    4. VIS-Tabelle für WLAN Wetterstation
    • Nashra
      Tja, leider bleibt der Fehler 😢
      15:05:01.527	info	javascript.0 (430) Start javascript script.js.Wetter.Statistik-tabelle
      15:05:01.553	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: registered 2 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
      15:05:01.817	error	javascript.0 (430) script.js.Wetter.Statistik-tabelle: SyntaxError: Unexpected token : in JSON at position 12
      15:05:01.817	error	javascript.0 (430) at script.js.Wetter.Statistik-tabelle:65:56
      15:05:01.817	error	javascript.0 (430) at dataStuff (script.js.Wetter.Statistik-tabelle:56:15)
      15:05:01.817	error	javascript.0 (430) at main (script.js.Wetter.Statistik-tabelle:168:4)
      • SBorg
        SBorg Forum Testing Most Active @Nashra last edited by
        @nashra Ich kann es halt "leider" nicht testen 😉
        wie üblich ... (der letzte Output genügt)
         if (typeof(formathelp)=="object") {helper=getState(id).val[0];}
          else if (typeof(formathelp)=="string") { helper=String(getState(id).val);
        console.log(typeof(helper));
        console.log(helper);
                                                   helper=JSON.parse(helper.substring(1, helper.length-1));
        console.log("2nd helper: "+helper);
          else { helper=JSON.parse(getState(id).val); }
        • Nashra
          @SBorg
          16:11:26.603	info	javascript.0 (430) Start javascript script.js.Wetter.Statistik-tabelle
          16:11:26.630	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle-sborg: registered 2 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
          16:11:26.727	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: string
          16:11:26.727	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: {"Tiefstwert":8.22,"Hoechstwert":17.72,"Temp_Durchschnitt":13.81,"Max_Windboe":29.45,"Max_Regenmenge":8.1,"Regenmenge_Monat":42.7,"warme_Tage":0,"Sommertage":0,"heisse_Tage":0,"Frost_Tage":0,"kalte_Tage":0,"Eistage":0,"sehr_kalte_Tage":0}
          16:11:26.728	error	javascript.0 (430) script.js.Wetter.Statistik-tabelle: SyntaxError: Unexpected token : in JSON at position 12
          16:11:26.728	error	javascript.0 (430) at script.js.Wetter.Statistik-tabelle:71:56
          16:11:26.728	error	javascript.0 (430) at dataStuff (script.js.Wetter.Statistik-tabelle:56:15)
          16:11:26.729	error	javascript.0 (430) at main (script.js.Wetter.Statistik-tabelle:178:4)
          16:11:45.898	info	javascript.0 (430) Stop script script.js.Wetter.Statistik-tabelle
            liv-in-sky @SBorg last edited by
            @sborg
            problem ist -glaube ich - diese zeile :
            helper=JSON.parse(helper.substring(1, (getState(id).val).length-1));
            • SBorg
              SBorg Forum Testing Most Active @liv-in-sky last edited by
              @liv-in-sky Jepp, aus irgendeinem Grund entfernt er bei @Nashra beim einlesen die "[]" ich will jetzt per "indexof()" prüfen ob sie drin sind, dann kann ich normal weitermachen oder sie wieder hinzufügen. Nicht schön, aber so funktioniert es für alle...
