    3. Einsteigerfragen
    4. Homematic Adapter findet Geräte nicht
      paul53 @j h last edited by
      @j-h sagte: XML-Api Addon installiert
      Das ist unnötig.
      • j h
        j h @Codierknecht last edited by
        @codierknecht
        Ich hab den Port jetzt mal noch hier hinzugefügt, aber zuvor war die Einstellung ja auch bereits auf "Ports offen"
        @Homoran
        Hier ein kleiner Auszug aus dem DebugLog nach einem Neustart
        hm-rpc.0
        2023-01-08 13:46:47.734	debug	PING ok
        hm-rpc.0
        2023-01-08 13:46:47.724	debug	Send PING...
        hm-rpc.0
        2023-01-08 13:46:47.723	debug	[KEEPALIVE] Check if connection is alive
        hm-rpc.0
        2023-01-08 13:45:17.721	debug	start ping interval
        hm-rpc.0
        2023-01-08 13:45:17.721	debug	clear connecting interval
        hm-rpc.0
        2023-01-08 13:45:17.720	info	Connected
        hm-rpc.0
        2023-01-08 13:45:17.707	debug	start connecting interval
        hm-rpc.0
        2023-01-08 13:45:17.703	debug	xmlrpc -> 192.168.178.80:2010/ init ["http://http://192.168.178.45/:2010","IoBro:hm-rpc.0:17d68861e7654575c20ac2bc23ea3834"]
        hm-rpc.0
        2023-01-08 13:45:17.703	debug	Connect...
        hm-rpc.0
        2023-01-08 13:45:17.702	info	xmlrpc client is trying to connect to 192.168.178.80:2010/ with ["http://http://192.168.178.45/:2010","IoBro:hm-rpc.0:17d68861e7654575c20ac2bc23ea3834"]
        hm-rpc.0
        2023-01-08 13:45:17.701	info	xmlrpc server is trying to listen on 192.168.178.45:2010
        hm-rpc.0
        2023-01-08 13:45:17.622	info	starting. Version 1.15.16 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.19.0, js-controller: 4.0.24
        hm-rpc.0
        2023-01-08 13:45:17.497	debug	Plugin sentry Initialize Plugin (enabled=true)
        hm-rpc.0
        2023-01-08 13:45:17.441	debug	States connected to redis: 0.0.0.0:9000
        hm-rpc.0
        2023-01-08 13:45:17.395	debug	States create User PubSub Client
        hm-rpc.0
        2023-01-08 13:45:17.394	debug	States create System PubSub Client
        hm-rpc.0
        2023-01-08 13:45:17.389	debug	Redis States: Use Redis connection: 0.0.0.0:9000
        hm-rpc.0
        2023-01-08 13:45:17.382	debug	Objects connected to redis: 0.0.0.0:9001
        hm-rpc.0
        2023-01-08 13:45:17.379	debug	Objects client initialize lua scripts
        hm-rpc.0
        2023-01-08 13:45:17.368	debug	Objects create User PubSub Client
        hm-rpc.0
        2023-01-08 13:45:17.368	debug	Objects create System PubSub Client
        hm-rpc.0
        2023-01-08 13:45:17.367	debug	Objects client ready ... initialize now
        hm-rpc.0
        2023-01-08 13:45:17.344	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
        hm-rpc.0
        2023-01-08 13:45:06.588	info	Terminated (NO_ERROR): Without reason
        hm-rpc.0
        2023-01-08 13:45:06.587	info	terminating
        hm-rpc.0
        2023-01-08 13:45:06.583	info	Disconnected
        hm-rpc.0
        2023-01-08 13:45:06.565	info	xmlrpc -> 192.168.178.80:2010/ init ["http://http://192.168.178.45/:2010",""]
        hm-rpc.0
        2023-01-08 13:44:36.563	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
        hm-rpc.0
        2023-01-08 13:27:06.526	info	Connected
        Ich sehe gerade das dort 2 mal "http" bei der URL drin steht (und ein Slash vor dem Port). Bei der Konfiguration der Homematic Adresse habe ich das aber nicht mit angegeben ?!
