    4. Huawei Sun2000 & ioBroker via JS script funktioniert
      majawe @zoid1988 last edited by
      @zoid1988 hast du es im Adapter hinzugefügt?
      • Z
        zoid1988 @majawe last edited by
        @majawe
        Vielen Dank, wusste garnicht das man das machen kann ... Wieder etwas gelernt ...
        Das Script startet jetzt, aber ich bekomme leider keine Daten ausgelesen.
        Habe die Werte bei mir jetzt so angepasst (ich habe leider - noch - keinen Akku):
        client.connectTCP("10.168.1.111", { port: 502 });
        const ModBusIDs = [1];
        const PowerMeterID = 0;
        const BatteryUnits = [[0, 0]];
        Folgende Infos find ich im Log:
        30.12.2022, 11:33:51.829 [info ]: javascript.0 (1120689) script.js.PV: Triggering read of inverter 1 at address 35300 with length 40
        30.12.2022, 11:33:51.830 [warn ]: javascript.0 (1120689) script.js.PV: Error received reading address 35300 from id: 1 with error: undefined
        30.12.2022, 11:33:53.829 [info ]: javascript.0 (1120689) script.js.PV: Processing new data...
        30.12.2022, 11:33:53.832 [info ]: javascript.0 (1120689) script.js.PV: Processing done!
        30.12.2022, 11:33:53.833 [info ]: javascript.0 (1120689) script.js.PV: Triggering read of inverter 1 at address 30000 with length 81
        30.12.2022, 11:33:53.833 [warn ]: javascript.0 (1120689) script.js.PV: Error received reading address 30000 from id: 1 with error: undefined
        30.12.2022, 11:33:55.830 [info ]: javascript.0 (1120689) script.js.PV: Triggering read of inverter 1 at address 37100 with length 114
        30.12.2022, 11:33:55.830 [warn ]: javascript.0 (1120689) script.js.PV: Error received reading address 37100 from id: 1 with error: undefined
        30.12.2022, 11:33:57.830 [info ]: javascript.0 (1120689) script.js.PV: Triggering read of inverter 1 at address 32000 with length 116
        30.12.2022, 11:33:57.830 [warn ]: javascript.0 (1120689) script.js.PV: Error received reading address 32000 from id: 1 with error: undefined
        30.12.2022, 11:33:59.830 [info ]: javascript.0 (1120689) script.js.PV: Triggering read of inverter 1 at address 37000 with length 68
        30.12.2022, 11:33:59.831 [warn ]: javascript.0 (1120689) script.js.PV: Error received reading address 37000 from id: 1 with error: undefined
        30.12.2022, 11:34:01.830 [info ]: javascript.0 (1120689) script.js.PV: Triggering read of inverter 1 at address 37700 with length 100
        30.12.2022, 11:34:01.831 [warn ]: javascript.0 (1120689) script.js.PV: Error received reading address 37700 from id: 1 with error: undefined
        30.12.2022, 11:34:03.831 [info ]: javascript.0 (1120689) script.js.PV: Triggering read of inverter 1 at address 37800 with length 100
        30.12.2022, 11:34:03.831 [warn ]: javascript.0 (1120689) script.js.PV: Error received reading address 37800 from id: 1 with error: undefined
        30.12.2022, 11:34:05.831 [info ]: javascript.0 (1120689) script.js.PV: Triggering read of inverter 1 at address 38200 with length 100
        30.12.2022, 11:34:05.832 [warn ]: javascript.0 (1120689) script.js.PV: Error received reading address 38200 from id: 1 with error: undefined
        30.12.2022, 11:34:07.832 [info ]: javascript.0 (1120689) script.js.PV: Triggering read of inverter 1 at address 38300 with length 100
        30.12.2022, 11:34:07.833 [warn ]: javascript.0 (1120689) script.js.PV: Error received reading address 38300 from id: 1 with error: undefined
        30.12.2022, 11:34:08.028 [info ]: javascript.0 (1120689) Stop script script.js.PV
        Z oswibz 2 Replies Last reply Reply Quote 0
        • Z
          zoid1988 @zoid1988 last edited by
          @zoid1988
          So, ich muss mich kurz selbst korrigieren.
          Ich habe bereits die Lösung mit Node-red im Einsatz und hab jetzt mal den Node-red Adapter gestoppt und nun haben sich die Einträge im Log verändert.
