    4. Livisi/Innogy-Smarthome Adapter 1.0.0 (Beta) (BREAKING)
    • I
      ITCrowd @apollon77 last edited by ITCrowd
      @apollon77 Super Arbeit. Danke.
      Keiner der alten Fehler tritt mehr auf. Nur die Instanz.0 hat sporadisch einen Schluckauf. Instanz.1 zeigt dieses Verhalten nicht. (Beide lokales Smarthome)
      2023-01-03 01:03:03.154 - warn: innogy-smarthome.0 (275406) Adapter is not connected ... Will recheck in 30 seconds!
      2023-01-03 01:03:33.181 - warn: innogy-smarthome.0 (275406) Adapter is still not connected to the Innogy API, restarting!
      2023-01-03 01:03:36.398 - info: innogy-smarthome.0 (275406) Initialization sequence completed: found 42 devices
      2023-01-03 02:43:03.164 - warn: innogy-smarthome.0 (275406) Adapter is not connected ... Will recheck in 30 seconds!
      2023-01-03 02:43:33.166 - warn: innogy-smarthome.0 (275406) Adapter is still not connected to the Innogy API, restarting!
      2023-01-03 02:43:36.407 - info: innogy-smarthome.0 (275406) Initialization sequence completed: found 42 devices
      2023-01-03 03:28:03.171 - warn: innogy-smarthome.0 (275406) Adapter is not connected ... Will recheck in 30 seconds!
      2023-01-03 03:28:33.173 - warn: innogy-smarthome.0 (275406) Adapter is still not connected to the Innogy API, restarting!
      2023-01-03 03:28:36.402 - info: innogy-smarthome.0 (275406) Initialization sequence completed: found 42 devices
      2023-01-03 05:58:03.184 - warn: innogy-smarthome.0 (275406) Adapter is not connected ... Will recheck in 30 seconds!
      2023-01-03 05:58:33.187 - warn: innogy-smarthome.0 (275406) Adapter is still not connected to the Innogy API, restarting!
      2023-01-03 05:58:36.086 - info: innogy-smarthome.0 (275406) Initialization sequence completed: found 42 devices
      usw.
        apollon77 @ITCrowd last edited by
        @itcrowd Bitte mal in der Konfig dss "debug" einschalten und Debug Log ... dann siehst Du was passiert ... ich tippe darauf das die Zentrale die Verbindung schliesst (warum auch immer) und damit verbindet such der Adapter neu ... Das wurde berichtet.
        • I
          @apollon77 Beide Zentralen haben sproadisch das gleiche Problem. (Debugprotokoll siehe Spoiler)
          Eine Zentrale ist über ein 1m Netzwerkkabel an einer FritzBox angeschlossen, die Andere über eine VPN-Verbindung.
          Noch ein Bug in der Firmware?
          2023-01-04 00:02:22.831 - debug: innogy-smarthome.0 (616139) DEBUG EVENT {"type":"check_timer"}
          2023-01-04 00:02:22.838 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:22.832Z (ack = true)
          2023-01-04 00:02:23.174 - debug: innogy-smarthome.0 (616139) DEBUG EVENT {"type":"error_handler","data":{}}
          2023-01-04 00:02:23.175 - debug: innogy-smarthome.0 (616139) DEBUG EVENT {"type":"check_timer_then"}
          2023-01-04 00:02:23.175 - debug: innogy-smarthome.0 (616139) DEBUG EVENT {"type":"reinit_realtime_updates_due_to_timer_detected_changes"}
          2023-01-04 00:02:23.176 - debug: innogy-smarthome.0 (616139) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
          2023-01-04 00:02:23.180 - debug: innogy-smarthome.0 (616139) GOT AN IGNORED ERROR: {"code":"WS_ERR_INVALID_CLOSE_CODE"}
          2023-01-04 00:02:23.180 - debug: innogy-smarthome.0 (616139) STACK: RangeError: Invalid WebSocket frame: invalid status code 0
          at Receiver.controlMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:561:18)
          at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:429:42)
          at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:148:22)
          at Receiver._write (/opt/iobroker/node_modules/ws/lib/receiver.js:83:10)
          at writeOrBuffer (node:internal/streams/writable:391:12)
          at _write (node:internal/streams/writable:332:10)
          at Receiver.Writable.write (node:internal/streams/writable:336:10)
          at Socket.socketOnData (/opt/iobroker/node_modules/ws/lib/websocket.js:1272:35)
          at Socket.emit (node:events:513:28)
          at Socket.emit (node:domain:489:12)
          at addChunk (node:internal/streams/readable:315:12)
          at readableAddChunk (node:internal/streams/readable:289:9)
          at Socket.Readable.push (node:internal/streams/readable:228:10)
          at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
          2023-01-04 00:02:23.183 - debug: innogy-smarthome.0 (616139) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
          2023-01-04 00:02:23.185 - debug: innogy-smarthome.0 (616139) OPEN
          2023-01-04 00:02:23.230 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:23.175Z (ack = true)
          2023-01-04 00:02:23.232 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:23.175Z (ack = true)
