    5. [ Gelöst ] Kamerabild aufnehmen (speichern)
    • I
      ioBrokerMike last edited by ioBrokerMike
      Moin
      Brauche Hilfe von Experten.
      Ich möchte, wenn es Klingelt ein Bild meiner IP Kamera speichern.
      Was ich habe ist folgendes :
      • Das Blockly Script
      <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="*Wd9o_3QBbmu7n(.|H9M" x="37.666656494140625" y="-112.33335876464844">
       <value name="OID0">
         <shadow type="field_oid" id="x;IGNi$;5Kn:kB`tq1{$">
           <field name="oid">cul.0.FS20.F85000.cmd</field>
       <value name="OID1">
         <shadow type="field_oid" id="@nInN9t]rzjFfqw{DoLD">
           <field name="oid">cul.0.FS20.F85001.cmd</field>
         <block type="controls_if" id=",E+)WRA_=k%0lckb]:h[">
             <block type="logic_compare" id="mc*;#$q(in/W,^NYSm0.">
               <field name="OP">GT</field>
                 <block type="on_source" id=")!]cHIs5IHqe:aSL?i;W">
                 <block type="math_number" id=";~!@F3p$erxkoh%mO_Kq">
                   <field name="NUM">0</field>
             <block type="exec" id="|dc(Wlzqg,`[3J#AwM-E">
               <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
               <field name="WITH_STATEMENT">FALSE</field>
               <field name="LOG">log</field>
               <value name="COMMAND">
                 <shadow type="text" id="D-t0!nfSJz;wNEZt3zIo">
                   <field name="TEXT">sudo wget –output-document /opt/iobroker/tmp/CamBild.jpg 'http://xxx.xxx.xxx.xx:80/snapshot.cgi?user=abc&amp;pwd"'</field>
                 <block type="text" id="*wuA:AUw8Pje6_^m*FSt">
                   <field name="TEXT">sudo wget –output-document /opt/iobroker/tmp/CamBild.jpg 'http://xxx.xxx.xxx.xx:80/snapshot.cgi?user=abc&amp;pwd='</field>
                 <block type="comment" id="=K3U4+r?LSApEOLoXn)m">
                   <field name="COMMENT">Zur Kontrolle ob " falls " ausgeführt </field>
                     <block type="update" id="Cik=io5YoK.Ny/-vV}jL">
                       <field name="OID">0_userdata.0.HaustürKamera.LastAktion</field>
                         <block type="time_get" id="5a{-58b8y%qD*-RU5%UN">
                           <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                           <field name="OPTION">custom</field>
                           <field name="FORMAT">TT.MM.JJJJ | SS:mm:ss</field>
      • Den Link der Kamera
        http://xxx.xxx.xxx.xx:80/snapshot.cgi?user=abc&pwd=
        Der mir das Bild im Browser anzeigt.
      • Das Verzeichnis
        /opt/iobroker/tmp/ mit Schreibrechte
      Nur leider tut sich da nichts.
      Bin auf eure Hilfe angewiesen. 😞
      E Codierknecht Glasfaser 3 Replies Last reply Reply Quote 0
        emil70 @ioBrokerMike last edited by
        @iobrokermike sagte in Kamerabild aufnehmen (speichern):
        Was passiert den, wenn du den wget Befehl über Konsole(Putty) ausführst?
        Mein Befehl sieht so aus
        wget --output-document /opt/iobroker/Kamerabilder/Eingang1.jpg "http://xxx.xxx.xxx.xxx/snap.jpeg"
        • Codierknecht
          Codierknecht Developer Most Active @ioBrokerMike last edited by
          @iobrokermike @emil70
          Nur zur Info: Ihr braucht die IP-Adressen eures Heimnetzes hier nicht zu verschleiern.
          Das ist euer Netz - da kommt keiner ran - zumindest nicht ohne euer Zutun.