              • SBorg
                @nashra
                                                           if (helper.indexOf("[")>=0) { helper=JSON.parse(helper.substring(1, helper.length-1)); }
                                                             else { helper=JSON.parse(helper); }
                • Nashra
                  Nashra Most Active Forum Testing last edited by Nashra
                  gelöscht
                  • Nashra
                    @SBorg
                    16:42:47.832	info	javascript.0 (430) Start javascript script.js.Wetter.Statistik-tabelle
                    16:42:47.849	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: registered 2 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                    16:42:47.899	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: string
                    16:42:47.899	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: {"Tiefstwert":8.22,"Hoechstwert":17.72,"Temp_Durchschnitt":13.81,"Max_Windboe":29.45,"Max_Regenmenge":8.1,"Regenmenge_Monat":42.7,"warme_Tage":0,"Sommertage":0,"heisse_Tage":0,"Frost_Tage":0,"kalte_Tage":0,"Eistage":0,"sehr_kalte_Tage":0}
                    16:42:47.899	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: {"Tiefstwert":-3.72,"Hoechstwert":20.27,"Temp_Durchschnitt":1.03,"Max_Windboe":36.69,"Max_Regenmenge":5.5,"Regenmenge_Monat":20.8,"warme_Tage":5,"Sommertage":0,"heisse_Tage":0,"Frost_Tage":3,"kalte_Tage":8,"Eistage":0,"sehr_kalte_Tage":0}
                    16:42:47.899	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: {"Tiefstwert":-4.72,"Hoechstwert":14.61,"Temp_Durchschnitt":9.42,"Max_Windboe":46.02,"Max_Regenmenge":12.9,"Regenmenge_Monat":204.4,"warme_Tage":12,"Sommertage":0,"heisse_Tage":0,"Frost_Tage":13,"kalte_Tage":22,"Eistage":0,"sehr_kalte_Tage":0}
                    16:42:47.899	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: { "Tiefstwert": -1.77, "Hoechstwert": 12.27, "Temp_Durchschnitt": 2.95, "Max_Windboe": 40.39, "Max_Regenmenge": 22.3, "Regenmenge_Monat": 165.6, "warme_Tage": 0, "Sommertage": 0, "heisse_Tage": 0, "Tropennaechte":0, "Wuestentage":0, "Frost_Tage": 10, "kalte_Tage": 26, "Eistage": 0, "sehr_kalte_Tage": 0 }
                    16:42:47.899	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: { "Tiefstwert": -10.61, "Hoechstwert": 20.22, "Temp_Durchschnitt": 4.19, "Max_Windboe": 34.92, "Max_Regenmenge": 27.4, "Regenmenge_Monat": 203.4, "warme_Tage": 1, "Sommertage": 0, "heisse_Tage": 0, "Tropennaechte":0, "Wuestentage":0, "Frost_Tage": 10, "kalte_Tage": 13, "Eistage": 4, "sehr_kalte_Tage": 2 }
                    16:42:47.900	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: { "Tiefstwert": -3.72, "Hoechstwert": 24.38, "Temp_Durchschnitt": 6.68, "Max_Windboe": 36.69, "Max_Regenmenge": 17.1, "Regenmenge_Monat": 67.8, "warme_Tage": 2, "Sommertage": 0, "heisse_Tage": 0, "Tropennaechte":0, "Wuestentage":0, "Frost_Tage": 5, "kalte_Tage": 15, "Eistage": 0, "sehr_kalte_Tage": 0 }
                    16:42:47.900	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: string
                    16:42:47.900	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: { "Tiefstwert": -0.77, "Hoechstwert": 22.22, "Temp_Durchschnitt": 7.58, "Max_Windboe": 38.46, "Max_Regenmenge": 15.4, "Regenmenge_Monat": 43.5, "warme_Tage": 2, "Sommertage": 0, "heisse_Tage": 0, "Tropennaechte":0, "Wuestentage":0, "Frost_Tage": 6, "kalte_Tage": 9, "Eistage": 0, "sehr_kalte_Tage": 0 }
                    16:42:47.900	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: { "Tiefstwert": 0.5, "Hoechstwert": 28.38, "Temp_Durchschnitt": 11.83, "Max_Windboe": 36.69, "Max_Regenmenge": 11.7, "Regenmenge_Monat": 95.7, "warme_Tage": 6, "Sommertage": 1, "heisse_Tage": 0, "Tropennaechte":0, "Wuestentage":0, "Frost_Tage": 0, "kalte_Tage": 0, "Eistage": 0, "sehr_kalte_Tage": 0 }
