    4. Adapter "smartmeter"
      apollon77 last edited by
      Komisch komisch … mach mal wieder auf serial nur lesen und den override raus. Ich kapiere es gerade nicht. Versuch bitte mal Version 5.10 oder 5.11 (im Admin Expertenmodus unter Adapter dann ganz rechts ist ein Dropdown-Menü für ältere versionen. Will nur sicher gehen das es nicht an der 0.5.12 liegt ...
        church last edited by
        Bei den "downgrades" bekomme ich folgende Fehlermeldungen:
        iobroker	2017-08-14 17:00:27.100	info	exit 0
        iobroker	2017-08-14 17:00:27.085	info	Adapter "smartmeter" updated
        iobroker	2017-08-14 17:00:27.022	info	upload [0] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
        iobroker	2017-08-14 17:00:26.960	info	upload [1] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
        iobroker	2017-08-14 17:00:26.804	info	upload [2] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
        iobroker	2017-08-14 17:00:26.727	info	upload [3] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
        iobroker	2017-08-14 17:00:26.636	info	upload [4] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
        iobroker	2017-08-14 17:00:26.603	info	got /opt/iobroker/node_modules/iobroker.smartmeter/admin
        iobroker	2017-08-14 17:00:19.439	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.smartmeter"
        iobroker	2017-08-14 17:00:19.404	info	npm ERR! /opt/npm-debug.log
        iobroker	2017-08-14 17:00:19.404	info	npm ERR! Please include the following file with any support request:
        iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget a package version that doesn't exist.
        iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget In most cases you or one of your dependencies are requesting
        iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget This is most likely not a problem with npm itself.
        iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget 0.5.12, 0.5.8, 0.5.7, 0.5.6, 0.5.5, 0.5.4, 0.5.0, 0.4.1, 0.4.0, 0.3.3, 0.3.2, 0.3.1, 0.3.0, 0.2.6, 0.2.4, 0.2.0, 0.1.1, 0.1.0
        iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget Valid install targets:
        iobroker	2017-08-14 17:00:19.404	info	npm ERR! notarget No compatible version found: iobroker.smartmeter@0.5.11
        iobroker	2017-08-14 17:00:19.404	info	npm ERR! code ETARGET
        iobroker	2017-08-14 17:00:19.398	info	npm ERR! npm v3.10.10
        iobroker	2017-08-14 17:00:19.398	info	npm ERR! node v6.11.2
        iobroker	2017-08-14 17:00:19.398	info	npm ERR! Linux 4.9.35-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.smartmeter@0.5.11" "--production" "--prefix" "/opt/iobroker"
        iobroker	2017-08-14 17:00:07.577	info	npm install iobroker.smartmeter@0.5.11 --production --prefix "/opt/iobroker" (System call)
        iobroker	2017-08-14 17:00:05.362	info	upgrade smartmeter@0.5.11
          Ok dann nimm die 0.5.8 😉 das André waren github Zwischenversionen …
            Bis 0.5.9 runter hatte ich probiert 8-)
            Downgrade auf 0.5.8 hat dann funktioniert und es werden jetzt erstmalig die Datenpunkte angelegt:
            Leider bleibt es bei dem einmaligen Einlesen, im log kommt dann wieder der Fehler:
            smartmeter.0	2017-08-15 14:33:54.508	debug	SERIALPORT CLOSE
            smartmeter.0	2017-08-15 14:33:54.508	warn	Exception: Error: No or too long message from Serial Device.
            smartmeter.0	2017-08-15 14:33:54.508	error	Error: No or too long message from Serial Device. at SerialResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialR
            smartmeter.0	2017-08-15 14:33:54.507	error	uncaught exception: No or too long message from Serial Device.