          Mal ganz davon abgesehen, sehen die Adressen bei fast jedem hier gleich oder zumindest sehr ähnlich aus.
          192.168.178.1 ist in der Regel der Router (FritzBox).
          • Glasfaser
            Glasfaser @ioBrokerMike last edited by
            WAS tut nichts !?
            • Es wird nicht getriggert ,
              es wird kein Bild geholt ,
              es wird kein Bild gespeichert .
              es kommt eine Fehlermeldung
            • I
              ioBrokerMike @Glasfaser last edited by
              @emil70
              mit sudo
              pi@iobroker-pi:~ $ sudo wget –output-document /opt/iobroker/tmp/CamBild.jpeg 'http://192.168.178.200:80/snapshot.cgi?user=abc&pwd='
              --2023-01-04 11:27:33--  http://xn--output-document-du9h/
              Resolving xn--output-document-du9h (xn--output-document-du9h)... failed: Name or service not known.
              wget: unable to resolve host address ‘xn--output-document-du9h’
              /opt/iobroker/tmp/CamBild.jpeg: Scheme missing.
              --2023-01-04 11:27:34--  http://192.168.178.200/snapshot.cgi?user=abc&pwd=
              Connecting to 192.168.178.200:80... connected.
              HTTP request sent, awaiting response... 200 OK
              Length: 28860 (28K) [image/jpeg]
              Saving to: ‘snapshot.cgi?user=admin&pwd=.4’
              snapshot.cgi?user=admin&pwd=.4      100%[==================================================================>]  28.18K  --.-KB/s    in 0.01s
              2023-01-04 11:27:34 (1.91 MB/s) - ‘snapshot.cgi?user=admin&pwd=.4’ saved [28860/28860]
              FINISHED --2023-01-04 11:27:34--
              Total wall clock time: 0.4s
              Downloaded: 1 files, 28K in 0.01s (1.91 MB/s)
              ohne sudo
              pi@iobroker-pi:~ $  wget –output-document /opt/iobroker/tmp/CamBild.jpeg 'http://192.168.178.200:80/snapshot.cgi?user=admin&pwd='
              --2023-01-04 11:41:03--  http://xn--output-document-du9h/
              --2023-01-04 11:41:03--  http://192.168.178.200/snapshot.cgi?user=admin&pwd=
              Length: 29192 (29K) [image/jpeg]
              Saving to: ‘snapshot.cgi?user=abc&pwd=.6’
              snapshot.cgi?user=admin&pwd=.6      100%[==================================================================>]  28.51K  --.-KB/s    in 0.01s
              2023-01-04 11:41:03 (2.00 MB/s) - ‘snapshot.cgi?user=abc&pwd=.6’ saved [29192/29192]
              FINISHED --2023-01-04 11:41:03--
              Total wall clock time: 0.1s
              Downloaded: 1 files, 29K in 0.01s (2.00 MB/s)
              @glasfaser
              Es wird kein Bild gespeichert.
              Ob es geholt wird weiß ich nicht?
              @Codierknecht
              OK, hast recht werde sie stehen lassen.
              System ist von außen ja nicht Zugänglich.
              Glasfaser 2 Replies Last reply Reply Quote 0
              • Glasfaser
                ist
                jpg
                • Glasfaser
                  Das ist auch merkwürdig ..
                  geht ein :
                  ping google.com
                  • I
                    @glasfaser sagte in Kamerabild aufnehmen (speichern):
                    t auch merkwürdig
                    pi@iobroker-pi:~ $ ping google.com
                    PING google.com(fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e)) 56 data bytes
                    64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=1 ttl=119 time=20.7 ms
                    64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=2 ttl=119 time=9.99 ms
                    64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=3 ttl=119 time=10.0 ms
                    64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=4 ttl=119 time=9.55 ms
                    64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=5 ttl=119 time=9.66 ms
                    64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=6 ttl=119 time=9.63 ms
                    64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=7 ttl=119 time=9.98 ms
                    64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=8 ttl=119 time=9.82 ms
                    • Glasfaser
                      das ist falsch , der Bindestrich vor output !!!!
                      deshalb die Meldung
                      so :
                      • I
                        @glasfaser
                        deshalb die Meldung
                        Leider ohne Erfolg.
