    3. Off Topic
    4. Proxmox
    5. Proxmox VM mit IOBroker OWServer
      Laser @Laser last edited by Laser
      Neu IOBroker installiert. Ohne Neustart:
      otto@debian11:~$ sudo systemctl status owserver
      ● owserver.service - Backend server for 1-wire control
           Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor pres>
           Active: active (running) since Mon 2023-01-02 11:03:38 CET; 5min ago
      TriggeredBy: ● owserver.socket
             Docs: man:owserver(1)
         Main PID: 372 (owserver)
            Tasks: 4 (limit: 4618)
           Memory: 1.4M
              CPU: 108ms
           CGroup: /system.slice/owserver.service
                   └─372 /usr/bin/owserver --foreground -c /etc/owfs.conf
      Jan 02 11:03:38 debian11 systemd[1]: Starting Backend server for 1-wire control>
      Jan 02 11:03:38 debian11 owserver[372]: DEFAULT: ow_opt.c:(780) systemd mode -->
      Jan 02 11:03:38 debian11 owserver[372]: DEFAULT: ow_opt.c:(670) systemd mode -->
      Jan 02 11:03:38 debian11 owserver[372]: DEFAULT: ow_usb_msg.c:(214) Opened USB >
      Jan 02 11:03:38 debian11 owserver[372]: DEFAULT: ow_usb_cycle.c:(128) Set DS949>
      Jan 02 11:03:38 debian11 systemd[1]: Started Backend server for 1-wire control.
      lines 1-18/18 (END)
           Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor preset: enabled)
           Memory: 1.4M
              CPU: 108ms
      Jan 02 11:03:38 debian11 systemd[1]: Starting Backend server for 1-wire control...
      Jan 02 11:03:38 debian11 owserver[372]: DEFAULT: ow_opt.c:(780) systemd mode -- ignore foreground request
      Jan 02 11:03:38 debian11 owserver[372]: DEFAULT: ow_opt.c:(670) systemd mode -- ignore 'p' option
      Jan 02 11:03:38 debian11 owserver[372]: DEFAULT: ow_usb_msg.c:(214) Opened USB DS9490 bus master at 2:2.
      Jan 02 11:03:38 debian11 owserver[372]: DEFAULT: ow_usb_cycle.c:(128) Set DS9490 2:2 unique id to 81 69 8E 35 >
      lines 1-18/18 (END)
           Memory: 1.4M
              CPU: 108ms
      Jan 02 11:03:38 debian11 owserver[372]: DEFAULT: ow_usb_cycle.c:(128) Set DS9490 2:2 unique id to 81 69 8E 35 00 00 00 5F
      lines 1-18/18 (END)
      Nach Neustart VM:
      [sudo] Passwort für otto:
           Active: failed (Result: signal) since Mon 2023-01-02 11:10:49 CET; 7s ago
          Process: 487 ExecStart=/usr/bin/owserver --foreground -c /etc/owfs.conf (code=killed, signal=SEGV)
         Main PID: 487 (code=killed, signal=SEGV)
              CPU: 24ms
      Jan 02 11:10:49 debian11 systemd[1]: owserver.service: Main process exited, code=killed, status=11/SEGV
      Jan 02 11:10:49 debian11 systemd[1]: owserver.service: Failed with result 'signal'.
      Jan 02 11:10:49 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 5.
      Jan 02 11:10:49 debian11 systemd[1]: Stopped Backend server for 1-wire control.
      Jan 02 11:10:49 debian11 systemd[1]: owserver.service: Start request repeated too quickly.
      Jan 02 11:10:49 debian11 systemd[1]: Failed to start Backend server for 1-wire control.
      Während der Installation war der OWServer noch zugänglich!
      L crunchip 2 Replies Last reply Reply Quote 0
        Was mache ich falsch? Wo kann ich mit Suchen ansetzen?
