    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
      guergen @Thomas Braun last edited by guergen
      @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
      curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
      iob@iob:~$ curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
      `eO▒A▒▒ ~▒▒▒>▒▒▒▒0y6k▒▒▒y▒▒▒8▒#▒▒n▒▒-▒ޕ▒ޢz▒SYQ▒S▒▒▒▒▒▒▒▒▒▒\▒Ne5N▒▒▒o▒▒,K}▒▒▒▒7z lw▒ھ▒|▒▒k▒U▒▒▒x▒8▒E▒X͚▒z^▒gv▒8▒▒▒@J▒F▒8▒EǞP▒▒i'▒▒▒▒Q▒x▒~>X4�"A▒▒
      ▒▒▒1▒▒▒5▒X▒▒▒,w▒▒▒R|▒Ɩq/▒▒▒s▒ՀMk3▒}8}▒*▒▒▒h▒ZX▒▒G▒▒▒▒"
      ▒▒os+h 1N▒ۙ▒▒▒ʔ▒w▒_s▒▒▒B▒▒!▒▒ÿ▒▒▒▒▒▒▒▒[X)vz▒▒▒▒▒;▒[▒▒aސ▒▒▒!▒▒▒2▒畝▒=9א▒`[.▒▒+▒K▒cpp▒▒驧▒▒_▒w▒=▒▒>mk=@▒▒F▒x_▒Kcg▒▒▒▒▒▒D▒Q5'▒▒▒V▒▒▒]▒@Ji
      r▒▒7}▒▒▒r▒▒7▒▒;▒▒uYV▒▒#-wx▒▒K▒▒;▒▒▒
      ▒▒▒qyR#▒Sz▒8▒▒▒!▒▒▒ᝋ▒ ▒5▒phttps://packagecloud.io/ookla/speedtest-cli (https://packagecloud.io/docs#gpg_signing) <support@packagecloud.io>▒N
      8!▒%▒▒:~V▒,▒1▒9▒▒#▒▒`eO
              1▒9▒▒#▒▒▒▒▒H▒▒=i▒%▒▒8|▒▒T1h▒▒▒Ks'▒▒0▒e▒"▒m▒9▒▒Y;҅▒ġRq▒T▒r▒euڦ#Źʶ▒▒▒▒/▒▒▒▒▒&▒姑▒4ya▒▒B▒sA▒▒y▒T[▒b▒▒@▒e▒▒▒#*% S▒
      ▒V
      ▒▒2▒v}▒▒J-J▒▒? ▒.▒~▒▒b▒W▒B▒G▒▒bB▒z<▒▒▒Iȕ▒a7▒l▒▒▒R▒&4Oāu▒▒▒▒u▒▒=
      ▒▒?▒&▒▒▒?▒֛]I▒t▒▒▒yXH+▒!▒▒t▒▒:▒▒Q▒F▒m▒0▒/▒O<▒▒H&▒▒sb▒▒▒d
                                                             ▒▒Pa▒e}▒6▒▒U▒▒6▒▒▒▒[▒▒▒|6▒Y▒s▒▒▒▒&▒j'▒O▒▒Ht▒P▒$qo1̵L~▒0▒M▒!▒▒▒q▒,▒=-▒▒t▒▒Mf,͠▒)e▒Ę▒x▒s▒▒TK$▒▒>?aY▒)▒&▒▒▒▒▒▒▒▒▒G▒▒▒▒G▒▒ɴ▒hn▒▒P▒▒+TP▒▒.▒▒}2y        ▒,▒▒▒غ4▒"=▒
      V▒ *ۗ[*▒a*▒▒t{cA;▒F▒6▒▒▒ǫ▒Eʡ
      `eO▒:▒t▒#▒▒K~i▒▒▒SܫVDP▒▒W▒4*)}▒▒▒▒+3KI▒@p▒_▒▒
                                                   ▒F˧֧▒Eu▒▒▒B=▒D▒´Gy▒v▒▒▒X▒s8▒▒.Zy▒oeh#▒▒▒▒▒R$▒▒(
      ."▒c▒▒▒Q▒!SRjӣ▒▒0▒PP1EF▒▒H▒z2i'p▒V▒▒▒[>▒o▒Hw▒wat▒▒~?▒l)▒▒{t▒U~▒$▒)FC▒▒@▒▒r▒W▒▒▒1▒&▒e▒7▒ݡ▒▒W(J▒ `X▒U▒▒▒▒{m▒}▒@▒p▒▒▒▒4▒й▒N%1▒▒@0x`#
