    • Armilar
      Armilar Most Active Forum Testing @Frank579 last edited by
      @frank579
      Danke hab's noch gesehen. Da geht ein http-Request nicht durch...
      Was passiert, wenn du
      http://IP_vom_Panel/cm?cmnd=Status0
      mit der IP vom Panel im Browser absendest
        Chrille1507 @JohGre last edited by
        @johgre said in SONOFF NSPanel mit Lovelace UI:
        @armilar Ja, ist bzw. war Erste Seite, nun die Zweite. Es kommt aber ein anderes Warning
        6:56:38.830	warn	javascript.0 (1121) script.js.Energie.NSPanel.NSPanelTs_ts: function GeneratePowerPage: Cannot read properties of undefined (reading 'red')
        16:56:38.830	warn	javascript.0 (1121) script.js.Energie.NSPanel.NSPanelTs_ts: function SendToPanel: Cannot read properties of undefined (reading 'payload')
        Ist es eigentlich zwingend notwendig alle Elemete [0-6] in der richtigen Reihenfolge bzw. alle im JSON zu haben?
        Konntest du das Problem mittlerweile lösen? Ich habe es auch, konnte aber keine Lösung finden.
          Frank579 @Armilar last edited by Frank579
          @armilar sagte in SONOFF NSPanel mit Lovelace UI:
          Kommt das :
          {"Status":{"Module":0,"DeviceName":"NSPanel_01","FriendlyName":["NSPanel_01","NSPanel_01"],"Topic":"NSPanel_01","ButtonTopic":"0","Power":1,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"https://ota.tasmota.com/tasmota32/release/tasmota32.bin","RestartReason":"Vbat power on reset","Uptime":"0T07:23:29","StartupUTC":"2023-01-01T08:29:16","Sleep":0,"CfgHolder":4617,"BootCount":19,"BCResetTime":"2022-12-31T21:21:45","SaveCount":73},"StatusFWR":{"Version":"12.3.1(tasmota)","BuildDateTime":"2022.12.16 10:36:41","Core":"2_0_5_3","SDK":"v4.4.3","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 rev.3","CR":"461/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"192.168.50.10","LogPort":514,"SSId":["SmartHome",""],"TelePeriod":10,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":1481,"Free":1856,"Heap":125,"StackLowMark":3,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["00000407","9F9AD7CF","0015A001","B7F7BFCF","05DA9BC0","E0360DC7","400840D2","20200000","D43C482D","000000A1"],"Drivers":"1,2,3,4,5,7,8,9,10,11,12,14,16,17,20,21,24,26,27,29,34,35,38,50,52,59,60,62,63,82,86,87,88","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,28,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,127"},"StatusNET":{"Hostname":"NSPanel-01","IPAddress":"192.168.50.62","Gateway":"192.168.50.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.2.4","DNSServer2":"0.0.0.0","Mac":"E0:E2:E6:0C:0E:54","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"0.0.0.0","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00"},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0},"StatusMQT":{"MqttHost":"192.168.50.10","MqttPort":8883,"MqttClientMask":"NSPanel_01","MqttClient":"NSPanel_01","MqttUser":"nspanel","MqttCount":2,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2023-01-01T15:52:45","Local":"2023-01-01T16:52:45","StartDST":"2023-03-26T02:00:00","EndDST":"2023-10-29T03:00:00","Timezone":"+01:00","Sunrise":"08:43","Sunset":"17:03"},"StatusSNS":{"Time":"2023-01-01T16:52:45","ANALOG":{"Temperature1":22.1},"ESP32":{"Temperature":61.1},"TempUnit":"C"},"StatusSTS":{"Time":"2023-01-01T16:52:45","Uptime":"0T07:23:29","UptimeSec":26609,"Heap":124,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":239},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"SmartHome","BSSId":"E6:63:DA:74:AA:33","Channel":11,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":2,"Downtime":"0T00:00:04"}}}
          sieht ja eigentlich nicht so schlecht aus 🙂
          • Armilar
            Armilar Most Active Forum Testing @Frank579 last edited by Armilar
            @frank579
            Ja, das sieht auch sehr schön aus. Wie erwartet. Aber warum kann es dann der ioBroker nicht?
            Sieh mal nach, ob in deiner ioBroker JavaScript-Adapter-Instanz u.a.
            request
            unter npm-Module eingetragen ist?
