER MESSAGE HANDLING:
                          smartmeter.0	2017-08-15 14:33:44.453	debug	CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
                          smartmeter.0	2017-08-15 14:33:44.453	debug	SET MESSAGE TIMEOUT TIMER: 10000
                          smartmeter.0	2017-08-15 14:33:44.453	debug	SerialResponseTransport do not support sending of Data! Ignore them
                          smartmeter.0	2017-08-15 14:33:44.452	debug	CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
                          smartmeter.0	2017-08-15 14:33:44.452	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
                          smartmeter.0	2017-08-15 14:33:44.451	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r\n" -> ["/ESY5Q3DA2004 V3.03\r\n","/ESY5Q3DA2004 V3.03"]
                          smartmeter.0	2017-08-15 14:33:44.451	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          smartmeter.0	2017-08-15 14:33:44.449	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03" -> null
                          smartmeter.0	2017-08-15 14:33:44.449	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          smartmeter.0	2017-08-15 14:33:44.449	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.0" -> null
                          smartmeter.0	2017-08-15 14:33:44.448	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3" -> null
                          smartmeter.0	2017-08-15 14:33:44.448	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          smartmeter.0	2017-08-15 14:33:44.448	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004" -> null
                          smartmeter.0	2017-08-15 14:33:44.447	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          smartmeter.0	2017-08-15 14:33:44.447	debug	MATCH-RESULT SIGNON: "/ESY5" -> null
                          smartmeter.0	2017-08-15 14:33:44.445	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          smartmeter.0	2017-08-15 14:33:43.558	debug	SET MESSAGE TIMEOUT TIMER: 10000
                          smartmeter.0	2017-08-15 14:33:43.557	debug	SERIALPORT OPEN
                          smartmeter.0	2017-08-15 14:33:43.557	debug	CREATE SERIALPORT: 9600 7 1 even
                          smartmeter.0	2017-08-15 14:33:43.556	debug	SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"10","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transportSe
                          smartmeter.0	2017-08-15 14:33:43.555	info	starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.11.2
                          host.raspberrypi	2017-08-15 14:33:41.007	info
                          Kann das ggfs. an der Leerzeile nach der ersten Zeile (/ESY5Q3DA2004 V3.03) der D0-Message liegen?
                            Die Leerzeile ist korrekt. Auf welchem Betriebssystem läuft das denn bei dir? Linux Mac oder Windows? Wenn du den Adapter stops und dann neu startest geht es dann wieder ein mal?
                              Und hast du das log von dem einen mal wo es geklappt hat?
                                Iobroker läuft bei mir auf einem Rpi3 mit Raspbian Jessie! In meinem letzten post hatte ich den log angehangen, wo es funktioniert hat!
                                Ich habe den Adapter nochmal deinstalliert, reboot und dann neu installiert. Jetzt werden andere Datenpunkte angelegt:
                                Hier der log seit Neuinstallation:
                                host.raspberrypi	2017-08-16 09:51:39.924	error	instance system.adapter.smartmeter.0 terminated with code 0 (OK)
                                smartmeter.0	2017-08-16 09:51:39.893	info	terminating
                                smartmeter.0	2017-08-16 09:51:39.393	debug	SERIALPORT CLOSE
                                smartmeter.0	2017-08-16 09:51:39.389	warn	Exception: Error: No or too long message from Serial Device.
                                smartmeter.0	2017-08-16 09:51:39.383	error	at Timer.listOnTimeout (timers.js:214:5)
                                smartmeter.0	2017-08-16 09:51:39.383	error	at tryOnTimeout (timers.js:250:5)
                                smartmeter.0	2017-08-16 09:51:39.383	error	at ontimeout (timers.js:386:14)
                                smartmeter.0	2017-08-16 09:51:39.383	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:87:22)
                                smartmeter.0	2017-08-16 09:51:39.383	error	at SerialResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:200:11)
                                smartmeter.0	2017-08-16 09:51:39.383	error	Error: No or too long message from Serial Device.
                                smartmeter.0	2017-08-16 09:51:39.382	error	uncaught exception: No or too long message from Serial Device.
