    4. jarvis v3.1.x - just another remarkable vis
      MCU @Michael Sauer last edited by
      @michael-sauer Dann bitte die Einstellungen von allen Rollläden die zugeordnet sind. Den Level DP.
      Und das Layout der zugehörigen Statelist.
      Michael Sauer 1 Reply Last reply Reply Quote 0
      • Michael Sauer
        Michael Sauer @MCU last edited by
        @mcu
        "esszimmershutterleft_79374": {
            "name": "Esszimmer Shutter left",
            "icon": "",
            "label": "",
            "function": "blind",
            "states": {
              "Position": {
                "state": "linkeddevices.0.Esszimmer.Shutter.left.Position",
                "actionElement": "BlindLevelAction",
                "action": "linkeddevices.0.Esszimmer.Shutter.left.Position",
                "stateKey": "Position",
                "properties": "",
                "_updated": 1672599562801
              "online": {
                "state": "linkeddevices.0.Esszimmer.Shutter.left.online",
                "stateKey": "online",
                "icon": {
                  "0": "mdi:window-shutter",
                  ">0": "mdi:window-shutter-open"
                "_updated": 1672085540849,
                "display": {
                  "true": "online",
                  "false": "offline"
            "options": {
              "suppressPopup": true
            "id": "esszimmershutterleft_79374",
            "attributes": {
              "_created": 1671996045683,
              "imported": true,
              "manufacturer": {
                "name": "Linked Devices",
                "namespace": "linkeddevices"
              "_updated": 1672599511749
            "revision": "d91e2"
          "esszimmershutterright_4599b": {
            "name": "Esszimmer Shutter right",
            "icon": "",
            "label": "",
            "states": {
              "Position": {
                "state": "linkeddevices.0.Esszimmer.Shutter.right.Position",
                "action": "linkeddevices.0.Esszimmer.Shutter.right.Position",
                "display": "",
                "_updated": 1672599570729
              "online": {
                "state": "linkeddevices.0.Esszimmer.Shutter.right.online",
                "icon": {
                "_updated": 1672085551583,
                "display": {
                  "true": "online",
                  "false": "offline"
            "options": {
            "id": "esszimmershutterright_4599b",
            "attributes": {
              "imported": true,
              "manufacturer": {
              "_updated": 1672599566557
            "revision": "1c7ca"
        "5f4d97c7-5815-4057-8953-9ffddaf61926": {
            "id": "5f4d97c7-5815-4057-8953-9ffddaf61926",
            "config": {
              "dense": false,
              "horizontal": false,
              "stacked": false
            "_created": 1671888786057,
            "title": "Rollladen Esszimmer",
            "label": "Esszimmer",
            "module": "StateList",
            "items": [
                "type": "group",
                "name": "alle",
                "id": "38e4639c-575b-4102-a122-60448d3f9d8a",
                "isInGroup": true,
                "actions": true,
                "groupElement": "ButtonGroupAction"
                "type": "device",
                "deviceId": "esszimmershutterleft_79374",
                "id": "47be2acb-082d-407e-a6b2-80f65ecca689",
                "primaryStateKey": "Position",
                "bodyStateKey": "Position",
                "isInGroup": true,
                "bodyElement": "LevelBody",
                "showState": false,
                "label": "links",
                "secondaryStatesKeys": [],
                "LevelBodyConfig": {
                  "Position": {
                    "showMarkersSteps": false,
                    "step": "10",
                    "thumbSize": "30"
                "BlindLevelActionConfig": {
                  "Position": {
                    "val": "val"
                "type": "device",
                "deviceId": "esszimmershutterright_4599b",
                "id": "384962ca-0d3b-46e4-8049-47674db0a39d",
                "isInGroup": true,
                "showState": false,
                "label": "rechts",
                  "Position": {
                    "step": "10",
                    "thumbSize": "30"
                  "Position": {
                    "val": "val"
            "revision": "82aab",
            "_updated": 1672952769383,
            "_copied": 1671996384307
        Danke,
          MCU last edited by MCU
          @michael-sauer Bitte als Bild. Hast du eigene DPs angelegt oder die Standard-DPs für Blinds genutzt?
          sieht nach eigenen DPs aus. Das funktioniert nicht.
          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/gewerk/rolllaeden-blind-v3
          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/actionelement/blindlevelaction#mehrere-rolllaeden-blinds-gleichzeitig-steuern
            @dering
            Dann bitte hier weiter.
            Es gibt keine Empfehlung.
            Wenn du schon eine JSON-Tabelle hast, kannst du den DP auch mit dem jsonTable-Module nutzen.
            • Michael Sauer
              Michael Sauer @MCU last edited by Michael Sauer
              Habe den Datenpunkt umbenannt in "level". Jetzt geht es. Danke.
              • Michael Sauer
                Gibt es eine Möglichkeit aus einem iob Objekt welches einen Json String enthält diesen direkt einzulesen?
                Dominik F. M 2 Replies Last reply Reply Quote 0
                  dering last edited by
                  Ich komme leider nicht auf eine Lösung.
                  Ich habe Homematic Geräte und Shelly Geräte usw. Die möchte ich alle in einer StateList haben um darüber zu filtern/sortieren.
                  Wie krieg ich alle Geräte in die StateList ohne sie einzeln auswählen zu müssen?
                  Die nächste Herausforderung wäre dann, werden Geräte, die später hinzugefügt werden, dann auch auto. der StateList hinzugefügt?
                  • Dominik F.
                    Dominik F. @Michael Sauer last edited by Dominik F.