        Das dachte ich mir, wollte es aber versuchen.
          Homoran Global Moderator Administrators @j h last edited by
          @j-h sagte in Homematic Adapter findet Geräte nicht:
          ich auch!
          starte mal den iobroker neu (und die ccu)
            paul53 @j h last edited by paul53
            @j-h sagte in: Bei der Konfiguration der Homematic Adresse habe ich das aber nicht mit angegeben ?!
            Callback-Adresse im Tab "ZUSÄTZLICHE EINSTELLUNGEN"?
            Da sich ioBroker und RM im gleichen Subnetz befinden, kann man die Callback-Adresse leer lassen.
            j h 1 Reply Last reply Reply Quote 0
            • j h
              j h @paul53 last edited by
              Stimmt, die hatte ich noch drin stehen.
              War auch nur ein Test den ich in meiner Verzweiflung mal ausprobiert hatte.
              Hab sie nun wieder gelöscht. Der Log sieht jetzt wie folgt aus:
              hm-rpc.0
              2023-01-08 14:14:20.315	debug	start ping interval
              hm-rpc.0
              2023-01-08 14:14:20.315	debug	clear connecting interval
              hm-rpc.0
              2023-01-08 14:14:20.314	info	Connected
              hm-rpc.0
              2023-01-08 14:14:20.304	debug	start connecting interval
              hm-rpc.0
              2023-01-08 14:14:20.300	debug	xmlrpc -> 192.168.178.80:2010/ init ["http://192.168.178.45:2010","IoBro:hm-rpc.0:dec1e05b2fe448c084e64f17678317e4"]
              hm-rpc.0
              2023-01-08 14:14:20.300	debug	Connect...
              hm-rpc.0
              2023-01-08 14:14:20.299	info	xmlrpc client is trying to connect to 192.168.178.80:2010/ with ["http://192.168.178.45:2010","IoBro:hm-rpc.0:dec1e05b2fe448c084e64f17678317e4"]
              hm-rpc.0
              2023-01-08 14:14:20.299	info	xmlrpc server is trying to listen on 192.168.178.45:2010
              hm-rpc.0
              2023-01-08 14:14:20.222	info	starting. Version 1.15.16 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.19.0, js-controller: 4.0.24
              hm-rpc.0
              2023-01-08 14:14:20.105	debug	Plugin sentry Initialize Plugin (enabled=true)
              hm-rpc.0
              2023-01-08 14:14:20.077	debug	States connected to redis: 0.0.0.0:9000
              hm-rpc.0
              2023-01-08 14:14:20.027	debug	States create User PubSub Client
              hm-rpc.0
              2023-01-08 14:14:20.026	debug	States create System PubSub Client
              hm-rpc.0
              2023-01-08 14:14:20.019	debug	Redis States: Use Redis connection: 0.0.0.0:9000
              hm-rpc.0
              2023-01-08 14:14:20.008	debug	Objects connected to redis: 0.0.0.0:9001
              hm-rpc.0
              2023-01-08 14:14:20.005	debug	Objects client initialize lua scripts
              hm-rpc.0
              2023-01-08 14:14:19.992	debug	Objects create User PubSub Client
              hm-rpc.0
              2023-01-08 14:14:19.991	debug	Objects create System PubSub Client
              hm-rpc.0
              2023-01-08 14:14:19.986	debug	Objects client ready ... initialize now
              hm-rpc.0
              2023-01-08 14:14:19.963	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
              hm-rpc.0
              2023-01-08 14:14:16.091	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              hm-rpc.0
              2023-01-08 14:14:16.091	debug	Plugin sentry destroyed
              hm-rpc.0
              2023-01-08 14:14:16.090	info	terminating
              hm-rpc.0
              2023-01-08 14:14:16.090	info	Disconnected
              hm-rpc.0
              2023-01-08 14:14:16.082	info	xmlrpc -> 192.168.178.80:2010/ init ["http://http://192.168.178.45/:2010",""]
              hm-rpc.0
              2023-01-08 14:14:16.081	info	Got terminate signal TERMINATE_YOURSELF
              hm-rpc.0
              2023-01-08 14:13:17.799	debug	start ping interval
              hm-rpc.0
              2023-01-08 14:13:17.798	debug	clear connecting interval
              hm-rpc.0
              2023-01-08 14:13:17.792	debug	xmlrpc -> 192.168.178.80:2010/ init ["http://http://192.168.178.45/:2010","IoBro:hm-rpc.0:17d68861e7654575c20ac2bc23ea3834"]
              hm-rpc.0
              2023-01-08 14:12:47.792	debug	start connecting interval
              @Homoran
              Neustarts hatte ich schon mehrfach ausgeführt
                ist jetzt alles da?
