    4. Tankerkönig Adapter Komplett umbau
    • Segway
      Segway @Issi last edited by Segway
      @issi
      Habe des öfteren folgendes im Log - keine Ahnung woher das kommt:
      2022-12-31 13:55:09.991	error	[ Adapter V:3.3.1 addDiscount ] error: TypeError: Cannot read properties of undefined (reading 'length') stack: TypeError: Cannot read properties of undefined (reading 'length') at Tankerkoenig.addDiscount (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:2040:47) at /opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:240:47 at Array.map (<anonymous>) at Tankerkoenig.setDiscount (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:236:42) at Tankerkoenig.requestData (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:154:31) at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:190:5)
      tankerkoenig.0
      2022-12-31 13:50:08.016	error	[ Adapter V:3.3.1 addDiscount ] error: TypeError: Cannot read properties of undefined (reading 'length') stack: TypeError: Cannot read properties of undefined (reading 'length') at Tankerkoenig.addDiscount (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:2040:47) at /opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:240:47 at Array.map (<anonymous>) at Tankerkoenig.setDiscount (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:236:42) at Tankerkoenig.requestData (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:154:31) at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:190:5)
      Issi 1 Reply Last reply Reply Quote 0
      • Issi
        Issi Developer @Segway last edited by
        @segway
        hast du bei deinen Stationen Rabatt aktiviert?
        • Segway
          @issi sagte in Tankerkönig Adapter Komplett umbau:
          @segway
          Ja habe ich
          • Issi
            @segway
            könntest du mir die Station ID und den Rabatt, den du eingestellt hast, per PM schicken, damit ich schauen kann, was da schiefläuft
            • Segway
              @segway
              Kann ich machen, allerdings habe ich noch keinen Rabatt eingetragen, da ich den noch raussuchen muss wie der "verrechnet" wird. Hatte es erstmal nur so aktiviert und es steht quasi 0€ drin
              Issi 2 Replies Last reply Reply Quote 0
              • Issi
                @segway o. k. danke ich probiere das dann so
                • Issi
                  @segway
                  hmm, der erste Test hat so weit funktioniert schicke mir bitte die ID der Station vielleicht kommt da ein andere wert als bei mir
                  • Segway
                    @segway
                    Mhhh, ich habe erstmal bei allen 10 Tankstellen das aktiviert. möchtest du alle 10 haben ?
                    • Issi
                      @segway
                      schaue mal, ob alle Stationen einen Preis bei e5 /e10 /Diesel haben, das könnte es auch noch sein, das eventuell eine Station keinen Preis hat
                      • Segway
                        @segway
                        Ah ok,
                        ich habe eine FREIE Tankstelle dabei und die hat in der Tat bei E10 KEINEN Preis vorhanden !
                        • Issi
                          @segway
                          kannst du die ID mir mal schicken
                          • Segway
                            @segway
                            du hast Post 🙂
                            • Issi
                              @segway
                              genau die war es danke ich überlege mir da ein Fix vorerst kannst du bei der den Rabatt für E10 rausmachen
                              • Segway
                                @segway
                                Alles klar super Danke ! Dafür teste ich ja 🙂
                                Issi 1 Reply Last reply Reply Quote 1
                                • Issi
                                  @segway
                                  hast du gestern die Version von GitHub probiert, kommt beim Ausschalten immer noch der Fehler mit der DB?
                                  • Segway
                                    @segway
                                    Ja hatte gestern die GitHub Version installiert an zwei Standorten !
                                    Bei beiden kann ich diesen Fehler momentan nicht mehr erkennen beim Ein- / Ausschalten !
                                    • Issi
                                      @segway
                                      ok, danke dann kann es vielleicht wirklich an den setStateAsync gelegen haben.
                                      Ich habe nämlich beim Ausschalten den state tankerkoenig.0.stations.adapterStatus auf offline gesetzt.
                                      Ich mache mal ein normales setState so der Adapter nicht warten soll, bis der state gesetzt wurde, vielleicht war da das Problem, dass er gewartet hat, aber die DB schon geschlossen wurde.
                                      Ich werde das in die neue Version 3.3.2 einbauen, kannst dann ja Bescheid geben, ob der Fehler wieder kommt.
                                      Segway 1 Reply Last reply Reply Quote 1
                                      • Segway
                                        Das werde ich auf jeden Fall tun !
                                        • Chaot
                                          Chaot last edited by
                                          Aus einer bei mir angegebenen Tankstellen kommen keine weiteren Werte wie Adresse, Name usw.. Das liegt vermutlich daran, dass sie zur Zeit geschlossen ist.
                                          Die machen vermutlich Mitte Januar wieder auf wenn die Firma ihre Füllrohre wieder geflickt hat. Mal schauen ob das dann kommt.
                                          • Flexer
                                            Flexer last edited by
                                            Hallo in die Runde,
                                            irgendwie bekomme ich keine Werte mehr in den Datenpunkten.
                                            Ich habe Version 3.3.1.
                                            Die Werte werden einmal geladen beim Adapterstart oder neustart geladen, aber dann erfolgt keine Aktualisierung mehr. Log ist sauber. Tankstellen IDs sind richtig. Tankstelle ist auch offen.
                                            Habe Adapter auch einmal komplett gelöscht und neu aufgesetzt.
                                            Bin ehrlich gesagt ratlos. Hat jemand eine Idee?
                                            DJMarc75 Segway 2 Replies Last reply Reply Quote 0
                                            tankerkönig
                                            36
                                            318
                                            39132
