    4. Test Adapter vis 2.0 (Alpha)
      shellyrulestheworld @Thomas Braun last edited by
      Irgendwie komm ich mit vis2 noch nicht klar. Mal kurz ein neues Projekt erstellt und dann den Trashschedule rein geogen. Ergebnis:
      web.0
      	278481	2022-12-31 08:49:18.728	error	17 -
      web.0
      	278481	2022-12-31 08:49:18.728	error	16 - 57799/K0/<@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:35619
      web.0
      	278481	2022-12-31 08:49:18.728	error	15 - p3@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1894:3299
      web.0
      	278481	2022-12-31 08:49:18.727	error	14 - Ca@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:38308
      web.0
      	278481	2022-12-31 08:49:18.727	error	13 - G0@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:41846
      web.0
      	278481	2022-12-31 08:49:18.726	error	12 - on@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:42513
      web.0
      	278481	2022-12-31 08:49:18.726	error	11 - Vc@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:32242
      web.0
      	278481	2022-12-31 08:49:18.726	error	10 - _8@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:32751
      web.0
      	278481	2022-12-31 08:49:18.725	error	9 - h8@http://192.168.178.77:8082/vis-2-beta/static/js/main.c31a7d5a.js:1896:32982
      web.0
      	278481	2022-12-31 08:49:18.725	error	8 - componentDidMount@http://192.168.178.77:8082/vis-2-beta/static/js/188.b5f35900.chunk.js:16:53862
      web.0
      	278481	2022-12-31 08:49:18.724	error	7 - renderWidget@http://192.168.178.77:8082/vis-2-beta/static/js/188.b5f35900.chunk.js:16:70324
      web.0
      	278481	2022-12-31 08:49:18.724	error	6 - e.template@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:1401:47
      web.0
      	278481	2022-12-31 08:49:18.724	error	5 - renderAs@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:1465:39
      web.0
      	278481	2022-12-31 08:49:18.723	error	4 - renderTo@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:1449:63
      web.0
      	278481	2022-12-31 08:49:18.723	error	3 - r@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:1370:29
      web.0
      	278481	2022-12-31 08:49:18.718	error	2 - n/<@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:2223:26
      web.0
      	278481	2022-12-31 08:49:18.718	error	1 - n.prototype.render@http://192.168.178.77:8082/vis-2-beta/lib/js/can.custom.js:2229:46
      web.0
      	278481	2022-12-31 08:49:18.717	error	0 - TypeError: vis.binds.trashschedule is undefinedthis.fn@tplTrashscheduleHelper.js:24:16
      web.0
      	278481	2022-12-31 08:49:18.716	error	can't render tplTrashscheduleHelper w000001 on "default":
        apollon77 @shellyrulestheworld last edited by
        @peterschatz dann ließ mal den ersten post und handle entsprechend. Wie dort steht müssen Widgets ggf angepasst werden und scheinbar ist trashschedule eins davon
        • Merlin123
          Merlin123 last edited by
          Mal ein kleines Update von mir:
          Mit der .16er Version zeigt er "meine" Visualisierung im Editor an. Da ich aber großteils die Inventwo Widgets nutze, die wohl noch nicht kompatibel sind, geht die Vis natürlich nicht. Aber alles andere wird im Editor jetzt angezeigt. bis zur .10er Version, die ich als letztes probiert habe, hat das ja auch nicht nicht geklappt.
          In der normalen Darstellung der VIS kommt aber nur ein weißer Bildschirm, nicht mal die Sachen, die im Editor noch zu sehen sind, werde dargestellt.
          Console wirft das aus
          bootstrap.jsx:20 iobroker.vis-2-beta@2.0.16 using theme "colored"
          main.c31a7d5a.js:657
          main.c31a7d5a.js:657 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
          main.c31a7d5a.js:657 Help us to create open source project with reactJS!
          main.c31a7d5a.js:657 See you :)
          socket.io.js:66 [2023-01-02T10:23:17.017Z] Try to connect
          VM40:140 Version vis-canvas-gauges: 0.1.5
          VM41:4 Uncaught TypeError: Cannot read properties of undefined (reading 'localization')
              at <anonymous>:4:39
              at Qe.<anonymous> (visEngine.jsx:1154:38)
              at Generator.next (<anonymous>)
              at 188.b5f35900.chunk.js:29:17517
              at new Promise (<anonymous>)
              at bi (188.b5f35900.chunk.js:29:17337)
              at Qe.setInnerHTML (visEngine.jsx:1117:42)
              at Qe.<anonymous> (visEngine.jsx:1183:29)
              at o (188.b5f35900.chunk.js:29:17375)
          VM44:75 Version vis-history: 1.0.0
          VM46:110 Version vis-jqui-mfd: 1.0.12
          iconFont.min.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
          fritzdect.js:46 Version fritzdect: 0.0.2
          slideshow.js:348 Version slideshow: 0.0.1
          trashschedule.js:152 Version trashschedule: 2.1.0
          metro-bootstrap.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis-2-beta/widgets/metro/js/metro.js:1          Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis-2-beta/wid…/info/js/info.js:84 Uncaught SyntaxError: Unexpected end of input
          DevTools failed to load source map: Could not load content for chrome-extension://gighmmpiobklfepjocnamgkkbiglidom/browser-polyfill.js.map: System error: net::ERR_FILE_NOT_FOUND
          DevTools failed to load source map: Could not load content for http://192.168.0.251:8082/vis-2-beta/static/js/main.c31a7d5a.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
          DevTools failed to load source map: Could not load content for http://192.168.0.251:8082/vis-2-beta/static/js/313.3238287f.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
          Ist wie gesagt nur mal ein Update, aber vielleicht hilft es ja den Entwicklern so sehen, wo es noch hakt.
