    4. Test Adapter vis 2.0 (Alpha)
    • Feuersturm
      Feuersturm @shellyrulestheworld last edited by Feuersturm
      @peterschatz
      Mich irritiert, das iobroker bei mir bei dem upload Befehl im Verlauf bei mir mit upload [1375] vis-2-beta anfängt und bei dir mit upload [851] vis-2-beta
      So sieht bei mir die Ausgabe aus, wenn ich die nach dem npm install den upload Befehl ausführe:
      proxmox@ioBrokerTestsystem:/opt/iobroker$ iob upload vis-2-beta
      upload [4] vis-2-beta.admin /opt/iobroker/node_modules/iobroker.vis-2-beta/admin/index.html index.html text/html
      upload [3] vis-2-beta.admin /opt/iobroker/node_modules/iobroker.vis-2-beta/admin/index_m.html index_m.html text/html
      upload [2] vis-2-beta.admin /opt/iobroker/node_modules/iobroker.vis-2-beta/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] vis-2-beta.admin /opt/iobroker/node_modules/iobroker.vis-2-beta/admin/vis.png vis.png image/png
      upload [0] vis-2-beta.admin /opt/iobroker/node_modules/iobroker.vis-2-beta/admin/words.js words.js application/javascript
      Update "system.adapter.vis-2-beta.0"
      Adapter "system.adapter.vis.0" restarted.
      upload [1375] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/_socket/info.js _socket/info.js application/javascript
      upload [1350] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/img/bulb_off.png img/bulb_off.png image/png
      upload [1300] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/lib/css/themes/jquery-ui/blitzer/images/ui-icons_004276_256x240.png lib/css/themes/jquery-ui/blitzer/images/ui-icons_004276_256x240.png image/png
      upload [1250] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_flat_30_cccccc_40x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_flat_30_cccccc_40x100.png image/png
      upload [1200] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_25_30273a_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_25_30273a_1x100.png image/png
      upload [1150] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ffffff_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ffffff_40x100.png image/png
      upload [1100] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_95_fef1ec_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_95_fef1ec_1x400.png image/png
      upload [1050] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_flat_30_cccccc_40x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_flat_30_cccccc_40x100.png image/png
      upload [1000] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.min.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.min.css text/css
      upload [950] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/signals/waterDrops.png signals/waterDrops.png image/png
      upload [900] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/static/js/188.8cf4b307.chunk.js.map static/js/188.8cf4b307.chunk.js.map application/json
      upload [850] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/static/js/697.4b022435.chunk.js.map static/js/697.4b022435.chunk.js.map application/json
      upload [800] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/static/js/85.3b1dcf50.chunk.js static/js/85.3b1dcf50.chunk.js application/javascript
      upload [750] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/static/js/main.8bc173f1.js static/js/main.8bc173f1.js application/javascript
      upload [700] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/static/media/Driveway.fbd31101c5a80a8bb37a.svg static/media/Driveway.fbd31101c5a80a8bb37a.svg image/svg+xml
      upload [650] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/static/media/Receiver.26b5ae166395a6dcb83f.svg static/media/Receiver.26b5ae166395a6dcb83f.svg image/svg+xml
      upload [600] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/basic/img/Prev_HtmlLogout.png widgets/basic/img/Prev_HtmlLogout.png image/png
      upload [550] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/fancyswitch/doc.html widgets/fancyswitch/doc.html text/html
      upload [500] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/google-fonts/fonts/Marck_Script/OFL.txt widgets/google-fonts/fonts/Marck_Script/OFL.txt text/plain
      upload [450] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/history/lib/js/jquery.sparkline.min.js widgets/history/lib/js/jquery.sparkline.min.js application/javascript
      upload [400] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/jqui-mfd/img/fts_markise_75.svg widgets/jqui-mfd/img/fts_markise_75.svg image/svg+xml
      upload [350] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/jqui-mfd/img/light_light_dim_50.png widgets/jqui-mfd/img/light_light_dim_50.png image/png
      upload [300] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/map/img/marker-gold.png widgets/map/img/marker-gold.png image/png
