    • André Koschnik
      André Koschnik @Armilar last edited by
      hab erfolgreich mein NS Panel gestern in betrieb genommen und wollte mit gern eine PagePower erstellen.
      Ich habe einen Info Alias erstellt und in mit der Datenpunkt verknüpft.
      let CardPowerExample: PagePower =
          "type": "cardPower",
          "heading": "cardPower Emulator",
          "useColor": true,
          "subPage": false,
          "parent": undefined,
          "items": [
              <PageItem>{ id: 'alias.0.Sensoren.PagePower' },
      und mit folgendem inhalt gefütter ( das sind die aus der beschreibung)
          "id": 1,
          "value": 3,
          "unit": "kW",
          "direction": "in",
          "icon": "battery-charging-60",
          "iconColor": 10,
          "speed": -3
          "id": 2,
          "value": 6.1,
          "unit": "kW",
          "direction": "in",
          "icon": "solar-power-variant",
          "iconColor": 1,
          "speed": 3
          "id": 3,
          "value": 4.9,
          "unit": "kW",
          "direction": "in",
          "icon": "wind-turbine",
          "iconColor": 0,
          "speed": 3
          "id": 4,
          "value": 1.6,
          "unit": "kW",
          "direction": "in",
          "icon": "shape",
          "iconColor": 10,
          "speed": 3
          "id": 5,
          "value": 6.4,
          "unit": "kW",
          "direction": "in",
          "icon": "transmission-tower",
          "iconColor": 0,
          "speed": 2
          "id": 6,
          "value": 0,
          "unit": "kW",
          "direction": "in",
          "icon": "car",
          "iconColor": 0,
          "speed": 3
      leider bekomme ich immer fehler kann mir jemand weiterhelfen?
      15:55:28.869	info	javascript.0 (23873) script.js.house.panel.NsPanelTs_0: compiling TypeScript source...
      15:55:29.512	info	javascript.0 (23873) script.js.house.panel.NsPanelTs_0: source code did not change, using cached compilation result...
      15:55:29.566	info	javascript.0 (23873) script.js.house.panel.NsPanelTs_0: Wetter-Alias existiert bereits
      15:55:29.610	info	javascript.0 (23873) script.js.house.panel.NsPanelTs_0: registered 20 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
      15:55:30.313	warn	javascript.0 (23873) script.js.house.panel.NsPanelTs_0: function GeneratePowerPage: Cannot read properties of undefined (reading 'iconColor')
      15:55:30.314	warn	javascript.0 (23873) script.js.house.panel.NsPanelTs_0: function SendToPanel: Cannot read properties of undefined (reading 'payload')
      15:55:33.449	info	javascript.0 (23873) Stop script script.js.house.panel.NsPanelTs_0
      • Armilar
        Armilar Most Active Forum Testing @André Koschnik last edited by Armilar
        @andré-koschnik
        Ist noch nicht beschrieben, aber du benötigst ebenfalls eine "id": 0,
        Beispiel:
            "id": 0,
            "value": 13,
            "unit": "kW",
            "icon": "emoticon-happy-outline",
            "iconColor": 0
            "id": 1,
            "value": 3,
            "unit": "kW",
            "direction": "in",
            "iconColor": 10,
            "speed": -3
            "id": 2,
            "value": 4.7,
            "unit": "kW",
            "direction": "in",
            "iconColor": 3,
            "speed": 2
            "id": 3,
            "value": 4.3,
            "unit": "kW",
            "direction": "in",
            "iconColor": 1,
            "speed": 3
            "id": 4,
            "value": 3.4,
            "unit": "kW",
            "direction": "in",
            "icon": "shape",
            "iconColor": 10,
            "speed": 3
            "id": 5,
            "value": 0.1,
            "unit": "kW",
            "direction": "in",
            "iconColor": 0,
            "speed": 2
            "id": 6,
            "value": 2.5,
            "unit": "kW",
            "direction": "in",
            "icon": "car",
            "iconColor": 5,
            "speed": 2
        Wenn du das Beispiel in den Datenpunkt kopierst, dann sollte die aber etwas anzeigen...
