    4. Adapter "smartmeter"
      church last edited by
      Iobroker läuft bei mir auf einem Rpi3 mit Raspbian Jessie! In meinem letzten post hatte ich den log angehangen, wo es funktioniert hat!
      Ich habe den Adapter nochmal deinstalliert, reboot und dann neu installiert. Jetzt werden andere Datenpunkte angelegt:
      Hier der log seit Neuinstallation:
      host.raspberrypi	2017-08-16 09:51:39.924	error	instance system.adapter.smartmeter.0 terminated with code 0 (OK)
      smartmeter.0	2017-08-16 09:51:39.893	info	terminating
      smartmeter.0	2017-08-16 09:51:39.393	debug	SERIALPORT CLOSE
      smartmeter.0	2017-08-16 09:51:39.389	warn	Exception: Error: No or too long message from Serial Device.
      smartmeter.0	2017-08-16 09:51:39.383	error	at Timer.listOnTimeout (timers.js:214:5)
      smartmeter.0	2017-08-16 09:51:39.383	error	at tryOnTimeout (timers.js:250:5)
      smartmeter.0	2017-08-16 09:51:39.383	error	at ontimeout (timers.js:386:14)
      smartmeter.0	2017-08-16 09:51:39.383	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:87:22)
      smartmeter.0	2017-08-16 09:51:39.383	error	at SerialResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:200:11)
      smartmeter.0	2017-08-16 09:51:39.383	error	Error: No or too long message from Serial Device.
      smartmeter.0	2017-08-16 09:51:39.382	error	uncaught exception: No or too long message from Serial Device.
      smartmeter.0	2017-08-16 09:51:39.348	debug	MESSAGE TIMEOUT TRIGGERED
      smartmeter.0	2017-08-16 09:49:39.346	debug	REMAINING DATA AFTER MESSAGE HANDLING:
      smartmeter.0	2017-08-16 09:49:39.345	debug	CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
      smartmeter.0	2017-08-16 09:49:39.345	debug	SET MESSAGE TIMEOUT TIMER: 120000
      smartmeter.0	2017-08-16 09:49:39.344	debug	SerialResponseTransport do not support sending of Data! Ignore them
      smartmeter.0	2017-08-16 09:49:39.342	debug	CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
      smartmeter.0	2017-08-16 09:49:39.337	debug	CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
      smartmeter.0	2017-08-16 09:49:39.333	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
      smartmeter.0	2017-08-16 09:49:39.332	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r\n" -> ["/ESY5Q3DA2004 V3.03\r\n","/ESY5Q3DA2004 V3.03"]
      smartmeter.0	2017-08-16 09:49:39.331	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
      smartmeter.0	2017-08-16 09:49:39.330	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.03\r" -> null
      smartmeter.0	2017-08-16 09:49:39.330	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
      smartmeter.0	2017-08-16 09:49:39.329	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3.0" -> null
      smartmeter.0	2017-08-16 09:49:39.328	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
      smartmeter.0	2017-08-16 09:49:39.327	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V3" -> null
      smartmeter.0	2017-08-16 09:49:39.327	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
      smartmeter.0	2017-08-16 09:49:39.325	debug	MATCH-RESULT SIGNON: "/ESY5Q3DA2004 V" -> null
      smartmeter.0	2017-08-16 09:49:39.324	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
      smartmeter.0	2017-08-16 09:49:39.323	debug	MATCH-RESULT SIGNON: "/ESY" -> null
      smartmeter.0	2017-08-16 09:49:39.321	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
      smartmeter.0	2017-08-16 09:49:37.752	debug	SET MESSAGE TIMEOUT TIMER: 120000
      smartmeter.0	2017-08-16 09:49:37.745	debug	SERIALPORT OPEN
      smartmeter.0	2017-08-16 09:49:37.729	debug	CREATE SERIALPORT: 9600 7 1 even
