    4. Test Adapter Material Design Widgets v0.5.x
    • Scrounger
      Scrounger Developer @ice987 last edited by
      @ice987
      Das ist aber normal im Editor. Die States werden da nur beim laden aktualisiert und wenn man an den Einstellungen des Widgets etwas ändert.
      ice987 D3ltoroxp O 3 Replies Last reply Reply Quote 0
      • ice987
        ice987 @Scrounger last edited by
        @scrounger
        ah ok, dann ist alles i.O. Ich dachte nur, da das Widget Button Toggle vertikal auch direkt im Editor aktualisiert wird.
        das value Widget kann auch so genutzt werden, was die ganze Geschichte sehr interessant macht (zwei DP's als Binding, ohne Object ID) 😳
        [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<div class='vis-widget materialdesign-widget materialdesign-value materialdesign-value-html-element'\n\tstyle='width: 100%; height: 100%; position: relative; display: flex; align-items: center;'\n\tmdw-debug='false'\n\tmdw-oid='nothing_selected'\n\tmdw-targetType='auto'\n\tmdw-overrideText=' '\n\tmdw-textAlign='start'\n\tmdw-valueLabelWidth='4'\n\tmdw-valuesFontColor='#mdwTheme:vis-materialdesign.0.colors.value.text'\n\tmdw-valuesFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.text'\n\tmdw-valuesFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.text'\n\tmdw-prepandTextColor='#mdwTheme:vis-materialdesign.0.colors.value.prepand'\n\tmdw-prepandTextFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.prepand'\n\tmdw-prepandTextFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.prepand'\n\tmdw-appendTextColor='#mdwTheme:vis-materialdesign.0.colors.value.append'\n\tmdw-appendTextFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.append'\n\tmdw-appendTextFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.append'\n\tmdw-image='{wert1:0_userdata.0.test.test26;wert2:0_userdata.0.test.wert27;wert1 === \\\"true\\\" ? \\\"/vis.0/main/img/icon_nowifi.png\\\" : (wert2 >= -50 ? \\\"/vis.0/main/img/icon_wifi_excellent.png\\\" : (wert2 < -50 && wert2 >= -60 ? \\\"/vis.0/main/img/icon_wifi_good.png\\\" : (wert2 < -60 && wert2 >= -70 ? \\\"/vis.0/main/img/icon_wifi_fair.png\\\" : \\\"/vis.0/main/img/icon_wifi_weak.png\\\")))}'\n\tmdw-iconPosition='left'\n\tmdw-iconHeight='25'\n\tmdw-effectFontColor='#mdwTheme:vis-materialdesign.0.colors.value.effect'\n\tmdw-effectFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.effect'\n\tmdw-effectDuration='750'\n></div>"},"style":{"left":"659px","top":"116px"},"widgetSet":"basic"}]
          darkiop Most Active @Scrounger last edited by
          @scrounger sagte in Test Adapter Material Design Widgets v0.5.x:
          @darkiop
          puhhhh...
          Wahrscheinlich müsstest du direkt im VIS Editor ein Skript schreiben, dass den Datenpunkt liest und in Abhängigkeit dann jedem Widget eine Klasse zu weist. Für diese beiden Klassen kannst dann css regeln erstellen.
          Hatte schon befürchtet das man das evtl. per Skript abfangen muss.
          Wenn du nur den Hintergrund anpassen willst, würd ich nen html Widget in den Hintergrund legen und dann per binding die hintergrundfarbe in Abhängigkeit des Datenpunktes setzen.
          Ja, die Idee hatte ich auch, werd ich demnächst noch Testen.
          Kannst du nicht den Uhula Widgets die Layout datenpunkte des Theme Editors per binding zuweisen?
          Ich nutze von Uhulas Framework eigentlich nur den Rahmen - also alles was die Seite Responsiv macht - die Inhalte werden größtenteils mit deinen Widgets dargestellt. Und Uhulas Konzept mit mehreren Page Views habe ich auf eine Page View mit einem View in Widget 8 und deiner TopAppBar angepasst.
