    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
      Fauli85 last edited by
      2 war jetzt gar nicht so viel 🙂
      ubiobr2021@ds1618:~$ sudo apt full-upgrade
      Reading package lists... Done
      Building dependency tree... Done
      Calculating upgrade... Done
      The following packages were automatically installed and are no longer required:
        accountsservice alsa-topology-conf alsa-ucm-conf at bsdmainutils
        cryptsetup-run dconf-gsettings-backend dconf-service g++-9 gcc-10-base
        glib-networking glib-networking-common glib-networking-services
        gsettings-desktop-schemas language-selector-common libaccountsservice0
        libasn1-8-heimdal libasound2 libasound2-data libcanberra0 libcbor0.6
        libdconf1 libdns-export1109 libevent-2.1-7 libffi7 libfl2 libfuse2
        libfwupdplugin1 libgdk-pixbuf2.0-0 libgssapi3-heimdal libhcrypto4-heimdal
        libheimbase1-heimdal libheimntlm0-heimdal libhogweed5 libhx509-5-heimdal
        libicu66 libisl22 libjson-c4 libjsoncpp1 libkrb5-26-heimdal libldap-2.4-2
        libltdl7 libmpdec2 libnettle7 libntfs-3g883 libogg0 libpcre2-posix2
        libperl5.30 libproxy1v5 libpython3.8 libpython3.8-minimal
        libpython3.8-stdlib libreadline5 libroken18-heimdal libsoup2.4-1
        libsoup2.4-common libstdc++-9-dev libtdb1 liburcu6 libvorbis0a
        libvorbisfile3 libwebp6 libwind0-heimdal libxmlb1 ltrace lz4 ncal
        perl-modules-5.30 popularity-contest python3-entrypoints
        python3-requests-unixsocket python3-simplejson python3.8 python3.8-minimal
        session-migration sound-theme-freedesktop x11proto-xext-dev
      Use 'sudo apt autoremove' to remove them.
      # News about significant security updates, features and services will
      # appear here to raise awareness and perhaps tease /r/Linux ;)
      # Use 'pro config set apt_news=false' to hide this and future APT news.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Thomas Braun Most Active @Fauli85 last edited by
        @fauli85 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
        Dann mach das mal:
        sudo apt autoremove
        Beim Umzug von focal auf jammy hast du das nodesource-Repo übersehen.
        sudo nano /etc/apt/sources.list.d/nodesource.list
        Und dann dort statt focal einfach jammy reinschreiben.
        Speichern mit STRG-O, Enter-Taste, STRG-X.
        Dann nochmal
        sudo apt update
          mache jetzt grade
          sudo apt autoremove
          Bei der Frage habe ich mit yes geantwortet und bin jetzt bei 25% ca..
          Brauchst Du hier einen Bildschirmauszug?
            und zu Punkt 2
            ubiobr2021@ds1618:~$ sudo apt update
            Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
            Get:2 https://deb.nodesource.com/node_14.x jammy InRelease [4563 B]
            Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
            Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
            Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
            Get:7 https://deb.nodesource.com/node_14.x jammy/main amd64 Packages [773 B]
            Hit:6 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy InRelease
            Fetched 5336 B in 2s (2981 B/s)
            All packages are up to date.
              @fauli85
              Ja, sollte jetzt passen.
                Also Terminal neu startet und leider kommt die Meldung immer noch 😞
                98 updates could not be installed automatically. For more details,
                see /var/log/unattended-upgrades/unattended-upgrades.log
                  Achso, nee, in der nodesource.list bitte noch aus
                  node_14.x
                  node_16.x
                  machen.
                  iob stop
                  sudo apt update
                  iob start
                    Dann schau da mal rein:
                    less -R /var/log/unattended-upgrades/unattended-upgrades.log
                      Fauli85 last edited by Fauli85
                      die 4 Befehle habe ich gemacht
                      hier die liste var
                      ubiobr2021@ds1618:~$ less -R /var/log/unattended-upgrades/unattended-upgrades.lo                             g
                      2023-01-04 06:26:31,048 INFO Package python3-simplejson is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,053 INFO Package python3-systemd is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,061 INFO Package python3-yaml is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,062 INFO Package python3-zope.interface is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,105 INFO Package rsyslog is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,136 INFO Package sed is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,152 INFO Package sudo is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,157 INFO Package systemd is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,158 INFO Package systemd-sysv is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,159 INFO Package systemd-timesyncd is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,161 INFO Package tar is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,184 INFO Package udev is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,190 INFO Package util-linux is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,201 INFO Package vim is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,210 INFO Package vim-common is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,219 INFO Package vim-runtime is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 06:26:31,228 INFO Package vim-tiny is kept back because a related package is kept back or due to local apt_preferences(5).
