Proxmox VM mit IOBroker OWServer
@crunchip
die Zeile auskommentiert:otto@debian11:~$ sudo systemctl status owserver [sudo] Passwort für otto: ● owserver.service - Backend server for 1-wire control Loaded: bad-setting (Reason: Unit owserver.service has a bad unit file setting.) Active: inactive (dead) TriggeredBy: ● owserver.socket Docs: man:owserver(1) otto@debian11:~$ sudo systemctl status owserver ● owserver.service - Backend server for 1-wire control Loaded: bad-setting (Reason: Unit owserver.service has a bad unit file setting.) Active: inactive (dead) TriggeredBy: ● owserver.socket Docs: man:owserver(1) -
@laser sagte in Proxmox VM mit IOBroker OWServer:
davon habe ich nichts geschrieben, du solltest die Option rauslöschen
anstatt
ExecStart=/usr/bin/owserver --foreground -c /etc/owfs.confsollte das dann drin stehen
ExecStart=/usr/bin/owserver -c /etc/owfs.conf -
@crunchip
Das war ein Mißverständnis aber trotz Allem:otto@debian11:~$ sudo systemctl status owserver [sudo] Passwort für otto: ● owserver.service - Backend server for 1-wire control Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor preset: enabled) Active: failed (Result: signal) since Mon 2023-01-02 13:26:39 CET; 15s ago TriggeredBy: ● owserver.socket Docs: man:owserver(1) Process: 484 ExecStart=/usr/bin/owserver -c /etc/owfs.conf (code=killed, signal=SEGV) Main PID: 484 (code=killed, signal=SEGV) CPU: 24ms Jan 02 13:26:38 debian11 systemd[1]: owserver.service: Main process exited, code=killed, status=11/SEGV Jan 02 13:26:38 debian11 systemd[1]: owserver.service: Failed with result 'signal'. Jan 02 13:26:39 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 5. Jan 02 13:26:39 debian11 systemd[1]: Stopped Backend server for 1-wire control. Jan 02 13:26:39 debian11 systemd[1]: owserver.service: Start request repeated too quickly. Jan 02 13:26:39 debian11 systemd[1]: owserver.service: Failed with result 'signal'. Jan 02 13:26:39 debian11 systemd[1]: Failed to start Backend server for 1-wire control. otto@debian11:~$ sudo systemctl status owserver ● owserver.service - Backend server for 1-wire control Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor preset: enabled) Active: failed (Result: signal) since Mon 2023-01-02 13:26:39 CET; 18s ago TriggeredBy: ● owserver.socket Docs: man:owserver(1) Process: 484 ExecStart=/usr/bin/owserver -c /etc/owfs.conf (code=killed, signal=SEGV) Main PID: 484 (code=killed, signal=SEGV) CPU: 24ms Jan 02 13:26:38 debian11 systemd[1]: owserver.service: Main process exited, code=killed, status=11/SEGV Jan 02 13:26:38 debian11 systemd[1]: owserver.service: Failed with result 'signal'. Jan 02 13:26:39 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 5. Jan 02 13:26:39 debian11 systemd[1]: Stopped Backend server for 1-wire control. Jan 02 13:26:39 debian11 systemd[1]: owserver.service: Start request repeated too quickly. Jan 02 13:26:39 debian11 systemd[1]: owserver.service: Failed with result 'signal'. Jan 02 13:26:39 debian11 systemd[1]: Failed to start Backend server for 1-wire control.otto@debian11:~$ sudo systemctl restart owserver Job for owserver.service failed because the service did not take the steps required by its unit configuration. See "systemctl status owserver.service" and "journalctl -xe" for details. -
ist das hier ein ioBroker Thema??
oder offtopic? -
so eindeutig kann man das nicht festmachen. Fest steht, nach Installation des IOBroker funktioniert der OWServer nicht mehr. -
und der gehört zu ioBroker?
Wo hättest Du das Thema gerne? Im Nirvana? IOBroker ohne Zusätze bringt keinen Nutzen.
So wie es früher hieß "Windows ohne Software funktioniert einwandfrei" -
was gibt denjournalctlaus? Am besten zweite Konsole aufmachen, wenn Duowserver.servicestartest# $ sudo journalctl -fOder gibt es noch weitere Log-Files, Syslog oder Logs vom owserver?