          Eine Idee war noch, das ganze über ein Bindung der BG-Optionen der Seite selbst zu machen (kein Widget selektiert):
          Leider sind hier Bindings ohne Funktion.
            darkiop Most Active @darkiop last edited by darkiop
            @Scrounger
            @darkiop sagte in Test Adapter Material Design Widgets v0.5.x:
            Ich hab mir jetzt so beholfen wie von dir Vorgeschlagean. Auf meiner page-View liegt ein HTML mit 100% x 100% und das bekommt über ein Binding eine class verpasst:
            {x:vis-materialdesign.0.colors.darkTheme;x=='true' ? 'bg-dark-theme' : 'bg-light-theme'}
            • D3ltoroxp
              D3ltoroxp @Scrounger last edited by
              @scrounger Gab es Änderungen an der Top App Bar ? Mein seitliches Menü ist weg, das war bei mir über das Top App Bar realisiert. Hatte heute mal neuste Version vom Adapter geupdated.
              • Glasfaser
                Glasfaser last edited by
                @d3ltoroxp sagte in Test Adapter Material Design Widgets v0.5.x:
                schau mal hier im passenden Thread :
                https://forum.iobroker.net/topic/29660/material-design-widgets-top-app-bar-widget/317
                  saeft_2003 Most Active last edited by saeft_2003
                  Hallo. Ich habe folgendes Problem ich habe ein Update gemacht von einer uralt Version 0.2.64 auf die aktuelle. Jetzt werden auf meinen iphone und ipad keine material design widgets mehr angezeigt.
                  Gibt es eine Lösung dafür? Ein downgrade ist nicht möglich!
                  • Edde
                    Edde last edited by
                    Guten Morgen.
                    Ich habe seit einiger Zeit folgendes Problem:
                    Ich sehe leider seit einiger Zeit keine einzige Material Widgets mehr auf meiner VIS (läuft im Fuly Browser).
                    Ich VIS Editor kann ich die Widgets auch aus dem Menu ziehen und es erscheint rechts die passende Bearbeitungsleiste. Nur sichtbar snd die Widgets hier auch nicht.
                    Nachdem ich mir nicht mehr zu helfen wusste, habe ich meinen iobroker neu aufgesetzt. Zunächst habe ich wieder die wichtigsten Adapter installiert und zum laufen gebracht. Danach alls erstes VIS Widget das Material Design und schwups, alles funktionierte. Als ich dann angefagen habe, weitere Widgets aus der Adapterliste zu installieren, verschwanden plötzlich wiedeer alle Material Widgets auf meiner VIS.
                    Daraufhin habe ich alle anderen Adapter wieder deinstalliert, auch den Materil Deign neu installiert, verschiedene Versionen ausprobiert, aber die Widgets bleiben verschwunden.
                    Das System läuft auf einem Raspberry 2 mit allen Adaptern aus der latest Repo.
                    Vielen dak für eure Hilfe.
                    Screenshot_20211203-054504_Samsung Internet.jpg Screenshot_20211203-054514_Samsung Internet.jpg Screenshot_20211203-055725_Chrome.jpg Screenshot_20211203-060345_Chrome.jpg
                      Rosi8818 last edited by Rosi8818
                      ich habe endlich geschafft mein System auf den neusten Stand zu bringen (mit deaktiviertem Admin 5 wegen LinkedDevices).
                      Jetzt würde ich gerne den Material Design Widget noch auf Version 0.5.x bringen.
                      Dabei bin ich mir absolut unsicher und habe Angst etwas falsch zu machen das meiner VIS anschl. einiges fehlt.
                      Ich weiß nicht ob ich eines der beiden "Breaking Changes" nutze.
                      1. Table Widget
                        2. List Widget habe ich rausgefunden und deshalb hier einiges gelöscht
                      Wie setze ich die Tabelle jetzt in das HTML Widget um, das ist mir noch nicht klar. Ich habe im "alten" Tablet Widget die ObjectID aus einem DP gelesen.