                    16:42:47.900	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: { "Tiefstwert": 9.5, "Hoechstwert": 34.5, "Temp_Durchschnitt": 19.81, "Max_Windboe": 21.88, "Max_Regenmenge": 24.3, "Regenmenge_Monat": 72.4, "warme_Tage": 23, "Sommertage": 16, "heisse_Tage": 3, "Tropennaechte":0, "Wuestentage":0, "Frost_Tage": 0, "kalte_Tage": 0, "Eistage": 0, "sehr_kalte_Tage": 0 }
                    16:42:47.900	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: { "Tiefstwert": 11.5, "Hoechstwert": 28.72, "Temp_Durchschnitt": 18.54, "Max_Windboe": 179.93, "Max_Regenmenge": 57.7, "Regenmenge_Monat": 125.1, "warme_Tage": 26, "Sommertage": 14, "heisse_Tage": 0, "Tropennaechte":0, "Wuestentage":0, "Frost_Tage": 0, "kalte_Tage": 0, "Eistage": 0, "sehr_kalte_Tage": 0 }
                    16:42:47.900	info	javascript.0 (430) script.js.Wetter.Statistik-tabelle: { "Tiefstwert": 0, "Hoechstwert": 0, "Temp_Durchschnitt": 0, "Max_Windboe": 0, "Max_Regenmenge": 0, "Regenmenge_Monat": 0, "warme_Tage": 0, "Sommertage": 0, "heisse_Tage": 0, "Tropennaechte":0, "Wuestentage":0, "Frost_Tage": 0, "kalte_Tage": 0, "Eistage": 0, "sehr_kalte_Tage": 0 }
                    16:42:51.172	info	javascript.0 (430) Stop script script.js.Wetter.Statistik-tabelle
                    Kein Fehler mehr, aber ist das ok mit der Ausgabe
                    • SBorg
                      @nashra sagte in VIS-Tabelle für WLAN Wetterstation:
                      Sieht gut aus. Wenn auch deine Tabelle in der VIS funktioniert warten wir mal bis zum nächsten Monatswechsel 🙂
                      Die "console.log..." kannst du nun alle entfernen oder per "//" auskommentieren, sonst wird dein Log über kurz oder lang recht voll 😉
                      Nashra 2 Replies Last reply Reply Quote 1
                      • Nashra
                        Nashra Most Active Forum Testing @SBorg last edited by
                        @sborg sagte in VIS-Tabelle für WLAN Wetterstation:
                        Ja, hatte ich schon gemacht mit //
                        Ok, dann warten wir mal bis Ende des Monats was dann passiert.
                        Vielen Dank erstmal 👍
                        • SBorg
                          Noch eine kleine Änderung wer denn möchte. Wenn man es jetzt in der VIS öffnet, springt er ja automatisch zum Januar 2023. Die Daten gibt es aber erst am 01. Februar. Wäre doch schön wenn er immer einen Monat weniger als den aktuellen springen würde (und für den Januar zzgl. noch -1 Jahr 🙂 ).
                          Einfach den kpl. Scheduler im Skript ersetzen:
                          schedule('*/30 * * * *', function() {
                            //Patch -1 Monat bzw. Jahr, damit immer etwas angezeigt wird (aktuelle Monatsdaten gibt es ja hier noch keine)
                              let MonatTmp = parseInt(formatDate(getDateObject((new Date().getTime())), "MM"));
                              let JahrTmp = 0;
                              if (MonatTmp>1) { MonatTmp--; } else { MonatTmp = 12; JahrTmp = -1; }
                            setState("javascript." + instance + ".Wetterstation.MonatAuswahl", MonatTmp) ;
                            setStateDelayed("javascript." + instance + ".Wetterstation.AuswahlJahr", parseInt(formatDate(getDateObject((new Date().getTime())), "JJJJ"))+JahrTmp ,10000);
                          • Nashra
                            Hallo @SBorg
                            es hat funktioniert, Tabelle zeigt Werte richtig an 👍 👍 👍
                            • SBorg
                              @nashra 😀 😎 👍 Trotzdem merkwürdig das ist...