                    @michael-sauer
                    Du kannst dir die Vis von Pittini noch nicht in Jarvis nachbauen. Ich habs auch schon versucht 😄
                    Du kannst dir allerdings die Vis als Iframe anzeigen lassen und damit dann auch steuern.
                    Edit:
                    ich habe dazu ein Issue angelegt, wäre super wenn du dafür stimmst. Das erhöht die Chance das es umgesetzt wird
                    https://github.com/Zefau/ioBroker.jarvis/issues/2148
                    TheBermud created this issue in Zefau/ioBroker.jarvis
                    open String schalten/verändern #2148
                      MCU @Michael Sauer last edited by MCU
                      @michael-sauer War noch im falschen Thema.
                      JSON-String Objekt kann man nur anzeigen.
                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/datenpunkt-eigenschaft/json-parse
                      Dominik F. 1 Reply Last reply Reply Quote 0
                        MCU @dering last edited by MCU
                        @dering Da gibt es keine Automatik.
                        Ich hab einen Feature Request für Selektor angelegt. -> hochvoten, damit es schneller realisiert wird!
                        https://github.com/Zefau/ioBroker.jarvis/issues/2145
                        mcuiobroker created this issue in Zefau/ioBroker.jarvis
                        open Selektor bzw. mehrere Selektoren als Grundlage für die StateList #2145
                        • Dominik F.
                          Dominik F. @MCU last edited by Dominik F.
                          @mcu sagte in jarvis v3.1.0-beta - just another remarkable vis:
                          @michael-sauer Das Gerät komplett neu machen mit den Standard DPs..
                          Ist das mittlerweile Möglich bzw. hat sich da was in Jarvis geändert?
                          Edit:
                          Oder war dein Post auf einen früheren Post bezogen wo es nicht um die Strings ging?
                          M Michael Sauer 2 Replies Last reply Reply Quote 0
                            MCU @Dominik F. last edited by MCU
                            @dominik-f Ja. Objekt aus JSON-String kann man darstellen, aber nicht verändern oder schalten.
                            • Dominik F.
                              @mcu
                              Schade. Vielleicht kommt es ja irgendwann mal 🙂
                                @dominik-f Schau mal, ob es ein Issue (github) gibt, sonst leg eins an?
                                  @dominik-f Was ist da jetzt das Besondere? Ich hab es gerade nicht verstanden. Dort wählst du aus einer Liste einen String aus und der wird in die ID gesetzt? Das macht doch jetzt schon die normale DropDownListe.
                                  Oder meinst du, dass die DropdownListe automatisch aus dem DP erstellt werden soll?
                                  Dominik F. Michael Sauer 2 Replies Last reply Reply Quote 0
                                  • Michael Sauer
                                    Michael Sauer @Dominik F. last edited by
                                    @dominik-f War auf ein Gruppen Problem mit Rollladen bezogen.
                                    • Dominik F.
                                      @mcu
                                      Ja genau, die DropdownListe soll automatisch erstellt werden. Welche Werte angezeigt werden sollen, kann im Adapter angepasst und verändert werden.
                                      • Dominik F.
                                        @michael-sauer
                                        Achso, hatte nur in deinem Screenshot was von Dropdown und Heatingcontrol gelesen und dachte daher das du was ähnliches meinst.
                                          @dominik-f Dann schreib es bitte in den Issue dazu.
                                          • Michael Sauer
                                            @mcu Das man diese Liste dynamisch erstellen kann. Hatte mir bereits ein Helfer Script gebaut um die Datenpunkte von der VIS von Pittini als Json neu zu erstellen. Der Rest wären auch nur Datenpunkte zum Editieren.
                                            let userdata = "0_userdata.0.JARVIS.",
                                                ObjectArray_Heatingcontrol = [
                                                        "JarvisDatenpunkt":{id:'UsedRooms', initial: 0, forceCreation: false, common: { read: true, write: true, name: "Raeume Json", type: "mixed", def: 0 }},
                                                        "HeatingcontrolDatenpunkt":"heatingcontrol.0.info.UsedRooms"
                                                        "JarvisDatenpunkt":{id:'OverrideTempValueListText', initial: 0, forceCreation: false, common: { read: true, write: true, name: "OverrideTemp", type: "mixed", def: 0 }},
                                                        "HeatingcontrolDatenpunkt":"heatingcontrol.0.vis.OverrideTempValueListText"
                                            CreateJarvisJson_Heatingcontroller();
                                            function CreateJarvisJson_Heatingcontroller(){
                                                ObjectArray_Heatingcontrol.forEach(function(Datenpunkt){
                                            // console.log(Datenpunkt.JarvisDatenpunkt);
                                                    CreateDPObject(Datenpunkt.JarvisDatenpunkt,async function(){
                                                        let temp_Array = {};
                                                        getState(Datenpunkt.HeatingcontrolDatenpunkt).val.split(/;/).forEach(function(dat){
                                                            temp_Array[dat] = dat;
                                                        setState(
                                                            userdata+Datenpunkt.JarvisDatenpunkt.id,
                                                            JSON.stringify(temp_Array),
                                                            true
                                            function CreateDPObject(DP_state,init){
                                                createState(userdata+DP_state.id, DP_state.initial, DP_state.forceCreation, DP_state.common, function () {
                                                        console.log('Datenpunkte sind angelegt');
                                                        init();
                                            Ist natütlich weit aufwendiger und nicht so dynamisch wenn ich jede Dropdownliste manuell mit den Werten erstellen muss.
                                            92
                                            1847
                                            712728
