    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
      ManfredHi @decnet last edited by
      @decnet sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
      @tombox Danke!!!! Manchmal ist die Lösund so einfach, aber ich bin Laie.
      Apropo Anfänger, wie kann ich den Status z.B. von "homeconnect.0.SIEMENS-CS658GRS6-68A40E1A317F.programs.active.BSH_Common_Root_ActiveProgram" in VIS so Anzeigen wie unter Objekte, also im deutschen Klartext z.B. "Heißluft", nicht als engl. Schachtelwort "Cooking.Oven.Program.HeatingMode.HotAir".
      Hab ich auch noch nicht herausgefunden. Ich hab mir einfach einen eigenen Datenpunkt gemacht und über ein Script je nach gewähltem Programm befüllt.
        sigi234 Forum Testing Most Active @decnet last edited by sigi234
        Mit Materialdesign Widgets:
        [{"tpl":"tplVis-materialdesign-value","data":{"oid":"homeconnect.0.401010522278007458.status.BSH_Common_Status_OperationState","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","targetType":"auto","textAlign":"start","valueLabelWidth":"3","valuesFontColor":"#ffffff","valuesFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.text","valuesFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.text","prepandTextColor":"#00bdb2","prepandTextFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.prepand","prepandTextFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.prepand","appendTextColor":"#mdwTheme:vis-materialdesign.0.colors.value.append","appendTextFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.append","appendTextFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.append","image":"/vis-icontwo/Devices/dishwasher.png","imageColor":"#mdwTheme:vis-materialdesign.0.colors.value.icon","iconPosition":"left","effectFontColor":"#mdwTheme:vis-materialdesign.0.colors.value.effect","effectFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.effect","effectDuration":"750","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"overrideText":"{val:homeconnect.0.401010522278007458.status.BSH_Common_Status_OperationState; val== \"BSH.Common.EnumType.OperationState.Inactive\" ? \"Inaktiv\" : val==\"BSH.Common.EnumType.OperationState.Ready\" ? \"Bereit\" : val==\"BSH.Common.EnumType.OperationState.Run\" ? \"Programm läuft\" : val==\"BSH.Common.EnumType.OperationState.Finished\" ? \"Programm beendet\" : \"no-no\" }","generateHtmlControl":"true","prepandText":"","debug":false,"iconHeight":"31","changeEffectEnabled":false},"style":{"left":"891px","top":"248px","width":"180px","height":"55px","z-index":"4"},"widgetSet":"materialdesign"}]
        Natürlich an Eure anpassen, ist eine Geschirrspüler
          decnet @sigi234 last edited by
          @sigi234 Danke für Deinen Tip. Leider verstehe ich nicht, wie ich ihn in VIS nutzen kann.
          LG
          Lutz
          • icebear
            icebear last edited by
            Ich hab meinen Bosch Backofen HSG636XS6 jetzt soweit das ich ihn starten kann und per Blockly ein Script läuft welches mir per Timer die Temperaturen verändert (braucht man z.B. zum Backen).
            Was allerdings bei mir nicht funktioniert ist der DP "Cooking_Oven_Status_CurrentCavityTemperature". Der bleibt immer auf 60° stehen. Wäre aber schön wenn man die tatsächliche Temperatur sehen könnte ob die mit der eingestellten übereinstimmt. (Ja ich kann auch zum Backofen gehen und kontrollieren ob das was per Script gefordert ist auch vom Backofen eingestellt wurde)
            Hat einer eine Idee?
            Gruß Holger
              gyle last edited by gyle
              @tombox hi, habe auch v 1.1.1 und hatte das problem, dass sich die states nicht mehr aktualisierten...
              habe daraufhin mal alle Objekte gelöscht und den adapter neu initialisiert.
              nun habe ich folgenden Zustand:
              mir fehlen die Objekte zum aktuellen status:
              wo kann das problem liegen?
              homeconnect.0
              2022-12-16 14:28:25.786	info	Found 1 devices
              homeconnect.0
              2022-12-16 14:28:25.195	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v14.20.1, js-controller: 4.0.23
              homeconnect.0
              2022-12-16 14:28:18.907	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              homeconnect.0
              2022-12-16 14:28:18.901	info	terminating
              homeconnect.0
              2022-12-16 14:28:18.889	info	Got terminate signal TERMINATE_YOURSELF
              homeconnect.0
              2022-12-16 14:26:30.811	info	Found 1 devices
              homeconnect.0
              2022-12-16 14:26:30.679	info	Token received succesfully
              homeconnect.0
              2022-12-16 14:26:24.407	info	SingleKey details submitted
              homeconnect.0
              2022-12-16 14:26:23.201	info	Try new SingleKey Login
              homeconnect.0
              2022-12-16 14:26:23.200	info	Normal Login response Your login details are incorrect, please check the information you entered.
              homeconnect.0
              2022-12-16 14:26:22.591	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v14.20.1, js-controller: 4.0.23
              T H 2 Replies Last reply Reply Quote 0
                tombox @gyle last edited by
                @gyle Einfach mal 24h warten ob es dann wieder geht
                  gyle @tombox last edited by
                  @tombox hm, irgendwie ändert sich nix an der situation - habe auch nochmals den bestehenden Objektbaum gelöscht - ohner erfolg.
