    4. Welche HW, der PI4 scheint zu langsam
      manu4771 @manu4771 last edited by
      Hi, wie stelle ich das an?
        Thomas Braun Most Active @manu4771 last edited by
        @manu4771
        iob diag
        eingeben?
        Wenn das nicht funktioniert:
        iob stop
        iob fix
        iob start
        iob diag
          Homoran Global Moderator Administrators @manu4771 last edited by
          @manu4771 sagte in Welche HW, der PI4 scheint zu langsam:
          Intel Celeron 847
          Passmark von 487!
          vergiss es! mit Faktorv5 könnte man drüber reden
            manu4771 @Thomas Braun last edited by manu4771
            da schua an, nach dem fix hat es funktionert.
            reicht dir die Zusammenfassung?
            v.2022-12-31
            Operatingsystem: Raspbian GNU/Linux 10 (buster)
            Installation: Native
            Timezone: Europe/Berlin
            User-ID: 1000
            X-Server: true
            Boot Target: graphical.target
            Pending OS-Updates: 0
            Nodejs-Installation: /usr/bin/nodejs v14.21.1
            /usr/bin/node v14.21.1
            /usr/bin/npm 6.14.17
            ioBroker Core: js-controller 4.0.23
            admin 6.2.23
            ioBroker Status: iobroker is running on this host.
            Objects type: jsonl
            States type: jsonl
            Status admin:
            • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            Pending iob updates: 18
            Active repo(s): stable
            Objects: 18240
            States: 15338
            Size of iob-Database:
            18M /opt/iobroker/iobroker-data/objects.jsonl
            4.6M /opt/iobroker/iobroker-data/states.jsonl
            Bin selbst drauf gekommen, NEIN!
            Skript v.2022-12-31
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Architecture:   armv7l
            Docker:         false
            Virtualization: none
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 10 (buster)
            Release:        10
            Codename:       buster
            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="10"
            VERSION="10 (buster)"
            VERSION_CODENAME=buster
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            Systemuptime and Load:
             20:46:10 up 2 days, 18:32,  2 users,  load average: 1.71, 1.83, 1.21
            CPU threads: 4
            *** Time and Time Zones ***
            Fri Jan  6 19:46:10 UTC 2023
            Fri Jan  6 20:46:10 CET 2023
            CET +0100
            Europe/Berlin
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           3.8G        1.4G        1.0G        220M        1.4G        2.4G
            Swap:           99M          0B         99M
            Total:         3.9G        1.4G        1.1G
                     3838 M total memory
                     1399 M used memory
                      607 M active memory
                     1986 M inactive memory
                     1023 M free memory
                      202 M buffer memory
                     1213 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            /dev/root      ext4       59G  6.5G   50G  12% /
            devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
            tmpfs          tmpfs     1.9G  5.0M  1.9G   1% /dev/shm
            tmpfs          tmpfs     1.9G  177M  1.8G  10% /run
            tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
            /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
            tmpfs          tmpfs     384M  8.0K  384M   1% /run/user/1000
            Show mounted filesystems (real ones only):
            TARGET                SOURCE         FSTYPE          OPTIONS
            /                     /dev/mmcblk0p2 ext4            rw,noatime,commit=600
            |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
            |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
            `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            858M    /var/
            506M    /var/cache
            494M    /var/cache/apt
            434M    /var/cache/apt/archives
            126M    /var/lib
            /opt/iobroker/backups:
            205M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            423M    /opt/iobroker/iobroker-data/
            339M    /opt/iobroker/iobroker-data/files
            78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
            59M     /opt/iobroker/iobroker-data/backup-objects
            48M     /opt/iobroker/iobroker-data/files/javascript.admin
            21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.00a59c14.chunk.js.map
            20M     /opt/iobroker/iobroker-data/objects.jsonl
            12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
            *** NodeJS-Installation ***
            nodejs:
              Installed: 14.21.1-deb-1nodesource1
              Candidate: 14.21.1-deb-1nodesource1
              Version table:
             *** 14.21.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u2 500
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  4.0.23
            admin:          6.2.23
            javascript:     6.0.3
            Adapters from github:   8
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
            + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
              system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
              system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
            + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
              system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
              system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
            + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
            + system.adapter.history.0                : history               : raspberrypi                              -  enabled
            + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
              system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
              system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
              system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
              system.adapter.ical.3                   : ical                  : raspberrypi                              -  enabled
              system.adapter.ical.4                   : ical                  : raspberrypi                              -  enabled
