    4. Homematic Funkgong HmIP-MP3P über Blockly steuern
      heli-wolf @Homoran last edited by
      wie bekomme ich aus einem Screenshot einen Text ??
      • Glasfaser
        Glasfaser @heli-wolf last edited by Glasfaser
        @heli-wolf sagte in Homematic Funkgong HmIP-MP3P über Blockly steuern:
        Nicht Code-Tags dafür nutzen !
        so ... das Bild hochladen
          heli-wolf @Glasfaser last edited by
          Ok, Sorry jetzt sollte es klappen.
          • Codierknecht
            Codierknecht Developer Most Active @heli-wolf last edited by Codierknecht
            @heli-wolf
            irgendwie habe ich das mit den Code-Tags nicht richtig gemacht, offensichtlich
            Die Objektdaten „IN DIE ZWISCHENABLAGE KOPIEREN“ und dann hier in Code-Tags posten.
            So wie hier:
              "type": "state",
              "common": {
                "name": "Gaszähler:1.STATE",
                "role": "value.window",
                "def": 0,
                "type": "number",
                "read": true,
                "write": false,
                "min": 0,
                "max": 1,
                "states": {
                  "0": "CLOSED",
                  "1": "OPEN"
              "native": {
                "MIN": "CLOSED",
                "UNIT": "\"\"",
                "OPERATIONS": 5,
                "MAX": "OPEN",
                "FLAGS": 1,
                "ID": "STATE",
                "TAB_ORDER": 0,
                "TYPE": "ENUM",
                "DEFAULT": "CLOSED",
                "VALUE_LIST": [
                  "CLOSED",
                  "OPEN"
                "CONTROL": "DOOR_SENSOR.STATE"
              "_id": "hm-rpc.0.001E1D899E914F.1.STATE",
              "acl": {
                "object": 1636,
                "state": 1636,
                "owner": "system.user.admin",
              "from": "system.adapter.hm-rega.0",
              "user": "system.user.admin",
              "ts": 1672600095186
            Und zwar vom angemeckerten DP „PROCESS“
              heli-wolf @Codierknecht last edited by
              @codierknecht
                "_id": "hm-rpc.5.001518A9A59DBF.2",
                "type": "channel",
                "common": {
                  "name": "Funkgong_flachHmIP-MP3P 001518A9A59DBF:2"
                "native": {
                  "TYPE": "ACOUSTIC_SIGNAL_VIRTUAL_RECEIVER",
                  "SUBTYPE": "",
                  "ADDRESS": "001518A9A59DBF:2",
                  "RF_ADDRESS": 0,
                  "CHILDREN": [],
                  "PARENT": "001518A9A59DBF",
                  "PARENT_TYPE": "HmIP-MP3P",
                  "INDEX": 2,
                  "AES_ACTIVE": 1,
                  "PARAMSETS": [
                    "MASTER",
                    "VALUES",
                    "LINK",
                    "SERVICE"
                  "FIRMWARE": "",
                  "AVAILABLE_FIRMWARE": "",
                  "UPDATABLE": true,
                  "FIRMWARE_UPDATE_STATE": "",
                  "VERSION": 1,
                  "FLAGS": 1,
                  "LINK_SOURCE_ROLES": "",
                  "LINK_TARGET_ROLES": "REMOTE_CONTROL CONDITIONAL_SWITCH SWITCH LEVEL",
                  "DIRECTION": 2,
                  "GROUP": "",
                  "TEAM": "",
                  "TEAM_TAG": "",
                  "TEAM_CHANNELS": [],
                  "INTERFACE": "",
                  "ROAMING": 0,
                  "RX_MODE": 0
                "ts": 1670333539975,
                "acl": {
                  "object": 1636,
              Sorry, bin nicht sehr bewandert mit den Fehlerauswertungen !!
                Homoran Global Moderator Administrators @heli-wolf last edited by
                @heli-wolf ist das
                @codierknecht sagte in Homematic Funkgong HmIP-MP3P über Blockly steuern:
                • Glasfaser
                  Glasfaser @Homoran last edited by Glasfaser
                  hier sind gerade Bilderrätsel , das meint er
                  Aus dem Screenshot konnte er nicht zitieren
                    Homoran Global Moderator Administrators @Glasfaser last edited by Homoran
                    @glasfaser sagte in Homematic Funkgong HmIP-MP3P über Blockly steuern:
                    is mich klar
                    edit:
                    oops aber lange Leitung!
                    das ust ja die ID
                    aber das Ist ein CHANNEL. was meckert der mit value rum?
                      @heli-wolf versuchst du einen Kanal statt eines DPs anzusteuern?
                        ich habe genau die drei Bereiche im Skript angesprochen die bei der Direktauswahl sich geändert haben.