      smartmeter.0	2017-08-16 09:49:37.722	debug	SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"300","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transport
      smartmeter.0	2017-08-16 09:49:37.711	info	starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.11.2
      smartmeter.0	2017-08-16 09:49:37.632	debug	statesDB connected
      smartmeter.0	2017-08-16 09:49:37.561	debug	objectDB connected
      host.raspberrypi	2017-08-16 09:49:35.093	info	instance system.adapter.smartmeter.0 started with pid 1232
      host.raspberrypi	2017-08-16 09:49:35.042	info	object change system.adapter.smartmeter.0
      host.raspberrypi	2017-08-16 09:49:05.618	info	object change system.adapter.smartmeter.0
      host.raspberrypi	2017-08-16 09:48:50.699	info	object change system.adapter.smartmeter.0
      iobroker	2017-08-16 09:48:15.635	info	exit 0
      iobroker	2017-08-16 09:48:15.621	info	host.raspberrypi object system.adapter.smartmeter.0 created
      host.raspberrypi	2017-08-16 09:48:15.615	info	object change system.adapter.smartmeter.0
      iobroker	2017-08-16 09:48:15.572	info	host.raspberrypi object system.adapter.smartmeter.0.alive created
      iobroker	2017-08-16 09:48:15.541	info	host.raspberrypi object system.adapter.smartmeter.0.connected created
      iobroker	2017-08-16 09:48:15.511	info	host.raspberrypi object system.adapter.smartmeter.0.memHeapUsed created
      iobroker	2017-08-16 09:48:15.481	info	host.raspberrypi object system.adapter.smartmeter.0.memHeapTotal created
      iobroker	2017-08-16 09:48:15.445	info	host.raspberrypi object system.adapter.smartmeter.0.memRss created
      iobroker	2017-08-16 09:48:15.418	info	host.raspberrypi object system.adapter.smartmeter.0.uptime created
      iobroker	2017-08-16 09:48:15.383	info	host.raspberrypi object system.adapter.smartmeter.0.inputCount created
      iobroker	2017-08-16 09:48:15.352	info	host.raspberrypi object system.adapter.smartmeter.0.outputCount created
      iobroker	2017-08-16 09:48:15.335	info	host.raspberrypi create instance smartmeter
      iobroker	2017-08-16 09:48:13.496	info	add smartmeter
        knopers1 last edited by
        Hallo Apollon77
        ich wollte an meinem Gaszähler den Verbrauch auslesen.
        Genau ist es ein GT4 Gaszähler siehe Bild. Als Hardware wurde einfach ein Magnet-Reedkontakt an einem ESP8266 (WEMO D1 mini) angeschlossen.
        Dort als Betriebssystem habe ich Tasmota installiert. Daten kommen über MQTT Adapter an IOBroker an.
        Der magnetische Kontakt hängt jetzt am Zählwerk in der letzten Stelle des Zählwerks.
        Somit wird alle 0.01 m³ (=10l) mein Reedkontakt kurzgeschlossen.
        Unter MQTT Adapter sehe ich ob der Kontakt true oder false ist.
        Ich kann den Eingang des Wemos auch so umkonfigurieren, dass man dort die Zählimpulse zählen kann…
        Kannst Du mich auf die Spur bringen, ob dein Adapter damit umgehen kann?
        Ich würde gerne mit dem FLOT Adapter mir eine schöne Grafik basteln.
        Dazu ein Wert für den aktuellen Verbrauch, gesamten Verbrauch sowie Kosten loggen können.
        Kannst Du helfen?
          @noxx:
          funktioniert der Adapter auch mit ESPeasy und dem Pulse Counter?
          Oder gibt es Arduino Lösungen? Habe am Arduino im moment ein Read-Schalter, der
          Read-Schalter am Gaszähler.
          Ähnlich wie hier: https://voizchat.de/gaszaehler-verbrauc … erry-gpio/ `
          noxx hat schon mal ne ähnliche Frage gestellt,geht nicht. Ein paar Seiten weiter vorn. Außerdem gibts von ihm auch noch ne Lösung wo aus einer Webseite Daten ausgelesen werden können.
          http://forum.iobroker.net/viewtopic.php?f=21&t=7556&hilit=gasz%C3%A4hler gibts dazu noch ein paar Infos.
