    4. Awattar - die billigsten Strom-Stunden nutzen
      Schimi @paul53 last edited by
      @paul53 oh sorry... blöd von mir....
      einmal als Bild:
      und als Code:
        <variables>
          <variable id="%{8F(7sB61_K]=(]=HUc">preise</variable>
          <variable id="rlR`S0q{is}DhiGVddaP">i</variable>
          <variable id="CzYDP|Yq/)s$HVs]C,93">id</variable>
          <variable id="*.=ljhdPztMh1WA90]sW">minSumme</variable>
          <variable id=".e57X)pK7UP$$qvwNJ_S">summe3</variable>
          <variable id=";U~,MEV1]:ofSH@pu[N#">end</variable>
          <variable id="w^d~TO3AMO(L(P]Yph+4">start</variable>
          <variable type="cron" id="scheduleStart">scheduleStart</variable>
          <variable type="cron" id="scheduleEnd">scheduleEnd</variable>
        </variables>
        <block type="schedule" id="C_I%*H=O%|is`$_/t|lC" x="113" y="88">
          <field name="SCHEDULE">0 * * * *</field>
            <block type="variables_set" id=";hK/pc]qO-Uz_q;D#,rZ">
              <field name="VAR" id="%{8F(7sB61_K]=(]=HUc">preise</field>
                <block type="lists_create_with" id="%vX!Cs$LYl73ZDqXwvFj">
                <block type="controls_for" id="N`)3NT@?!vred;oGWc5D">
                  <field name="VAR" id="rlR`S0q{is}DhiGVddaP">i</field>
                  <value name="FROM">
                    <shadow type="math_number" id="7Cu}S9{og6!x8lO0nB,,">
                      <field name="NUM">0</field>
                  <value name="TO">
                    <shadow type="math_number" id="ahEnHWNYjesQxUBi#Ef$">
                      <field name="NUM">23</field>
                  <value name="BY">
                    <shadow type="math_number" id="MO}{O*G6$8UERzMUWcfj">
                      <field name="NUM">1</field>
                  <statement name="DO">
                    <block type="variables_set" id="z|@x,@W|7zQZ#ZTs,t4}">
                      <field name="VAR" id="CzYDP|Yq/)s$HVs]C,93">id</field>
                        <block type="text_join" id="Aj}iP57B$WXCk?eb!sD$" inline="true">
                          <value name="ADD0">
                            <block type="text" id="YMX,!x@T6C@Zm`g(gc*H">
                              <field name="TEXT">awattar.0.prices.</field>
                          <value name="ADD1">
                            <block type="variables_get" id="V3Sl3*:1;h9ni?Uu6ESE">
                          <value name="ADD2">
                            <block type="text" id="4:wi$V)WcA}=Vu3|vLae">
                              <field name="TEXT">.totalPriceKwh</field>
                        <block type="lists_setIndex" id="=Ms[3R531nFy4Hh|f%Jr">
                          <mutation at="false"></mutation>
                          <field name="WHERE">LAST</field>
                          <value name="LIST">
                            <block type="variables_get" id="4vlq|cB#S;Eb?swa*_u5">
                          <value name="TO">
                            <block type="get_value_var" id="M+DlC0RvZ?zmwV7vBYc;">
                              <value name="OID">
                                <shadow type="text" id="t_E|h)a?}V^SX`IQ}@79">
                                  <field name="TEXT"></field>
                                <block type="variables_get" id="k#y/!YFW%zgfT*@;OJGQ">
                    <block type="variables_set" id="/vaqD$KpY#8:rnM%)w{C">
                      <field name="VAR" id="*.=ljhdPztMh1WA90]sW">minSumme</field>
                        <block type="math_number" id="onjmyp,$nceE0u9y8#)t">
                          <field name="NUM">30</field>
                        <block type="controls_for" id="9`Es?C9}G=XwuUU5a/|5">
                          <value name="FROM">
                            <shadow type="math_number" id="x/I;VhH1;`#ZjhYq.RD#">
                          <value name="TO">
                            <shadow type="math_number" id="FnCNxvOD62s7Fkv.7?*a">
                              <field name="NUM">22</field>
                          <value name="BY">
                            <shadow type="math_number" id="16|)K-L;%nUKjRyq*P$4">
                            <block type="variables_set" id="Jr0b_10U[n})RhkM=fz0">
                              <field name="VAR" id=".e57X)pK7UP$$qvwNJ_S">summe3</field>
                                <block type="math_arithmetic" id="$Z0-X;1B{HHC7C_5,mc^" inline="false">
                                  <field name="OP">ADD</field>
                                    <shadow type="math_number" id="EEJ*wsJWpAVi(R]ic,|0">
                                    <block type="math_arithmetic" id=".pqa+jCVbZMUxV~-JR7b" inline="false">
                                        <shadow type="math_number" id="r6YO2,@XR_uL{akr=~LQ">