                                smartmeter.0	2017-08-16 09:51:39.348	debug	MESSAGE TIMEOUT TRIGGERED
                                smartmeter.0	2017-08-16 09:49:39.346	debug	REMAINING DATA AFTER MESSAGE HANDLING:
                                smartmeter.0	2017-08-16 09:49:39.345	debug	CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
                                smartmeter.0	2017-08-16 09:49:39.345	debug	SET MESSAGE TIMEOUT TIMER: 120000
                                smartmeter.0	2017-08-16 09:49:39.344	debug	SerialResponseTransport do not support sending of Data! Ignore them
                                smartmeter.0	2017-08-16 09:49:39.342	debug	CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
                                smartmeter.0	2017-08-16 09:49:39.337	debug	CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
                                smartmeter.0	2017-08-16 09:49:39.333	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
                                smartmeter.0	2017-08-16 09:49:39.332	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r\n" -> ["/ESY5Q3DA2004 V3.03\r\n","/ESY5Q3DA2004 V3.03"]
                                smartmeter.0	2017-08-16 09:49:39.331	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                smartmeter.0	2017-08-16 09:49:39.330	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r" -> null
                                smartmeter.0	2017-08-16 09:49:39.330	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                smartmeter.0	2017-08-16 09:49:39.329	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.0" -> null
                                smartmeter.0	2017-08-16 09:49:39.328	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                smartmeter.0	2017-08-16 09:49:39.327	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3" -> null
                                smartmeter.0	2017-08-16 09:49:39.327	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                smartmeter.0	2017-08-16 09:49:39.325	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V" -> null
                                smartmeter.0	2017-08-16 09:49:39.324	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                smartmeter.0	2017-08-16 09:49:39.323	debug	MATCH-RESULT SIGNON: "/ESY" -> null
                                smartmeter.0	2017-08-16 09:49:39.321	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                smartmeter.0	2017-08-16 09:49:37.752	debug	SET MESSAGE TIMEOUT TIMER: 120000
                                smartmeter.0	2017-08-16 09:49:37.745	debug	SERIALPORT OPEN
                                smartmeter.0	2017-08-16 09:49:37.729	debug	CREATE SERIALPORT: 9600 7 1 even
                                smartmeter.0	2017-08-16 09:49:37.722	debug	SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"300","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transport
                                smartmeter.0	2017-08-16 09:49:37.711	info	starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.11.2
                                smartmeter.0	2017-08-16 09:49:37.632	debug	statesDB connected
                                smartmeter.0	2017-08-16 09:49:37.561	debug	objectDB connected
                                host.raspberrypi	2017-08-16 09:49:35.093	info	instance system.adapter.smartmeter.0 started with pid 1232
                                host.raspberrypi	2017-08-16 09:49:35.042	info	object change system.adapter.smartmeter.0
                                host.raspberrypi	2017-08-16 09:49:05.618	info	object change system.adapter.smartmeter.0
                                host.raspberrypi	2017-08-16 09:48:50.699	info	object change system.adapter.smartmeter.0
                                iobroker	2017-08-16 09:48:15.635	info	exit 0
                                iobroker	2017-08-16 09:48:15.621	info	host.raspberrypi object system.adapter.smartmeter.0 created
                                host.raspberrypi	2017-08-16 09:48:15.615	info	object change system.adapter.smartmeter.0
                                iobroker	2017-08-16 09:48:15.572	info	host.raspberrypi object system.adapter.smartmeter.0.alive created
                                iobroker	2017-08-16 09:48:15.541	info	host.raspberrypi object system.adapter.smartmeter.0.connected created
                                iobroker	2017-08-16 09:48:15.511	info	host.raspberrypi object system.adapter.smartmeter.0.memHeapUsed created
                                iobroker	2017-08-16 09:48:15.481	info	host.raspberrypi object system.adapter.smartmeter.0.memHeapTotal created
                                iobroker	2017-08-16 09:48:15.445	info	host.raspberrypi object system.adapter.smartmeter.0.memRss created
                                iobroker	2017-08-16 09:48:15.418	info	host.raspberrypi object system.adapter.smartmeter.0.uptime created
                                iobroker	2017-08-16 09:48:15.383	info	host.raspberrypi object system.adapter.smartmeter.0.inputCount created
                                iobroker	2017-08-16 09:48:15.352	info	host.raspberrypi object system.adapter.smartmeter.0.outputCount created
                                iobroker	2017-08-16 09:48:15.335	info	host.raspberrypi create instance smartmeter
                                iobroker	2017-08-16 09:48:13.496	info	add smartmeter
                                  knopers1 last edited by
                                  Hallo Apollon77
                                  ich wollte an meinem Gaszähler den Verbrauch auslesen.