        André Koschnik C 2 Replies Last reply Reply Quote 0
        • André Koschnik
          @armilar
          alles klar, ein array fängt mit Eintrag 0 an. ist getestet und funktioniert bei mir
          • missi
            missi last edited by
            Moin,
            kurz vor weg, finde das ganze Projekt mega gut lese diesen Bericht fast wie ein Buch 🐶
            Was ich aber nicht finde ist, auf meinem Panel geht die Uhr eine Stunde zu früh, wo nimmt er die Uhrzeit her ?
            im Broker auf dem Panel und hwclock ist die Zeit korrekt nur nicht auf dem Panel.
            Bin etwas Ratlos, hätte jemand ein Tipp für mich
            Wünsche euch ein Frohes neues Jahr 2023
            Beste Grüße
            • Armilar
              Armilar Most Active Forum Testing @missi last edited by Armilar
              @missi sagte in SONOFF NSPanel mit Lovelace UI:
              hwclock
              Es wird die Systemzeit genommen und an das Panel übertragen. Den Fehler kannst du auch in jedem anderen Blockly reproduzieren:
              https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen#19-abweichende-uhrzeit
              Kann zwei Ursachen haben:
              Je nach System kann natürlich auch eine VM (z.B. Proxmox) ihr Unwesen treiben...
              1. Lösung: die Systemzeit (und Standort auf Berlin) korrigieren. In der Regel sollte danach ein Neustart des Betriebssystems erfolgen.
              2. Lösung: Eine veraltete nodeJS-Version könnte das Problem sein... Sollte in der Konsole mit node -v keine 16.19.0 herauskommen, dann sollte in jedem Fall gehandelt werden.
                • Das Release beginnt mit 16.X.X**
                  Dann einfach
                  sudo apt-get update
                  sudo apt-get dist-upgrade
                  sudo reboot
                  durchführen (sollte sowieso mindestens einmal im Monat erfolgen)
                • Das Release beginnt mit 14.X.X oder noch kleiner:
                  Jetzt ist zwingend das nodeJS auf einen neuen Stand zu bringen:
                  Anleitung siehe hier:
                  https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
              • egal
                egal last edited by
                so langsam bekommt das Teil so 'richtigen' Nutzen aka WAF ;-D
                Habe mal die MediaCard für den Volumio-Player angepaßt (relevente Routinen erweitert), funkt soweit ganz gut inkl. dynamischer Playlist (Mißbrauch des Shuffle-Buttons für den Refresh-Init hierfür)
                let VolumioBoss: PageMedia =
                    'type': 'cardMedia',
                    'heading': 'Volumio-Büro',
                    'useColor': true,
                    'subPage': false,
                    'parent': undefined,
                    'items': [<PageItem>{
                                adapterPlayerInstance: 'volumio.0.',
                                speakerList: [], /* this must, no function */
                                playList: [],    /* empty for dynamic reading */
                                colorMediaIcon: colorSpotify,
                                colorMediaTitle: colorSpotify,
                                colorMediaArtist: Yellow,
                                autoCreateALias : true
                let VolumioMobil: PageMedia =
                    'heading': 'Volumio-Mobil',
                    'useColor': true,
                    'subPage': false,
                                adapterPlayerInstance: 'volumio.1.',
                                colorMediaIcon: Yellow,
                                colorMediaTitle: Yellow,
                                colorMediaArtist: Gray,
                Bloß der volumio-Adapter ist ziemlich empfindlich (schmiert häufig ab, wenn man zu schnell tastet), und mehrer Adapter beeinflussen sich bei den Events: Titel/Artistwechsel gehen an alle Instanzen ?!?
                Hat irgend jemand hier noch Volumios im Einsatz ?
                Armilar 1 Reply Last reply Reply Quote 1
                • Armilar
                  Armilar Most Active Forum Testing @egal last edited by Armilar
                  @egal sagte in SONOFF NSPanel mit Lovelace UI:
                  Volumios
                  Denke die Änderungen könnte man mit aufnehmen, oder? Könntest du die (ich denke es ist die GenerateMediaPage, die createAutoMediaAlias, die HandleButtonEvent und wahrscheinlich die GenerateDetailPage) Änderungen auch posten? Es gibt immer jemanden, der es gebrauchen kann 😉
                  Welches Icon benötigst du denn im Shuffle?