          A Feuersturm skvarel 3 Replies Last reply Reply Quote 0
            adsfa @Merlin123 last edited by adsfa
            Hi zusammen, bei mir lädt leider die linke Spalte nicht. Hat jemand eine Idee woran das liegen kann?
            vis-2-beta.0
            2023-01-02 13:10:02.607 info vis license is OK.
            vis-2-beta.0
            2023-01-02 13:10:02.401 info starting. Version 2.0.16 in /opt/iobroker/node_modules/iobroker.vis-2-beta, node: v14.19.2, js-controller: 4.0.23
            Glasfaser Feuersturm 2 Replies Last reply Reply Quote 0
            • Glasfaser
              Glasfaser @adsfa last edited by Glasfaser
              @adsfa sagte in Test Adapter vis 2.0 (Alpha):
              würde ich erstmal auf den "aktuellen" Stand bringen !
              A 1 Reply Last reply Reply Quote 2
              • Feuersturm
                Feuersturm @adsfa last edited by
                Bei dir steht links oben unter dem Mülleimer "undefined". Dort steht normalerweise das geladene Projekt.
                Erstelle mal ein neues Projekt und prüfe dann, ob sich die linke Spalte mit den Widgets aufbaut. Ein Browser Cache leeren könnte auch hilfreich sein.
                • Feuersturm
                  Feuersturm @Merlin123 last edited by
                  @merlin123 sagte in Test Adapter vis 2.0 (Alpha):
                  Es gibt zu Inventwo hier ein issue https://github.com/ioBroker/ioBroker.vis/issues/594 du kannst es dir ja einmal ansehen, ob das dein Problem wiederspiegelt.
                  Was meinst du mit der "normalen Darstellung" Bei Problemen einmal durch die aktuellen issues https://github.com/ioBroker/ioBroker.vis/issues durchschauen und wenn dort dein Problem nicht auftaucht, leg bitte ein neues an.
                  Es ist auch kein Problem, wenn ein issue mal doppelt ist, das wird dann notfalls auf "duplicate" gestellt und geschlossen, falls es das issue doch schon gab.
                  Bluefox als Entwickler wird sicht die github issues anschauen und abarbeiten und sich nicht durch diesen Forumsthread kämpfen 😉
                  Haifeif created this issue in ioBroker/ioBroker.vis
                  open VIS2.X: Import Probleme mit vis-inventwo widgets #61
                    adsfa @Glasfaser last edited by
                    @glasfaser Danke, guter Tipp.
                    @Feuersturm Damit hat es funktioniert 🙂 Danke!
                      Telefisch @adsfa last edited by
                      Hallo Ihr…
                      vielen Dank für die neue Version.
                      Ich habe grade erst angefangen sie auszuprobieren aber hätte schon eine Anmerkung.
                      Oft arbeite ich über‘s iPad und hatte daher darauf gehofft, dass es etwas besser mit der Unterstützung wird.
                      Leider ist das aber nicht der Fall…
                      Daher eine Frage, nach einem kleinen Feature.
                      Ist es möglich das mittlere Fenster, also die Ansicht des Editor-Fensters mit Scrollbars auszustatten? Im Augenblich hängt die Darstellung immer oben Links und lässt sich nicht verschieben geschweige denn zoomen.
                      …nur so als Anregung…
                      • Feuersturm
                        Feuersturm @Telefisch last edited by
                        @telefisch Im Browser am Laptop sieht es so aus. Wenn ich ein Element nach unten ziehe, dann bekomme ich auch einen Scrollbalken angezeigt. Ist das bei dir am Tablet anders?
                          Telefisch @Feuersturm last edited by Telefisch
                          @feuersturm na toll…
                          manchmal komme ich mir vor wie der letzte Depp…
                          Hab hundert Mal drauf rum gedrückt, geschoben und gescrollt… NIX
                          Jetzt nochmal neu geöffnet und siehe da…
                          Naja, dann soll es wohl laufen.
                          Danke 😉
                          • skvarel
                            skvarel Developer @Merlin123 last edited by skvarel
                            @merlin123 .. was geht bei unseren inventwo Widgets nicht?
                            Das einzige, was zur Zeit noch nicht geht ist das Binding. Alles andere funktioniert.