            Falls nicht, kurz eintragen, speichern und den ioBroker mal durchstarten
            • TomDuke
              TomDuke last edited by
              @Armilar
              auf meinem Raspberry, dort läuft mein ioBroker, ist die Zeit auch korrekt,
              habs mit Date ausgelesen, Neustart vom Pi hat auch nichts gebracht
              • Armilar
                Armilar Most Active Forum Testing @TomDuke last edited by
                @tomduke
                Erstelle kurz ein Blockly
                  <block type="schedule" id="6Yu`)QwfE4qpNfmr268P" x="87" y="37">
                    <field name="SCHEDULE">* * * * * *</field>
                      <block type="debug" id="l?5O/}11]yr#/m#;`2FP">
                        <value name="TEXT">
                          <shadow type="text" id=";K3bqfLSLWG6r5B(k/C{">
                          <block type="time_get" id="(NH7-ko5K-Lstw6QrhtK">
                            <field name="OPTION">hh:mm:ss.sss</field>
                Dann vergleiche es mit der Uhrzeit
                TomDuke 1 Reply Last reply Reply Quote 0
                  @armilar
                  War nicht drin, hat aber auch nichts verändert 😞
                  Armilar egal 2 Replies Last reply Reply Quote 0
                  • Armilar
                    @frank579
                    Das ist die Funktion über die wir sprechen. Trage mal die IP fest ein und starte neu? Was passiert?
                    EDIT: Also wie gerade eben im Browser:
                    `http://${get_current_tasmota_ip_address()}/cm?cmnd=Status0`
                    Die Formatierung der Anführungszeichen sollte ` sein.
                    • TomDuke
                      TomDuke @Armilar last edited by
                      @tomduke
                              <value name="TEXT">
                      Ok, damit geht es, danke
                      • Armilar
                        Armilar Most Active Forum Testing @Chrille1507 last edited by
                        @chrille1507 sagte in SONOFF NSPanel mit Lovelace UI:
                        red
                        Es gibt im Script keine Farbekonstante mit kleingeschriebenen "red" sondern mit großgeschriebenen "Red". Da dürfte der Fehler liegen
                        • Armilar
                          @tomduke
                          Wie damit geht es? Ist die gleiche Funktion wie im Script??? Sollte auch die gleiche Zeit anzeigen...
                          • egal
                            egal @Frank579 last edited by
                            @frank579
                            WebAdmin Passwort im Tasmota vergeben ?
                            das war mein Thema 😉
                            Armilar F 2 Replies Last reply Reply Quote 2
                              @armilar
                              sieht jetzt so aus
                              function get_tasmota_status0() {
                                  try {
                                      if (Debug) {
                                          console.log('Requesting tasmota status0');
                                      request({
                                          url: `http://192.168.50.62/cm?cmnd=Status0`,
                                          headers: {
                                              'User-Agent': 'ioBroker'
                              kommt aber auch nichts
                              • Armilar
                                Armilar Most Active Forum Testing @egal last edited by Armilar
                                @egal
                                guter Hinweis... darf nämlich nicht
                                egal 1 Reply Last reply Reply Quote 1
                                  Frank579 @egal last edited by Frank579
                                  @egal sagte in SONOFF NSPanel mit Lovelace UI:
                                  Natürlich 🙂
                                  Habe überall Passwörter gesetzt ...
                                    Frank579 @Frank579 last edited by
                                    @frank579
                                    okay dann muss ich das wohl mal raus holen 🙂
                                    • Armilar
                                      @frank579
                                      IP ermitteln kann das Skript schon... Passworter hacken noch nicht 😉
                                      • egal
                                        egal @Armilar last edited by egal
                                        @armilar
                                        oder script anpassen:
                                        `http://${get_current_tasmota_ip_address()}/cm?user=admin&password=PASSWORD&cmnd=Status0`
                                        (alle meine Tasmotas, Shellys, ESP-Homes + Co haben Passwörter)
                                        edit: Korrektur s.o.
                                        Armilar F 2 Replies Last reply Reply Quote 0
                                        • Armilar
                                          @egal
                                          Habe ich eben auch drüber nachgedacht... Mit weiteren Parametern 🙄
                                            @armilar
                                            Ohne Passwort geht's 👍
                                            Hätte man drauf kommen können wenn man es nirgendwo angeben muss. Dachte aber läuft alles über MQTT
                                            lovelace ui nspanel sonoff
                                            270
                                            7689
                                            6513815