                      Auszug daraus
                      [{"W_tag":"<font color=\"#1345fb\"><span></font>Fr</span>","Datum":"<font color=\"#1345fb\"><span></font>24.12.2021</span>","Zeit":"<font color=\"#1345fb\"><span></font>&longmapsto; </span>","Event":"<font color=\"#1345fb\"><span>&#128309;&ensp;</font>Urlaub Conny:</span>","Tage":"<font color=\"#1345fb\"><span></font>-5</span>"},{"W_tag":"Do","Datum":"30.12.2021","Zeit":"&RightArrowLeftArrow;","Event":"Stadtwerke Daten ablesen - Zählerstände ... abfragen &#8595;","Tage":"morgen"},{"W_tag":"<font color=\"#1345fb\"><span></font>Do</span>","Datum":"<font color=\"#1345fb\"><span></font>30.12.2021</span>","Zeit":"<font color=\"#1345fb\"><span></font>&RightArrowLeftArrow;</span>","Event":"<font color=\"#1345fb\"><span>&#127874;&ensp;</font>Geburtstag von ...&#8595;</span>","Tage":"<font color=\"#1345fb\"><span></font>morgen</span>"},{"W_tag":"<font color=\"#1345fb\"><span></font>Fr</span>","Datum":"<font color=\"#1345fb\"><span></font>31.12.2021</span>","Zeit":"<font color=\"#1345fb\"><span></font>&RightArrowLeftArrow;</span>","Event":"<font color=\"#1345fb\"><span>&#9022;&e
                      aber was mache ich jetzt mit den Feldern Spaltenlayout[X]...?
                      Hat jemand eine kleine Idee, ein Anschubser für mich?
                      Ralf
                      • I
                        iobrokerin @Rosi8818 last edited by
                        Hi, wie kann ich das Widget installieren? Ich kann es nicht finden im ioBroker, wenn ich nach "vis-material" suche...
                          liv-in-sky @iobrokerin last edited by
                          @iobrokerin
                          • I
                            iobrokerin @liv-in-sky last edited by iobrokerin
                            @liv-in-sky Vielen Dank für die Hilfestellung, aber der Adapter erscheint auch in dem "GitHub"-Fenster nicht. Filtere ich noch irgendwas, dass er nicht angezeigt wird?
                            Edit: Got it. Man muss auf Beta umstellen.....
                            • Glasfaser
                              Glasfaser last edited by Glasfaser
                              @iobrokerin sagte in Test Adapter Material Design Widgets v0.5.x:
                              ... danach wieder zurückstellen !!!!
                              • Curtis777
                                Curtis777 last edited by
                                @Scrounger
                                Ich habe den Effekt das im VIS Editor im Chrome Browser alles funktioniert.
                                Sobald ich aber die VIS am Tablet in Wallpanel (wo die VIS läuft) oder Fully Kiosk APP öffne ist die Stelle leer an welcher der Kalender sein sollte.
                                Öffne ich am selben Gerät die Chrome APP läufts.
                                Hab mal Testweise ein anderes Widget aus deiner Sammlung hinzugefügt allerdings wird das ebenfalls nicht angezeigt.
                                  Laser @Curtis777 last edited by Laser
                                  @Scrounger Kann das sein, daß "Materialdesign" riesige Recourcen verschlingt? Nach der Installation ging auf dem Raspi mit 4GB Ram fast nichts mehr. Nach dem Deinstallieren funktioniert VIS nicht mehr richtig. Es wird immer nur eine bestimmte Seite angesprungen. "Material Design" fasse ich nur noch mit der Kneifzange an!
                                    Sushibomba last edited by Sushibomba
                                    @Scrounger Wie bekomme ich den Scroll-Balken weg und die gesamte Liste angezeigt? Mit oben und unten schon ausprobiert. Gleiches Ergebnis.
                                    Und noch ne Frage...
                                    Bei Rollladen fehlt das Symbol für vollständig geöffnet. Woran kann das liegen?
                                    Adapter Version: 0.59
                                    @sigi234 Hast du vielleicht ne Antwort für mich weil du das Problem damals auch hattest das nicht alles vom Dropdown sichtbar war?
                                    • O
                                      Oli @Scrounger last edited by
                                      @scrounger
                                      Wird es für deinen Adapter auch eine Integration für VIS 2 geben?
                                      adapter material material design widgets vis visualisation widget
                                      22
                                      110
                                      17750