                und der Haken bei neu einlesen wieder weg?
                • j h
                  j h @Homoran last edited by
                  Nein, weder sind die Geräte in den Objekten, noch ist der Haken in der Config weg gegangen
                    @j-h .80 ist die CCU und .45 der ioBroker?
                    was mich allerdings irritiert ist
                    • j h
                      j h last edited by
                      @homoran said in Homematic Adapter findet Geräte nicht:
                      Korrekt
                      "IoBro" ist der Host name. Oder was verwirrt dich dort?
                        ist das dahinter die IPv6 Adresse?
                        wenn ja, wo kommt die her?
                        • j h
                          Puhhh eigentlich hab ich da nichts eingestellt. Habe lediglich in der fritzbox eine statische ip vergeben (die 45)
                            @j-h alles gut!
                            hab gerade bei mir getestet, sieht genauso aus.
                            • j h
                              Mehr oder weniger gut 😅
                              Ich bin ratlos 🙈
                                Ich bin ratlos
                                da sind wir ja schon 2!
                                ich würde jetzt einmal die Instanz löschen und neu anlegen.
                                hab keine Ahnung was da faul ist. Außer an der RM wurde wieder etwas geändert.
                                • j h
                                  Auch den Adapter habe ich bereits neu installiert. Die RM VM hatte ich auch bereits mal neu installiert.
                                  Evtl könnte ich dabei mal eine ältere Version auswählen
                                    Die RM VM
                                    ach VM! Wirklich kein Container?
                                    j h paul53 2 Replies Last reply Reply Quote 0
                                    • j h
                                      Ne, richtige VM.
                                      Ich habe nach der offiziellen Doku für Proxmox installiert.
                                      https://github.com/jens-maus/RaspberryMatic/wiki/Installation-Proxmox-VE
                                      Soll ich mal als Container installieren?
                                        paul53 @Homoran last edited by paul53
                                        @homoran sagte: ach VM! Wirklich kein Container?
                                        Entscheidend ist, ob sich RM und ioBroker im gleichen oder in verschiedenen Subnetz(en) befinden.
                                        • bahnuhr
                                          bahnuhr Forum Testing Most Active @j h last edited by
                                          Ne, richtige VM.
                                          Ich bin genau nach dieser Anleitung vor gegangen.
                                          Also RM in einer VM unter Proxmox.
                                          Und dies funktioniert einwandfrei.
                                          Ich vermute es liegt an den Einstellungen
                                          RM - hm-rega - hm-rpc
                                            paul53 @bahnuhr last edited by
                                            @bahnuhr sagte: hm-rega
                                            Die Einstellungen von hm-rega haben keinen Einfluss - HM-RPC funktioniert auch ohne HM-Rega-Adapter. Dann allerdings ohne Namen und Aufzählungen aus der RM.
                                            hm-rpc homematic homematic ip
                                            4378