                              • Nashra
                                jep, da hast du Recht aber ganz ehrlich, ist mir egal, hauptsache läuft jetzt 😁
                                • Negalein
                                  Negalein Global Moderator @SBorg last edited by Negalein
                                  Das Design wird dir bekannt vorkommen, "deine" Version des Skriptes bei mir:
                                  Hallo
                                  Hast du eine aktuelle View davon?
                                  Bei mir kommt in der View undefinied.
                                  • SBorg
                                    SBorg Forum Testing Most Active @Negalein last edited by
                                    @negalein
                                    Ich glaube eher du hast da ein rudimentäres Problem (ich antworte gleich im WLAN-Skript Thread).
                                    Da hat sich seit Uhrzeiten nichts dran geändert:
                                    // @liv-in-sky 4.10.2021 11:45
                                    //forum: https://forum.iobroker.net/topic/38286/vis-tabelle-f%C3%BCr-wlan-wetterstation
                                    const dataInputPath="0_userdata.0.Statistik.Wetter.Data";  //SEHR WICHTIG !!!!!!!!!
                                    const inhaltFarbe="black";
                                    const inhaltHintergrund="lightgray";
                                    const monatFarbe="white";
                                    const hintergrund="gray";
                                    const htmlFarbTableBorderColor="black";
                                    const abstandZelle=6;
                                    const htmlRahmenLinien="all";
                                    const htmlSchriftgroessehtmlSchriftart=""; //nicht verwendbar!
                                    const htmlFarbFelderschrift="red";         //nicht verwendbar!
                                    const htmlSchriftgroesse="13px";
                                    const htmlSchriftart="Ubuntu-Light";       //"monospace" oder z.b. "Helvetica"
                                    const weite="auto";                        //oder "500px"
                                    let myTable="table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                                        "; font-family:"+htmlSchriftart+";\"";
                                    const varData={
                                                 Tiefstwert:       { einheit:"°C",   name:"Minimum Temperatur"},
                                                 Hoechstwert:      { einheit:"°C",   name:"Maximum Temperatur"},
                                                 Temp_Durchschnitt:{ einheit:"°C",   name:"Durchschnittstemperatur"},
                                                 Max_Windboee:     { einheit:'km/h', name:"Max Windböe"},
                                                 Max_Regenmenge:   { einheit:'l/m²', name:"Max. Regen/Tag"},
                                                 Regenmenge_Monat: { einheit:'l/m²', name:"Regen"},
                                                 Regentage:        { einheit:"",     name:"Regentage"},
                                                 sehr_kalte_Tage:  { einheit:"",     name:"Sehr kalte Tage (Min. unter -10°C)"},
                                                 Eistage:          { einheit:"",     name:"Eistage (Max. unter 0°C)"},
                                                 Frost_Tage:       { einheit:"",     name:"Frosttage (Min. unter 0°C)"},
                                                 kalte_Tage:       { einheit:"",     name:"Kalte Tage (Max. unter 10°C)"},
                                                 warme_Tage:       { einheit:"",     name:"Warme Tage (über 20°C)"},
                                                 Sommertage:       { einheit:"",     name:"Sommertage (über 25°C)"},
                                                 Tropennaechte:    { einheit:"",     name:"Tropennächte (Min. über 20°C)"},
                                                 heisse_Tage:      { einheit:"",     name:"Heiße Tage (über 30°C)"},
                                                 Wuestentage:      { einheit:"",     name:"Wüstentage (über 35°C)"}
                                    const table_rowspan = Object.keys(varData).length + 1;
                                    const monate =["JANUAR","FEBRUAR","MÄRZ","APRIL","MAI","JUNI","JULI","AUGUST","SEPTEMBER","OKTOBER","NOVEMBER","DEZEMBER"];
                                    //--------------------------nix mehr ändern ab hier--------------------------------------
                                    let myObj;
                                    let myArrAll=[]
                                    let myArrErstellt=[]