          Scheinbar kann er jetzt erfolgreich was abfragen, aber in den Objekten stehen immer noch alle Werte auf 0.
            majawe @badsnoopy667 last edited by
            @badsnoopy667 Klappt super den Wert zu ändern, hast du evtl eine Idee wie ich den Akku laden lassen kann? habe es mit 47100 (1) probiert aber es funktioniert nicht......9c46b519-9196-42f1-ae9b-17da6d60c51b-image.png
              badsnoopy667 @majawe last edited by
              @majawe
              Nein, das habe ich noch nicht probiert, da ich keinen variablen Stromtarif habe... aber darüber nachgedacht, ob es geht, habe ich auch schon. Falls Du also etwas rausbekommen solltest, sag gerne Bescheid! 🙂
                badsnoopy667 @majawe last edited by badsnoopy667
                @majawe
                Kurzes Update: Über Modbus habe ich es noch nicht geschafft den Akku laden zu lassen. Ich vermute übrigens, Du hast nicht die letzte Version (V3) Der "modbus-interface-definitions"
                Link: solar-inverter-modbus-interface-definitions-v3.0.pdf .
                Das Register was Du da zeigst gibt es da nicht mehr. Es gibt aber ein Register [Energy storage unit] Time-of-use electricity price periods - 47200. Da kann man wohl die Lade- und Entladezeiten eintragen für den Akku. Da das Ding aber 41 Zeichen lang ist, habe ich keinen Plan, wie das korrekte Format aussehen muss. Ich habe mal den Huawei Support angeschrieben.
                Aber: Was ich gerade mal getestet habe: Mit der SUN2000 App (Nicht FusionSolar, geht aber vll auch, k.a.) habe ich mich auf den Wechselrichter als Installateur verbunden (über das SDongle WLan im Keller) und habe die Betriebsweise das Akkus auf "TOU" gestellt. Also zeitgesteuertes Laden. Wenn man da dann eine Ladezeit einträgt, fängt das Ding auch an aus dem Netz zu laden.
                Daher meine fixe Idee als Workaround: In der App eine Ladezeit einstelle (z.B. von 23:00 - 6:00 Uhr Nachts, in der Annahme das Nachts die günstigesten Preise vorliegen). Und dann das Register [Energy storage unit] Maximum charging power - 47075 entsprechend auf 0 setzen, zu Zeiten wenn man nicht laden will und auf 5000 (für 5000W, bei mind. 10kWh Akku, sonst weniger), wenn man laden möchte in dieser Zeit. Morgens natürlich dann wieder hochsetzen. Habe ich aber noch nicht ausprobiert. Könnte mir aber vorstellen, dass es klappt. Bin mir nur nicht sicher, ob er dann noch entlädt (in der Zeit wo die Ladeleistung 0 ist, aber die Ladezeit gesetzt ist).
                  @badsnoopy667 said in Huawei Sun2000 & ioBroker via JS script funktioniert:
                  Die Idee hatte ich auch schon, leider bekomme ich es nicht hin das er die 0 annimmt bzw überträgt
                    @majawe
                    Das sollte ja das kleinste Problem sein. Der Wert wird genauso geschrieben wie das Register 47077 (Max. Entladeleistung). Hab's gerade probiert. Wenn ich im Flow die Adresse von 47077 auf 47075 ändere (und sonst alles gleich lasse), kann ich die Ladeleistung einstellen. "0" habe ich nicht probiert, aber 4999 und 5000W hat geklappt.
                      @badsnoopy667 könntest du mir den flow mal exportieren oder ein scrennshot der karte bitte machen?🙏
                        @majawe
                        Hier der Flow für beide Zustände (Charge und Discharge)
                        flows_read_write_charge_discharge.json
                        Sobald du eines der beiden Objekte "_SET" änderst (vorher anlegen!), wird das entsprechende Register geschrieben.
                        Und wie immer bei meinem Flow: Achte auf die Unit-ID. Bei mir ist die 2, bei dir vermutlich nicht! Mein WR war mal defekt.
                        Hast Du darauf geachtet beim Ändern nicht nur den Namen, sondern wirklich die Adresse zu ändern? Das hab ich schon ein paar mal durcheinander gebracht. Der Name allein hilft nicht, der ist sowieso völlig beliebig.
                        M B 2 Replies Last reply Reply Quote 0
                          @badsnoopy667 Funktioniert heute auf Anhieb komischer weise 🙂 ich denke es lag am Dongle update
                          Tou kannst du auch online umstellen unter, https://region02eu5.fusionsolar.huawei.com, Dongle, EMS Control oder direkt am Handy unter Dongel, Parametereinstellung, Arbeitsmodus Tou.
                          Also brauchst dich nicht direkt am Wechselrichter einloggen
                            @badsnoopy667 Super 👍 👍 👍 👍 👍 so wird es gemacht
                            Danke🙏
                              @majawe
                              Schön, dass es klappt! Aber ENT-laden im Ladezeitraum tut er nicht, oder? Das ist nämlich vermutlich noch der Haken. Den Zeitraum würde ich ja immer (in der Nacht) stehen lassen und über die Ladeleistung dann quasi aktivieren und deaktivieren.