            smartmeter.0	2017-08-15 14:33:54.506	debug	MESSAGE TIMEOUT TRIGGERED
            smartmeter.0	2017-08-15 14:33:44.454	debug	REMAINING DATA AFTER MESSAGE HANDLING:
            smartmeter.0	2017-08-15 14:33:44.453	debug	CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
            smartmeter.0	2017-08-15 14:33:44.453	debug	SET MESSAGE TIMEOUT TIMER: 10000
            smartmeter.0	2017-08-15 14:33:44.453	debug	SerialResponseTransport do not support sending of Data! Ignore them
            smartmeter.0	2017-08-15 14:33:44.452	debug	CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
            smartmeter.0	2017-08-15 14:33:44.452	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
            smartmeter.0	2017-08-15 14:33:44.451	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r\n" -> ["/ESY5Q3DA2004 V3.03\r\n","/ESY5Q3DA2004 V3.03"]
            smartmeter.0	2017-08-15 14:33:44.451	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
            smartmeter.0	2017-08-15 14:33:44.449	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03" -> null
            smartmeter.0	2017-08-15 14:33:44.449	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
            smartmeter.0	2017-08-15 14:33:44.449	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.0" -> null
            smartmeter.0	2017-08-15 14:33:44.448	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3" -> null
            smartmeter.0	2017-08-15 14:33:44.448	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
            smartmeter.0	2017-08-15 14:33:44.448	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004" -> null
            smartmeter.0	2017-08-15 14:33:44.447	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
            smartmeter.0	2017-08-15 14:33:44.447	debug	MATCH-RESULT SIGNON: "/ESY5" -> null
            smartmeter.0	2017-08-15 14:33:44.445	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
            smartmeter.0	2017-08-15 14:33:43.558	debug	SET MESSAGE TIMEOUT TIMER: 10000
            smartmeter.0	2017-08-15 14:33:43.557	debug	SERIALPORT OPEN
            smartmeter.0	2017-08-15 14:33:43.557	debug	CREATE SERIALPORT: 9600 7 1 even
            smartmeter.0	2017-08-15 14:33:43.556	debug	SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"10","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transportSe
            smartmeter.0	2017-08-15 14:33:43.555	info	starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.11.2
            host.raspberrypi	2017-08-15 14:33:41.007	info
            Kann das ggfs. an der Leerzeile nach der ersten Zeile (/ESY5Q3DA2004 V3.03) der D0-Message liegen?
              Die Leerzeile ist korrekt. Auf welchem Betriebssystem läuft das denn bei dir? Linux Mac oder Windows? Wenn du den Adapter stops und dann neu startest geht es dann wieder ein mal?
                Und hast du das log von dem einen mal wo es geklappt hat?
                  Iobroker läuft bei mir auf einem Rpi3 mit Raspbian Jessie! In meinem letzten post hatte ich den log angehangen, wo es funktioniert hat!
                  Ich habe den Adapter nochmal deinstalliert, reboot und dann neu installiert. Jetzt werden andere Datenpunkte angelegt:
                  Hier der log seit Neuinstallation:
                  host.raspberrypi	2017-08-16 09:51:39.924	error	instance system.adapter.smartmeter.0 terminated with code 0 (OK)
                  smartmeter.0	2017-08-16 09:51:39.893	info	terminating
                  smartmeter.0	2017-08-16 09:51:39.393	debug	SERIALPORT CLOSE
                  smartmeter.0	2017-08-16 09:51:39.389	warn	Exception: Error: No or too long message from Serial Device.
                  smartmeter.0	2017-08-16 09:51:39.383	error	at Timer.listOnTimeout (timers.js:214:5)
                  smartmeter.0	2017-08-16 09:51:39.383	error	at tryOnTimeout (timers.js:250:5)
                  smartmeter.0	2017-08-16 09:51:39.383	error	at ontimeout (timers.js:386:14)
                  smartmeter.0	2017-08-16 09:51:39.383	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:87:22)
                  smartmeter.0	2017-08-16 09:51:39.383	error	at SerialResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:200:11)
                  smartmeter.0	2017-08-16 09:51:39.383	error	Error: No or too long message from Serial Device.