              system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
            + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
              system.adapter.kodi.0                   : kodi                  : raspberrypi                              - disabled, port: 9090
            + system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi                              -  enabled
              system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
            + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
              system.adapter.mihome-lamp.1            : mihome-lamp           : raspberrypi                              - disabled, port: 54321
              system.adapter.mobile-alerts.0          : mobile-alerts         : raspberrypi                              -  enabled
            + system.adapter.pi-hole.0                : pi-hole               : raspberrypi                              -  enabled
              system.adapter.rickshaw.0               : rickshaw              : raspberrypi                              -  enabled
              system.adapter.roomba.0                 : roomba                : raspberrypi                              - disabled
              system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
              system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
              system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 192.168.2.2
            + system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
              system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
            + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
              system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
              system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
              system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
              system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
              system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
              system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
              system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
              system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.2.2, run as: admin
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
              system.adapter.windows-control.0        : windows-control       : raspberrypi                              - disabled
            + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
              system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi                              - disabled
              system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled
            + instance is alive
            ioBroker-Repositories
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.3.5    , installed 6.2.23 [Updatable]
            Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
            Adapter    "backitup"     : 2.5.9    , installed 2.4.12 [Updatable]
            Adapter    "bring"        : 1.8.1    , installed 1.8.1
            Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
            Adapter    "deconz"       : 1.3.21   , installed 1.3.21
            Adapter    "devices"      : 1.1.2    , installed 1.0.12 [Updatable]
            Adapter    "discovery"    : 3.1.0    , installed 3.0.5  [Updatable]
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "fb-checkpresence": 1.1.20, installed 1.1.19 [Updatable]
            Adapter    "flot"         : 1.11.0   , installed 1.11.0
            Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
            Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
            Adapter    "homekit-controller": 0.5.1, installed 0.5.1
            Adapter    "hue"          : 3.7.1    , installed 3.7.1
            Adapter    "ical"         : 1.13.2   , installed 1.13.1 [Updatable]
            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "iot"          : 1.11.9   , installed 1.11.9
            Adapter    "javascript"   : 6.1.4    , installed 6.0.3  [Updatable]
            Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
            Adapter    "kodi"         : 2.0.8    , installed 2.0.8
            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
            Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
            Adapter    "meross"       : 1.14.0   , installed 1.14.0
            Adapter    "mihome-lamp"  : 1.1.0    , installed 1.1.0
            Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
            Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
            Adapter    "roomba"       : 1.1.4    , installed 1.1.4
            Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
            Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
            Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
            Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
            Adapter    "tankerkoenig" : 3.1.0    , installed 2.1.1  [Updatable]
            Adapter    "tr-064"       : 4.2.17   , installed 4.2.16 [Updatable]
            Adapter    "tuya"         : 3.12.1   , installed 3.8.1  [Updatable]
            Adapter    "vis"          : 1.4.15   , installed 1.4.15
            Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
            Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.3  [Updatable]
            Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
            Adapter    "vis-icontwo"  : 0.90.0   , installed 0.89.0 [Updatable]
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
            Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
            Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.5  [Updatable]
            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
            Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.2  [Updatable]
            Adapter    "windows-control": 0.1.5  , installed 0.1.5
            Adapter    "yahka"        : 0.13.1   , installed 0.13.1
            Adapter    "yeelight-2"   : 1.1.2    , installed 1.1.2
            Adapter    "zigbee"       : 1.8.10   , installed 1.7.5  [Updatable]
            Objects and States
            Objects:        18227
            States:         15325
            Hit:1 http://phoscon.de/apt/deconz buster InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:3 http://archive.raspberrypi.org/debian buster InRelease
            Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       27036      1775/deCONZ
            tcp        0      0 192.168.2.2:8082        0.0.0.0:*               LISTEN      1001       10738821   17212/io.web.0
            tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          17191      564/dnsmasq
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17241      558/sshd
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7392835    3926/cupsd
            tcp        0      0 0.0.0.0:8088            0.0.0.0:*               LISTEN      1000       27191      1775/deCONZ
            tcp        0      0 192.168.2.2:1883        0.0.0.0:*               LISTEN      1001       10726888   15105/io.sonoff.0
            tcp        0      0 127.0.0.1:33345         0.0.0.0:*               LISTEN      1001       10738142   17408/io.yahka.0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10723191   14262/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10723184   14262/iobroker.js-c
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10723285   14341/io.admin.0
            tcp6       0      0 :::53                   :::*                    LISTEN      0          17193      564/dnsmasq
            tcp6       0      0 :::22                   :::*                    LISTEN      0          17251      558/sshd
            tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18655      546/xrdp-sesman
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7392834    3926/cupsd
            tcp6       0      0 :::3389                 :::*                    LISTEN      115        18283      581/xrdp
            tcp6       0      0 :::33605                :::*                    LISTEN      1001       10738049   17408/io.yahka.0
            tcp6       0      0 :::61991                :::*                    LISTEN      1001       10731009   15750/io.harmony.0
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       10731010   15750/io.harmony.0
            udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          17190      564/dnsmasq
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          20547      455/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          7392854    3927/cups-browsed
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10738050   17408/io.yahka.0
            udp        0      0 192.168.2.240:5353      0.0.0.0:*                           1001       10725358   15215/io.tr-064.0
            udp        0      0 192.168.2.2:5353        0.0.0.0:*                           1001       10725357   15215/io.tr-064.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14998      363/avahi-daemon: r
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10728750   15591/io.deconz.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10728747   15591/io.deconz.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       27202      1775/deCONZ
            udp        0      0 0.0.0.0:34690           0.0.0.0:*                           108        15000      363/avahi-daemon: r
            udp6       0      0 :::45582                :::*                                108        15001      363/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          20927      455/dhcpcd
            udp6       0      0 :::53                   :::*                                0          17192      564/dnsmasq
            udp6       0      0 :::5353                 :::*                                108        14999      363/avahi-daemon: r
            udp6       0      0 :::1900                 :::*                                1001       10728752   15591/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1001       10728751   15591/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1001       10728749   15591/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1001       10728748   15591/io.deconz.0
            2023-01-06 20:47:06.126  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:06.127  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:06.128  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:06.129  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:06.130  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:06.131  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:13.004  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:13.006  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:13.007  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:13.008  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:13.009  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:13.010  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:13.011  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:13.012  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:16.114  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:16.115  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:16.116  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:16.117  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:16.118  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:16.119  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:16.120  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:16.122  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            2023-01-06 20:47:16.123  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
            Da piHole aktuell nicht läuft habe ich die Instanz mal gleich gestoppt. 😃
            Thomas Braun sprobst 2 Replies Last reply Reply Quote 0
              manu4771 @Homoran last edited by
              Das hilft schon weiter.
              Für was könnte ich die Mühle dann noch verwenden? Nur für DeConz und pi-hole frisst der NUC ja zu viel Strom im Vergleich zum PI.
                @manu4771
                Das reicht zumindest um zu sehen, dass du da auf einem toten System mit graphischer Oberfläche, alter nodejs-Version und 18 verpennten iob-Updates unterwegs bist.
                Da könntest du mit Sicherheit noch einiges herauskitzeln. Alleine der X-Server bringt schon einiges an unnötigem Ballast mit.
                  Die graphische Oberfläche war tatsächlich gewollt, da ich DeConz gerne in der GUI bediene.
                  Soll jetzt keine Ausrede sein, die Adapater könnten sich aber gerne automatisch installieren. Wenn das System nur laufen soll will ich mich nicht ständig damit beschäfftigen MÜSSEN.
                  Ist das Linux wirklich schon out-dated und bekomme es nicht mehr hochgezogen ohne neuinstallation?