                    Fridolin01 last edited by
                    Habe den BSH Adapter schon länger am laufen für mein Siemens Induktionskochfeld
                    Bisher was es nicht möglich den Energieverbrauch nach dem Kochen als Datenpunkt zu generieren.
                    Ist dies nun möglich?
                    Wenn nicht was benötigst du um dies zu realisieren?
                    Würde das Projekt gerne unterstützen.
                    Das Kochfeld zeigt nach jeden Kochvorgang an zum Beispiel 0,56 kWh.
                    Dieser Wert würde mich brennend als Datenpunkt interessieren.
                    arteck B 2 Replies Last reply Reply Quote 0
                      arteck Developer Most Active @Fridolin01 last edited by
                      @fridolin01 wenn die API es nicht hergibt..können wir nicht zaubern..
                      siehst du den Wert in der App ??
                        Frank the Tank @RicoGesch last edited by
                        @ricogesch Hi, hab das selbe Problem, was hast du gemacht damit es geht?
                        LG
                        R 1 Reply Last reply Reply Quote -1
                          Fridolin01 @arteck last edited by
                          @arteck leider nein
                          War nur eine Frage dachte das es irgendwie machbar sei.
                          Vieleicht bessert Bosch ja irgendwann nach
                            RicoGesch @Frank the Tank last edited by
                            @frank-the-tank
                            Hi, leider weiss ich nicht mehr was ich gemacht habe, ist leider zu lange her... Sorry
                            • werner2000x
                              werner2000x last edited by
                              Ich habe einen BOSCH-HSG636XS6 im Homeconnect Adapter erfolgreich eingebunden (ohne Bosch Bridge).
                              Zwar sehe ich alle Variable, kann sie allerdings nicht in VIS darstellen oder ändern.
                              Selbst das object "homeconnect.0.BOSCH-HSG636XS6-68A40E003607.status.BSH_Common_Status_DoorState"
                              kann ich nicht in VIS darstellen. Der Zustand in VIS ist immer der gleiche trotz Zustandsänderung.
                              Hat jemand schon eine VIS dazu gebaut oder einen Rat?
                              Was ich ausserdem möchte ist den Zustand "homeconnect.0.BOSCH-HSG636XS6-68A40E003607.status.BSH_Common_Status_OperationState" in VIS darstellen.
                                lustig29 last edited by
                                Seit geraumer Zeit läuft der Adapter nicht mehr richtig. Die Verbindung wird immer wieder getrennt und wieder hergestellt. Hatte sowas schon mal jemand?
                                eusec.0
                                2023-01-29 11:24:22.280	info	Connected to station T8010P23220312FE on host 192.168.0.70 and port 22316
                                eusec.0
                                2023-01-29 11:24:17.255	info	Disconnected from station T8010P23220312FE
                                T L 2 Replies Last reply Reply Quote 0
                                  sigi234 Forum Testing Most Active @werner2000x last edited by
                                  @werner2000x sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                                  https://forum.iobroker.net/topic/28717/vis-von-sigi234?_=1674988019656
                                    tombox @lustig29 last edited by
                                    @lustig29 Ich glaube du bist im falschen Adapter
                                      lustig29 @tombox last edited by
                                      @tombox
                                      Oh, Mist stimmt 🤦🏼‍♂️
                                        lustig29 @lustig29 last edited by
                                        @lustig29 Bitte löschen. Falscher Thread
                                          heromic @gyle last edited by
                                          @gyle Hi, hast du schon eine Lösung gefunden.
                                          Habe aktuell das gleiche Problem.
                                          Node.js: v16.18.0
                                            gyle @heromic last edited by
                                            @heromic bei mir trat das nach umstellung auf die neue authentifierungsmethode auf.
                                            auch in der app war dann keine verbindung zum gerät mehr da....
                                            habe dann das gerät neu über die app verbunden und danach ging es dann wieder...
                                            bsh bsh home connect home connect homeconnect adapter
                                            195
                                            1373
                                            498964
