    4. Livisi/Innogy-Smarthome Adapter 1.0.0 (Beta) (BREAKING)
      apollon77 @ITCrowd last edited by
      @itcrowd Bitte mal in der Konfig dss "debug" einschalten und Debug Log ... dann siehst Du was passiert ... ich tippe darauf das die Zentrale die Verbindung schliesst (warum auch immer) und damit verbindet such der Adapter neu ... Das wurde berichtet.
      • I
        ITCrowd @apollon77 last edited by
        @apollon77 Beide Zentralen haben sproadisch das gleiche Problem. (Debugprotokoll siehe Spoiler)
        Eine Zentrale ist über ein 1m Netzwerkkabel an einer FritzBox angeschlossen, die Andere über eine VPN-Verbindung.
        Noch ein Bug in der Firmware?
        2023-01-04 00:02:22.831 - debug: innogy-smarthome.0 (616139) DEBUG EVENT {"type":"check_timer"}
        2023-01-04 00:02:22.838 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:22.832Z (ack = true)
        2023-01-04 00:02:23.174 - debug: innogy-smarthome.0 (616139) DEBUG EVENT {"type":"error_handler","data":{}}
        2023-01-04 00:02:23.175 - debug: innogy-smarthome.0 (616139) DEBUG EVENT {"type":"check_timer_then"}
        2023-01-04 00:02:23.175 - debug: innogy-smarthome.0 (616139) DEBUG EVENT {"type":"reinit_realtime_updates_due_to_timer_detected_changes"}
        2023-01-04 00:02:23.176 - debug: innogy-smarthome.0 (616139) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
        2023-01-04 00:02:23.180 - debug: innogy-smarthome.0 (616139) GOT AN IGNORED ERROR: {"code":"WS_ERR_INVALID_CLOSE_CODE"}
        2023-01-04 00:02:23.180 - debug: innogy-smarthome.0 (616139) STACK: RangeError: Invalid WebSocket frame: invalid status code 0
        at Receiver.controlMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:561:18)
        at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:429:42)
        at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:148:22)
        at Receiver._write (/opt/iobroker/node_modules/ws/lib/receiver.js:83:10)
        at writeOrBuffer (node:internal/streams/writable:391:12)
        at _write (node:internal/streams/writable:332:10)
        at Receiver.Writable.write (node:internal/streams/writable:336:10)
        at Socket.socketOnData (/opt/iobroker/node_modules/ws/lib/websocket.js:1272:35)
        at Socket.emit (node:events:513:28)
        at Socket.emit (node:domain:489:12)
        at addChunk (node:internal/streams/readable:315:12)
        at readableAddChunk (node:internal/streams/readable:289:9)
        at Socket.Readable.push (node:internal/streams/readable:228:10)
        at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
        2023-01-04 00:02:23.183 - debug: innogy-smarthome.0 (616139) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
        2023-01-04 00:02:23.185 - debug: innogy-smarthome.0 (616139) OPEN
        2023-01-04 00:02:23.230 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:23.175Z (ack = true)
        2023-01-04 00:02:23.232 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:23.175Z (ack = true)
        2023-01-04 00:02:23.233 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:23.175Z (ack = true)
        2023-01-04 00:02:23.233 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.connection changed: false (ack = true)
        2023-01-04 00:02:23.236 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.connection changed: false (ack = true)
        2023-01-04 00:02:23.237 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.connection changed: true (ack = true)
        2023-01-04 00:02:29.847 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:29.843Z (ack = true)
        2023-01-04 00:02:29.848 - debug: innogy-smarthome.0 (616139) state innogy-smarthome.0.info.lastRealTimeEventReceived changed: 2023-01-03T23:02:29.844Z (ack = true)
        2023-01-04 00:41:34.794 - debug: innogy-smarthome.1 (616170) DEBUG EVENT {"type":"check_timer"}
        2023-01-04 00:41:34.802 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.lastRealTimeEventReceived changed: 2023-01-03T23:41:34.795Z (ack = true)
        2023-01-04 00:41:35.177 - debug: innogy-smarthome.1 (616170) DEBUG EVENT {"type":"error_handler","data":{}}
        2023-01-04 00:41:35.177 - debug: innogy-smarthome.1 (616170) DEBUG EVENT {"type":"check_timer_then"}