                    Ja. Buster ist im September 2022 dahingeschieden. Nach den bei Debian üblichen 3 Jahren mit einem Jahr Parallelbetrieb zur aktuellen Stable 'Bullseye'. Das kommt nicht überraschend oder unangekündigt.
                    Hoch ziehen kannst du das (zumindest versuchen). Hatte mal ein HowTo dazu geschrieben.
                      Bloß keine Auto-Updates. Das will keiner.
                        So dann mal Butter bei die Fische, was machen wir?
                        Hilft es den den PI von DeConz zu befreien oder ist der Load minimal?
                        Dann könnte ich auch auf die grafische Oberfläche verzichten.
                        Aber wohin damit?
                        Bei der Übung wäre dann natürlich eine saubere Neuinstallation kein Problem.
                        Kommen wir aber nochmal zur Eingangsfrage.
                        Wenn ich wirklich Spaß mit dem ioBroker haben will, was kaufe ich mir dann als kleinen Home Server ohne gleich ein Rack zu brauchen?
                        Hier fristet auch noch ein QNAP TS-853A-4G 8 Bay Desktop NAS Gehäuse mit 4GB RAM ein trostloses dasein, da der Streamingmarkt die Nutzung obsolot gemacht hat.
                        Ist mittlerweile aber auch schon wieder 5 Jahre alt das gute Ding.
                        Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                          Aber wohin damit?
                          Bring den doch über den zigbee-Adapter in den ioBroker. Dann sparste dir den deCONZ-Kram auch schon ein. Zusammen mit dem Desktop dann halt.
                            Mir reicht hier ein RPi4 mit 8 GB RAM vollkommen aus. Ist halt bei jedem verschieden, was da alles drüber laufen soll.
                              warte, ich brauche die in meinen Augen bescheide DeConz SW nicht zwingend? Der Zigbee Adapter arbeitet genau so mit dem Conbee II?
                                Mittlerweile ja.
                                  das nicht, aber auch noch lange nicht kritisch.
                                  Aber wohin damit?
                                  in den Orcus, über den Jordan, egal!
                                  QNAP TS-853A-4G
                                  schon besser, über 1000 bei passmark, aber noch lange nicht gut.
                                  Auch nur 4GB RAM und damit soll noch einiges anderes laufen.
                                  ein 8Bay frisst aber gut Strom!
                                  bleib beim Raspi würde ich sagen
                                    Gut, danke jungs. Dann machen wir mal die Tage ne sauber neuinstallation und verzichten auf DeConz, ich erhoffe mir da auch weitere vorteile bzw. eine bessere implemntierung in ioBroker, manche Datenpunkte von DeConz sind schon... naja. Performanter wirds dann ja auch sein. Ich bin gespannt =)=)
                                      Natürlich stellt sich mir auch die Frage ob meine gefühlten Verzögerungen überhautp auf die HW zurückzuführen sind
                                      eher nicht! zumindest nicht serverseitig
                                      • sprobst
                                        sprobst @manu4771 last edited by
                                        @manu4771 ok, also am Speicher oder CPU liegt das sicher nicht. Die Distribution ist alt aber ok. Ob X-Server ja oder nein, ist bei 1GB freiem Speicher auch egal. Kannst Du mal schauen wie sich io-wait im Kommando "top" in so einer "langsam Phase" verhält? Ich tippe mal mehr auf langsamen IO auf USB-Stick oder SD-Card. (Dann geht auch der "CPU-Load" hoch, weil der gibt ja nur an dass ein Prozess wartet, was nicht notwendigerweise CPU sein muss, sondern auch IO sein kann). Lösung könnte eine USB-SSD o.Ä. sein (da sollte man jedenfalls alle iobroker relevanten Verz. drauf legen).
                                        Thomas Braun 1 Reply Last reply Reply Quote -1
                                          Thomas Braun Most Active @sprobst last edited by Thomas Braun
                                          @sprobst
                                          Auf einem Server läuft kein X.
                                          Grundsätzlich nicht.
                                          1069