      ▒▒▒I3JA▒▒▒▒~▒▒L؈▒▒@)M؟3▒eNR~P▒c>9▒`0p▒▒▒"{▒▒▒▒)▒▒@▒▒
      ▒�,▒▒▒▒+▒?▒▒:جw▒▒▒▒ld▒Ќ▒?´▒▒~BB▒ih▒D▒▒/▒▒V▒?s▒x▒▒D▒▒▒▒▒▒!▒)▒M▒֛'▒#_V▒7W▒▒▒zXyM'I(        H▒.!.▒F▒▒▒LZ▒\▒l{-O▒▒V▒z▒
       !▒%▒▒:~V▒,▒1▒9▒▒#▒▒`eO 1▒9▒▒#▒▒▒t
      !▒7▒▒▒&▒▒"'▒a«▒mW`eO
              ▒a«▒mW+▒}V▒▒▒▒▒▒"}▒|Huw▒▒▒;&u;▒▒▒▒n1u▒▒▒▒B▒D▒▒▒▒Hi▒.▒&XjV▒~e_▒▒f^G▒▒▒]-▒▒
      4r}▒▒OVӒ^'▒     Խ▒▒▒▒:)4\▒h▒▒▒Ϝ▒▒d▒Ҥ▒Yh▒▒1      ▒`▒▒▒▒b▒▒▒▒t▒TP▒d▒▒Yg^▒▒▒gB▒"Ļu a▒▒F^▒"▒=▒u▒;▒▒|n▒Y▒▒۬t5
        R▒▒V▒▒▒▒t▒▒▒▒▒▒V)=▒.▒xAA.r(3▒▒▒?▒▒?_d▒▒▒▒6▒▒▒▒▒▒V▒▒L▒▒ ▒V▒H▒l▒
      ▒(▒Rּ▒/▒▒=▒^}▒▒$~ܪ▒C!Zw ▒▒TL▒▒g▒▒▒P▒[5k▒ ▒▒▒▒▒▒7[pk$H▒%E▒f▒U▒+▒▒)▒|叆▒춑▒\z.▒▒r▒▒װRШ▒B{t▒5▒▒t▒v;"▒5qI▒ TD▒f4▒▒á▒G▒▒▒r▒▒s▒▒▒=W▒h▒0Xi▒=^<;e▒▒▒S->▒▒▒0}Yk▒▒C▒i▒tr▒!▒Ώ▒▒▒m▒{▒t)ÛS▒▒  ▒▒▒ʯWaf▒r▒▒~z▒▒▒▒;▒▒,▒▒▒▒xd▒t▒▒QL▒²▒▒▒g9▒b^▒▒T▒▒x)▒%
      ▒▒▒`▒&▒F▒▒$л▒▒g{▒l▒▒@▒+^G/@▒ݗ▒▒▒▒▒▒O▒cmG▒Q8{%▒▒>▒o▒a▒▒c5▒nTC{Ap▒h▒≈ɪ▒▒x▒B▒▒@(▒▒"▒Ƒ▒▒"▒$▒p▒▒▒▒▒i;`▒▒▒▒@▒W▒vgA▒-lBW▒8▒▒q▒▒(;▒▒▒۴զ▒is-▒▒▒▒^k▒^#u<▒y<▒▒▒)▒9▒I▒/▒l][▒ݱ~a"%{*Z▒
      챔▒▒▒R▒y▒▒_▒▒9u[2▒▒▒j▒▒▒`▒▒/
      +-▒▒{▒ϓ▒▒ N#9▒Z▒▒▒u▒T▒  ▒▒▒+▒}▒L▒(
      ▒O;}▒yC^▒6▒MCl3▒▒▒GC▒ﵨ?a▒▒▒4▒▒▒~▒▒4ȻH.7▒.d▒*iob@iob:~$ PuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTY^C
      ▒V
      Kann ich nur mit StRg "C" abbrechen
      • SKB
        SKB Developer Most Active @guergen last edited by SKB
        @guergen Schau mal, ob dein Zeichensatz in Putty passt. Sieht mir schwer danach aus, als wenn dieser nicht stimmt 🙂
        https://seeseekey.net/archive/110592/#:~:text=Stattdessen muss bei PuTTY gesucht werden.&text=Um das Problem zu beheben,fehlerhaften Zeichen der Vergangenheit an.
          guergen @SKB last edited by guergen
          @skb Steht auf UTF-8
          Egtl. Richtig...
          Mit Iso-8859-15 wird es auch nicht besser
          Hat keiner eine Idee?