                                    let tableContent;
                                    let monWahlVIS;
                                    let lastThree;
                                    function dataStuff(){
                                    let myArrAll=[]
                                    let mySelector=dataInputPath+'.*.*'
                                    $(mySelector).each(function(id) {
                                    let ida=id.split("."); let lang=ida.length; let jahri=lang-2; let moni=lang-1;
                                    let obj2 = { jahr: ida[jahri]};
                                    let obj3 = { monat: ida[moni]};
                                    let formathelp=getState(id).val;
                                    let helper;
                                    helper={ ...helper, ...obj2, ...obj3}
                                    myArrAll.push(JSON.stringify(helper))
                                    //log(myArrAll)
                                    tableContent = ""
                                    myObj=JSON.parse("["+myArrAll.toString()+"]")
                                    if (lastThree==0) {
                                    //KOPFZEILE
                                    let choseMonth=monate[monWahlVIS-1]
                                    let choseMonthArr=choseMonth.split('')
                                    let test=""
                                    for (let i=0;i<choseMonthArr.length;i++){
                                    // log(choseMonthArr[i])
                                     test=test+choseMonthArr[i]+`
                                    //log(test)
                                    //tableContent+='<td  class=\"test-klein\"  rowspan=\"17\"\">'+choseMonth+'</td><td>Wetterwerte</td>'
                                    tableContent+='<td class=\"myWetterStation\" width=\"25px\"  style=\"color:'+monatFarbe+';font-size:26px; background-color:'+hintergrund+' ; vertical-align:middle; text-align:center \"   rowspan='+table_rowspan+'\">'+test+'</td><td style=\"color:'+monatFarbe+'; background-color:'+hintergrund+'"\>Jahreswerte</td>'
                                    for (let i=0;i<myObj.length;i++) {
                                     if(parseInt(myObj[i].monat)==monWahlVIS){
                                    tableContent += '<td style=\"color:'+monatFarbe+'; background-color:'+hintergrund+'"\ align=center>'  + myObj[i].jahr+'</td>'}
                                    }; tableContent="<tr style=\"font-weight\:bold\">"+tableContent+"</tr>"
                                    //RESTZEILEN
                                    for(var index in varData){
                                     tableContent+='<td style=\"color:'+inhaltFarbe+'; background-color:'+inhaltHintergrund+'\">'+varData[index].name+'</td>'
                                        if(myObj[i].monat==monWahlVIS){
                                          tableContent += '<td style=\"color:'+inhaltFarbe+'; background-color:'+inhaltHintergrund+'\" align=right>' + myObj[i][index] + ' '+ varData[index].einheit+'</td>'}
        }; tableContent="<tr>"+tableContent+"</tr>"
                                    } //lastThree
                                    else {
                                    //log(myObj[0].monat)
                                      myObj.sort(function (alpha, beta) {
                                               if (parseInt(alpha.monat) > parseInt(beta.monat))
                                                   return 1;
                                                if (parseInt(beta.monat) > parseInt(alpha.monat))
                                                   return -1;
                                                return 0;});
                                            //    log(myObj[0].monat)
                                    //KOPFZEILE LASTTHREE
                                    let choseJahr=lastThree.toString()//formatDate(getDateObject((new Date().getTime())), "JJJJ")//monate[monWahlVIS-1]
                                    let choseMonthArr=choseJahr.split('')
                                    let test=""
                                    //log(test)
                                    tableContent+='<td class=\"myWetterStation\" width=\"25px\"  style=\"color:'+monatFarbe+';font-size:26px; background-color:'+hintergrund+' ; vertical-align:middle; text-align:center \"   rowspan='+table_rowspan+'\">'+test+'</td><td style=\"color:'+monatFarbe+'; background-color:'+hintergrund+'"\>Wetterwerte</td>'
                                     if( parseInt(myObj[i].jahr)==parseInt(choseJahr) ){ //&& (parseInt(myObj[i].monat)==parseInt(monWahlVIS) || parseInt(myObj[i].monat)==parseInt(monWahlVIS)-1 || parseInt(myObj[i].monat)==parseInt(monWahlVIS)-2)){