VG
Bernd -
@dp20eic
Beim Start von OWSERVER:Jan 02 14:22:09 debian11 sudo[586]: pam_unix(sudo:session): session opened for user root(uid=0) by otto(uid=1000) Jan 02 14:22:12 debian11 qemu-ga[352]: info: guest-ping called Jan 02 14:22:23 debian11 qemu-ga[352]: info: guest-ping called Jan 02 14:22:29 debian11 sudo[589]: otto : TTY=pts/0 ; PWD=/home/otto ; USER=root ; COMMAND=/usr/bin/systemctl restart owserver Jan 02 14:22:29 debian11 sudo[589]: pam_unix(sudo:session): session opened for user root(uid=0) by otto(uid=1000) Jan 02 14:22:29 debian11 systemd[1]: Starting Backend server for 1-wire control... Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Failed with result 'protocol'. Jan 02 14:22:29 debian11 systemd[1]: Failed to start Backend server for 1-wire control. Jan 02 14:22:29 debian11 sudo[589]: pam_unix(sudo:session): session closed for user root Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 1. Jan 02 14:22:29 debian11 systemd[1]: Stopped Backend server for 1-wire control. Jan 02 14:22:29 debian11 systemd[1]: Starting Backend server for 1-wire control... Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Failed with result 'protocol'. Jan 02 14:22:29 debian11 systemd[1]: Failed to start Backend server for 1-wire control. Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 2. Jan 02 14:22:29 debian11 systemd[1]: Stopped Backend server for 1-wire control. Jan 02 14:22:29 debian11 systemd[1]: Starting Backend server for 1-wire control... Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Failed with result 'protocol'. Jan 02 14:22:29 debian11 systemd[1]: Failed to start Backend server for 1-wire control. Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 3. Jan 02 14:22:29 debian11 systemd[1]: Stopped Backend server for 1-wire control. Jan 02 14:22:29 debian11 systemd[1]: Starting Backend server for 1-wire control... Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Failed with result 'protocol'. Jan 02 14:22:29 debian11 systemd[1]: Failed to start Backend server for 1-wire control. Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 4. Jan 02 14:22:30 debian11 systemd[1]: Stopped Backend server for 1-wire control. Jan 02 14:22:30 debian11 systemd[1]: Starting Backend server for 1-wire control... Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Failed with result 'protocol'. Jan 02 14:22:30 debian11 systemd[1]: Failed to start Backend server for 1-wire control. Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 5. Jan 02 14:22:30 debian11 systemd[1]: Stopped Backend server for 1-wire control. Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Start request repeated too quickly. Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Failed with result 'protocol'. Jan 02 14:22:30 debian11 systemd[1]: Failed to start Backend server for 1-wire control. Jan 02 14:22:34 debian11 qemu-ga[352]: info: guest-ping calledIch konnte nichts Auschlußreiches finden. Habe auch schon einen neuen USB- Busmaster besorgt, der den OWServer mit Daten versorgt.
Wenn ich beim Durchreichen des USB statt der Hersteller ID direkt den Anschluß wähle, wo der USB Busmaster dranhängt, erscheint immer "ausgesteckt" -
IOBroker auf VM installiert. Danach OW Sever installiert. Ging nicht
was war denn da das Problem? vllt kommt man so dahinter warum beides zusammen nicht funktioniert
server: port = 192.168.2.103:4304
server: server = 192.168.10.1:3131
was sind das für IP's
hast du die Ports mal abgefragt ob sich da etwas behindert?
@crunchip
Dadurch, daß ich ständig neue VM's erzeugt habe, ändert sich auch die ID + IP-Adresse. Ich habe natürlich (so der Plan) immer die richtige IP- Adresse verwendet. -
Mit welchen Versionen bist du da unterwegs?
Könnte es sein, dass du noch in diesen Fehler rennst? -
otto@debian11:~$ /usr/bin/owhttpd -V /usr/bin/owhttpd version: 3.2p4 libow version: 3.2p4 otto@debian11:~$ -
Die gleiche Debian- und OWServer Version auf einem Mini-PC ohne Virtualisierung funktioniert aber!
Mein Produktivsystem möchte ich nicht mit allen möglichen Experimenten "versauen". Deshalb Proxmox auf einem NUC I3. -
@laser das beantwortet meine Frage nicht.
@homoran sagte in Proxmox VM mit IOBroker OWServer:
da ich Onewire nicht nutze weiss ich nicht, ob der OWServer Teil von ioBroker ist.
oder offtopic?Hab es jetzt mal dahin geschoben.
gar keine Frage.
Aber Reparaturanleitungen für einen Tesla sind auch kein ioBroker Thema, nur weil es für den Tesla einen Adapter gibt.Das gilt ebenso für Grafana, Influx DB usw.
OK. Offtopic. Das löst aber mein Problem nicht.
Hat denn niemand auf einer VM mit IOBroker die allgegenwärtigen 1wire- Temperaturfühler DS18B20 im Einsatz? Kann ich mir nicht vorstellen. -
Wenn "onewire" nicht Teil des IOBroker wäre, hätte ich ja dieses Problem nicht.
Es gibt ja den Adapter dafür!
Nicht der fehlerhafte Adapter ist das Problem, sondern dass bei Installation von IOBroker der OWServer nicht mehr funktioniert. Wenn das kein IOBroker problem ist?
Unter den Tisch kehren ist natürlich auch eine Lösung! -
Es gibt ja den Adapter dafür!was schrob ich?
und was schrieb ich?
"Nicht der fehlerhafte Adapter ist das Problem, sondern dass bei Installation von IOBroker der OWServer nicht mehr funktioniert. Wenn das kein IOBroker problem ist?"