                        async function Funkgong_Waschmaschine() {
                          setState("hm-rpc.5.001518A9A59DBF.2.SOUNDFILE"/*Funkgong_flachHmIP-MP3P 001518A9A59DBF:2.SOUNDFILE*/, 11);
                          setState("hm-rpc.5.001518A9A59DBF.2.PROCESS"/*Funkgong_flachHmIP-MP3P 001518A9A59DBF:2.PROCESS*/, 1);
                          setState("hm-rpc.5.001518A9A59DBF.2.LEVEL"/*Funkgong_flachHmIP-MP3P 001518A9A59DBF:2.LEVEL*/, 80);
                          setState("hm-rpc.5.001518A9A59DBF.6.COLOR"/*Funkgong_flachHmIP-MP3P 001518A9A59DBF:6.COLOR*/, 2);
                          setState("hm-rpc.5.001518A9A59DBF.6.LEVEL"/*Funkgong_flachHmIP-MP3P 001518A9A59DBF:6.LEVEL*/, 50);
                          setStateDelayed("hm-rpc.5.001518A9A59DBF.6.LEVEL"/*Funkgong_flachHmIP-MP3P 001518A9A59DBF:6.LEVEL*/, 0, 10000, false);
                        was bewirkt ein CHANNEL im Unterschied zum DP?
                          der Channel ist die übergeordnete Struktur!
                          dann hast du doch die falschen Objektdaten gepostet?
                            das ist der Inhalt von "0"
                              "_id": "hm-rpc.5.001518A9A59DBF.0",
                              "type": "channel",
                              "common": {
                                "name": "Funkgong_flachHmIP-MP3P 001518A9A59DBF:0"
                              "native": {
                                "TYPE": "MAINTENANCE",
                                "SUBTYPE": "",
                                "ADDRESS": "001518A9A59DBF:0",
                                "RF_ADDRESS": 0,
                                "CHILDREN": [],
                                "INDEX": 0,
                                "AES_ACTIVE": 1,
                                "PARAMSETS": [
                                  "MASTER",
                                  "VALUES",
                                  "SERVICE"
                                "FIRMWARE": "",
                                "UPDATABLE": true,
                                "VERSION": 1,
                                "FLAGS": 1,
                                "LINK_TARGET_ROLES": "",
                                "DIRECTION": 0,
                                "GROUP": "",
                                "TEAM": "",
                                "TEAM_TAG": "",
                                "INTERFACE": "",
                                "ROAMING": 0,
                                "RX_MODE": 0
                              "ts": 1670333538742,
                              "acl": {
                                "object": 1636,
                            Inhalt von "1":
                              "_id": "hm-rpc.5.001518A9A59DBF.1",
                              "type": "channel",
                              "common": {
                                "name": "Funkgong_flachHmIP-MP3P 001518A9A59DBF:1"
                              "native": {
                                "TYPE": "ACOUSTIC_SIGNAL_TRANSMITTER",
                                "SUBTYPE": "",
                                "ADDRESS": "001518A9A59DBF:1",
                                "RF_ADDRESS": 0,
                                "CHILDREN": [],
                                "INDEX": 1,
                                "AES_ACTIVE": 1,
                                "PARAMSETS": [
                                  "MASTER",
                                  "VALUES",
                                  "SERVICE"
                                "FIRMWARE": "",
                                "UPDATABLE": true,
                                "VERSION": 1,
                                "FLAGS": 1,
                                "DIRECTION": 0,
                                "GROUP": "",
                                "TEAM": "",
                                "TEAM_TAG": "",
                                "INTERFACE": "",
                                "ROAMING": 0,
                                "RX_MODE": 0
                              "ts": 1670333539564,
                              "acl": {
                                "object": 1636,
                            Inhalt von "6" - für die Lichtsteuerung:
                              "_id": "hm-rpc.5.001518A9A59DBF.6",
                              "type": "channel",
                              "common": {
                                "name": "Funkgong_flachHmIP-MP3P 001518A9A59DBF:6"
                              "native": {
                                "TYPE": "DIMMER_VIRTUAL_RECEIVER",
                                "SUBTYPE": "",
                                "ADDRESS": "001518A9A59DBF:6",
                                "RF_ADDRESS": 0,
                                "CHILDREN": [],
                                "INDEX": 6,
                                "AES_ACTIVE": 1,
                                "PARAMSETS": [
                                  "MASTER",
                                  "VALUES",
                                  "LINK",
                                  "SERVICE"
                                "FIRMWARE": "",
                                "UPDATABLE": true,
                                "VERSION": 1,
                                "FLAGS": 1,
                                "DIRECTION": 2,
                                "GROUP": "",
                                "TEAM": "",
                                "TEAM_TAG": "",
                                "INTERFACE": "",
                                "ROAMING": 0,
                                "RX_MODE": 0
                              "ts": 1670333542999,
                              "acl": {
                                "object": 1636,
                              heli-wolf @heli-wolf last edited by
                              @heli-wolf
                              und das ist unter Device:
                                "_id": "hm-rpc.5.001518A9A59DBF",
                                "type": "device",
                                "common": {
                                  "name": "Funkgong_flachHmIP-MP3P 001518A9A59DBF",
                                  "icon": "/icons/186_hmip-mp3p_thumb.png"
                                "native": {
                                  "TYPE": "HmIP-MP3P",
                                  "SUBTYPE": "MP3P",
                                  "ADDRESS": "001518A9A59DBF",
                                  "RF_ADDRESS": 7137078,
                                  "CHILDREN": [
                                    "001518A9A59DBF:0",
                                    "001518A9A59DBF:1",
                                    "001518A9A59DBF:2",
                                    "001518A9A59DBF:3",
                                    "001518A9A59DBF:4",
                                    "001518A9A59DBF:5",
                                    "001518A9A59DBF:6",
                                    "001518A9A59DBF:7",
                                    "001518A9A59DBF:8",
                                    "001518A9A59DBF:9"
                                  "PARENT": "",
                                  "PARENT_TYPE": "",
                                  "INDEX": 0,
                                  "AES_ACTIVE": 1,
                                  "PARAMSETS": [
                                    "MASTER",
                                    "SERVICE"
                                  "FIRMWARE": "1.0.26",
                                  "AVAILABLE_FIRMWARE": "1.0.26",
                                  "UPDATABLE": true,
                                  "FIRMWARE_UPDATE_STATE": "UP_TO_DATE",
                                  "VERSION": 1,
                                  "FLAGS": 1,
                                  "DIRECTION": 0,
                                  "GROUP": "",
                                  "TEAM": "",
                                  "TEAM_TAG": "",
                                  "INTERFACE": "",
                                  "ROAMING": 0,
                                  "RX_MODE": 3
                                "ts": 1670178467503,
                                "acl": {
                                  "object": 1636,
                                @heli-wolf
                                Ich glaube jetzt habe ich verstanden was gemeint war.