                                        <block type="lists_getIndex" id="~~.]:Q]4!CkmN/jm$x_z">
                                            <block type="variables_get" id="g%RY8@:Mn_Cg;]gGbzT0">
                                          <value name="AT">
                                            <block type="variables_get" id="F?#7D(_e}Do?IR3N]`,`">
                                        <shadow type="math_number" id="@}6wc^{^Uu}vI([sH!n=">
                                        <block type="lists_getIndex" id="7c_[^UuKU-BQ}lU(w$}]">
                                            <block type="variables_get" id="]I`WTj,8h=8|gx}zmSOY">
                                          <value name="AT">
                                            <block type="math_arithmetic" id="mVa2wQS4TTOX!CJ`#K(w">
                                                <shadow type="math_number" id="5=BK^ZhgjK`r$neEbA(}">
                                                <block type="variables_get" id=")~nBhcp{V*=y5rcJTfc,">
                                                <shadow type="math_number" id="knPaInZyJAjzec@7oE+8">
                                    <shadow type="math_number" id="G*k34$T%?v-f6f+8}|R$">
                                    <block type="lists_getIndex" id=";*8#8??ySI!x+)~B95$%">
                                        <block type="variables_get" id="`.HPPXKbLfdun_~FD`T!">
                                      <value name="AT">
                                        <block type="math_arithmetic" id="q[LUt{{r6_(]K017Ec)`">
                                            <shadow type="math_number">
                                            <block type="variables_get" id="h4a71d[~*{Q~`rc)Mo#o">
                                            <shadow type="math_number" id="X@[YosMR*qX)!CDv9^z-">
                                              <field name="NUM">2</field>
                                <block type="controls_if" id="Zg+rib${a)X51!wZ6p2)">
                                    <block type="logic_compare" id="kWxAv]7r`mnV7Ni#uaT[">
                                      <field name="OP">LT</field>
                                        <block type="variables_get" id="y3!!w.`ir_Z]HkihMfek">
                                        <block type="variables_get" id="Lt/ftuItnB28lQKcJ}jh">
                                    <block type="variables_set" id="x)G/XOGmqh:KPNT;:Dwu">
                                        <block type="variables_get" id="UE;AX`2z,_W52/OjyUdH">
                                        <block type="variables_set" id="+]:uUPB8C$TJX])0=eG9">
                                          <field name="VAR" id="w^d~TO3AMO(L(P]Yph+4">start</field>
                                            <block type="math_arithmetic" id="Z`uk%;tSS)XiXqfF*~I;">
                                                <shadow type="math_number" id="Rfrs@16dBP4o:`=v4ZFP">
                                                <block type="variables_get" id="mCOc-1us%F7%=cUqTc,d">
                                                <shadow type="math_number" id="j+t+3,1x,oTVi)Y8f|{0">
                            <block type="controls_if" id="r;Rl}[QG^hdgn@E;sT|j">
                                <block type="logic_compare" id="U?ma*@(V=cU6dM3*|*Ec">
                                  <field name="OP">EQ</field>
                                    <block type="variables_get" id=";@^X$-Y]^ey0y{D18qis">
                                      <field name="VAR" id=";U~,MEV1]:ofSH@pu[N#">end</field>
                                    <block type="math_number" id="J/C?X%]/@4G}Nr~XJAgz">
                                      <field name="NUM">24</field>
                                <block type="control" id="oINmsjcSdAP7OTPMoM?U">
                                    <block type="logic_boolean" id="FOZVjaxdP0#/kaJ#;_oL">
                                <block type="variables_set" id="B$]uU3-XQ)1x3orP9Oh1">
                                    <block type="math_arithmetic" id="ugu?@;8t;}.m-T!VtR.%">
                                        <shadow type="math_number" id="*i]5d[y@-33/[+X~Hw+p">
                                        <block type="variables_get" id="|gx4bdL{Q)S6jz41npy,">
                                        <shadow type="math_number" id="oc`La?%4qKo)S27P4ekO">
                                          <field name="NUM">3</field>
                                    <block type="schedule_clear" id="VpV#7nOi=sxr/ANwIE(u">
                                      <field name="NAME">scheduleStart</field>
                                        <block type="schedule_clear" id="c{WfH_fUAx(H2Pd,sL=-">