        Die Lösung -eine VM mit OWServer und FHEM, die andere VM mit IOBroker ohne OWServer aber mit FHEM Adapter funktioniert zwar, ist aber wohl nicht im Sinne der Erfinder...
          crunchip Forum Testing Most Active @Laser last edited by
          @laser zeig mal den Inhalt von
          cat /lib/systemd/system/owserver.service
          cat /lib/systemd/system/owserver.socket
          cat /etc/owfs.conf
            Laser @crunchip last edited by
            @crunchip
            [Unit]
            Description=Backend server for 1-wire control
            Documentation=man:owserver(1)
            [Service]
            Type=notify
            NotifyAccess=all
            Restart=on-failure
            #User=Debian-ow
            #Group=Debian-ow
            [Install]
            WantedBy=multi-user.target
            Also=owserver.socket
            [Unit]
            [Service]
            Type=notify
            NotifyAccess=all
            Restart=on-failure
            #User=Debian-ow
            #Group=Debian-ow
            [Install]
            otto@debian11:~$ ^C
            otto@debian11:~$
            otto@debian11:~$
            otto@debian11:~$
            otto@debian11:~$
            otto@debian11:~$ cat /lib/systemd/system/owserver.socket
            [Unit]
            Description=Listening socket for owserver
            [Socket]
            ListenStream=4304
            [Install]
            WantedBy=sockets.target
            # This is the main OWFS configuration file. You should read the
            # owfs.conf(5) manual page in order to understand the options listed
            # here.
            ######################## SOURCES ########################
            # With this setup, any client (but owserver) uses owserver on the
            # local machine...
            ! server: server = localhost:4304
            # ...and owserver uses the real hardware, by default fake devices
            # This part must be changed on real installation
            #server: FAKE = DS18S20,DS2405
            # USB device: DS9490
            server: usb = all
            # Serial port: DS9097
            #server: device = /dev/ttyS1
            # owserver tcp address
            #server: server = 192.168.10.1:3131
            # random simulated device
            ######################### OWFS ##########################
            #mountpoint = /mnt/1wire
            #allow_other
            ####################### OWHTTPD #########################
            http: port = 2121
            ####################### OWFTPD ##########################
            ftp: port = 2120
            ####################### OWSERVER ########################
            #server: port = localhost:4304
            server: port = 192.168.2.112:4304
              crunchip Forum Testing Most Active @Laser last edited by crunchip
              @laser sagte in Proxmox VM mit IOBroker OWServer:
              --foreground
              wenn du es mal ohne probierst, also das --foreground rauslöschen
              sudo  /lib/systemd/system/owserver.service
              und danach VM neu starten
                @crunchip
                die Zeile auskommentiert:
                     Loaded: bad-setting (Reason: Unit owserver.service has a bad unit file setting.)
                     Active: inactive (dead)
                crunchip ? 2 Replies Last reply Reply Quote 0
                  davon habe ich nichts geschrieben, du solltest die Option rauslöschen
                  anstatt
                  sollte das dann drin stehen
                  ExecStart=/usr/bin/owserver -c /etc/owfs.conf
                    A Former User @Laser last edited by
                    @laser
                    nicht die Zeile auskommentieren, nur das --foreground löschen
                    # sudo systemctl stop owserver.service
                    # sudo systemctl edit owserver.service
                    # sudo systemctl daemon-reload
                    # sudo systemctl start owserver.service
                    @crunchip war schneller 🙂
                      Laser @crunchip last edited by Laser
                      @crunchip
                      Das war ein Mißverständnis aber trotz Allem:
                           Active: failed (Result: signal) since Mon 2023-01-02 13:26:39 CET; 15s ago
                          Process: 484 ExecStart=/usr/bin/owserver -c /etc/owfs.conf (code=killed, signal=SEGV)
                         Main PID: 484 (code=killed, signal=SEGV)
                              CPU: 24ms
                      Jan 02 13:26:38 debian11 systemd[1]: owserver.service: Main process exited, code=killed, status=11/SEGV
                      Jan 02 13:26:38 debian11 systemd[1]: owserver.service: Failed with result 'signal'.
                      Jan 02 13:26:39 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 5.
                      Jan 02 13:26:39 debian11 systemd[1]: Stopped Backend server for 1-wire control.
                      Jan 02 13:26:39 debian11 systemd[1]: owserver.service: Start request repeated too quickly.
                      Jan 02 13:26:39 debian11 systemd[1]: owserver.service: Failed with result 'signal'.
                      Jan 02 13:26:39 debian11 systemd[1]: Failed to start Backend server for 1-wire control.
                           Active: failed (Result: signal) since Mon 2023-01-02 13:26:39 CET; 18s ago
                              CPU: 24ms
                      otto@debian11:~$ sudo systemctl restart owserver
                      Job for owserver.service failed because the service did not take the steps required by its unit configuration.
                      See "systemctl status owserver.service" and "journalctl -xe" for details.
                        ist das hier ein ioBroker Thema??
                        oder offtopic?