                  EDIT: bei "dynamisch" sollten die Enträge in der playList nicht die 900 Zeichen überschreiten, sonst gibts einen Speicherüberlauf in der InSel.
                  egal 1 Reply Last reply Reply Quote 0
                    Kuckuckmann @Armilar last edited by
                    @armilar ich übernehme das mal in die FAQ
                    • Armilar
                      Armilar Most Active Forum Testing @Kuckuckmann last edited by
                      @kuckuckmann
                      Jo, noch ist der Code nicht im Script...
                      • egal
                        egal @Armilar last edited by
                        @armilar
                        ja, gerne, mache ich morgen;
                        hier in diesem Fred oder PN ?
                        Icon muß ich mal schauen,
                        die 900char Grenze habe ich gesehen, muß ich noch prüfen 😉
                        • Armilar
                          @egal
                          Entweder hier, oder direkt als Pull Request
                          EDIT: Coole Nummer 👍 😊
                          Armilar egal 2 Replies Last reply Reply Quote 0
                            @armilar ich meinte die HM Thermostat Geschichte 😉
                            • Armilar
                              Armilar Most Active Forum Testing @Armilar last edited by Armilar
                              @armilar
                              Habe übrigens das Menü für das nächste Release noch weiter angepasst...
                              Subpages navigieren jetzt auch auf der selben Ebene, analog der Mainpages...
                              Home kann mit definierter Seite belegt werden
                              Und natürlich die targetPages von @TT-Tom mit dem Alias in der Menüitem-ID...
                              Beschreibung folgt.
                              Für die Änderungen benötigen wir allerdings noch ein neues TFT-Release (> v3.7.3), da sich dort doch ein paar mehr Änderungen ergeben haben.
                              Geht natürlich auch mit Subpages auf denen Steuerelemente sind:
                              • Armilar
                                Armilar Most Active Forum Testing @Kuckuckmann last edited by Armilar
                                @kuckuckmann
                                Ach da war ich mit meinen Gedanke ganz woanders. Ja klar, gerne. Aber die Funktionalität ist noch nicht bestätigt.
                                  danny_v1 @Armilar last edited by
                                  Hallo, ich habe gerade mal geupdatet, und hab mit großer Freude festgestellt das es jetzt ein WLED Seite gibt!!!
                                  Wie muss dazu das alias angelegt werden damit die Seite funktioniert???
                                    Elluminatus @Armilar last edited by Elluminatus
                                    @armilar Ich bin gerade etwas gefrustet. Habe es so aufgebaut wie hier angedacht. Leider ist es so, dass die Homematic Falmot Steuereinheit doch ein Wandthermostat zu brauchen scheint. Ich habe leider keinen State Eintrag unter dem Homematic Adapter den ich ansteuern könnte und eine reine Ansteuerung über die CCU geht auch leider nicht. Das ist sehr doof. Wollte ja mittels heatingcontrol Adapter hier arbeiten und dies dann mit NSPanel nutzen....
                                    Hat hier jemand ein NSPanel direkt an einem Homematic Falmot am laufen (OHNE zusätzliches HM Wandthermostat)?
                                    Beste Grüße
                                    Elluminatus
                                      @armilar Das bekomme ich nicht hin, der Falmot hat nichts zum ansteuern..
                                      bzw hier bei den Objekten:
                                      • Armilar
                                        Armilar Most Active Forum Testing @Elluminatus last edited by
                                        @elluminatus
                                        Was ist denn LEVEL?
                                        Sieht für mich nach einem SetPoint aus. Die Frage ist, von Wert/bis Wert kann der?
                                        T E 2 Replies Last reply Reply Quote 0
                                        • Armilar
                                          Armilar Most Active Forum Testing @danny_v1 last edited by
                                          @danny_v1
                                          @Kuckuckmann erstellt eine WIKI-Anleitung mit Beispiel hierzu.
                                          Im Grunde ist das Beispiel eine cardGrid mit 2 Sockets und 4 popUpInSel als Werteliste
                                            @armilar Super danke! Na dann warte ich mal noch auf die Anleitung.
                                            Armilar K 2 Replies Last reply Reply Quote 0
                                            lovelace ui nspanel sonoff
                                            270
                                            7689
                                            6513815