                                          <field name="NAME">scheduleEnd</field>
                                            <block type="schedule_create" id="~2)[D4+^nCxJb5fUG`8^">
                                              <value name="SCHEDULE">
                                                <shadow type="field_cron">
                                                  <field name="CRON">* * * * *</field>
                                                <block type="cron_builder" id="v=E2;/_dgRPdb!Q#Wgwg" inline="true">
                                                  <mutation xmlns="http://www.w3.org/1999/xhtml" seconds="false" as_line="false"></mutation>
                                                  <field name="LINE">FALSE</field>
                                                  <field name="WITH_SECONDS">FALSE</field>
                                                  <value name="DOW">
                                                    <shadow type="text" id="th=}ESiwWw6?95exLO$E">
                                                      <field name="TEXT">*</field>
                                                  <value name="MONTHS">
                                                    <shadow type="text" id="yz^]`[ZW$4:D:%6MjmJo">
                                                  <value name="DAYS">
                                                    <shadow type="text" id="SPfRBpgL-nS44r;Nt*co">
                                                  <value name="HOURS">
                                                    <shadow type="text">
                                                    <block type="variables_get" id="h75i1luVUBkt(Ju=+2+O">
                                                  <value name="MINUTES">
                                                    <shadow type="text" id="yRt?vmf%x+A/gh@1Oy=4">
                                                      <field name="TEXT">0</field>
                                                <block type="debug" id="X/j?Hf-R?oxReeMdatJm">
                                                  <value name="TEXT">
                                                    <shadow type="text" id=",D=8=!MA=fFCH%#oi_%+">
                                                    <block type="variables_get" id="G/gnC-{WW!80Z=j@?a*I">
                                                    <block type="control" id="c8j/f4Kb0kXgb]Lssn9O">
                                                        <block type="logic_boolean" id="pvR)i|;^d-!JtJ.tZ%z+">
                                                <block type="controls_if" id="NrXhX??|fd.KNk]Ht4gf">
                                                    <block type="logic_compare" id="*z@{j2~8GL2a4xah*$P9">
                                                        <block type="variables_get" id=".nR2M=0A9Vp+jktM*yYN">
                                                        <block type="math_number" id="ye`LyPc{Udxd+NTYSxof">
                                                    <block type="schedule_create" id="@i$WSd_S`X{lzj7cM2@f">
                                                        <shadow type="field_cron" id="[=pvs=Ss^ph)?G_:-4Mm">
                                                        <block type="cron_builder" id="GgGa.Ie}G~Kz`SG[KvK/" inline="true">
                                                          <value name="DOW">
                                                            <shadow type="text" id="%:%]5ri4`rg7BpQ|iD]1">
                                                            <shadow type="text" id="Qmk|a^CndrZE:^qt#9K8">
                                                          <value name="DAYS">
                                                            <shadow type="text" id="YDr;;;U.a}Sk:,%kR7Un">
                                                            <shadow type="text" id="]t%7:eX#x-.W3r/J!RFY">
                                                            <block type="variables_get" id=".c1^J;6rj)vY.AbI|8*3">
                                                            <shadow type="text" id="_js@zAppMtcx](q.SM_4">
                                                        <block type="control" id="ycEj|^3Z!}a;JH(_@uE[">
                                                            <block type="logic_boolean" id=",zq0N12JZSC|s.O)LVA0">
        paul53 @Schimi last edited by paul53
        @schimi
        Den "steuere"-Blöcken ist kein Datenpunkt zugewiesen.
        Außerdem darf der Zeitplan nur am Tagesende und nicht jede volle Stunde ausgeführt werden.
          Hi, habe es mal mit zugewiesenen Datenpunkt nochmal probiert... Hatte bisher den "steuer"-Blockly deaktiviert und wollte mit Pushover mitteilungen schicken um das alles zu testen).
