    4. Tankerkönig Adapter Komplett umbau
    • haselchen
      haselchen Most Active @Flexer last edited by
      @flexer
      Supi 👍
      • DJMarc75
        DJMarc75 last edited by
        nach Update auf 3.3.1 folgendes im Log natürlich nur beim Starten:
        tankerkoenig.0
        	2023-01-02 01:47:30.661	info	State value to set for "tankerkoenig.0.stations.2.postCode" has to be type "string" but received type "number"
        tankerkoenig.0
        	2023-01-02 01:47:30.395	info	State value to set for "tankerkoenig.0.stations.1.postCode" has to be type "string" but received type "number"
        tankerkoenig.0
        	2023-01-02 01:47:29.986	info	State value to set for "tankerkoenig.0.stations.0.postCode" has to be type "string" but received type "number"
        tankerkoenig.0
        	2023-01-02 01:47:29.811	info	State value to set for "tankerkoenig.0.stations.cheapest.diesel.postCode" has to be type "string" but received type "number"
        tankerkoenig.0
        	2023-01-02 01:47:29.626	info	State value to set for "tankerkoenig.0.stations.cheapest.e10.postCode" has to be type "string" but received type "number"
        tankerkoenig.0
        	2023-01-02 01:47:29.310	info	State value to set for "tankerkoenig.0.stations.cheapest.e5.postCode" has to be type "string" but received type "number"
        quasi den jeweiligen DP-Typ fixen.
        Issi 1 Reply Last reply Reply Quote 0
        • Issi
          Issi Developer @DJMarc75 last edited by Issi
          @djmarc75
          1. manuell in den DP Fixen
          2. löschen und neu generieren lassen
          3. auf die Version 3.3.2 gehen, da wird das automatisch gemacht (empfohlen)
          • Issi
            Issi Developer last edited by Issi
            In der Version 3.3.2 sind 2 neue states dazugekommen
            • tankerkoenig.0.stations.0.e5.difference ⇨ zeig die Differenz zu dem letzten short Preis an z. B. 1.80 € - 1.83 € = -0,03 €.
              Die der state zeigt sowohl positive als auch negative Werte an 0,02 / -0,02
            • tankerkoenig.0.stations.0.e5.cheapest ⇨ zeigt an das die Station gerade am billigsten ist true / false
            • DJMarc75
              DJMarc75 @Issi last edited by
              @issi sagte in Tankerkönig Adapter Komplett umbau:
              passt 👍
              Flexer 1 Reply Last reply Reply Quote 0
              • Flexer
                Flexer @DJMarc75 last edited by
                @Issi Hallo nochmal. Habe jetzt seit gestern nichts mehr an dem Adapter gemacht denn er lief ja mit Intervall 11 Minuten. Heute morgen dieses Bild bei mir.
                Issi 2 Replies Last reply Reply Quote 0
                • wendy2702
                  wendy2702 last edited by
                  Nach Update auf 3.3.2 habe ich das im Log
                  tankerkoenig.0
                  	2023-01-02 11:14:22.593	error	[ Adapter V:3.3.2 requestData axios: 1.2.2 ] response data: {"status":"error","ok":false,"message":"parameter error"}
                  tankerkoenig.0
                  	2023-01-02 11:14:22.593	error	[ Adapter V:3.3.2 requestData axios: 1.2.2 ] response not ok
                  tankerkoenig.0
                  	2023-01-02 11:14:22.478	info	Start first request
                  tankerkoenig.0
                  	2023-01-02 11:14:21.476	error	[ Adapter V:3.3.2 createObjects ] Error creating all states: TypeError: Cannot read properties of undefined (reading 'length')
                  tankerkoenig.0
                  	2023-01-02 11:14:19.535	info	Sync time set to 10 minutes or 600000 ms
                  tankerkoenig.0
                  	2023-01-02 11:14:19.535	warn	Sync time was too short (5). New sync time is 10 min
                  tankerkoenig.0
                  	2023-01-02 11:14:19.534	info	Adapter is already in daemon mode
                  tankerkoenig.0
                  	2023-01-02 11:14:19.484	info	starting. Version 3.3.2 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v16.18.1, js-controller: 4.0.23
                  • Issi
                    Issi Developer @wendy2702 last edited by
                    @wendy2702
                    hast du das durchgeführt ? https://forum.iobroker.net/topic/60140/tankerkönig-adapter-komplett-umbau/106
                    • wendy2702
                      wendy2702 @Issi last edited by wendy2702
                      @issi Wenn ich das bei einer vorhandenen Tankstelle mache kann ich auf "hinzufügen" klicken, das Fenster schließt sich nicht und ich muss "Abbrechen" damit es zu geht.