      upload [250] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/materialdesign/js/widgets/materialdesign.select.js widgets/materialdesign/js/widgets/materialdesign.select.js application/javascript
      upload [200] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/metro/fonts/metroSysIcons.ttf widgets/metro/fonts/metroSysIcons.ttf font/ttf
      upload [150] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/spotify-premium/img/repeat_one_black.png widgets/spotify-premium/img/repeat_one_black.png image/png
      upload [100] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/background.png widgets/timeandweather/img/background.png image/png
      upload [90] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/01-1.png widgets/timeandweather/img/clock/01-1.png image/png
      upload [80] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/111-1.png widgets/timeandweather/img/clock/111-1.png image/png
      upload [70] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/211-1.png widgets/timeandweather/img/clock/211-1.png image/png
      upload [60] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/311-1.png widgets/timeandweather/img/clock/311-1.png image/png
      upload [50] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/5-1.png widgets/timeandweather/img/clock/5-1.png image/png
      upload [40] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/6-1.png widgets/timeandweather/img/clock/6-1.png image/png
      upload [30] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/8-3.png widgets/timeandweather/img/clock/8-3.png image/png
      upload [20] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/clockbg2.png widgets/timeandweather/img/clock/clockbg2.png image/png
      upload [19] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/clockbg3.png widgets/timeandweather/img/clock/clockbg3.png image/png
      upload [18] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/clockbg4.png widgets/timeandweather/img/clock/clockbg4.png image/png
      upload [17] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/clockbg5.png widgets/timeandweather/img/clock/clockbg5.png image/png
      upload [16] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/clockbg6.png widgets/timeandweather/img/clock/clockbg6.png image/png
      upload [15] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/clock/pm.png widgets/timeandweather/img/clock/pm.png image/png
      upload [14] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/icon_left.png widgets/timeandweather/img/icon_left.png image/png
      upload [13] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/icon_right.png widgets/timeandweather/img/icon_right.png image/png
      upload [12] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/img/refresh_01.png widgets/timeandweather/img/refresh_01.png image/png
      upload [11] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/js/coolclock.js widgets/timeandweather/js/coolclock.js application/javascript
      upload [10] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/js/flipclock/flipclock.min.js widgets/timeandweather/js/flipclock/flipclock.min.js application/javascript
      upload [9] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/js/jquery.jdigiclock.js widgets/timeandweather/js/jquery.jdigiclock.js application/javascript
      upload [8] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/js/jquery.zweatherfeed.js widgets/timeandweather/js/jquery.zweatherfeed.js application/javascript
      upload [7] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/js/moreskins.js widgets/timeandweather/js/moreskins.js application/javascript
      upload [6] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/js/segment-display.js widgets/timeandweather/js/segment-display.js application/javascript
      upload [5] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather/js/segmentDisplay/segment-display.js widgets/timeandweather/js/segmentDisplay/segment-display.js application/javascript
      upload [4] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/timeandweather.html widgets/timeandweather.html text/html
      upload [3] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/trashschedule/css/style.css widgets/trashschedule/css/style.css text/css
      upload [2] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/trashschedule/js/trashschedule.js widgets/trashschedule/js/trashschedule.js application/javascript
      upload [1] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets/trashschedule.html widgets/trashschedule.html text/html
      upload [0] vis-2-beta /opt/iobroker/node_modules/iobroker.vis-2-beta/www/widgets.html widgets.html text/html
      Ist node bei dir richtig installiert?
      poste doch mal die Ausgabe von iob diag
      iob stop
      iob fix
      iob diag
      iob start
      S R 2 Replies Last reply Reply Quote 0
        g.pitzer @Feuersturm last edited by
        @feuersturm
        Danke für den gutgemeinten Ratschlag und deine Antworten.