                        pi@iobroker-pi:~ $ sudo wget -–output-document /opt/iobroker/tmp/CamBild.jpg 'http://192.168.178.200:80/snapshot.cgi?user=abc&pwd='
                        wget: invalid option -- '▒'
                        Usage: wget [OPTION]... [URL]...
                        Try `wget --help' for more options.
                        pi@iobroker-pi:~ $ wget -–output-document /opt/iobroker/tmp/CamBild.jpg 'http://192.168.178.200:80/snapshot.cgi?user=abc&pwd='
                        Bin schon ein schwerer Fall 😊
                        E Glasfaser 2 Replies Last reply Reply Quote 0
                          @iobrokermike setzt mal den http teil in
                          • I
                            ioBrokerMike @emil70 last edited by
                            @emil70
                            Leider nichts geändert.
                            pi@iobroker-pi:~ $  wget -–output-document /opt/iobroker/tmp/CamBild.jpg "http://192.168.178.200:80/snapshot.cgi?user=abc&pwd="
                            Codierknecht OliverIO 2 Replies Last reply Reply Quote 0
                            • Codierknecht
                              @iobrokermike
                              Hast Du im Passwort evtl. Sonderzeichen? Könnte ein mögliches Problem sein.
                              • OliverIO
                                OliverIO @ioBrokerMike last edited by OliverIO
                                ein Blick in die Doku von wget hätte hier schnell weitergeholfen.
                                die kann man in linux einfach mit
                                man wget
                                aufrufen. das in google eintippen hilft genauso weiter
                                https://linux.die.net/man/1/wget
                                unter dem Parameter -–output-document ist ersichtlich, das die Definitiopn der Datei mit einem Gleichheitszeichen angegeben wird.
                                In Linux wird jeder seperate Parameter immer mit einem Leerzeichen getrennt.
                                Wenn zu einem Parameter ein Wert gehört, dann wird meist dieser mit = zugewiesen, allerdings habe ich auch schon gesehen, das direkt ohne Leerzeichen dahinter weitergeschrieben wird.
                                wget -–output-document=/opt/iobroker/tmp/CamBild.jpg "http://192.168.178.200:80/snapshot.cgi?user=abc&pwd="
                                mit man <befehl> kann man sich eigentlich zu jedem shell kommando die hilfe aufrufen.
                                • I
                                  ioBrokerMike @OliverIO last edited by
                                  @oliverio sagte in Kamerabild aufnehmen (speichern):
                                  Auch mit dem = bekomme ich kein Bild.
                                  pi@iobroker-pi:~ $ wget -–output-document=/opt/iobroker/tmp/CamBild.jpg "http://192.168.178.200:80/snapshot.cgi?user=abc&pwd="
                                  • Glasfaser
                                    Glasfaser @ioBrokerMike last edited by Glasfaser
                                    da stimmt immer noch der -- !!!
                                    der ist bei dir kurz und lang !!!!
                                    siehe hier bei der Meldung die Bindestriche
                                    edit :
                                    so sieht der bei dir aus
                                    • Glasfaser
                                      @iobrokermike
                                      ??? was ist denn jetzt [gelöst]
                                      • I
                                        Vielen Dank an euch!
                                        Ihr hatte es nicht einfach mit mir.
                                        Hier die Lösung : wget --output-document /opt/iobroker/tmp/CamBild.jpg "http://192.168.178.200:80/snapshot.cgi?user=abc&pwd="
                                        • Glasfaser
                                          @iobrokermike sagte in [ Gelöst ] Kamerabild aufnehmen (speichern):
                                          Hier die Lösung
                                          Der Postbote hat geklingelt ...
                                          1067