                      EDIT: OK, es reicht nicht die einfach nur neu drüber zu kopieren. Die ID muss vorher gelöscht werden.
                      • Issi
                        @wendy2702
                        ja, ansonsten wird sie nicht als neu erkannt
                        • Issi
                          Issi Developer @Flexer last edited by
                          @flexer
                          hmm, das ist seltsam den bisher hatte keiner ein solches Problem, dass der Adapter nicht mehr Daten abruft.
                          Ändert sich der Zeitstempel bei den states?
                          Ich habe bei mir jetzt mal eine deiner Stationen eingetragen und lasse sie mit Loggen mal schauen, ob es bei mir auch auftritt.
                          • Issi
                            @flexer
                            wird der state json bei dir aktualisiert?
                            da kommen direkt nach dem Abfragen der daten vom server die Antwort mit den preisen rein
                            • Issi
                              Issi Developer @Issi last edited by Issi
                              @flexer
                              hattest du in der letzten Zeit Internet ausfälle gehabt?
                              Habe es jetzt nämlich bei mir auch, dass die werte stehen, nachdem das Internet weg war.
                              Dann kommt nämlich ein error Meldung und ab da steht er da habe ich den Neustart vom Timer vergessen.
                              Ich fixe es in der nächsten Version.
                              • Flexer
                                Flexer @Issi last edited by
                                @issi Ähm ja ich hab den ganzen Tag schon damit zu kämpfen. Mein Log ist seitenweise voller farben.
                                • Issi
                                  @flexer
                                  nicht nur deiner seit Sonntagmorgen bei mir auch ohne Ende ausfälle.
                                  Typisch Vodafone sage ich da nur.
                                    liv-in-sky last edited by
                                    habe tankerkönig abgedatet und nun das die ganze zeit im log:
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.712	warn	State "tankerkoenig.0.stations.lastUpdate" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.711	error	[ Adapter V:3.3.2 writeState ] error: TypeError: Cannot read properties of null (reading 'toString') stack: TypeError: Cannot read properties of null (reading 'toString') at Tankerkoenig.writeState (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:1746:24) at Tankerkoenig.requestData (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:159:6) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.tankerkoenig/src/main.ts:97:7)
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.665	warn	State "tankerkoenig.0.stations.1.e5.minmax.combined_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.664	warn	State "tankerkoenig.0.stations.1.e5.minmax.short_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.662	warn	State "tankerkoenig.0.stations.1.e5.minmax.3rd_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.661	warn	State "tankerkoenig.0.stations.1.e5.minmax.feed_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.659	warn	State "tankerkoenig.0.stations.1.e5.minmax.combined_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.657	warn	State "tankerkoenig.0.stations.1.e5.minmax.short_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.656	warn	State "tankerkoenig.0.stations.1.e5.minmax.3rd_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.654	warn	State "tankerkoenig.0.stations.1.e5.minmax.feed_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.652	warn	State "tankerkoenig.0.stations.1.e5.combined" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.650	warn	State "tankerkoenig.0.stations.1.e5.short" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.649	warn	State "tankerkoenig.0.stations.1.e5.difference" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.647	warn	State "tankerkoenig.0.stations.1.e5.3rd" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.646	warn	State "tankerkoenig.0.stations.1.e5.feed" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.644	warn	State "tankerkoenig.0.stations.1.overrides" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.643	warn	State "tankerkoenig.0.stations.1.openingTimes" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.642	warn	State "tankerkoenig.0.stations.1.wholeDay" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.641	warn	State "tankerkoenig.0.stations.1.longitude" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.640	warn	State "tankerkoenig.0.stations.1.latitude" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.639	warn	State "tankerkoenig.0.stations.1.houseNumber" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.637	warn	State "tankerkoenig.0.stations.1.postCode" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.636	warn	State "tankerkoenig.0.stations.1.city" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.635	warn	State "tankerkoenig.0.stations.1.fullStreet" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.633	warn	State "tankerkoenig.0.stations.1.street" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.632	warn	State "tankerkoenig.0.stations.1.discount" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.630	warn	State "tankerkoenig.0.stations.1.discounted" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.629	warn	State "tankerkoenig.0.stations.1.status" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.627	warn	State "tankerkoenig.0.stations.1.station_id" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.626	warn	State "tankerkoenig.0.stations.1.name" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.624	warn	State "tankerkoenig.0.stations.jsonTable" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.623	warn	State "tankerkoenig.0.stations.0.diesel.minmax.combined_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.621	warn	State "tankerkoenig.0.stations.0.diesel.minmax.short_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.619	warn	State "tankerkoenig.0.stations.0.diesel.minmax.3rd_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.616	warn	State "tankerkoenig.0.stations.0.diesel.minmax.feed_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.613	warn	State "tankerkoenig.0.stations.0.diesel.minmax.combined_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.610	warn	State "tankerkoenig.0.stations.0.diesel.minmax.short_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.607	warn	State "tankerkoenig.0.stations.0.diesel.minmax.3rd_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.605	warn	State "tankerkoenig.0.stations.0.diesel.minmax.feed_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.603	warn	State "tankerkoenig.0.stations.0.diesel.combined" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.600	warn	State "tankerkoenig.0.stations.0.diesel.short" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.597	warn	State "tankerkoenig.0.stations.0.diesel.difference" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.592	warn	State "tankerkoenig.0.stations.0.diesel.3rd" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.590	warn	State "tankerkoenig.0.stations.0.diesel.feed" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.588	warn	State "tankerkoenig.0.stations.0.e10.minmax.combined_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.585	warn	State "tankerkoenig.0.stations.0.e10.minmax.short_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.583	warn	State "tankerkoenig.0.stations.0.e10.minmax.3rd_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.575	warn	State "tankerkoenig.0.stations.0.e10.minmax.feed_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.549	warn	State "tankerkoenig.0.stations.0.e10.minmax.combined_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.548	warn	State "tankerkoenig.0.stations.0.e10.minmax.short_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.546	warn	State "tankerkoenig.0.stations.0.e10.minmax.3rd_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.544	warn	State "tankerkoenig.0.stations.0.e10.minmax.feed_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.542	warn	State "tankerkoenig.0.stations.0.e10.combined" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.541	warn	State "tankerkoenig.0.stations.0.e10.short" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.540	warn	State "tankerkoenig.0.stations.0.e10.difference" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.538	warn	State "tankerkoenig.0.stations.0.e10.3rd" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.536	warn	State "tankerkoenig.0.stations.0.e10.feed" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.535	warn	State "tankerkoenig.0.stations.0.e5.minmax.combined_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.530	warn	State "tankerkoenig.0.stations.0.e5.minmax.short_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.529	warn	State "tankerkoenig.0.stations.0.e5.minmax.3rd_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.528	warn	State "tankerkoenig.0.stations.0.e5.minmax.feed_max" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.526	warn	State "tankerkoenig.0.stations.0.e5.minmax.combined_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.525	warn	State "tankerkoenig.0.stations.0.e5.minmax.short_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.522	warn	State "tankerkoenig.0.stations.0.e5.minmax.3rd_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.521	warn	State "tankerkoenig.0.stations.0.e5.minmax.feed_min" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.519	warn	State "tankerkoenig.0.stations.0.e5.combined" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.518	warn	State "tankerkoenig.0.stations.0.e5.short" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.516	warn	State "tankerkoenig.0.stations.0.e5.difference" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.514	warn	State "tankerkoenig.0.stations.0.e5.3rd" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.511	warn	State "tankerkoenig.0.stations.0.e5.feed" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.509	