            Thomas Braun Most Active @guergen last edited by
            @guergen
            locale
            sagt?
              iob@iob:~$ locale
              LANG=de_DE.UTF-8
              LANGUAGE=
              LC_CTYPE="de_DE.UTF-8"
              LC_NUMERIC="de_DE.UTF-8"
              LC_TIME="de_DE.UTF-8"
              LC_COLLATE="de_DE.UTF-8"
              LC_MONETARY="de_DE.UTF-8"
              LC_MESSAGES="de_DE.UTF-8"
              LC_PAPER="de_DE.UTF-8"
              LC_NAME="de_DE.UTF-8"
              LC_ADDRESS="de_DE.UTF-8"
              LC_TELEPHONE="de_DE.UTF-8"
              LC_MEASUREMENT="de_DE.UTF-8"
              LC_IDENTIFICATION="de_DE.UTF-8"
              LC_ALL=
              iob@iob:~$
                m0uh last edited by m0uh
                code_textpi@raspberrypi:~ $ sudo apt update
                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:3 https://phoscon.de/apt/deconz buster InRelease
                Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
                Hit:5 https://apt.hyperion-project.org buster InRelease
                Hit:6 https://repos.influxdata.com/debian buster InRelease
                Hit:7 https://packages.grafana.com/enterprise/deb stable InRelease
                Hit:8 https://archive.raspbian.org/raspbian bullseye InRelease
                Hit:9 https://www.pivccu.de/piVCCU testing InRelease
                Ign:10 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
                Err:11 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
                  404  Not Found [IP: 2600:1f1c:2e5:6901:914d:db70:ee4c:8e5f 443]
                Reading package lists... Done
                E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file.
                N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                N: See apt-secure(8) manpage for repository creation and user configuration details.
                pi@raspberrypi:~ $ sudo apt install speedtest
                Building dependency tree... Done
                E: Unable to locate package speedtest
                pi@raspberrypi:~ $
                Scheinbar gibts kein File mehr über den Paketmanager? Any idea?
                EDIT:
                Hab mal in der sourceliste aus raspian -> debian gemacht und schon funktionierts
                  Thomas Braun Most Active @m0uh last edited by Thomas Braun
                  @m0uh
                  Da ist auch sonst Chaos drin.
                  Nie Releases mischen. Entweder ist das Buster oder Bullseye.
                  Wenn das da jetzt bei dir ein 'Bullseye / Debian 11' ist
                  (Prüfen mit
                  cat /etc/debian_version
                  stell das mit den drei Zeilen alles richtig:
                  sudo sed -i 's/bullseye\/updates/bullseye-security/g' /etc/apt/sources.list
                  sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list
                  sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*
                    Fauli85 last edited by
                    So ich hoffe, das ich das jetzt hier richtig mache (werde einfach zu alt).
                    Erst mal ein Frohes neues nachträglich.
                    Ich versuche jetzt schon gute 3 Tage den Speedtest zum laufen zu bekommen.
                    Gut 2 Tage habe ich gebraucht um mein Unbuntu auf den neusten stand zubringen 🙂 aber jetzt läuft es.
                    Auch den Speedtest habe ich Installiert bekommen und im Terminal gibt er auch die Daten aus.
                    JS- Script kopiert und die Zeile geändert (warum alle schreiben Zeile 210 - wenn es doch 216 ist - keine Plan)
                    In Zeile 32 noch die ID geändert (München 27345)
                    Aber ich bekomme im IoBroker Objekte keine Daten.
                    Laut Protokoll fehlt was... aber was -ich finde auch nichts im Netz und sorry nach 3 Tagen Suche darf ich hoffentlich mal um Hilfe Fragen :).
                    javascript.0
                    	2023-01-03 19:36:58.035	error	script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! exec is not available. Please enable "Enable Exec" option in instance settings
                    javascript.0
                    	2023-01-03 19:36:58.034	error	exec is not available. Please enable "Enable Exec" option in instance settings
                    Danke schon mal vorab für die Hilfe, sollten noch andere Infos benötigt werden - jeder Zeit gerne 🙂
                    Gruß eric
                    SKB Thomas Braun 3 Replies Last reply Reply Quote 0
                    • SKB
                      SKB Developer Most Active @Fauli85 last edited by
                      @fauli85 Du musst im Javascript Adapter die Ausführung von Exec zulassen. Dann klappt es 😉
                        Thomas Braun Most Active @Fauli85 last edited by
                        @fauli85
                        Entweder darf der User iobroker das Skript gar nicht ausführen oder es fehlt wie in der Meldung zu sehen der Haken an der Option im javaskript-Adapter
                          @fauli85 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                          So einem langsamen Akkustikkoppler hatte ich auch mal. War irgendwann in den 90ern.