                  smartmeter.0	2017-08-16 09:51:39.382	error	uncaught exception: No or too long message from Serial Device.
                  smartmeter.0	2017-08-16 09:51:39.348	debug	MESSAGE TIMEOUT TRIGGERED
                  smartmeter.0	2017-08-16 09:49:39.346	debug	REMAINING DATA AFTER MESSAGE HANDLING:
                  smartmeter.0	2017-08-16 09:49:39.345	debug	CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
                  smartmeter.0	2017-08-16 09:49:39.345	debug	SET MESSAGE TIMEOUT TIMER: 120000
                  smartmeter.0	2017-08-16 09:49:39.344	debug	SerialResponseTransport do not support sending of Data! Ignore them
                  smartmeter.0	2017-08-16 09:49:39.342	debug	CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
                  smartmeter.0	2017-08-16 09:49:39.337	debug	CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
                  smartmeter.0	2017-08-16 09:49:39.333	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
                  smartmeter.0	2017-08-16 09:49:39.332	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r\n" -> ["/ESY5Q3DA2004 V3.03\r\n","/ESY5Q3DA2004 V3.03"]
                  smartmeter.0	2017-08-16 09:49:39.331	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                  smartmeter.0	2017-08-16 09:49:39.330	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r" -> null
                  smartmeter.0	2017-08-16 09:49:39.330	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                  smartmeter.0	2017-08-16 09:49:39.329	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.0" -> null
                  smartmeter.0	2017-08-16 09:49:39.328	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                  smartmeter.0	2017-08-16 09:49:39.327	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3" -> null
                  smartmeter.0	2017-08-16 09:49:39.327	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                  smartmeter.0	2017-08-16 09:49:39.325	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V" -> null
                  smartmeter.0	2017-08-16 09:49:39.324	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                  smartmeter.0	2017-08-16 09:49:39.323	debug	MATCH-RESULT SIGNON: "/ESY" -> null
                  smartmeter.0	2017-08-16 09:49:39.321	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                  smartmeter.0	2017-08-16 09:49:37.752	debug	SET MESSAGE TIMEOUT TIMER: 120000
                  smartmeter.0	2017-08-16 09:49:37.745	debug	SERIALPORT OPEN
                  smartmeter.0	2017-08-16 09:49:37.729	debug	CREATE SERIALPORT: 9600 7 1 even
                  smartmeter.0	2017-08-16 09:49:37.722	debug	SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"300","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transport
                  smartmeter.0	2017-08-16 09:49:37.711	info	starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.11.2
                  smartmeter.0	2017-08-16 09:49:37.632	debug	statesDB connected
                  smartmeter.0	2017-08-16 09:49:37.561	debug	objectDB connected
                  host.raspberrypi	2017-08-16 09:49:35.093	info	instance system.adapter.smartmeter.0 started with pid 1232
                  host.raspberrypi	2017-08-16 09:49:35.042	info	object change system.adapter.smartmeter.0
                  host.raspberrypi	2017-08-16 09:49:05.618	info	object change system.adapter.smartmeter.0
                  host.raspberrypi	2017-08-16 09:48:50.699	info	object change system.adapter.smartmeter.0
                  iobroker	2017-08-16 09:48:15.635	info	exit 0
                  iobroker	2017-08-16 09:48:15.621	info	host.raspberrypi object system.adapter.smartmeter.0 created
                  host.raspberrypi	2017-08-16 09:48:15.615	info	object change system.adapter.smartmeter.0
                  iobroker	2017-08-16 09:48:15.572	info	host.raspberrypi object system.adapter.smartmeter.0.alive created
                  iobroker	2017-08-16 09:48:15.541	info	host.raspberrypi object system.adapter.smartmeter.0.connected created
                  iobroker	2017-08-16 09:48:15.511	info	host.raspberrypi object system.adapter.smartmeter.0.memHeapUsed created
                  iobroker	2017-08-16 09:48:15.481	info	host.raspberrypi object system.adapter.smartmeter.0.memHeapTotal created
                  iobroker	2017-08-16 09:48:15.445	info	host.raspberrypi object system.adapter.smartmeter.0.memRss created
                  iobroker	2017-08-16 09:48:15.418	info	host.raspberrypi object system.adapter.smartmeter.0.uptime created
                  iobroker	2017-08-16 09:48:15.383	info	host.raspberrypi object system.adapter.smartmeter.0.inputCount created
                  iobroker	2017-08-16 09:48:15.352	info	host.raspberrypi object system.adapter.smartmeter.0.outputCount created
                  iobroker	2017-08-16 09:48:15.335	info	host.raspberrypi create instance smartmeter
                  iobroker	2017-08-16 09:48:13.496	info	add smartmeter
                    knopers1 last edited by
                    Hallo Apollon77
                    ich wollte an meinem Gaszähler den Verbrauch auslesen.