        Da für mich das VIS nicht lebensnotwendig ist und ich mich nicht zuerst in VIS1 einarbeiten möchte um mich danach umzugewöhnen habe ich mich bewusst für VIS2 entschieden. Das es noch nicht 100% funktioniert ist mir auch bewusst., deshalb verfolge ich auch diesen Thread.
        lg
          shellyrulestheworld @Feuersturm last edited by shellyrulestheworld
          @feuersturm
                                  v.2022-12-13
          Operatingsystem:        Debian GNU/Linux 11 (bullseye)
          Installation:           Native
          Timezone:               Europe/Berlin
          User-ID:                1000
          X-Server:               false
          Pending OS-Updates:     2
          Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                  /usr/bin/node           v16.19.0
                                  /usr/bin/npm            8.19.3
          ioBroker Core:          js-controller           4.0.24
                                  admin                   6.3.5
          ioBroker Status:        iobroker is not running on this host.
          Objects type: jsonl
          States  type: jsonl
          Pending iob updates:    0
          Active repo(s): stable
          Objects:                13281
          States:                 11416
          Size of iob-Database:
          14M     /opt/iobroker/iobroker-data/objects.jsonl
          2.6M    /opt/iobroker/iobroker-data/states.jsonl
          ====================== END OF SUMMARY ==================
          Das vorherige auch?
          • Feuersturm
            @peterschatz Wollte das hier sehen
                                    /usr/bin/npm            8.19.3
            Das sieht aber normal aus.
            @Thomas-Braun @apollon77 Habt ihr eine Idee, warum der Upload hier vom Adapter anscheinend nicht richtig funktioniert bzw. unvollständig ist?
              ReblausGT Developer @Feuersturm last edited by
              @feuersturm said in Test Adapter vis 2.0 (Alpha):
              @peterschatz
              Das sieht bei mir identisch aus, Start des Upload bei 851... mit gleichem Effekt, dass die neue Vis gar nicht startet.
                apollon77 @shellyrulestheworld last edited by
                @peterschatz as workaround create the menioned directory manually and it should work
                  apollon77 @Feuersturm last edited by
                  @feuersturm Doch der ist vollständig ... woran siehst Du das es nicht so ist?
                    shellyrulestheworld @apollon77 last edited by
                    Läuft --> vielen Dank!
                      Markus 6 @shellyrulestheworld last edited by
                      Ich habe gerade den Adapter(v2.0.16) installiert und bei mir öffnet sich nur eine weiße leere Seite, wenn ich die Vis öffnen möchte (http://X.X.X.X:8082/vis-2-beta/edit.html). Der Adapter ist grün. Fehlermeldungen habe ich keine.
                      • Feuersturm
                        Feuersturm @apollon77 last edited by
                        @apollon77 sagte in Test Adapter vis 2.0 (Alpha):
                        Ich hatte das daran festgemacht, dass es bei mir mit upload [1375] vis-2-beta anfängt und bei @peterschatz mit upload [851] vis-2-beta
                        Läuft denn hier was bei der Adapter Installation falsch, was im Github issure https://github.com/ioBroker/ioBroker.vis/issues/624 für Bluefox hinterlegt werden sollte oder wo fühlst du den Fehler der zu dem Problem von peterschatz führt?
                        shelly20222 created this issue in ioBroker/ioBroker.vis
                        closed VIS2-beta is not starting #624
                        • Feuersturm
                          Feuersturm @Markus 6 last edited by
                          @markus-6 sagte in Test Adapter vis 2.0 (Alpha):
                          Die interne IP brauchst du nicht aus Xen 😉
                          Poste doch mal deine Einstellungen vom web Adapter und auch welche Version installiert ist.
                            Markus 6 @Feuersturm last edited by
                            • Feuersturm
                              @markus-6 Setz mal unten den Haken bei reine Websockets verwenden und probiere es dann erneut.