                              Wobei man streiten kann, ob das ein Problem ist, im Winter ist der Akku Nachts sowieso fast immer leer. Dann spielt es keine Rolle. Und im Sommer brauche ich ihn ihn nicht extern laden.
                              Zu der FusionSolar Seite: Wo geht das denn? Bei mir kann ich da gar nix einstellen. Welche Dongle Firmware ist das? Oder hast Du da Installateur Zugriff auf FusionSolar?
                                @badsnoopy667 Ich denke bei sonnenuntergang setze ich den auf 0watt, und dann wenn kleiner als 5cent = 5000Watt. Den Rest erledigt Tou zwischen 0 - 5 Uhr.
                                  majawe @badsnoopy667 last edited by majawe
                                  @badsnoopy667 Ich habe den Installateur zugang, da ist der Punkt sichtbar. Der Dongle hat die FW PC133 am ende aber gesehen habe ich den Punkt bereits mit der PC130
                                    Thomas42 last edited by Thomas42
                                    Erst mal vielen Dank für das Script, hat fast sofort funtioniert.
                                    Ich musste nur die IDs raten, bei meiner nagelneuen Anlage mit 2 KTLs und dem Powermeter und ohne Batterien bin ich hier gelandet:
                                    const ModBusIDs = [1, 2];
                                    Powermeter läuft wunderbar.
                                    Das Problem, daß die Werte nur einmal geschrieben wurden habe ich mit einem Workaround hier gelöst:
                                    function forcesetState(objectname, value, options) {
                                        if(!existsState(objectname)) {
                                            createState(objectname, value, options);
                                            console.log("createstate " +  objectname + " to value " + value);
                                        //Workaround
                                        setState(objectname, value);
                                    also das setstate aus der else-clause genommen, denn das !existsState scheint nicht sauber zu funktionieren.
                                    Ach so, noch eine gute Nachricht:
                                    Der Installateur kann den Modbus (inwischen?) remote aktivieren, da muss keiner vor Ort sein.
                                    Hat mich eine Mail an meinen Solateur gekostet und zwei Stunden später war alles aktiv.
                                    severendis 1 Reply Last reply Reply Quote 0
                                    • oswibz
                                      oswibz @zoid1988 last edited by oswibz
                                      @zoid1988 Hallo zusammen, gibt es hier Neuigkeiten. Hab heute mein WR angeschlossen. Datenpunkte wurden generiert aber erhalte den selben Fehler. Gibt es Lösungen? Danke an alle für die Hilfe!
                                      Ich habe auch den Workaround eingesetzt, erhalte immer aber die gleiche Warnung:
                                      21:02:25.393 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 30000 with length 81
                                      21:02:25.394 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 30000 from id: 1 with error: undefined
                                      21:02:27.393 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 37100 with length 114
                                      21:02:27.394 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 37100 from id: 1 with error: undefined
                                      21:02:29.394 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 32000 with length 116
                                      21:02:29.394 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 32000 from id: 1 with error: undefined
                                      21:02:31.394 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 37000 with length 68
                                      21:02:31.395 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 37000 from id: 1 with error: undefined
                                      21:02:33.395 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 37700 with length 100
                                      21:02:33.396 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 37700 from id: 1 with error: undefined
                                      21:02:35.395 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 37800 with length 100
                                      21:02:35.396 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 37800 from id: 1 with error: undefined
                                      21:02:37.395 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 38200 with length 100
                                      21:02:37.396 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 38200 from id: 1 with error: undefined
                                      21:02:39.406 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 38300 with length 100
                                      21:02:39.406 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 38300 from id: 1 with error: undefined
                                      21:02:41.406 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 38400 with length 100
                                      21:02:41.407 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 38400 from id: 1 with error: undefined
                                      21:02:43.407 info javascript.0 (23379) script.js.Test.PV-Test: Triggering read of inverter 1 at address 35300 with length 40
                                      21:02:43.408 warn javascript.0 (23379) script.js.Test.PV-Test: Error received reading address 35300 from id: 1 with error: undefined
                                      oswibz Z 2 Replies Last reply Reply Quote 0
                                      • oswibz
                                        oswibz @oswibz last edited by
                                        Dear all, any support on my issue (see above).
                                        Thanks for your support
                                          Thomas42 @oswibz last edited by
                                          @oswibz
                                          Als Newbie: Da stimmen Deine IDs nicht. So, wie ich das Script verstehe, gibt es die ID, aber es ist nicht der Gerätetyp, der abgefragt wird.
                                          oswibz 1 Reply Last reply Reply Quote 0
                                          • oswibz
                                            oswibz @Thomas42 last edited by
                                            @thomas42
                                            wo finde ich den korrekten ID?
                                            477
                                            90306