                      2023-01-04 09:35:17,043 INFO Starting unattended upgrades script
                      2023-01-04 09:35:17,046 INFO Allowed origins are: o=Ubuntu,a=jammy, o=Ubuntu,a=jammy-security, o=UbuntuESMApps,a=jammy-apps-security, o=UbuntuESM,a=jammy-infra-security
                      2023-01-04 09:35:17,047 INFO Initial blacklist:
                      2023-01-04 09:35:17,048 INFO Initial whitelist (not strict):
                      jetzt steht da Ende und ich kann nix eingeben 😞
                      stop kommt gleich noch mehr - nein kommt nicht mehr.
                      Komme aus dem END nicht raus lacht das wäre jetzt ein Grund für mich das Terminal neu so öffnen
                      und wieder was gelernt "q" einfach tippen
                      • Segway
                        Segway @Thomas Braun last edited by
                        Ich schaue auch hin und wieder mal nach Spendetest, aber alles was ich anpacke gibt so furchtbar unterschiedliche Ergebnisse.
                        Gerade nochmal mit meinem Laptop getestet der direkt am Hauptrouter hängt!
                        Bei 1000MBit gab es 2x 170 Mbps, einmal 700 und einmal 360
                        alles über den Edge browser mal eben schnell gemacht.
                        Ist das alles wirklich aussagekräftig ?
                        Thomas Braun F 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @Segway last edited by Thomas Braun
                          @segway sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                          Hier passt es. Ich habe mir einen stabilen Server in meiner Nähe gesucht und den fix eingetragen. Mit der Voreinstellung 'such den besten Server alleine' hatte ich auch äußerst schwankende Graphen. Mittlerweile ist das aber sehr stabil:
                          50MBit upload (hellgrau)
                          1000MBit down (dunkelgrau)
                            apt policy sudo
                            sagt?
                              Fauli85 @Segway last edited by
                              @segway
                              ich habe auch ne feste ID
                                 Speedtest by Ookla
                                    Server: Net-D-Sign GmbH - Munich (id: 52143)
                                       ISP: Vodafone Germany
                              Idle Latency:    10.49 ms   (jitter: 2.06ms, low: 6.43ms, high: 12.53ms)
                                  Download:   927.10 Mbps (data used: 899.3 MB)
                                               21.36 ms   (jitter: 6.89ms, low: 6.04ms, high: 316.66ms)
                                    Upload:    49.66 Mbps (data used: 43.7 MB)
                                               14.87 ms   (jitter: 5.36ms, low: 4.71ms, high: 278.77ms)
                               Packet Loss:     0.0%
                                Result URL: https://www.speedtest.net/result/c/55c43e6a-54df-4e5a-9914-aa8a5a7027f9
                                Fauli85 @Thomas Braun last edited by
                                sagt
                                ubiobr2021@ds1618:~$ apt policy sudo
                                sudo:
                                  Installed: 1.9.9-1ubuntu2.1
                                  Candidate: 1.9.9-1ubuntu2.1
                                  Version table:
                                 *** 1.9.9-1ubuntu2.1 500
                                        500 http://de.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
                                        100 /var/lib/dpkg/status
                                     1.9.9-1ubuntu2 500
                                        500 http://de.archive.ubuntu.com/ubuntu jammy/main amd64 Packages
                                • Segway
                                  @thomas-braun & @Fauli85
                                  Und wie habt ihr den besten Server herausgefunden ?
                                  Ich mach das grad per console
                                  Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                                    @segway
                                    Tip am Rande:
                                    Per
                                    https://c.speedtest.net/speedtest-servers-static.php
                                    sollte man eine ID (hier z. B. 12345) eines zuverlässigen Servers identifizieren und im skript in Zeile 32 fix eintragen.
                                    Da einfach mal mit verschiedenen IDs fix eingetragen herumexperimentieren.
                                    In der Konsole konnte man aber auch über eine Option einen Server fix übergeben.
                                    man speedtest hilft gerne weiter.
                                    • Codierknecht
                                      Codierknecht Developer Most Active @Segway last edited by Codierknecht
                                      Wenn Du bei Ookla einen gut funktionierenden Server gefunden hast, brauchst Du nur mit der Maus über den Servernamen fahren. Der angezeigte Link endet mit der ID des Servers.
                                      • Segway
                                        Segway @Codierknecht last edited by
                                        @codierknecht
                                        Ja hab da so ziemlich alle schon durch. aber komme nicht über 350 MBit. Da kämpfe ich schon immer mit.
                                        Keine Ahnung was da los ist.
                                          Über WLAN?
                                            @fauli85
                                            Sollte eigentlich jetzt passen.
                                            Was sagt
                                            ls -lAh /etc/apt/preferences.d/
                                            391
                                            72704