                                Das Problem war beim Channel 2 unter PROCESS.
                                Das sind jetzt die Objektdaten von Process
                                  "type": "state",
                                  "common": {
                                    "name": "Funkgong_flachHmIP-MP3P 001518A9A59DBF:2.PROCESS",
                                    "role": "",
                                    "def": 0,
                                    "type": "number",
                                    "read": true,
                                    "write": false,
                                    "min": 0,
                                    "max": 1,
                                    "states": {
                                      "0": "STABLE",
                                      "1": "NOT_STABLE"
                                  "native": {
                                    "MIN": "STABLE",
                                    "OPERATIONS": 5,
                                    "MAX": "NOT_STABLE",
                                    "FLAGS": 1,
                                    "ID": "PROCESS",
                                    "TYPE": "ENUM",
                                    "DEFAULT": "STABLE",
                                    "VALUE_LIST": [
                                      "STABLE",
                                      "NOT_STABLE"
                                  "ts": 1670333540410,
                                  "_id": "hm-rpc.5.001518A9A59DBF.2.PROCESS",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                  jetzt
                                  ja! 👍
                                    Das war jetzt der Exkurs zu Objekten!
                                    jetzt bitte nochmal die Fehlermeldung provozieren und diese vollständig als Text in code-tags posten.
                                    Der Screenshot scheint zusätzlich noch abgeschnitten zu sein.
                                      hm-rpc.5
                                      	122096	2023-01-06 19:40:04.297	error	Cannot call setValue: XML-RPC fault: Invalid parameter or value
                                      hm-rpc.5
                                      	122096	2023-01-06 19:40:04.297	error	xmlrpc -> setValue ["001518A9A59DBF:2","PROCESS",1] ENUM
                                      javascript.0
                                      	101206	2023-01-06 19:40:02.762	warn	Read-only state "hm-rpc.5.001518A9A59DBF.2.PROCESS" has been written without ack-flag with value "1"
                                      hm-rpc.5
                                      	122096	2023-01-06 19:39:54.310	error	Cannot call setValue: XML-RPC fault: Invalid parameter or value
                                      hm-rpc.5
                                      	122096	2023-01-06 19:39:54.309	error	xmlrpc -> setValue ["001518A9A59DBF:2","PROCESS",1] ENUM
                                      javascript.0
                                      	101206	2023-01-06 19:39:52.726	warn	Read-only state "hm-rpc.5.001518A9A59DBF.2.PROCESS" has been written without ack-flag with value "1"
                                      javascript.0
                                      	101206	2023-01-06 19:39:45.933	info	script.js.common.Meine_Skripte.Waschmaschine_fertig: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      javascript.0
                                      	101206	2023-01-06 19:39:45.914	info	Start javascript script.js.common.Meine_Skripte.Waschmaschine_fertig
                                      hm-rpc.3
                                      	122119	2023-01-06 19:39:10.137	info	xmlrpc -> listDevices 0
                                        @heli-wolf und jetzt bitte mal die javascript Ansicht des Blocklys
                                          @heli-wolf wenn ich das richtig sehe ist process nicht zum beschreiben.
                                          deaktiviere den Block mal über die rechte Maustaste. und trigger neu.
                                            var timeout;
                                            // Beschreibe diese Funktion …
                                            on({id: "shelly.0.SHPLG-S#4022D8898398#1.Relay0.Switch"/*Switch*/, change: "ne"}, async function (obj) {
                                              var value = obj.state.val;
                                              await Funkgong_Waschmaschine();
                                              timeout = setTimeout(async function () {
                                              }, 10000);
                                            2337