warn	State "tankerkoenig.0.stations.0.overrides" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.508	warn	State "tankerkoenig.0.stations.0.openingTimes" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.506	warn	State "tankerkoenig.0.stations.0.wholeDay" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.504	warn	State "tankerkoenig.0.stations.0.longitude" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.503	warn	State "tankerkoenig.0.stations.0.latitude" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.501	warn	State "tankerkoenig.0.stations.0.houseNumber" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.499	warn	State "tankerkoenig.0.stations.0.postCode" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.498	warn	State "tankerkoenig.0.stations.0.city" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.496	warn	State "tankerkoenig.0.stations.0.fullStreet" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.494	warn	State "tankerkoenig.0.stations.0.street" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.492	warn	State "tankerkoenig.0.stations.0.discount" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.491	warn	State "tankerkoenig.0.stations.0.discounted" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.489	warn	State "tankerkoenig.0.stations.0.status" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.488	warn	State "tankerkoenig.0.stations.0.station_id" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.487	warn	State "tankerkoenig.0.stations.0.name" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.485	warn	State "tankerkoenig.0.stations.4.diesel.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.483	warn	State "tankerkoenig.0.stations.3.diesel.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.481	warn	State "tankerkoenig.0.stations.2.diesel.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.480	warn	State "tankerkoenig.0.stations.1.diesel.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.478	warn	State "tankerkoenig.0.stations.0.diesel.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.477	warn	State "tankerkoenig.0.stations.4.e10.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.475	warn	State "tankerkoenig.0.stations.3.e10.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.473	warn	State "tankerkoenig.0.stations.2.e10.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.471	warn	State "tankerkoenig.0.stations.1.e10.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.470	warn	State "tankerkoenig.0.stations.0.e10.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.468	warn	State "tankerkoenig.0.stations.4.e5.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.466	warn	State "tankerkoenig.0.stations.3.e5.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.464	warn	State "tankerkoenig.0.stations.2.e5.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.461	warn	State "tankerkoenig.0.stations.1.e5.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.458	warn	State "tankerkoenig.0.stations.0.e5.cheapest" has no existing object, this might lead to an error in future versions
                                    tankerkoenig.0
                                    2023-01-02 19:31:23.451	warn	State "tankerkoenig.0.stations.json" has no existing object, this might lead to an error in future versions
                                    irgend eine idee dazu ?
                                    • Issi
                                      Issi Developer @liv-in-sky last edited by
                                      @liv-in-sky
                                      liv-in-sky 1 Reply Last reply Reply Quote 1
                                        liv-in-sky @Issi last edited by
                                        @issi
                                        erstmal danke
                                        ok - die beschreibung funktionierte nicht ganz - habe dann rabatt eingeschaltet, hinzugefügt und dann gespeichert - dann wieder rabatt rausgenommen - jetzt ist nur noch das als fehler übrig
                                        tankerkoenig.0
                                        2023-01-02 19:42:07.438 error [ Adapter V:3.3.2 createObjects ] Error creating all states: TypeError: Cannot read properties of null (reading 'length')
                                        • Issi
                                          @liv-in-sky
                                          hast du da irgendein Feld leer, z. B. Hausnummer?
                                          • Steff
                                            Steff last edited by
                                            @Issi,
                                            ich bin heute auf die Version 3.2.2 gegangen.
                                            Ist echt super geworden - danke für die vielen neuen Funktionen!
                                            Gruß Steffen
                                            tankerkönig
                                            36
                                            318
                                            37372