                                @feuersturm Die Seite bleibt leider weiterhin weiß. Ich habe die Adapter auch schon neu geladen. Nen anderen Browser habe ich auch schon getestet.
                                • Feuersturm
                                  @markus-6 Was gibt denn die Konsole für Fehler aus, wenn du F12 drückst?
                                    • Feuersturm
                                      @markus-6 Ich komme leider nicht weiter. Hab gerade auf meinem Testsystem mal die web Adapter Version 4.3.0 wie bei dir installiert und die gleichen Einstellungen (integriert + reine Websockets verwenden) eingestellt und bei mir lädt der vis2 Editor.
                                      Hast du den "ws" Adapter bei dir auch installiert, wenn ja in welcher Version?
                                      Ansonsten bitte hier https://github.com/ioBroker/ioBroker.vis/issues ein issue anstellen mit den bisher von dir bereitgestellten Informationen, damit Bluefox sich das ansehen kann.
                                        @feuersturm ws ist nicht mehr installiert. Danke trotzdem für die Hilfe.
                                          Thomas Braun Most Active last edited by
                                          @markus-6
                                          ws muss installiert sein für den vis-Adapter, soweit ich weiß.
                                            shellyrulestheworld @Thomas Braun last edited by
                                            Irgendwie komm ich mit vis2 noch nicht klar. Mal kurz ein neues Projekt erstellt und dann den Trashschedule rein geogen. Ergebnis:
                                            web.0
                                            	278481	2022-12-31 08:49:18.728	error	17 -
                                            web.0
                                            	278481	2022-12-31 08:49:18.728	error	16 - 57799/K0/<@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:35619
                                            web.0
                                            	278481	2022-12-31 08:49:18.728	error	15 - p3@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1894:3299
                                            web.0
                                            	278481	2022-12-31 08:49:18.727	error	14 - Ca@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:38308
                                            web.0
                                            	278481	2022-12-31 08:49:18.727	error	13 - G0@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:41846
                                            web.0
                                            	278481	2022-12-31 08:49:18.726	error	12 - on@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:42513
                                            web.0
                                            	278481	2022-12-31 08:49:18.726	error	11 - Vc@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:32242
                                            web.0
                                            	278481	2022-12-31 08:49:18.726	error	10 - _8@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:32751
                                            web.0
                                            	278481	2022-12-31 08:49:18.725	error	9 - h8@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:32982
                                            web.0
                                            	278481	2022-12-31 08:49:18.725	error	8 - componentDidMount@http://192.168.178.77:8082/vis-2-beta/static/js/188.b5f35900.chunk.js:16:53862
                                            web.0
                                            	278481	2022-12-31 08:49:18.724	error	7 - renderWidget@http://192.168.178.77:8082/vis-2-beta/static/js/188.b5f35900.chunk.js:16:70324
                                            web.0
                                            	278481	2022-12-31 08:49:18.724	error	6 - e.template@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:1401:47
                                            web.0
                                            	278481	2022-12-31 08:49:18.724	error	5 - renderAs@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:1465:39
                                            web.0
                                            	278481	2022-12-31 08:49:18.723	error	4 - renderTo@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:1449:63
                                            web.0
                                            	278481	2022-12-31 08:49:18.723	error	3 - r@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:1370:29
                                            web.0
                                            	278481	2022-12-31 08:49:18.718	error	2 - n/<@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:2223:26
                                            web.0
                                            	278481	2022-12-31 08:49:18.718	error	1 - n.prototype.render@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:2229:46
                                            web.0
                                            	278481	2022-12-31 08:49:18.717	error	0 - TypeError: vis.binds.trashschedule is undefinedthis.fn@tplTrashscheduleHelper.js:24:16
                                            web.0
                                            	278481	2022-12-31 08:49:18.716	error	can't render tplTrashscheduleHelper w000001 on "default":
                                            780
                                            227500