          RappiRN
            woww, Danke Dir für den Link!
              apollon77 last edited by
              @church: muss ich Montag checken …
                Super, danke!
                  Arminhh last edited by
                  Guten Morgen,
                  ich habe jetzt alle Seiten durch gelesen! Leider habe ich noch ein Problem.
                  Ich habe mir diese Woche den extra den Multihost eingerichtet. Der Slave ein PI 3B ist im Keller und der Lesekopf von UDO angeschlossen.
                  Der Smartmeter Adapter lässt sich installieren. Beim Starten des Adapters erscheint die Fehlermeldung wie auf Seite 28 gefunden
                  host.rasp_pv1_goke 2017-07-24 21:35:41.501 error instance system.adapter.smartmeter.0 terminated with code 1 ()
                  host.rasp_pv1_goke 2017-07-24 21:35:40.719 info instance system.adapter.smartmeter.0 started with pid 11153
                  host.rasp_pv1_goke 2017-07-24 21:35:35.334 info Restart adapter system.adapter.smartmeter.0 because enabled
                  Scheinbar muss laut Seite 28
                  " Komisch … Dann löscht mal den "open-sml" ordner und installiere dann den Adapter. Sollte dann wieder installiert werden. Falls nicht wirf auch smartmeter-obis weg (oder gleich beides)"
                  gelöscht werden!
                  Leider finde ich weder wen der Adapter installiert ist, noch wenn er deinstalliert ist die beiden Verzeichnisse!
                  Danke für die Hilfe
                    Hallo Armin,
                    nur damit wir vom gleichen reden:
                    Bei Multihost darf vor der Verbindung zum Master NUR der admin (und der Discovery) installiert sein.
                    Alles andere muss anschließend über den Master (unter Host.1=Slave) installiert werden.
                    Auf keinen Fall vorher auf dem Keller-Pi installieren und dann erst als Slave definieren.
                    Hast du das so ausgeführt?
                    Rainer
                      Danke für den Hinweis! Das habe ich berücksichtigt! Erst die Verbindung zwischen Host und Slave dann über den Master Admin auf dem Slave den Smartmeter Adapter installiert!
                      mfg
                      Armin
                        Danke für die Antwort,
                        dann ist die Grundinstallation schon mal ok (so habe ich es auch - allerdings mit einem Pi2) und es läuft.
                        Dann müsste @apollon77 etwas dazu sagen, der ist aber in Urlaub, was ihn aber anscheinend nicht hindern wird 😉
                        Rainer
                          Ich habe auch test weise mal einen anderen Adapter installiert. Der lief auf Anhieb auf dem Slave ! Liegt also nicht an meiner Installation!
                          mfg
                          Arminhh
                            Vielleicht wären noch deine Versionen von js-controller und admin interessant.
                            Rainer
                              alles aktuell
                              js-controller 1.1.2
                              Admin 2.0.2
                                die Dateien bzw. Verzeichnisse habe ich inzwischen gefunden gelöscht und neu installiert. Leider bekomme ich immer noch die Fehlermeldung
                                host.IOBrokerKeller	2017-08-17 14:30:03.823	info	Do not restart adapter system.adapter.smartmeter.0 because disabled or deleted
                                host.IOBrokerKeller	2017-08-17 14:30:03.822	error	instance system.adapter.smartmeter.0 terminated with code 1 ()
                                host.IOBrokerKeller	2017-08-17 14:29:34.382	info	instance system.adapter.smartmeter.0 terminated with code null ()
                                host.IOBrokerKeller	2017-08-17 14:29:34.381	warn	instance system.adapter.smartmeter.0 terminated due to SIGTERM
                                host.IOBrokerKeller	2017-08-17 14:29:34.374	info	stopInstance system.adapter.smartmeter.0 killing pid 1842
                                host.IOBrokerKeller	2017-08-17 14:29:34.373	info	stopInstance system.adapter.smartmeter.0
                                host.IOBrokerKeller	2017-08-17 14:29:34.373	info	"system.adapter.smartmeter.0" disabled
                                host.IOBrokerKeller	2017-08-17 14:29:34.372	info	object change system.adapter.smartmeter.0
                                host.IOBrokerKeller	2017-08-17 14:29:33.143	info	instance system.adapter.smartmeter.0 started with pid 1842
                                host.IOBrokerKeller	2017-08-17 14:29:32.146	info	Restart adapter system.adapter.smartmeter.0 because enabled
                                host.IOBrokerKeller	2017-08-17 14:29:32.146	error	instance system.adapter.smartmeter.0 terminated with code 1 ()
                                host.IOBrokerKeller	2017-08-17 14:29:30.517	info	instance system.adapter.smartmeter.0 started with pid 1836
                                host.IOBrokerKeller	2017-08-17 14:29:03.105	info	Restart adapter system.adapter.smartmeter.0 because enabled
                                Hat noch jemand einen Tip?
