    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
      Thomas Braun Most Active @Fauli85 last edited by
      @fauli85 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
      /var/log/unattended-upgrades/unattended-upgrades.log
      Dann schau da mal rein:
      less -R /var/log/unattended-upgrades/unattended-upgrades.log
        Fauli85 last edited by Fauli85
        die 4 Befehle habe ich gemacht
        hier die liste var
        ubiobr2021@ds1618:~$ less -R /var/log/unattended-upgrades/unattended-upgrades.lo                             g
        2023-01-04 06:26:31,048 INFO Package python3-simplejson is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,053 INFO Package python3-systemd is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,061 INFO Package python3-yaml is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,062 INFO Package python3-zope.interface is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,105 INFO Package rsyslog is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,136 INFO Package sed is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,152 INFO Package sudo is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,157 INFO Package systemd is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,158 INFO Package systemd-sysv is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,159 INFO Package systemd-timesyncd is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,161 INFO Package tar is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,184 INFO Package udev is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,190 INFO Package util-linux is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,201 INFO Package vim is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,210 INFO Package vim-common is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,219 INFO Package vim-runtime is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,228 INFO Package vim-tiny is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 09:35:17,043 INFO Starting unattended upgrades script
        2023-01-04 09:35:17,046 INFO Allowed origins are: o=Ubuntu,a=jammy, o=Ubuntu,a=jammy-security, o=UbuntuESMApps,a=jammy-apps-security, o=UbuntuESM,a=jammy-infra-security
        2023-01-04 09:35:17,047 INFO Initial blacklist:
        2023-01-04 09:35:17,048 INFO Initial whitelist (not strict):
        jetzt steht da Ende und ich kann nix eingeben 😞
        stop kommt gleich noch mehr - nein kommt nicht mehr.
        Komme aus dem END nicht raus lacht das wäre jetzt ein Grund für mich das Terminal neu so öffnen
        und wieder was gelernt "q" einfach tippen
        • Segway
          Segway @Thomas Braun last edited by
          Ich schaue auch hin und wieder mal nach Spendetest, aber alles was ich anpacke gibt so furchtbar unterschiedliche Ergebnisse.
          Gerade nochmal mit meinem Laptop getestet der direkt am Hauptrouter hängt!
          Bei 1000MBit gab es 2x 170 Mbps, einmal 700 und einmal 360
          alles über den Edge browser mal eben schnell gemacht.
          Ist das alles wirklich aussagekräftig ?
          Thomas Braun F 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @Segway last edited by Thomas Braun
            @segway sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
            Hier passt es. Ich habe mir einen stabilen Server in meiner Nähe gesucht und den fix eingetragen. Mit der Voreinstellung 'such den besten Server alleine' hatte ich auch äußerst schwankende Graphen. Mittlerweile ist das aber sehr stabil:
            50MBit upload (hellgrau)
            1000MBit down (dunkelgrau)
              apt policy sudo
              sagt?
                Fauli85 @Segway last edited by
                @segway
                ich habe auch ne feste ID
                   Speedtest by Ookla
                      Server: Net-D-Sign GmbH - Munich (id: 52143)
                         ISP: Vodafone Germany
                Idle Latency:    10.49 ms   (jitter: 2.06ms, low: 6.43ms, high: 12.53ms)
                    Download:   927.10 Mbps (data used: 899.3 MB)
                                 21.36 ms   (jitter: 6.89ms, low: 6.04ms, high: 316.66ms)
                      Upload:    49.66 Mbps (data used: 43.7 MB)
                                 14.87 ms   (jitter: 5.36ms, low: 4.71ms, high: 278.77ms)
                 Packet Loss:     0.0%
                  Result URL: https://www.speedtest.net/result/c/55c43e6a-54df-4e5a-9914-aa8a5a7027f9
                  Fauli85 @Thomas Braun last edited by
                  sagt
                  ubiobr2021@ds1618:~$ apt policy sudo
                  sudo:
                    Installed: 1.9.9-1ubuntu2.1
                    Candidate: 1.9.9-1ubuntu2.1
                    Version table:
                   *** 1.9.9-1ubuntu2.1 500
                          500 http://de.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
                          100 /var/lib/dpkg/status
                       1.9.9-1ubuntu2 500
                          500 http://de.archive.ubuntu.com/ubuntu jammy/main amd64 Packages
                  • Segway
                    @thomas-braun & @Fauli85
                    Und wie habt ihr den besten Server herausgefunden ?
                    Ich mach das grad per console
                    Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                      @segway
                      Tip am Rande:
                      Per
                      https://c.speedtest.net/speedtest-servers-static.php
                      sollte man eine ID (hier z. B. 12345) eines zuverlässigen Servers identifizieren und im skript in Zeile 32 fix eintragen.
                      Da einfach mal mit verschiedenen IDs fix eingetragen herumexperimentieren.
                      In der Konsole konnte man aber auch über eine Option einen Server fix übergeben.
                      man speedtest hilft gerne weiter.
                      • Codierknecht
                        Codierknecht Developer Most Active @Segway last edited by Codierknecht
                        Wenn Du bei Ookla einen gut funktionierenden Server gefunden hast, brauchst Du nur mit der Maus über den Servernamen fahren. Der angezeigte Link endet mit der ID des Servers.
                        • Segway
                          Segway @Codierknecht last edited by
                          @codierknecht
                          Ja hab da so ziemlich alle schon durch. aber komme nicht über 350 MBit. Da kämpfe ich schon immer mit.
                          Keine Ahnung was da los ist.
                            Über WLAN?
                              @fauli85
                              Sollte eigentlich jetzt passen.
                              Was sagt
                              ls -lAh /etc/apt/preferences.d/
                                @segway
                                Router mal neu gestartet?
                                Ich hatte auch lange Zeit Vodafon Cabel nur 350 etc nie höher.
                                Alle Netzwerkkabel getauscht
                                Neuste Fritzbox
                                Dann war ich schon mal bei 500 von 1000.
                                Am Schluss kam ein neuer Rechner und seit dem bin ich bei 950
                                • Segway
                                  Ne per Lan angeschlossen direkt am Hauptswitch
                                  F Thomas Braun 2 Replies Last reply Reply Quote 0
                                    nicht viel 🙂
                                    ubiobr2021@ds1618:~$ ls -lAh /etc/apt/preferences.d/
                                    total 0
                                      @segway said in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                      Hauptswitch
                                      Ach und die habe ich auch alle getauscht.
                                        @segway
                                        Könnte halt auch lokal bei dir was sein.
                                        Aber Speedtests sind auch sehr mit Vorsicht zu genießen. Insbesondere mit den ganz dicken Leitungen kommen dann doch viele Server nicht dauerhaft hinterher.
                                        Segway 2 Replies Last reply Reply Quote 0
                                        • Segway
                                          @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                          Deswegen hab ich es eher immer ignoriert und für nicht gut befunden.
                                          Aber momentan scheint da echt einer auf der Leitung zu stehen ! Eine 5Gb Datei runtergezogen vom Telekom server und komme nicht über 12 MB/s
                                          mhhhhh .... was ist da los komische Sache
                                          Hauptswitch
                                          Ist ein neuer 24 Port Unifi Switch drin !
                                          • Segway
                                            Ja steht ja sogar da, dass bei einem Cable Max Anschluss ehemals UM eher problematisch ist.
                                            Iobroker läuft ja in einer VM bei mir --> macht das dann überhaupt Sinn das Skript zu installieren ??? Läuft ja nicht nativ
                                            1.0k
                                            391
                                            72697
