    4. Server Cannot start inMem-objects on port 9001
      woehrer @Thomas Braun last edited by
      Bin jetzt mal hoch auf v16
      woehrer@iobrokerifa:/opt/iobroker$ node -v
      v16.19.0
      woehrer@iobrokerifa:/opt/iobroker$ npm -v
      8.19.3
      woehrer@iobrokerifa:/opt/iobroker$ iobroker fix
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installation fixer!
          Script version: 2022-12-09
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      OK:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Holen:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
      OK:3 https://deb.nodesource.com/node_16.x jammy InRelease
      Holen:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease [99,8 kB]
      Holen:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
      Es wurden 324 kB in 1 s geholt (576 kB/s).
      Paketlisten werden gelesen… Fertig
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/4)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
          Database maintenance (3/4)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (4/4)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      Bekomme immernoch die Fehlermeldung und der admin Adapter startet weiterhin nicht. Alles andere scheint aber zu laufen
      Thomas Braun crunchip W 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @woehrer last edited by
        @woehrer
        iobroker diag
        ausführen und Ergebnisse bekannt geben.
          crunchip Forum Testing Most Active @woehrer last edited by
          @woehrer sagte in Server Cannot start inMem-objects on port 9001:
          iob logs --watch
          iob list instances
            woehrer @woehrer last edited by woehrer
            @woehrer
                                    v.2022-12-13
            Operatingsystem:        Ubuntu 22.04.1 LTS
            Installation:           microsoft
            Timezone:               Europe/Berlin
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     0
            Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                    /usr/bin/node           v16.19.0
                                    /usr/bin/npm            8.19.3
            ioBroker Core:          js-controller           4.0.23
                                    admin                   6.3.3
            Objects type: jsonl
            States  type: jsonl
            Pending iob updates:    2
            Active repo(s): stable
            Objects:                6726
            States:                 6193
            Size of iob-Database:
            7.5M    /opt/iobroker/iobroker-data/objects.jsonl
            4.7M    /opt/iobroker/iobroker-data/objects.json.migrated
            4.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
            5.0M    /opt/iobroker/iobroker-data/states.jsonl
            1.2M    /opt/iobroker/iobroker-data/states.json.migrated
            1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
            ====================== END OF SUMMARY ==================
            2022-12-22 09:47:26.773  - info: host.iobrokerifa instance system.adapter.admin.0 started with pid 3788
            2022-12-22 09:47:27.787  - info: admin.0 (3788) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
            2022-12-22 09:47:27.814  - info: admin.0 (3788) requesting all states
            2022-12-22 09:47:27.816  - info: admin.0 (3788) requesting all objects
            2022-12-22 09:47:27.956  - warn: admin.0 (3788) Cannot check node.js versions: Error: unexpected end of file
            2022-12-22 09:47:28.326  - info: admin.0 (3788) received all objects
            2022-12-22 09:47:28.438  - info: admin.0 (3788) Request actual repository...
            2022-12-22 09:47:28.523  - info: admin.0 (3788) http server listening on port 8081
            2022-12-22 09:47:28.523  - info: admin.0 (3788) Use link "http://localhost:8081" to configure.
            2022-12-22 09:47:28.527  - info: admin.0 (3788) socket.io server listening on port 8081
            2022-12-22 09:47:28.539  - error: admin.0 (3788) uncaught exception: Cannot read properties of null (reading '_acl')
            2022-12-22 09:47:28.539  - error: admin.0 (3788) TypeError: Cannot read properties of null (reading '_acl')
                at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                at processImmediate (node:internal/timers:468:21)
            2022-12-22 09:47:28.540  - error: admin.0 (3788) Cannot read properties of null (reading '_acl')
            2022-12-22 09:47:28.556  - info: admin.0 (3788) terminating http server on port 8081
            2022-12-22 09:47:28.560  - info: admin.0 (3788) terminating
            2022-12-22 09:47:28.561  - warn: admin.0 (3788) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-12-22 09:47:28.779  - info: host.iobrokerifa Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
            2022-12-22 09:47:28.814  - error: host.iobrokerifa instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2022-12-22 09:47:28.814  - info: host.iobrokerifa Restart adapter system.adapter.admin.0 because enabled
            Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
              @woehrer
              Das ist WSL2 oder sowas?
                Das ist eine virtuelle Maschine in der Ubuntu 22 läuft
                  virtuelle Maschine
                  Welche?
                    @woehrer selbiges ist auch hier
                    https://forum.iobroker.net/post/914523
                      apollon77 @woehrer last edited by
                      @woehrer Admin 6.3.5 installieren!
                        Karl 1 last edited by
                        Bei mir ist ein ähnliches Problem aufgetreten wie bei bischemer am 14. März 2022 und bei offensichtlich mehreren anderen.
                        Ich habe den RPI mit sudo shutdown -h 0 runtergefahren, die Stromversorgung abgeklemmt und mit Win32DiskImager die SD auf eine Backup Platte kopiert.
                        Nach dem erneuten Einlegen der SD und Anlegen der Versorgungsspannung startet der RPI und auch der ioBroker, der Zugriff über das Web Interface und Vis ist nicht mehr möglich.
                        Den gleichen Effekt hatte ich schon vor einigen Wochen, ich habe mich damit beholfen, dass ich mit einem früheren Backup alle zwischenzeitlichen Änderungen nachgezogen habe (was man einmal machen kann, was aber keine Dauerlösung ist).
                        Da der Effekt m.E. entweder mit dem Shutdown oder dem Abklemmen der Versorgung zu tun hat, kann dieses Problem immer wieder auftauchen, sei es bei einem regulären Backup oder bei einem Spannungsausfall im Versorgungsnetz.