                    Genau ist es ein GT4 Gaszähler siehe Bild. Als Hardware wurde einfach ein Magnet-Reedkontakt an einem ESP8266 (WEMO D1 mini) angeschlossen.
                    Dort als Betriebssystem habe ich Tasmota installiert. Daten kommen über MQTT Adapter an IOBroker an.
                    Der magnetische Kontakt hängt jetzt am Zählwerk in der letzten Stelle des Zählwerks.
                    Somit wird alle 0.01 m³ (=10l) mein Reedkontakt kurzgeschlossen.
                    Unter MQTT Adapter sehe ich ob der Kontakt true oder false ist.
                    Ich kann den Eingang des Wemos auch so umkonfigurieren, dass man dort die Zählimpulse zählen kann…
                    Kannst Du mich auf die Spur bringen, ob dein Adapter damit umgehen kann?
                    Ich würde gerne mit dem FLOT Adapter mir eine schöne Grafik basteln.
                    Dazu ein Wert für den aktuellen Verbrauch, gesamten Verbrauch sowie Kosten loggen können.
                    Kannst Du helfen?
                      @noxx:
                      funktioniert der Adapter auch mit ESPeasy und dem Pulse Counter?
                      Oder gibt es Arduino Lösungen? Habe am Arduino im moment ein Read-Schalter, der
                      Read-Schalter am Gaszähler.
                      Ähnlich wie hier: https://voizchat.de/gaszaehler-verbrauc … erry-gpio/ `
                      noxx hat schon mal ne ähnliche Frage gestellt,geht nicht. Ein paar Seiten weiter vorn. Außerdem gibts von ihm auch noch ne Lösung wo aus einer Webseite Daten ausgelesen werden können.
                      http://forum.iobroker.net/viewtopic.php?f=21&t=7556&hilit=gasz%C3%A4hler gibts dazu noch ein paar Infos.
                      RappiRN
                        woww, Danke Dir für den Link!
                          @church: muss ich Montag checken …
                            Super, danke!
                              Arminhh last edited by
                              Guten Morgen,
                              ich habe jetzt alle Seiten durch gelesen! Leider habe ich noch ein Problem.
                              Ich habe mir diese Woche den extra den Multihost eingerichtet. Der Slave ein PI 3B ist im Keller und der Lesekopf von UDO angeschlossen.
                              Der Smartmeter Adapter lässt sich installieren. Beim Starten des Adapters erscheint die Fehlermeldung wie auf Seite 28 gefunden
                              host.rasp_pv1_goke 2017-07-24 21:35:41.501 error instance system.adapter.smartmeter.0 terminated with code 1 ()
                              host.rasp_pv1_goke 2017-07-24 21:35:40.719 info instance system.adapter.smartmeter.0 started with pid 11153
                              host.rasp_pv1_goke 2017-07-24 21:35:35.334 info Restart adapter system.adapter.smartmeter.0 because enabled
                              Scheinbar muss laut Seite 28
                              " Komisch … Dann löscht mal den "open-sml" ordner und installiere dann den Adapter. Sollte dann wieder installiert werden. Falls nicht wirf auch smartmeter-obis weg (oder gleich beides)"
                              gelöscht werden!