        2023-01-04 00:41:35.178 - debug: innogy-smarthome.1 (616170) DEBUG EVENT {"type":"reinit_realtime_updates_due_to_timer_detected_changes"}
        2023-01-04 00:41:35.178 - debug: innogy-smarthome.1 (616170) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
        2023-01-04 00:41:35.185 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.lastRealTimeEventReceived changed: 2023-01-03T23:41:35.177Z (ack = true)
        2023-01-04 00:41:35.186 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.lastRealTimeEventReceived changed: 2023-01-03T23:41:35.177Z (ack = true)
        2023-01-04 00:41:35.187 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.lastRealTimeEventReceived changed: 2023-01-03T23:41:35.178Z (ack = true)
        2023-01-04 00:41:35.188 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.connection changed: false (ack = true)
        2023-01-04 00:41:35.206 - debug: innogy-smarthome.1 (616170) GOT AN IGNORED ERROR: {"code":"WS_ERR_INVALID_CLOSE_CODE"}
        2023-01-04 00:41:35.206 - debug: innogy-smarthome.1 (616170) STACK: RangeError: Invalid WebSocket frame: invalid status code 0
        2023-01-04 00:41:35.208 - debug: innogy-smarthome.1 (616170) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
        2023-01-04 00:41:35.230 - debug: innogy-smarthome.1 (616170) OPEN
        2023-01-04 00:41:35.232 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.connection changed: false (ack = true)
        2023-01-04 00:41:35.235 - debug: innogy-smarthome.1 (616170) state innogy-smarthome.1.info.connection changed: true (ack = true)
          @itcrowd Faktisch ist das scheinbar ein Fehler in der Firmware ... ja ... Da ird scheinbar die Websocket connection geschlossen mit Fehlercode 0 was so nicht gestattet ist ... Also er würde das Websocket eh neu verbinden ,müssen (weils ja beim schliessen passiert) ... aber am Ende geht alles mit dem Reconnect ... Das wäre mein Wissensstand
          • N
            niiccooo1 last edited by niiccooo1
            Hallo Zusammen,
            ich freue mich, dass ich mein System zukünftig noch ein bisschen länger verwenden kann.
            Ich sehe jedoch keinen Datenpunkt für die Fensterkontakte. Wurden die schon implementiert?
            Viele Grüße,
            Nico
            Winni 1 Reply Last reply Reply Quote 0
            • Winni
              Winni @niiccooo1 last edited by
              @niiccooo1 Bei mir sind alle da:
              Lösche mal die alten Objekte und starte den Adapter neu.
              N 1 Reply Last reply Reply Quote 1
              • N
                niiccooo1 @Winni last edited by
                @winni das wars gewesen. Besten Dank!
                • Winni
                  @niiccooo1 Freut mich 😀
                  • N
                    @winni Doch nicht so ganz.
                    @apollon77 Ich hatte vor dem Adapter Update meine Zentrale neugestartet.
                    Beim Neustart verliert die Zentrale die Information über den Status der Fenstersensoren d.h. sie müssen einmal betätigt werden. Da ich während der Adaptereinrichtung kein Fenster betätgt hatte wurden die Objekte nicht angelegt.
                    Lösung: Fenster betätigen und Adapter neustarten.
                      SGK1 @niiccooo1 last edited by SGK1
                      @apollon77
                      Unterschiede V1 & V2 ?
                      existiert das Objekt Virtual/"SmarthomeController xxx" bei den Klassischen Zentralen (oberes Bild) nicht, oder wird es vom Adapter nur nicht erkannt?
                      Lassen sich die null-States beim V2 (unteres Bild) ggf. noch auslesen?
                      Beste Grüße
                      Michael
                        apollon77 @SGK1 last edited by
                        @sgk1 Da der Adapter sehr generisch ausliesst was kommt, nehme ich an das die zu Frage 1 nicht da sind und bei Frage 2 die Werte nicht da sind.
                        Ansonsten: Debug Log aktivieren bei beiden instanzen mir dann das Log aus dem Logfile unter /opt/iobroekr/log/... per E-mail an iobroker@fischer-ka.de senden und auf dieses Posting verweisen (Damit ich weiss um was es geht, am besten als Link) und GENAU beschreiben um was es geht (bedenke: Ich habe weder die eine noch die andere Generation hier und nutze es auch nicht, also erklärs einem "Livisi-Unwissenden"!