                                  Genau ist es ein GT4 Gaszähler siehe Bild. Als Hardware wurde einfach ein Magnet-Reedkontakt an einem ESP8266 (WEMO D1 mini) angeschlossen.
                                  Dort als Betriebssystem habe ich Tasmota installiert. Daten kommen über MQTT Adapter an IOBroker an.
                                  Der magnetische Kontakt hängt jetzt am Zählwerk in der letzten Stelle des Zählwerks.
                                  Somit wird alle 0.01 m³ (=10l) mein Reedkontakt kurzgeschlossen.
                                  Unter MQTT Adapter sehe ich ob der Kontakt true oder false ist.
                                  Ich kann den Eingang des Wemos auch so umkonfigurieren, dass man dort die Zählimpulse zählen kann…
                                  Kannst Du mich auf die Spur bringen, ob dein Adapter damit umgehen kann?
                                  Ich würde gerne mit dem FLOT Adapter mir eine schöne Grafik basteln.
                                  Dazu ein Wert für den aktuellen Verbrauch, gesamten Verbrauch sowie Kosten loggen können.
                                  Kannst Du helfen?
                                    @noxx:
                                    funktioniert der Adapter auch mit ESPeasy und dem Pulse Counter?
                                    Oder gibt es Arduino Lösungen? Habe am Arduino im moment ein Read-Schalter, der
                                    Read-Schalter am Gaszähler.
                                    Ähnlich wie hier: https://voizchat.de/gaszaehler-verbrauc … erry-gpio/ `
                                    noxx hat schon mal ne ähnliche Frage gestellt,geht nicht. Ein paar Seiten weiter vorn. Außerdem gibts von ihm auch noch ne Lösung wo aus einer Webseite Daten ausgelesen werden können.
                                    http://forum.iobroker.net/viewtopic.php?f=21&t=7556&hilit=gasz%C3%A4hler gibts dazu noch ein paar Infos.
                                    RappiRN
                                      woww, Danke Dir für den Link!
                                        @church: muss ich Montag checken …
                                          Super, danke!
                                            Arminhh last edited by
                                            Guten Morgen,
                                            ich habe jetzt alle Seiten durch gelesen! Leider habe ich noch ein Problem.
                                            Ich habe mir diese Woche den extra den Multihost eingerichtet. Der Slave ein PI 3B ist im Keller und der Lesekopf von UDO angeschlossen.
                                            Der Smartmeter Adapter lässt sich installieren. Beim Starten des Adapters erscheint die Fehlermeldung wie auf Seite 28 gefunden
                                            host.rasp_pv1_goke 2017-07-24 21:35:41.501 error instance system.adapter.smartmeter.0 terminated with code 1 ()
                                            host.rasp_pv1_goke 2017-07-24 21:35:40.719 info instance system.adapter.smartmeter.0 started with pid 11153
                                            host.rasp_pv1_goke 2017-07-24 21:35:35.334 info Restart adapter system.adapter.smartmeter.0 because enabled
                                            Scheinbar muss laut Seite 28
                                            " Komisch … Dann löscht mal den "open-sml" ordner und installiere dann den Adapter. Sollte dann wieder installiert werden. Falls nicht wirf auch smartmeter-obis weg (oder gleich beides)"
                                            gelöscht werden!
                                            Leider finde ich weder wen der Adapter installiert ist, noch wenn er deinstalliert ist die beiden Verzeichnisse!
                                            Danke für die Hilfe
                                            3625
                                            2373960