                            Runtime:
                            Editor:
                            sigi234 A 2 Replies Last reply Reply Quote 0
                              sigi234 Forum Testing Most Active @skvarel last edited by
                              @skvarel sagte in Test Adapter vis 2.0 (Alpha):
                              Und das PopUp.
                              skvarel 1 Reply Last reply Reply Quote 1
                              • skvarel
                                skvarel Developer @sigi234 last edited by
                                @sigi234 .. das gucken wir uns an, ob es an uns oder an VIS2 liegt!
                                    ammawel @skvarel last edited by
                                    @skvarel ... bei mir wird bis auf Background und Background Small kein Widget angezeigt. Keine Color-Einstellung hat irgendeinen Einfluss darauf. Die bisher verwendeten Universal, Multi und Slider sind unsichtbar...
                                    Danke für sachdienliche Hinweise
                                    skvarel 1 Reply Last reply Reply Quote 0
                                      Telefisch @sigi234 last edited by Telefisch
                                      Hiho...
                                      ich denke ich habe auch einen Bug gefunden, weiß aber nicht, ob er hier schon kommentiert wurde:
                                      Im Basic String img src-Widget werden die Bilder nicht oder nicht sofort angezeigt.
                                      Ich habe z.B. den Datenpunkt openweathermap.0.forecast.day1.icon eingefügt.
                                      Mit openweathermap.0.forecast.current.icon und openweathermap.0.forecast.day0.icon hatte ich gestern schon keinen Erfolg, aber heute Morgen war er dann doch mit einer Wolke gefüllt.
                                      Jetzt wollte ich an der VIS weiterbasteln und siehe da, keine Wolke bei day1 in der Laufzeit-Umschaltung, im Editor.
                                      Runtime in neuem Fenster zeigt nun auch bei day0 und bei current fehlendes Bild. (Icon für unterbrochenen Link)
                                      EDIT: Ich sehe grade Openweathermap hate keine Daten, wenn ich aus den Datenpunkten auswähle. Unter Objekte schon.
                                      • skvarel
                                        skvarel Developer @ammawel last edited by
                                        @ammawel .. die 'Small Widgets' sind EOL und werden nicht mehr weiterentwickelt!
                                        Wir arbeiten nur noch an diesen Widgets:
                                        Warum unsere Widgets bei dir nicht laufen, kann ich ehrlich gesagt nicht beantworten. Ich kann den Fall auch nicht nachstellen. Hier (und auch bei anderen) laufen die Widgets. Wir werden allerdings auch noch keine Änderungen an unserem Adapter machen, bis der VIS2 'fertig' ist und wir zu 100% wissen, dass es an uns liegt und nicht an einem Bug in VIS2.
                                        Chaot A 2 Replies Last reply Reply Quote 0
                                        • Chaot
                                          Chaot @skvarel last edited by
                                          Macht ja auch Sinn.
                                          Ich habe durchgängig die Widgets von euch im Einsatz. Leider fast alle auch mit Bindings. Aber die funktionieren ja auch bei anderen Widgets nicht oder nur eher zufällig. Also ist bisher blinder Aktionismus sinnlos.
                                            ammawel @skvarel last edited by ammawel
                                            @skvarel Danke, das war schon klar, dass die 'Small Widgets' nicht mehr unterstützt werden, die anderen wurden nur nicht angezeigt.
                                            Aber - und jetzt wird es verrückt:
                                            • Bisher startete vis-2 zögernd, erstellte Seiten funktionierten nicht, jede Menge Widgets wie Inventwo, TrashSchedule, TimeSwitch funktionierten nicht (s.o.)
                                            • Ich habe dann etwas nachgeforscht: In der Konsole des Browsers (F12) hatte ich bei vis-2 jede Menge Fehlermeldungen zu fehlenden Metro-Widget-Dateien. Die Metro-Widgets hatte ich unter dem bisherigen vis nicht installiert.
                                            • Ich habe dann die Metro-Widgets für das bisherige vis installiert
                                            • Danach startete vis-2 nicht mehr, es war nur ein weißer Bildschirm ohne jeden Inhalt zu sehen
                                            • Also habe ich vis-2 nach der Anleitung im ersten Beitrag "pseudo-aktualisiert", die Version blieb natürlich bei 2.0.16, sie wurde nur neu eingespielt
                                            • Und was soll ich sagen: Vis-2 startet flüssig, gespeicherte Seiten werden angezeigt, alle Widgets von inventwo, TimeSwitch (bisher nur Einmal-Ereignisse), TrashSchedule werden angezeigt und funktionieren
                                            So, wie das jetzt für mich aussieht, ist die Installation der Metro-Widgets für vis-2 von essentieller Bedeutung, eine notwendige Voraussetzung.
                                            Habe ich da in diesem Thread etwas überlesen? Eigentlich brauche ich die Metro-Widgets nicht... ... und würde sie auch gerne wieder loswerden.
                                            780
                                            262056