          2023-01-04 00:02:23.233 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:23.175Z (ack = true)
          2023-01-04 00:02:23.233 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.connection changed: false (ack = true)
          2023-01-04 00:02:23.236 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.connection changed: false (ack = true)
          2023-01-04 00:02:23.237 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.connection changed: true (ack = true)
          2023-01-04 00:02:29.847 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:29.843Z (ack = true)
          2023-01-04 00:02:29.848 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:29.844Z (ack = true)
          2023-01-04 00:41:34.794 - debug: innogy-smarthome.1 (616170) DEBUG EVENT {"type":"check_timer"}
          2023-01-04 00:41:34.802 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.lastRealTimeEventReceived changed: 2023-01-03T23:41:34.795Z (ack = true)
          2023-01-04 00:41:35.177 - debug: innogy-smarthome.1 (616170) DEBUG EVENT {"type":"error_handler","data":{}}
          2023-01-04 00:41:35.177 - debug: innogy-smarthome.1 (616170) DEBUG EVENT {"type":"check_timer_then"}
          2023-01-04 00:41:35.178 - debug: innogy-smarthome.1 (616170) DEBUG EVENT {"type":"reinit_realtime_updates_due_to_timer_detected_changes"}
          2023-01-04 00:41:35.178 - debug: innogy-smarthome.1 (616170) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
          2023-01-04 00:41:35.185 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.lastRealTimeEventReceived changed: 2023-01-03T23:41:35.177Z (ack = true)
          2023-01-04 00:41:35.186 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.lastRealTimeEventReceived changed: 2023-01-03T23:41:35.177Z (ack = true)
          2023-01-04 00:41:35.187 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.lastRealTimeEventReceived changed: 2023-01-03T23:41:35.178Z (ack = true)
          2023-01-04 00:41:35.188 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.connection changed: false (ack = true)
          2023-01-04 00:41:35.206 - debug: innogy-smarthome.1 (616170) GOT AN IGNORED ERROR: {"code":"WS_ERR_INVALID_CLOSE_CODE"}
          2023-01-04 00:41:35.206 - debug: innogy-smarthome.1 (616170) STACK: RangeError: Invalid WebSocket frame: invalid status code 0
          2023-01-04 00:41:35.208 - debug: innogy-smarthome.1 (616170) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
          2023-01-04 00:41:35.230 - debug: innogy-smarthome.1 (616170) OPEN
          2023-01-04 00:41:35.232 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.connection changed: false (ack = true)
          2023-01-04 00:41:35.235 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.connection changed: true (ack = true)
            @itcrowd Faktisch ist das scheinbar ein Fehler in der Firmware ... ja ... Da ird scheinbar die Websocket connection geschlossen mit Fehlercode 0 was so nicht gestattet ist ... Also er würde das Websocket eh neu verbinden ,müssen (weils ja beim schliessen passiert) ... aber am Ende geht alles mit dem Reconnect ... Das wäre mein Wissensstand
            • N
              niiccooo1 last edited by niiccooo1
              Hallo Zusammen,
              ich freue mich, dass ich mein System zukünftig noch ein bisschen länger verwenden kann.
              Ich sehe jedoch keinen Datenpunkt für die Fensterkontakte. Wurden die schon implementiert?
              Viele Grüße,
              Nico
              Winni 1 Reply Last reply Reply Quote 0
              • Winni
                Winni @niiccooo1 last edited by
                @niiccooo1 Bei mir sind alle da:
                Lösche mal die alten Objekte und starte den Adapter neu.
                N 1 Reply Last reply Reply Quote 1
                • N
                  niiccooo1 @Winni last edited by
                  @winni das wars gewesen. Besten Dank!
                  • Winni
                    @niiccooo1 Freut mich 😀
                    • N
                      @winni Doch nicht so ganz.
                      @apollon77 Ich hatte vor dem Adapter Update meine Zentrale neugestartet.
                      Beim Neustart verliert die Zentrale die Information über den Status der Fenstersensoren d.h. sie müssen einmal betätigt werden. Da ich während der Adaptereinrichtung kein Fenster betätgt hatte wurden die Objekte nicht angelegt.
                      Lösung: Fenster betätigen und Adapter neustarten.
                        SGK1 @niiccooo1 last edited by SGK1
                        @apollon77
                        Unterschiede V1 & V2 ?
                        existiert das Objekt Virtual/"SmarthomeController xxx" bei den Klassischen Zentralen (oberes Bild) nicht, oder wird es vom Adapter nur nicht erkannt?