                        • Great SUN
                          Great SUN last edited by
                          @apollon77
                          Hi...
                          Alle (nicht näher definierbare Anzahl) Restarts der Instanz scheint der Adapter das Passwort zu verlieren.
                          Evtl. hat einer eine Idee, was bei mir falsch ist/was ich anpassen muss, oder vielleicht ist es ja doch ein Bug im Adapter...
                          Danke!
                          Great SUN apollon77 2 Replies Last reply Reply Quote 0
                          • Great SUN
                            Great SUN @Great SUN last edited by
                            @apollon77 Evtl. renewed der auch den token nicht anständig... aktuell steht bei mir drin bis 10.1. wäre der gültig.
                            • DJMarc75
                              DJMarc75 @Great SUN last edited by
                              @great-sun Welche Version installiert ?
                              Great SUN 1 Reply Last reply Reply Quote 0
                              • Great SUN
                                Great SUN @DJMarc75 last edited by
                                @djmarc75 v1.2.4
                                  apollon77 @Great SUN last edited by
                                  @great-sun Hm ... also "passwort verlieren" kann aktuell nur passieren wenn du per Pro Cloud und dort Admin was an der Konfiguration änderst und einen js-controller < 4.0.24 hast ... Ansonsten wüsste ich nicht wie das passieren sollte.
                                  Sonst debug log aktivieren und "log spam" aushalten damit man mal ein Debug log von so einem Fall hat. Renewal sollte an sich tun ... aber auchhier ... Debug log
                                  • Great SUN
                                    Great SUN @apollon77 last edited by
                                    @apollon77 Okay... Ich nehme jetzt erstmal an, dass es mit dem Timeout vom Token zusammenhängt. js-controller ist 4.0.24.
                                    An der Konfiguration in dem iot Adapter änder ich derzeit immer mal wieder was (falls das mit der Pro Cloud gemeint ist), allerdings kann ich da ja jetzt spezifisch mal drauf achten.
                                    Danke erstmal für die Hints, da bringt mich ja schonmal weiter, wie/wo ich schauen kann. Wenn ich was finde, meld ich mich nochmal.
                                    Tschö mit Ö und noch einen schönen Sonntag Euch!
                                      @great-sun ne gemeint wäre wirklich Cloud Adapter und Admin über die pro Cloud. Da gabs ein Problem was zu verlorenen Passwörter. Geführt haben könnte. Aber mir js-Controller 4.0.24 sollte das egal sein.
                                      Dann mal Debug log mitlaufen lassen. Meine rudimentären Tests hatten gezeigt das refresh geht aber zeitlichen refresh weil während Laufzeit abgelaufen konnte ich nicht testen.
                                        Steuermann last edited by Steuermann
                                        Ich muss jetzt auch umsteigen…
                                        Und habe Probleme.
                                        Ich habe alles alte gelöscht und den Adapter v1.2.1 installiert.
                                        Ich habe den Smart Home 1 Controller Classic
                                        Bei shc IP gebe ich die
                                        Ipadresse mit oder ohne http:// ein und mit oder ohne :8080/
                                        Egal was ich mache es geht nicht.
                                        Bei aPasswort gehe ich das neue Lokale Admin Passwort ein. Gehe auf speichern und schließen und der Adapter sagt immer keine Verbindung.
                                        Start Authorization muss man für lokal doch nicht mehr machen oder? Weil da verläuft er sich scheinbar immer.
                                        apollon77 Winni 2 Replies Last reply Reply Quote 0
                                          apollon77 @Steuermann last edited by
                                          @steuermann sagte in Livisi/Innogy-Smarthome Adapter 1.0.0 (Beta) (BREAKING):
                                          naja hat eine IP Adresse ein Protokoll davor oder nen Port am Ende? Nein 🙂 Es ist nur "192.x.y.z"
                                          Was den Rest angeht können ggf die anderen User hier besser helfen.
                                          • Winni
                                            Winni @Steuermann last edited by
                                            @steuermann Hallo, hast du das Smarthome im SHC aktiviert?
                                            Also mittels der bisherigen App.
                                            Wenn nicht, so geht's:
                                            https://community.livisi.de/forum/thread/4551-infos-zum-lokalen-smarthome/?postID=38621&highlight=Smarthome%2B%2Baktivieren#
                                            werner2000x 1 Reply Last reply Reply Quote 1
                                            78
                                            9661