                            So schnell kann doch keiner lesen - ändern - und Antworten.
                            es war der Haken - dieser fehlte mir.
                            Darauf wäre ich nie im leben selber gekommen :(.
                            @Thomas-Braun
                            ich hatte viele Probleme - zu erst wollte das Update nicht, weil Fehler wegen Schlüssel Nr.
                            Dann habe ich 1 Tag gebraucht um den Fehler zu beheben und Gestern Nacht endlich Update lief.
                            Was ich gemacht habe etc. keine Ahnung - hab die Fehler gegoogelt und Schritt für Schritt gemacht (wenn man sich besser auskennt dann denke ich würde es schneller gehen)
                            Heute Abend wieder über Terminal rein Neues Version drauf aber 98 Dinge habe sich nicht aktualisiert.
                            Wieder gegoogelt und auch das irgendwie behoben :).
                            Wenn ich jetzt rein gehe neues Version und keine offenen Punkte mehr.
                            Aber ganz ehrlich ob mein Unbuntu 100% läuft keine Ahnung - es läuft und ich bin stolz drauf 🙂
                            DANKE für Eure schnelle Hilfe
                              @fauli85
                              Das kannste recht easy per
                              sudo apt update
                              prüfen. Tip am Rande: Für die ubuntus gibt es ein upgrade-Skript, das nimmt dir das allermeiste an Arbeit ab.
                              sudo do-release-upgrade
                              ruft das glaube ich auf.
                                den Test werde ich Morgen mal machen 🙂
                                DANKE
                                  Auch wenn es nicht hier rein gehört aber doch zu meinen anderen Posting passt.
                                  Jetzt bekomme ich wieder beim Start vom Terminal diese Meldung.
                                  Ich hatte irgendwie das mal geschafft weg zu bekommen aber wohl doch nicht.
                                  98 updates could not be installed automatically. For more details,
                                  see /var/log/unattended-upgrades/unattended-upgrades.log
                                  diesen Befehl hab ich schon probiert
                                  sudo apt update
                                    Das ist ja auch nur die halbe Miete.
                                    sudo apt update
                                    sudo apt full-upgrade
                                    sagt?
                                      @thomas-braun said in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                      Danke..
                                      Hab ich durchlaufen lassen und einen Neustart gemacht.
                                      Leider kommt die Meldung wieder
                                        Und das ist geheim oder was?
                                        Ohne die genauen, ungekürzten und unveränderten Ausgaben kann dir da keiner helfen.
                                          Ne nix ist geheim :).
                                          Das ist die komplette Meldung beim Starten des Terminals
                                          Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.15.0-56-generic x86_64)
                                           * Documentation:  https://help.ubuntu.com
                                           * Management:     https://landscape.canonical.com
                                           * Support:        https://ubuntu.com/advantage
                                            System information as of Wed Jan  4 18:36:35 UTC 2023
                                            System load:  0.46533203125       Processes:             145
                                            Usage of /:   10.2% of 195.80GB   Users logged in:       0
                                            Memory usage: 39%                 IPv4 address for ens3: 192.168.178.65
                                            Swap usage:   0%
                                           * Strictly confined Kubernetes makes edge and IoT secure. Learn how MicroK8s
                                             just raised the bar for easy, resilient and secure K8s cluster deployment.
                                             https://ubuntu.com/engage/secure-kubernetes-at-the-edge
                                          0 updates can be applied immediately.
                                          Ich muss leider zugeben das ich 2 (für mich) große Probleme habe 🙂
                                          1. ich kann kein Englisch und tu mich verdammt schwer zu verstehen was das System sagt. Versuche zwar mit Übersetzer zu Arbeiten aber ... jetzt kommen wir zu
                                          2. dann verstehe ich nicht 100% was die schreiben und wollen. Jedes mal spiele ich die Befehle durch und weis gar nicht so 100% ob es richtig ist was ich machen.
                                          Sorry Du hast Ihr einen alten Deppen vor Dir, der Stolz auf sein IoBroker ist und das er es soweit geschafft hat lacht
                                          Das ist wie als mich mein Vater mal vor Jahren in der Nacht Angerufen und Stolz drauf war auf Win98 ein nues Desktop Bild einzufügen :).
                                            @fauli85
                                            Mich interessiert die Ausgabe zu
                                            sudo apt update
                                            und dann noch von
                                            391
                                            72672