                        Lassen sich die null-States beim V2 (unteres Bild) ggf. noch auslesen?
                        Beste Grüße
                        Michael
                          apollon77 @SGK1 last edited by
                          @sgk1 Da der Adapter sehr generisch ausliesst was kommt, nehme ich an das die zu Frage 1 nicht da sind und bei Frage 2 die Werte nicht da sind.
                          Ansonsten: Debug Log aktivieren bei beiden instanzen mir dann das Log aus dem Logfile unter /opt/iobroekr/log/... per E-mail an iobroker@fischer-ka.de senden und auf dieses Posting verweisen (Damit ich weiss um was es geht, am besten als Link) und GENAU beschreiben um was es geht (bedenke: Ich habe weder die eine noch die andere Generation hier und nutze es auch nicht, also erklärs einem "Livisi-Unwissenden"!
                          • Great SUN
                            Great SUN last edited by
                            @apollon77
                            Hi...
                            Alle (nicht näher definierbare Anzahl) Restarts der Instanz scheint der Adapter das Passwort zu verlieren.
                            Evtl. hat einer eine Idee, was bei mir falsch ist/was ich anpassen muss, oder vielleicht ist es ja doch ein Bug im Adapter...
                            Danke!
                            Great SUN apollon77 2 Replies Last reply Reply Quote 0
                            • Great SUN
                              Great SUN @Great SUN last edited by
                              @apollon77 Evtl. renewed der auch den token nicht anständig... aktuell steht bei mir drin bis 10.1. wäre der gültig.
                              • DJMarc75
                                DJMarc75 @Great SUN last edited by
                                @great-sun Welche Version installiert ?
                                Great SUN 1 Reply Last reply Reply Quote 0
                                • Great SUN
                                  Great SUN @DJMarc75 last edited by
                                  @djmarc75 v1.2.4
                                    apollon77 @Great SUN last edited by
                                    @great-sun Hm ... also "passwort verlieren" kann aktuell nur passieren wenn du per Pro Cloud und dort Admin was an der Konfiguration änderst und einen js-controller < 4.0.24 hast ... Ansonsten wüsste ich nicht wie das passieren sollte.
                                    Sonst debug log aktivieren und "log spam" aushalten damit man mal ein Debug log von so einem Fall hat. Renewal sollte an sich tun ... aber auchhier ... Debug log
                                    • Great SUN
                                      Great SUN @apollon77 last edited by
                                      @apollon77 Okay... Ich nehme jetzt erstmal an, dass es mit dem Timeout vom Token zusammenhängt. js-controller ist 4.0.24.
                                      An der Konfiguration in dem iot Adapter änder ich derzeit immer mal wieder was (falls das mit der Pro Cloud gemeint ist), allerdings kann ich da ja jetzt spezifisch mal drauf achten.
                                      Danke erstmal für die Hints, da bringt mich ja schonmal weiter, wie/wo ich schauen kann. Wenn ich was finde, meld ich mich nochmal.
                                      Tschö mit Ö und noch einen schönen Sonntag Euch!
                                        @great-sun ne gemeint wäre wirklich Cloud Adapter und Admin über die pro Cloud. Da gabs ein Problem was zu verlorenen Passwörter. Geführt haben könnte. Aber mir js-Controller 4.0.24 sollte das egal sein.
                                        Dann mal Debug log mitlaufen lassen. Meine rudimentären Tests hatten gezeigt das refresh geht aber zeitlichen refresh weil während Laufzeit abgelaufen konnte ich nicht testen.
                                          Steuermann last edited by Steuermann
                                          Ich muss jetzt auch umsteigen…
                                          Und habe Probleme.
                                          Ich habe alles alte gelöscht und den Adapter v1.2.1 installiert.
                                          Ich habe den Smart Home 1 Controller Classic
                                          Bei shc IP gebe ich die
                                          Ipadresse mit oder ohne http:// ein und mit oder ohne :8080/
                                          Egal was ich mache es geht nicht.
                                          Bei aPasswort gehe ich das neue Lokale Admin Passwort ein. Gehe auf speichern und schließen und der Adapter sagt immer keine Verbindung.
                                          Start Authorization muss man für lokal doch nicht mehr machen oder? Weil da verläuft er sich scheinbar immer.
                                          apollon77 Winni 2 Replies Last reply Reply Quote 0
                                            apollon77 @Steuermann last edited by
                                            @steuermann sagte in Livisi/Innogy-Smarthome Adapter 1.0.0 (Beta) (BREAKING):
                                            naja hat eine IP Adresse ein Protokoll davor oder nen Port am Ende? Nein 🙂 Es ist nur "192.x.y.z"
                                            Was den Rest angeht können ggf die anderen User hier besser helfen.
                                            78
                                            9672