          Jedenfalls, jetzt mit "echtem" Datenpunkt und ausführung einmal am Tag... immer noch der gleiche Fehler... (Ich lasse es sofort loslaufen zum testen, ohne die wartezeit auf 23:59Uhr)
          javascript.0
          2022-12-29 19:58:39.438	error	at Script.runInContext (node:vm:141:12)
          javascript.0
          2022-12-29 19:58:39.437	error	at script.js.common.Sonstiges.Tibber_test:36:3
          javascript.0
          2022-12-29 19:58:39.437	error	at script.js.common.Sonstiges.Tibber_test:23:62
          javascript.0
          2022-12-29 19:58:39.436	error	script.js.common.Sonstiges.Tibber_test: TypeError: Cannot read properties of undefined (reading 'toString')
          javascript.0
          2022-12-29 19:58:39.434	info	script.js.common.Sonstiges.Tibber_test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2022-12-29 19:58:39.426	info	Start javascript script.js.common.Sonstiges.Tibber_test
            <variables>
            </variables>
              <field name="SCHEDULE">59 23 * * *</field>
                      <value name="FROM">
                      <value name="TO">
                      <value name="BY">
                              <value name="ADD0">
                              <value name="ADD1">
                              <value name="ADD2">
                              <value name="LIST">
                              <value name="TO">
                                  <value name="OID">
                              <value name="FROM">
                              <value name="TO">
                              <value name="BY">
                                              <value name="AT">
                                              <value name="AT">
                                          <value name="AT">
                                      <field name="OID">0_userdata.0.example_state</field>
                                                      <value name="DOW">
                                                      <value name="DAYS">
                                                              <value name="DOW">
                                                              <value name="DAYS">
          @judisi könntest du mir vielleicht dein Blockly exportieren? Vielleicht habe ich auch irgendwo nen Tippfehler und finde ihn einfach nicht....
          paul53 J 2 Replies Last reply Reply Quote 0
            @schimi sagte: Vielleicht habe ich auch irgendwo nen Tippfehler
            Ich kann keinen finden. Bau mal Log-Ausgaben der Variablen preise und start ein.
            EDIT: Hier fehlt noch der Datenpunkt:
              Datenpounkt aktualiesiert, kein unterschied....
              Debug auf preis:
              javascript.0
              2022-12-30 01:49:08.818	info	script.js.common.Sonstiges.Tibber_test: [19.87981,19.87505,19.8691,19.74058,19.75605,19.88338,19.99405,20.01071,21.06862,20.71043,20.62832,20.47719,20.23681,20.4046,22.37405,22.92026,23.2368,24.11026,26.11779,25.70486,23.16778,22.97619,23.13089,22.50733]
              Debug auf start:
              javascript.0
              2022-12-30 01:49:18.421	info	script.js.common.Sonstiges.Tibber_test: undefined
                @schimi sagte: Debug auf preis:
                Sieht gut aus.
                @schimi sagte in Awattar - die billigsten Strom-Stunden nutzen:
                Debug auf start:
                Habe ich vermutet. Grund: "setze minSumme auf 30" ist viel zu klein. Ändere es auf 99 oder größer und es wird wohl funktionieren.
                  tatsächlich.... auf 99 kommt der Fehler nicht mehr....
                  bin davon ausgegangen das er die 99 als 0,99€ interpretiert....
                  ich teste das Skript erstmal und versuche es zu verstehen 🙂
                  Eigentlich hatte ich es vor auf Tibber anzuwenden, aber erstmal so verstehen bevor ich daran "rumfummel" 🙂
                  DANKE!!!
                    judisi @Schimi last edited by judisi
                    @schimi
                    Hab das erst jetzt gesehen. Anbei (hoffe das geht so mit dem raufladen).awattar.txt
                    Momentan quäle ich mich ein wenig, weil der Awattar-Adapter nach 14:00 die Daten vom heutigen und den morgigen Tag holt. Das führt dazu, dass es dann zwei IDs mit identischen Startzeiten gibt - und dann stimmt die Sortierung der Preise nicht mehr: es werden die Preise von zwei Tagen vermischt.
                    Vielleicht findest ja du eine Lösung dafür. Ich versuche es über die Abrufintervalle sowohl vom Adapter als auch von den Script-Ausführungen zu regeln.
                      paul53 @judisi last edited by
                      @judisi sagte: Das führt dazu, dass es dann zwei IDs mit identischen Startzeiten gibt - und dann stimmt die Sortierung der Preise nicht mehr:
                      Worin unterscheiden sich die IDs?
                      Deshalb habe ich gefragt
                      @paul53 sagte in Awattar - die billigsten Strom-Stunden nutzen:
                      Auch für die Zeiten heute ab 14:00 Uhr?
                        judisi @paul53 last edited by
                        @paul53 said in Awattar - die billigsten Strom-Stunden nutzen:
                        Der Unterschied ist das startDate. Hab versucht als Bedingung einzubauen, dass die IDs "nicht von gestern sein dürfen", aber bin daran gescheitert.