                                Danke im Vorraus
                                LG
                                Arminhh
                                  Mach mal eine Installation als root auf der Konsole.
                                  cd /opt/iobroker
                                  npm install iobroker.smartmeter --production
                                  Rainer
                                    @Homoran:
                                    cd /opt/iobroker
                                    Rainer `
                                    die Idee hatte ich auch schon. Habe es aber trotzdem noch einmal probiert! War leider aber auch ohne Erfolg!
                                    host.IOBrokerKeller	2017-08-17 15:03:47.884	info	Restart adapter system.adapter.smartmeter.0 because enabled
                                    host.IOBrokerKeller	2017-08-17 15:03:47.883	error	instance system.adapter.smartmeter.0 terminated with code 1 ()
                                    host.IOBrokerKeller	2017-08-17 15:03:46.233	info	instance system.adapter.smartmeter.0 started with pid 2111
                                    host.IOBrokerKeller	2017-08-17 15:03:16.211	info	Restart adapter system.adapter.smartmeter.0 because enabled
                                    host.IOBrokerKeller	2017-08-17 15:03:16.211	error	instance system.adapter.smartmeter.0 terminated with code 1 ()
                                    host.IOBrokerKeller	2017-08-17 15:03:14.596	info	instance system.adapter.smartmeter.0 started with pid 2105
                                    Danke für die Hilfe!!
                                    mfg
                                    Arminhh
                                    • AlCalzone
                                      @Arminhh:
                                      Starte den Adapter mal manuell über die Konsole sodass man den Fehler sieht:
                                      cd /opt/iobroker/node_modules/iobroker.smartmeter
                                      node smartmeter.js --force --logs
                                        Hier das Ergebnis!
                                        root@IOBrokerKeller:/opt/iobroker/node_modules/iobroker.smartmeter# node smartmeter.js --force --logs
                                        /opt/iobroker/node_modules/bindings/bindings.js:83
                                                throw e
                                        Error: Module version mismatch. Expected 46, got 48.
                                            at Error (native)
                                            at Object.Module._extensions..node (module.js:434:18)
                                            at Module.load (module.js:343:32)
                                            at Function.Module._load (module.js:300:12)
                                            at Module.require (module.js:353:17)
                                            at require (internal/module.js:12:17)
                                            at bindings (/opt/iobroker/node_modules/bindings/bindings.js:76:44)
                                            at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings.js:3:35)
                                            at Module._compile (module.js:409:26)
                                            at Object.Module._extensions..js (module.js:416:10)
                                        root@IOBrokerKeller:/opt/iobroker/node_modules/iobroker.smartmeter#</anonymous>
                                          Hattest du uns schon die nodejs version genannt mit der du arbeitest?
                                          ..und wenn du schon dabei bist, bitte auch die npm-Version
                                          Rainer
                                            @Homoran:
                                            Rainer `
                                            node -v
                                            v4.8.4
                                            npm -v
                                            2.15.11
                                            3625
                                            2195412