                                    tableContent += '<td style=\"color:'+monatFarbe+'; background-color:'+hintergrund+'"\ align=center>'  + monate[parseInt(myObj[i].monat)-1]+'</td>';}
                                    //RESTZEILEN
                                    tableContent = '<'+myTable+' ><tbody>'+tableContent+'</tbody></table >'
                                    //log(tableContent)
                                    setState("0_userdata." + instance + ".Wetterstation.MonthlyDaten",tableContent)
                                    async function main() {
                                     if (!(await existsStateAsync("0_userdata." + instance + ".Wetterstation.MonthlyDaten"))) {
                                         await createStateAsync("0_userdata." + instance + ".Wetterstation.MonthlyDaten", "leer", {type: "string", name: "MonthlyDaten", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("0_userdata." + instance + "..Wetterstation.MonatAuswahl"))) {
                                         await createStateAsync("0_userdata." + instance + ".Wetterstation.MonatAuswahl", 10, {type: "number", name: "MonatAuswahl", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("0_userdata." + instance + ".Wetterstation.AuswahlJahr"))) {
                                         await createStateAsync("0_userdata." + instance + ".Wetterstation.AuswahlJahr", 0, {type: "number", name: "AuswahlJahr", role: "value", read: true, write: true, } ); }
                                     lastThree = (await getStateAsync("0_userdata." + instance + ".Wetterstation.AuswahlJahr")).val //? lastThree=true : lastThree=false;
                                     monWahlVIS=((await getStateAsync("0_userdata." + instance + ".Wetterstation.MonatAuswahl")).val )
                                     dataStuff();
                                    main()
                                    on({id: "0_userdata." + instance + ".Wetterstation.MonatAuswahl", change: "any"}, async function (obj) {
                                     main()
                                    on({id: "0_userdata." + instance + ".Wetterstation.AuswahlJahr", change: "any"}, async function (obj) {
                                     main()
                                       let JahrTmp = 0;
                                     setState("0_userdata." + instance + ".Wetterstation.MonatAuswahl", MonatTmp) ;
                                     setStateDelayed("0_userdata." + instance + ".Wetterstation.AuswahlJahr", parseInt(formatDate(getDateObject((new Date().getTime())), "JJJJ"))+JahrTmp ,10000);
                                    Springt immer zu aktuellem Monat minus 1 (also gerade heute dann automatisch auf Mai), im Januar dann auf Dezember und minus 1 Jahr.
                                    • Negalein
                                      Hast du auch einen VIS-Export für mich?
                                      • SBorg
                                        @negalein
                                        Ist wahrscheinlich gleich mit deinem
                                        [{"tpl":"tplJquiSelectList","data":{"oid":"0_userdata.0.Wetterstation.AuswahlJahr","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":true,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"0;2020;2021;2022;2023;2024","texts":"All Years;2020;2021;2022;2023;2024","height":"100","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"no_style":true},"style":{"left":"160px","top":"375px","box-shadow":"8px 8px 8px rgba(20, 20, 20, 50)"},"widgetSet":"jqui"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":true,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{0_userdata.0.Wetterstation.MonthlyDaten}"},"style":{"left":"160px","top":"405px","width":"auto","height":"auto","font-family":"","color":"#f7f51d","z-index":"1","box-shadow":"8px 8px 8px rgba(20, 20, 20, 50)"},"widgetSet":"basic"},{"tpl":"tplJquiSelectList","data":{"oid":"0_userdata.0.Wetterstation.MonatAuswahl","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":true,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"1;2;3;4;5;6;7;8;9;10;11;12","texts":"JANUAR;FEBRUAR;MÄRZ;APRIL;MAI;JUNI;JULI;AUGUST;SEPTEMBER;OKTOBER;NOVEMBER;DEZEMBER","height":"100","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"no_style":true},"style":{"left":"260px","top":"375px","width":"100px","height":"","box-shadow":"8px 8px 8px rgba(20, 20, 20, 50)","z-index":"1"},"widgetSet":"jqui"}]
                                          tritor @SBorg last edited by
                                          @sborg
                                          habe heute mal die Vis aktiviert und muß sagen, bin begeistert.
                                          vis
                                          11
                                          101
                                          14810