                          Laser @Homoran last edited by
                          so eindeutig kann man das nicht festmachen. Fest steht, nach Installation des IOBroker funktioniert der OWServer nicht mehr.
                            Homoran Global Moderator Administrators @Laser last edited by
                            und der gehört zu ioBroker?
                              Laser @Homoran last edited by Laser
                              Wo hättest Du das Thema gerne? Im Nirvana? IOBroker ohne Zusätze bringt keinen Nutzen.
                              So wie es früher hieß "Windows ohne Software funktioniert einwandfrei"
                                was gibt den journalctl aus? Am besten zweite Konsole aufmachen, wenn Du owserver.service startest
                                # $ sudo journalctl -f
                                Oder gibt es noch weitere Log-Files, Syslog oder Logs vom owserver?
                                VG
                                Bernd
                                  Laser @Guest last edited by Laser
                                  @dp20eic
                                  Beim Start von OWSERVER:
                                  Jan 02 14:22:09 debian11 sudo[586]: pam_unix(sudo:session): session opened for user root(uid=0) by otto(uid=1000)
                                  Jan 02 14:22:12 debian11 qemu-ga[352]: info: guest-ping called
                                  Jan 02 14:22:23 debian11 qemu-ga[352]: info: guest-ping called
                                  Jan 02 14:22:29 debian11 sudo[589]:     otto : TTY=pts/0 ; PWD=/home/otto ; USER=root ; COMMAND=/usr/bin/systemctl restart owserver
                                  Jan 02 14:22:29 debian11 sudo[589]: pam_unix(sudo:session): session opened for user root(uid=0) by otto(uid=1000)
                                  Jan 02 14:22:29 debian11 systemd[1]: Starting Backend server for 1-wire control...
                                  Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Failed with result 'protocol'.
                                  Jan 02 14:22:29 debian11 systemd[1]: Failed to start Backend server for 1-wire control.
                                  Jan 02 14:22:29 debian11 sudo[589]: pam_unix(sudo:session): session closed for user root
                                  Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 1.
                                  Jan 02 14:22:29 debian11 systemd[1]: Stopped Backend server for 1-wire control.
                                  Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 2.
                                  Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 3.
                                  Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 4.
                                  Jan 02 14:22:30 debian11 systemd[1]: Stopped Backend server for 1-wire control.
                                  Jan 02 14:22:30 debian11 systemd[1]: Starting Backend server for 1-wire control...
                                  Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Failed with result 'protocol'.
                                  Jan 02 14:22:30 debian11 systemd[1]: Failed to start Backend server for 1-wire control.
                                  Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 5.
                                  Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Start request repeated too quickly.
                                  Jan 02 14:22:34 debian11 qemu-ga[352]: info: guest-ping called
                                  Ich konnte nichts Auschlußreiches finden. Habe auch schon einen neuen USB- Busmaster besorgt, der den OWServer mit Daten versorgt.
                                  Wenn ich beim Durchreichen des USB statt der Hersteller ID direkt den Anschluß wähle, wo der USB Busmaster dranhängt, erscheint immer "ausgesteckt"
                                    IOBroker auf VM installiert. Danach OW Sever installiert. Ging nicht
                                    was war denn da das Problem? vllt kommt man so dahinter warum beides zusammen nicht funktioniert
                                    server: port = 192.168.2.103:4304
                                    was sind das für IP's
                                    hast du die Ports mal abgefragt ob sich da etwas behindert?
                                      @crunchip
                                      Dadurch, daß ich ständig neue VM's erzeugt habe, ändert sich auch die ID + IP-Adresse. Ich habe natürlich (so der Plan) immer die richtige IP- Adresse verwendet.
                                      Thomas Braun ? 2 Replies Last reply Reply Quote 0
                                        Thomas Braun Most Active @Laser last edited by
                                        @laser
                                        Mit welchen Versionen bist du da unterwegs?
                                        Könnte es sein, dass du noch in diesen Fehler rennst?
                                        https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=971513
                                          Laser @Thomas Braun last edited by
                                          otto@debian11:~$ /usr/bin/owhttpd -V
                                          /usr/bin/owhttpd version:
                                                  3.2p4
                                          libow version:
                                                  3.2p4
                                          otto@debian11:~$
                                            Die gleiche Debian- und OWServer Version auf einem Mini-PC ohne Virtualisierung funktioniert aber!
                                            Mein Produktivsystem möchte ich nicht mit allen möglichen Experimenten "versauen". Deshalb Proxmox auf einem NUC I3.
                                            1.2k
                                            81.1k
                                            14816