                        ... Mittlerweile ist mir der Grund der Frage auch klar...
                        Eigentlich holt der Adapter (nach 14:00) Zeiten ab heute 00:00 bis morgen 24:00
                          paul53 @judisi last edited by paul53
                          @judisi sagte: holt der Adapter (nach 14:00) Zeiten ab heute 00:00 bis morgen 24:00
                          Es sind zu jeder Zeit 48 Werte? Vor 14 Uhr gestern und heute, nach 14 Uhr heute und morgen?
                          Wie wirkt sich das auf die Sortierung (nach Preis) aus?
                          EDIT: Da der Selektor die IDs normalerweise sortiert liefert, sollte es so funktionieren:
                          J paul53 2 Replies Last reply Reply Quote 0
                            @judisi sagte: der Awattar-Adapter nach 14:00 die Daten vom heutigen und den morgigen Tag holt.
                            @schimi Für die 3 aufeinander folgenden Stunden müssen die Werte von morgen genommen werden:
                              Ich glaub ich hab einen Fehler entdeckt, den man gestern, am 31.12. noch nicht sehen hat können:
                              Das Startdatum der ID schaut so aus:
                              Somit muss die "Aktuelle Zeit als anwenderformatiert" dargestellt werden.
                              Jetzt lass ich das script mal laufen und bin gespannt ...
                              Danke!
                                muss dann nur die eine Zeile geändert werden oder dass was danach kommt auch?
                                  @schimi sagte: muss dann nur die eine Zeile geändert werden oder dass was danach kommt auch?
                                  Nur die erste Schleife von 24 bis 47.
                                    paul53 @paul53 last edited by paul53
                                    @paul53 sagte: Da der Selektor die IDs normalerweise sortiert liefert, sollte es so funktionieren:
                                    @judisi
                                    Korrektur: Der Selektor liefert nach String-Sortierung: 0, 1, 10, 11, 12 ... 19, 2, 20, 21, ...
                                    Also funktioniert es nicht so einfach: Man muss eine Zählschleife verwenden und die ID zusammensetzen.
                                      wenn du mal Zeit (und vor allem auch lust) hast... könntest du vielleicht das blockly "STep-by-Step" kommentieren?
                                      Ich behaupte mal das ich blockly (einfaches) Scripting (if-when) ganz gut hinbekomme... aber damit tu ich mich schwer (liegt vielleicht am alter inzwischen 🙂 )
                                        @schimi sagte: könntest du vielleicht das blockly "STep-by-Step" kommentieren?
                                        Frage besser gezielt nach, was für Dich nicht verständlich ist.
                                          Ich hab das Script ein paar Tage laufen lassen und beobachtet. Funktioniert alles wunderbar! Anbei die Export-Datei (es ist Warmwasser auf 1 billigste Stunde und Fußboden auf 4 billigste Stunden des Tages eingestellt zum Testen).awattar.txt
                                          Was ich nicht schaffe ist, den aktuellen Stundenpreis auszugeben, also den totalPriceKwh der aktuellen Stunde. Da wird mir mal der richtige aktuelle Stundenpreis von heute angezeigt, dann wieder der von gestern oder morgen (je nachdem, was ich probiere).
                                          Aktuell probierte ich es damit. Es lieferte
                                          • gestern bis 14:00 den richtigen Preis
                                          • gestern ab 15:00 (nachdem die Preise vom kommenden Tag abgeholt wurden um 14:45)den Preis vom nächsten Tag
                                          • heute ab 00:00 wieder den richtigen Preis
                                          Kann mir wer helfen? Vermutlich ist das viel zu umständlich, was ich gemacht habe und voller Fehler ...
                                            @judisi
                                            idDate darf nicht ausgewertet werden, denn es wird in der Schleife gesetzt. Die ID für den aktuellen Preis sollte doch zu jeder Zeit sein?
                                            "awattar.0.prices." + h + ".totalPriceKwh"
                                            Evtl. um 0:00 Uhr kann der Zeitplan zu früh auslösen bevor das Umlagern der Preise von morgen nach heute vom Awattar-Adapter beendet ist. Das kann man mit einer Verzögerung (2 s?) umgehen.
                                            EDIT: Es ist wohl der Tibber-Adapter der um Mitternacht umlagert?
                                            Falls nicht um Mitternacht umgelagert wird, muss idDate neu gebildet werden:
                                            Bei mir funktioniert es mit der unteren Version.
                                            82
                                            8488