                        Ich habe alles hier Geschriebene gelesen und nachvollzogen aber keine Lösung für mich gefunden!
                        Angefügt einige Infos zu meinem Problem:
                        pi@raspberrypi:~ $ iob info
                        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                        2023-01-02 19:09:42.694  - error: host.raspberrypi No connection to databases possible, restart
                        2023-01-02 19:09:42.748  - info: host.raspberrypi iobroker _restart
                        2023-01-02 19:09:48.841  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                        2023-01-02 19:09:48.862  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2023-01-02 19:09:48.865  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
                        2023-01-02 19:09:48.867  - info: host.raspberrypi ip addresses: 192.168.178.43 2003:ea:f10:b800:e3c1:cab5:4a9b:7a32 fe80::78fb:de3d:17ae:be62
                        2023-01-02 19:10:18.939  - error: host.raspberrypi No connection to databases possible, restart
                        ```pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -l
                        insgesamt 529504
                        drwxrwxrwx+   2 iobroker iobroker      4096 Mai  2  2022 backitup
                        drwxrwxrwx+   2 iobroker iobroker      4096 Jan  2 09:26 backup-objects
                        drwxrwxrwx+  21 iobroker iobroker      4096 Nov 26 11:59 files
                        drwxrwxrwx+ 185 iobroker iobroker     12288 Jan  2 00:02 history
                        -rw-rwxrw-+   1 iobroker iobroker      4715 Mai  2  2022 iobroker.json
                        -rw-rw-rw-+   1 iobroker iobroker         3 Jan  2 11:11 notifications.json
                        -rw-rw-rw-+   1 iobroker iobroker   3715730 Mai  2  2022 objects.json.bak.migrated
                        -rw-rw-rw-+   1 iobroker iobroker 524134421 Jan  2 10:52 objects.jsonl
                        drwxrwxrwx+   2 iobroker iobroker      4096 Jan  2 19:44 objects.jsonl.lock
                        -rw-rw-rw-+   1 iobroker iobroker   3718224 Mai  2  2022 objects.json.migrated
                        -rw-rw-rw-+   1 iobroker iobroker    442833 Mai  2  2022 states.json.bak.migrated
                        -rw-rw-rw-+   1 iobroker iobroker   9691615 Jan  2 11:11 states.jsonl
                        -rw-rw-rw-+   1 iobroker iobroker    442977 Mai  2  2022 states.json.migrated
                          apollon77 @Karl 1 last edited by
                          @karl-1 Dann fang doch mal mit "iob fix" an ... danach sollte deine objects.jsonl kleiner sein ... gehts dann besser?
                            Karl 1 @apollon77 last edited by
                            @apollon77 iob fix ändert nichts an der Größe der Daten!
                            iob fix wird innerhalb kürzester Zeit beendet. Kann es sein, dass es überhaupt nicht läuft?
                              Thomas Braun Most Active @Karl 1 last edited by
                              @karl-1 sagte in Server Cannot start inMem-objects on port 9001:
                              Mit welchen Meldungen?
                                Das gibt an sich eeeiniges aus .... Alternativ lass mal curl -sLf https://iobroker.net/fix.sh | bash - laufen
                                  @apollon77 sagte in Server Cannot start inMem-objects on port 9001:
                                  Da scheint nichts zu passieren!
                                    Karl 1 @Thomas Braun last edited by
                                    @thomas-braun Es gibt keine Meldungen!
                                      @karl-1 Was sagt "curl https://iobroker.net/fix.sh"?
                                        @apollon77
                                        pi@raspberrypi:/ $ curl https://iobroker.net/fix.sh
                                        curl: (60) SSL certificate problem: certificate has expired
                                        More details here: https://curl.haxx.se/docs/sslcerts.html
                                        curl performs SSL certificate verification by default, using a "bundle"
                                         of Certificate Authority (CA) public keys (CA certs). If the default
                                         bundle file isn't adequate, you can specify an alternate file
                                         using the --cacert option.
                                        If this HTTPS server uses a certificate signed by a CA represented in
                                         the bundle, the certificate verification probably failed due to a
                                         problem with the certificate (it might be expired, or the name might
                                         not match the domain name in the URL).
                                        If you'd like to turn off curl's verification of the certificate, use
                                         the -k (or --insecure) option.
                                          @karl-1 ist bei dir alles aktuell. Auf dem
                                          System? Alle Updates eingespielt? Wenn ja mach bei dem Curl ein „k“ bei den Parametern dazu. Aber warum
                                          Du das bekommst weiß ich nicht weil s das as Zertifikat an sich passt. Sieht mit eher wie fehlende Systemupdates aus
                                            @apollon77
        v.2022-12-31
                                            Operatingsystem:        Raspbian GNU/Linux 9.13 (stretch)
                                            Installation:           Native
                                            User-ID:                1000
                                            X-Server:               true
                                            Boot Target:            graphical.target
                                            Nodejs-Installation:    /usr/bin/nodejs         v14.21.1
        /usr/bin/node           v14.21.1
        /usr/bin/npm            6.14.17
        admin                   6.3.5
                                            ioBroker Status:        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.j        sonl"!
                                            Status admin:
                                            Pending iob updates:    0
                                            No connection to databases possible ...
                                            Objects:                1
                                            States:                 1
                                            500M    /opt/iobroker/iobroker-data/objects.jsonl
                                            3.6M    /opt/iobroker/iobroker-data/objects.json.migrated
                                            3.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                            564K    /opt/iobroker/iobroker-data/states.jsonl
                                            436K    /opt/iobroker/iobroker-data/states.json.migrated
                                            436K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                            apollon77 Thomas Braun 2 Replies Last reply Reply Quote 0
                                            429
                                            82788