                              Leider finde ich weder wen der Adapter installiert ist, noch wenn er deinstalliert ist die beiden Verzeichnisse!
                              Danke für die Hilfe
                                Hallo Armin,
                                nur damit wir vom gleichen reden:
                                Bei Multihost darf vor der Verbindung zum Master NUR der admin (und der Discovery) installiert sein.
                                Alles andere muss anschließend über den Master (unter Host.1=Slave) installiert werden.
                                Auf keinen Fall vorher auf dem Keller-Pi installieren und dann erst als Slave definieren.
                                Hast du das so ausgeführt?
                                Rainer
                                  Danke für den Hinweis! Das habe ich berücksichtigt! Erst die Verbindung zwischen Host und Slave dann über den Master Admin auf dem Slave den Smartmeter Adapter installiert!
                                  mfg
                                  Armin
                                    Danke für die Antwort,
                                    dann ist die Grundinstallation schon mal ok (so habe ich es auch - allerdings mit einem Pi2) und es läuft.
                                    Dann müsste @apollon77 etwas dazu sagen, der ist aber in Urlaub, was ihn aber anscheinend nicht hindern wird 😉
                                    Rainer
                                      Ich habe auch test weise mal einen anderen Adapter installiert. Der lief auf Anhieb auf dem Slave ! Liegt also nicht an meiner Installation!
                                      mfg
                                      Arminhh
                                        Vielleicht wären noch deine Versionen von js-controller und admin interessant.
                                        Rainer
                                          alles aktuell
                                          js-controller 1.1.2
                                          Admin 2.0.2
                                            die Dateien bzw. Verzeichnisse habe ich inzwischen gefunden gelöscht und neu installiert. Leider bekomme ich immer noch die Fehlermeldung
                                            host.IOBrokerKeller	2017-08-17 14:30:03.823	info	Do not restart adapter system.adapter.smartmeter.0 because disabled or deleted
                                            host.IOBrokerKeller	2017-08-17 14:30:03.822	error	instance system.adapter.smartmeter.0 terminated with code 1 ()
                                            host.IOBrokerKeller	2017-08-17 14:29:34.382	info	instance system.adapter.smartmeter.0 terminated with code null ()
                                            host.IOBrokerKeller	2017-08-17 14:29:34.381	warn	instance system.adapter.smartmeter.0 terminated due to SIGTERM
                                            host.IOBrokerKeller	2017-08-17 14:29:34.374	info	stopInstance system.adapter.smartmeter.0 killing pid 1842
                                            host.IOBrokerKeller	2017-08-17 14:29:34.373	info	stopInstance system.adapter.smartmeter.0
                                            host.IOBrokerKeller	2017-08-17 14:29:34.373	info	"system.adapter.smartmeter.0" disabled
                                            host.IOBrokerKeller	2017-08-17 14:29:34.372	info	object change system.adapter.smartmeter.0
                                            host.IOBrokerKeller	2017-08-17 14:29:33.143	info	instance system.adapter.smartmeter.0 started with pid 1842
                                            host.IOBrokerKeller	2017-08-17 14:29:32.146	info	Restart adapter system.adapter.smartmeter.0 because enabled
                                            host.IOBrokerKeller	2017-08-17 14:29:32.146	error	instance system.adapter.smartmeter.0 terminated with code 1 ()
                                            host.IOBrokerKeller	2017-08-17 14:29:30.517	info	instance system.adapter.smartmeter.0 started with pid 1836
                                            host.IOBrokerKeller	2017-08-17 14:29:03.105	info	Restart adapter system.adapter.smartmeter.0 because enabled
                                            Hat noch jemand einen Tip?
                                            Danke im Vorraus
                                            LG
                                            Arminhh
                                            3625
                                            2192979
